[rtems-docs] Update company name
Sebastian Huber
Fri May 19 05:42:54 UTC 2023
The embedded brains GmbH & Co. KG is the legal successor of embedded
brains GmbH.
bsp-howto/getentropy.rst | 2 +-
bsp-howto/i2c.rst | 2 +-
bsp-howto/index.rst | 2 +-
bsp-howto/initilization_code.rst | 2 +-
bsp-howto/spi.rst | 2 +-
bsp-howto/target-hash.rst | 2 +-
c-user/barrier/directives.rst | 2 +-
c-user/barrier/index.rst | 2 +-
c-user/barrier/introduction.rst | 2 +-
c-user/cache/directives.rst | 2 +-
c-user/cache/index.rst | 2 +-
c-user/cache/introduction.rst | 2 +-
c-user/clock/background.rst | 2 +-
c-user/clock/directives.rst | 2 +-
c-user/clock/index.rst | 2 +-
c-user/clock/introduction.rst | 2 +-
c-user/config/bdbuf.rst | 2 +-
c-user/config/classic-api.rst | 2 +-
c-user/config/classic-init-task.rst | 2 +-
c-user/config/device-driver.rst | 2 +-
c-user/config/directives.rst | 2 +-
c-user/config/event-record.rst | 2 +-
c-user/config/filesystem.rst | 2 +-
c-user/config/general.rst | 2 +-
c-user/config/idle-task.rst | 2 +-
c-user/config/introduction.rst | 2 +-
c-user/config/mpci.rst | 2 +-
c-user/config/posix-api.rst | 2 +-
c-user/config/posix-init-thread.rst | 2 +-
c-user/config/scheduler-general.rst | 2 +-
c-user/config/task-stack-alloc.rst | 2 +-
c-user/directive_status_codes.rst | 2 +-
c-user/dual-ported-memory/directives.rst | 2 +-
c-user/dual-ported-memory/index.rst | 2 +-
c-user/dual-ported-memory/introduction.rst | 2 +-
c-user/event/directives.rst | 2 +-
c-user/event/index.rst | 2 +-
c-user/event/introduction.rst | 2 +-
c-user/fatal-error/directives.rst | 2 +-
c-user/fatal-error/index.rst | 2 +-
c-user/fatal-error/introduction.rst | 2 +-
c-user/glossary.rst | 2 +-
c-user/index.rst | 2 +-
c-user/initialization/directives.rst | 2 +-
c-user/initialization/index.rst | 2 +-
c-user/initialization/introduction.rst | 2 +-
c-user/interrupt/directives.rst | 2 +-
c-user/interrupt/index.rst | 2 +-
c-user/interrupt/introduction.rst | 2 +-
c-user/io/directives.rst | 2 +-
c-user/io/index.rst | 2 +-
c-user/io/introduction.rst | 2 +-
c-user/kernel-character-io/directives.rst | 2 +-
c-user/kernel-character-io/index.rst | 2 +-
c-user/kernel-character-io/introduction.rst | 2 +-
c-user/linker_sets.rst | 2 +-
c-user/message/directives.rst | 2 +-
c-user/message/index.rst | 2 +-
c-user/message/introduction.rst | 2 +-
c-user/multiprocessing/directives.rst | 2 +-
c-user/multiprocessing/index.rst | 2 +-
c-user/multiprocessing/introduction.rst | 2 +-
c-user/object-services/directives.rst | 2 +-
c-user/object-services/index.rst | 2 +-
c-user/object-services/introduction.rst | 2 +-
c-user/partition/directives.rst | 2 +-
c-user/partition/index.rst | 2 +-
c-user/partition/introduction.rst | 2 +-
c-user/rate-monotonic/directives.rst | 2 +-
c-user/rate-monotonic/index.rst | 2 +-
c-user/rate-monotonic/introduction.rst | 2 +-
c-user/region/directives.rst | 2 +-
c-user/region/index.rst | 2 +-
c-user/region/introduction.rst | 2 +-
c-user/rtems_data_types.rst | 2 +-
c-user/scheduling-concepts/directives.rst | 2 +-
c-user/scheduling-concepts/index.rst | 2 +-
c-user/scheduling-concepts/introduction.rst | 2 +-
c-user/self_contained_objects.rst | 2 +-
c-user/semaphore/directives.rst | 2 +-
c-user/semaphore/index.rst | 2 +-
c-user/semaphore/introduction.rst | 2 +-
c-user/signal/directives.rst | 2 +-
c-user/signal/index.rst | 2 +-
c-user/signal/introduction.rst | 2 +-
c-user/symmetric_multiprocessing_services.rst | 2 +-
c-user/task/background.rst | 2 +-
c-user/task/directives.rst | 2 +-
c-user/task/index.rst | 2 +-
