[PATCH] libmisc/shell: Fix file pointer leak and improved input data sanitation.
Joel Sherrill
joel at rtems.org
Wed May 17 14:10:55 UTC 2023
This looks ok. I will push it.
Coverity is run up 1215 am and 1215 pm my time (910am now) so we should
have feedback in a few hours.
--joel
On Tue, May 16, 2023 at 7:04 PM <aaron.nyholm at unfoldedeffective.com> wrote:
> From: Aaron Nyholm <aaron.nyholm at southerninnovation.com>
> Coverity #1530126
> Coverity #1530125
> cpukit/libmisc/shell/main_flashdev.c | 27 ++++++++++-----------------
> 1 file changed, 10 insertions(+), 17 deletions(-)
> diff --git a/cpukit/libmisc/shell/main_flashdev.c
> b/cpukit/libmisc/shell/main_flashdev.c
> index 495373235f..ca2454b33c 100644
> --- a/cpukit/libmisc/shell/main_flashdev.c
> +++ b/cpukit/libmisc/shell/main_flashdev.c
> @@ -78,6 +78,15 @@ static int rtems_flashdev_shell_main( int argc, char
> *argv[] ) {
> for (i = 1; i < argc; ++i) {
> if (argv[i][0] == '-') {
> + * Check that a path to flashdev has been provided before running
> + * command.
> + if (dev_path == NULL) {
> + printf("Please input FLASH_DEV_PATH before instruction\n");
> + return 1;
> + /* Run command */
> switch (argv[i][1]) {
> case ('r'):
> /* Read */
> @@ -112,7 +121,6 @@ static int rtems_flashdev_shell_main( int argc, char
> *argv[] ) {
> printf(rtems_flashdev_shell_usage);
> break;
> } else if (dev_path == NULL) {
> dev_path = argv[i];
> } else {
> @@ -145,10 +153,6 @@ int flashdev_shell_read(
> printf("Missing argument\n");
> return -1;
> - if (dev_path == NULL) {
> - printf("Please input FLASH_DEV_PATH before instruction\n");
> - return 1;
> /* Get arguments */
> errno = 0;
> @@ -181,6 +185,7 @@ int flashdev_shell_read(
> buffer = calloc((bytes + bytes%4), 1);
> if (buffer == NULL) {
> printf("Failed to allocate read buffer\n");
> + close(fd);
> return -1;
> @@ -230,10 +235,6 @@ int flashdev_shell_write(
> return -1;
> - return 1;
> /* Get arguments */
> errno = 0;
> @@ -337,10 +338,6 @@ int flashdev_shell_erase(
> return -1;
> - return 1;
> /* Get arguments */
> errno = 0;
> @@ -546,10 +543,6 @@ static int flashdev_shell_page(
> return -1;
> - return 1;
> /* Get arguments */
> errno = 0;
> 2.25.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230517/fa990ebe/attachment.htm>