c-user/task/introduction.rst | 2 +-
c-user/task/operations.rst | 2 +-
c-user/timer/directives.rst | 2 +-
c-user/timer/index.rst | 2 +-
c-user/timer/introduction.rst | 2 +-
c-user/user-extensions/directives.rst | 2 +-
c-user/user-extensions/index.rst | 2 +-
c-user/user-extensions/introduction.rst | 2 +-
common/license.rst | 2 +-
common/version.py | 2 +-
cpu-supplement/epiphany.rst | 2 +-
cpu-supplement/index.rst | 2 +-
cpu-supplement/riscv.rst | 2 +-
cpu-supplement/sparc.rst | 2 +-
eng/build-system.rst | 4 +--
eng/coding-doxygen.rst | 2 +-
eng/coding-file-hdr.rst | 2 +-
eng/doc-guide.rst | 2 +-
eng/glossary.rst | 2 +-
eng/index.rst | 2 +-
eng/issue-tracking.rst | 2 +-
eng/mission.rst | 2 +-
eng/preface.rst | 2 +-
eng/prequalification.rst | 2 +-
eng/python-devel.rst | 2 +-
eng/req/index.rst | 2 +-
eng/req/items.rst | 28 +++++++++----------
eng/req/management.rst | 2 +-
eng/req/req-for-req.rst | 2 +-
eng/req/tooling.rst | 2 +-
eng/req/traceability.rst | 2 +-
eng/stakeholders.rst | 2 +-
eng/test-framework.rst | 2 +-
filesystem/index.rst | 2 +-
images/eng/bld-bsp.dot | 2 +-
images/eng/bld-bsp2.dot | 2 +-
images/eng/bld-deps.dot | 2 +-
images/eng/bld-deps2.dot | 2 +-
images/eng/req-add.puml | 2 +-
images/eng/req-modify.puml | 2 +-
images/eng/req-spec-items.puml | 2 +-
images/user/patch-review.puml | 2 +-
shell/index.rst | 2 +-
user/bld/index.rst | 2 +-
user/bsps/arm/altera-cyclone-v.rst | 2 +-
user/bsps/arm/fvp.rst | 2 +-
user/bsps/arm/imx.rst | 2 +-
user/bsps/arm/imxrt.rst | 2 +-
user/bsps/arm/lpc24xx.rst | 2 +-
user/bsps/arm/realview-pbx-a9.rst | 2 +-
user/bsps/arm/stm32h7.rst | 2 +-
user/bsps/arm/xilinx-zynqmp.rst | 2 +-
user/bsps/bsps-aarch64.rst | 2 +-
user/bsps/bsps-arm.rst | 2 +-
user/bsps/bsps-bfin.rst | 2 +-
user/bsps/bsps-i386.rst | 2 +-
user/bsps/bsps-lm32.rst | 2 +-
user/bsps/bsps-m68k.rst | 2 +-
user/bsps/bsps-microblaze.rst | 2 +-
user/bsps/bsps-mips.rst | 2 +-
user/bsps/bsps-moxie.rst | 2 +-
user/bsps/bsps-nios2.rst | 2 +-
user/bsps/bsps-or1k.rst | 2 +-
user/bsps/bsps-powerpc.rst | 2 +-
user/bsps/bsps-riscv.rst | 2 +-
user/bsps/bsps-sh.rst | 2 +-
user/bsps/bsps-sparc.rst | 2 +-
user/bsps/bsps-sparc64.rst | 2 +-
user/bsps/bsps-v850.rst | 2 +-
user/bsps/bsps-x86_64.rst | 2 +-
user/bsps/index.rst | 2 +-
user/hardware/architectures.rst | 2 +-
user/migration/v4_11-to-v5.rst | 2 +-
user/migration/v5-to-v6.rst | 2 +-
user/start/bsp-build.rst | 2 +-
user/start/bsp-test.rst | 2 +-
user/start/prefixes.rst | 2 +-
user/start/preparation.rst | 2 +-
user/start/sources.rst | 2 +-
user/start/tools.rst | 2 +-
user/support/bugs.rst | 2 +-
user/support/contrib.rst | 2 +-
user/support/index.rst | 2 +-
user/support/support-project.rst | 2 +-
user/tracing/eventrecording.rst | 2 +-
175 files changed, 189 insertions(+), 189 deletions(-)
diff --git a/bsp-howto/getentropy.rst b/bsp-howto/getentropy.rst
index decc2af..cf8471a 100644
--- a/bsp-howto/getentropy.rst
+++ b/bsp-howto/getentropy.rst
@@ -1,6 +1,6 @@
.. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 2017 embedded brains GmbH <rtems at embedded-brains.de>
+.. Copyright (C) 2017 embedded brains GmbH & Co. KG
Entropy Source
diff --git a/bsp-howto/i2c.rst b/bsp-howto/i2c.rst
index 66d6653..af1cfe2 100644
--- a/bsp-howto/i2c.rst
+++ b/bsp-howto/i2c.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2016, 2019 embedded brains GmbH <rtems at embedded-brains.de>
+.. Copyright (C) 2016, 2019 embedded brains GmbH & Co. KG
I2C Driver
diff --git a/bsp-howto/index.rst b/bsp-howto/index.rst
index d095fc7..d8ff326 100644
--- a/bsp-howto/index.rst
+++ b/bsp-howto/index.rst
@@ -9,7 +9,7 @@ RTEMS BSP and Driver Guide (|version|).
.. topic:: Copyrights and License
| |copy| 2017 Christian Mauderer
- | |copy| 2016, 2020 embedded brains GmbH
+ | |copy| 2016, 2020 embedded brains GmbH & Co. KG
| |copy| 2016, 2020 Sebastian Huber
| |copy| 1988, 2017 On-Line Applications Research Corporation (OAR)
diff --git a/bsp-howto/initilization_code.rst b/bsp-howto/initilization_code.rst
index b1fcb0d..deb70a5 100644
--- a/bsp-howto/initilization_code.rst
+++ b/bsp-howto/initilization_code.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2020 embedded brains GmbH
+.. Copyright (C) 2020 embedded brains GmbH & Co. KG
.. Copyright (C) 2020 Sebastian Huber
.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
diff --git a/bsp-howto/spi.rst b/bsp-howto/spi.rst
index 1da5fa0..cf7918a 100644
--- a/bsp-howto/spi.rst
+++ b/bsp-howto/spi.rst
@@ -1,6 +1,6 @@
SPI Driver
diff --git a/bsp-howto/target-hash.rst b/bsp-howto/target-hash.rst
index bcb651b..af73ae3 100644
--- a/bsp-howto/target-hash.rst
+++ b/bsp-howto/target-hash.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2021 embedded brains GmbH <rtems at embedded-brains.de>
+.. Copyright (C) 2021 embedded brains GmbH & Co. KG
Target Hash
diff --git a/c-user/barrier/directives.rst b/c-user/barrier/directives.rst
index c51974c..4eded62 100644
--- a/c-user/barrier/directives.rst
+++ b/c-user/barrier/directives.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2020, 2021 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 2020, 2021 embedded brains GmbH & Co. KG
.. This file is part of the RTEMS quality process and was automatically
diff --git a/c-user/barrier/index.rst b/c-user/barrier/index.rst
index ddf0b56..e924c83 100644
--- a/c-user/barrier/index.rst
+++ b/c-user/barrier/index.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
.. index:: barrier
diff --git a/c-user/barrier/introduction.rst b/c-user/barrier/introduction.rst
index 11013bf..e1c957f 100644
--- a/c-user/barrier/introduction.rst
+++ b/c-user/barrier/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/cache/directives.rst b/c-user/cache/directives.rst
index 98349db..a97654e 100644
--- a/c-user/cache/directives.rst
+++ b/c-user/cache/directives.rst
@@ -1,7 +1,7 @@
.. Copyright (C) 2016 Pavel Pisa
-.. Copyright (C) 2014, 2021 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 2014, 2021 embedded brains GmbH & Co. KG
.. Copyright (C) 2000, 2008 On-Line Applications Research Corporation (OAR)
diff --git a/c-user/cache/index.rst b/c-user/cache/index.rst
index c8f7263..57c124f 100644
--- a/c-user/cache/index.rst
+++ b/c-user/cache/index.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
.. index:: cache
diff --git a/c-user/cache/introduction.rst b/c-user/cache/introduction.rst
index 6cae4b2..a632c9c 100644
--- a/c-user/cache/introduction.rst
+++ b/c-user/cache/introduction.rst
@@ -1,7 +1,7 @@
diff --git a/c-user/clock/background.rst b/c-user/clock/background.rst
index ded0461..11a3cb5 100644
--- a/c-user/clock/background.rst
+++ b/c-user/clock/background.rst
@@ -1,6 +1,6 @@
Background
diff --git a/c-user/clock/directives.rst b/c-user/clock/directives.rst
index e99c44e..a6e00ca 100644
--- a/c-user/clock/directives.rst
+++ b/c-user/clock/directives.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/clock/index.rst b/c-user/clock/index.rst
index d84a37a..cf41998 100644
--- a/c-user/clock/index.rst
+++ b/c-user/clock/index.rst
@@ -1,6 +1,6 @@
.. index:: clock
diff --git a/c-user/clock/introduction.rst b/c-user/clock/introduction.rst
index 13be673..6ba814b 100644
--- a/c-user/clock/introduction.rst
+++ b/c-user/clock/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/config/bdbuf.rst b/c-user/config/bdbuf.rst
index a897fa9..2d27d54 100644
--- a/c-user/config/bdbuf.rst
+++ b/c-user/config/bdbuf.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/config/classic-api.rst b/c-user/config/classic-api.rst
index d026593..212f666 100644
--- a/c-user/config/classic-api.rst
+++ b/c-user/config/classic-api.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/config/classic-init-task.rst b/c-user/config/classic-init-task.rst
index 2f3059e..a104008 100644
--- a/c-user/config/classic-init-task.rst
+++ b/c-user/config/classic-init-task.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/config/device-driver.rst b/c-user/config/device-driver.rst
index 9d46211..1e31575 100644
--- a/c-user/config/device-driver.rst
+++ b/c-user/config/device-driver.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 1988, 2021 On-Line Applications Research Corporation (OAR)
diff --git a/c-user/config/directives.rst b/c-user/config/directives.rst
index 715d6e9..25351e9 100644
--- a/c-user/config/directives.rst
+++ b/c-user/config/directives.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2009, 2021 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 2009, 2021 embedded brains GmbH & Co. KG
diff --git a/c-user/config/event-record.rst b/c-user/config/event-record.rst
index f1e7969..1e5c52a 100644
--- a/c-user/config/event-record.rst
+++ b/c-user/config/event-record.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2019, 2022 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 2019, 2022 embedded brains GmbH & Co. KG
.. generated. If you find something that needs to be fixed or
diff --git a/c-user/config/filesystem.rst b/c-user/config/filesystem.rst
index 6e053f2..f61ae13 100644
--- a/c-user/config/filesystem.rst
+++ b/c-user/config/filesystem.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/config/general.rst b/c-user/config/general.rst
index 65e8d36..5ff79e7 100644
--- a/c-user/config/general.rst
+++ b/c-user/config/general.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2020, 2023 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 2020, 2023 embedded brains GmbH & Co. KG
.. Copyright (C) 1988, 2022 On-Line Applications Research Corporation (OAR)
diff --git a/c-user/config/idle-task.rst b/c-user/config/idle-task.rst
index f177438..e98ad83 100644
--- a/c-user/config/idle-task.rst
+++ b/c-user/config/idle-task.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2020, 2022 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 2020, 2022 embedded brains GmbH & Co. KG
diff --git a/c-user/config/introduction.rst b/c-user/config/introduction.rst
index b9aebf9..8852a24 100644
--- a/c-user/config/introduction.rst
+++ b/c-user/config/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/config/mpci.rst b/c-user/config/mpci.rst
index 003afd3..ab9d568 100644
--- a/c-user/config/mpci.rst
+++ b/c-user/config/mpci.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/config/posix-api.rst b/c-user/config/posix-api.rst
index 71033c1..f788c08 100644
--- a/c-user/config/posix-api.rst
+++ b/c-user/config/posix-api.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/config/posix-init-thread.rst b/c-user/config/posix-init-thread.rst
index c038ec8..348a94d 100644
--- a/c-user/config/posix-init-thread.rst
+++ b/c-user/config/posix-init-thread.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/config/scheduler-general.rst b/c-user/config/scheduler-general.rst
index 6f914bc..d347d6b 100644
--- a/c-user/config/scheduler-general.rst
+++ b/c-user/config/scheduler-general.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 2010 Gedare Bloom
diff --git a/c-user/config/task-stack-alloc.rst b/c-user/config/task-stack-alloc.rst
index a11cf3e..c79833f 100644
--- a/c-user/config/task-stack-alloc.rst
+++ b/c-user/config/task-stack-alloc.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/directive_status_codes.rst b/c-user/directive_status_codes.rst
index d93f850..0421af7 100644
--- a/c-user/directive_status_codes.rst
+++ b/c-user/directive_status_codes.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2015 embedded brains GmbH
+.. Copyright (C) 2015 embedded brains GmbH & Co. KG
.. index:: Status Codes
diff --git a/c-user/dual-ported-memory/directives.rst b/c-user/dual-ported-memory/directives.rst
index 7b216a4..b96e3c7 100644
--- a/c-user/dual-ported-memory/directives.rst
+++ b/c-user/dual-ported-memory/directives.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/dual-ported-memory/index.rst b/c-user/dual-ported-memory/index.rst
index cc114ac..98dd9fe 100644
--- a/c-user/dual-ported-memory/index.rst
+++ b/c-user/dual-ported-memory/index.rst
@@ -1,6 +1,6 @@
.. index:: ports
.. index:: dual ported memory
diff --git a/c-user/dual-ported-memory/introduction.rst b/c-user/dual-ported-memory/introduction.rst
index fd7cc8e..515a1f1 100644
--- a/c-user/dual-ported-memory/introduction.rst
+++ b/c-user/dual-ported-memory/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/event/directives.rst b/c-user/event/directives.rst
index bf8f74c..04a2894 100644
--- a/c-user/event/directives.rst
+++ b/c-user/event/directives.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/event/index.rst b/c-user/event/index.rst
index 17ccfbc..dd926e1 100644
--- a/c-user/event/index.rst
+++ b/c-user/event/index.rst
@@ -1,6 +1,6 @@
.. index:: events
diff --git a/c-user/event/introduction.rst b/c-user/event/introduction.rst
index 2876b2c..ebdec2d 100644
--- a/c-user/event/introduction.rst
+++ b/c-user/event/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/fatal-error/directives.rst b/c-user/fatal-error/directives.rst
index 6aa4b20..434172f 100644
--- a/c-user/fatal-error/directives.rst
+++ b/c-user/fatal-error/directives.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2015, 2021 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 2015, 2021 embedded brains GmbH & Co. KG
diff --git a/c-user/fatal-error/index.rst b/c-user/fatal-error/index.rst
index 89cbe30..40eca3b 100644
--- a/c-user/fatal-error/index.rst
+++ b/c-user/fatal-error/index.rst
@@ -1,6 +1,6 @@
.. index:: fatal errors
diff --git a/c-user/fatal-error/introduction.rst b/c-user/fatal-error/introduction.rst
index ff86922..fc310f4 100644
--- a/c-user/fatal-error/introduction.rst
+++ b/c-user/fatal-error/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/glossary.rst b/c-user/glossary.rst
index 59801ed..204eba5 100644
--- a/c-user/glossary.rst
+++ b/c-user/glossary.rst
@@ -1,7 +1,7 @@
.. Copyright (C) 2020 Richi Dubey (richidubey at gmail.com)
+.. Copyright (C) 2015, 2023 embedded brains GmbH & Co. KG
.. Copyright (C) 1988, 1998 On-Line Applications Research Corporation (OAR)
Glossary
diff --git a/c-user/index.rst b/c-user/index.rst
index 385ea95..09aafe8 100644
--- a/c-user/index.rst
+++ b/c-user/index.rst
@@ -10,7 +10,7 @@ RTEMS Classic API Guide (|version|).
| |copy| 2017 Chris Johns
| |copy| 2017 Kuan-Hsun Chen
- | |copy| 2015, 2020 embedded brains GmbH
+ | |copy| 2015, 2020 embedded brains GmbH & Co. KG
| |copy| 2015, 2020 Sebastian Huber
| |copy| 2011 Petr Benes
| |copy| 2010 Gedare Bloom
diff --git a/c-user/initialization/directives.rst b/c-user/initialization/directives.rst
index ca5c9c2..bb3fa95 100644
--- a/c-user/initialization/directives.rst
+++ b/c-user/initialization/directives.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/initialization/index.rst b/c-user/initialization/index.rst
index b41fcdd..cbca400 100644
--- a/c-user/initialization/index.rst
+++ b/c-user/initialization/index.rst
@@ -1,6 +1,6 @@
.. _RTEMSAPIClassicInit:
diff --git a/c-user/initialization/introduction.rst b/c-user/initialization/introduction.rst
index 173e60f..15722f6 100644
--- a/c-user/initialization/introduction.rst
+++ b/c-user/initialization/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/interrupt/directives.rst b/c-user/interrupt/directives.rst
index 22d2c9b..80eddfd 100644
--- a/c-user/interrupt/directives.rst
+++ b/c-user/interrupt/directives.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2008, 2022 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 2008, 2022 embedded brains GmbH & Co. KG
diff --git a/c-user/interrupt/index.rst b/c-user/interrupt/index.rst
index d3e4429..92d332d 100644
--- a/c-user/interrupt/index.rst
+++ b/c-user/interrupt/index.rst
@@ -1,6 +1,6 @@
.. index:: interrupts
diff --git a/c-user/interrupt/introduction.rst b/c-user/interrupt/introduction.rst
index 3e10414..14ea275 100644
--- a/c-user/interrupt/introduction.rst
+++ b/c-user/interrupt/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/io/directives.rst b/c-user/io/directives.rst
index dcf0fc7..7def56a 100644
--- a/c-user/io/directives.rst
+++ b/c-user/io/directives.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/io/index.rst b/c-user/io/index.rst
index 424c776..b1147a9 100644
--- a/c-user/io/index.rst
+++ b/c-user/io/index.rst
@@ -1,6 +1,6 @@
.. index:: device drivers
.. index:: IO Manager
diff --git a/c-user/io/introduction.rst b/c-user/io/introduction.rst
index 7d2c35d..95a5942 100644
--- a/c-user/io/introduction.rst
+++ b/c-user/io/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/kernel-character-io/directives.rst b/c-user/kernel-character-io/directives.rst
index f13010e..e0476fe 100644
--- a/c-user/kernel-character-io/directives.rst
+++ b/c-user/kernel-character-io/directives.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 2015 On-Line Applications Research Corporation (OAR)
diff --git a/c-user/kernel-character-io/index.rst b/c-user/kernel-character-io/index.rst
index c6a9b6b..2d1d13b 100644
--- a/c-user/kernel-character-io/index.rst
+++ b/c-user/kernel-character-io/index.rst
@@ -1,6 +1,6 @@
.. index:: Kernel Character I/O Support
diff --git a/c-user/kernel-character-io/introduction.rst b/c-user/kernel-character-io/introduction.rst
index ef3512b..dc3ac26 100644
--- a/c-user/kernel-character-io/introduction.rst
+++ b/c-user/kernel-character-io/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/linker_sets.rst b/c-user/linker_sets.rst
index 8ad4846..74fc957 100644
--- a/c-user/linker_sets.rst
+++ b/c-user/linker_sets.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2015, 2020 embedded brains GmbH
+.. Copyright (C) 2015, 2020 embedded brains GmbH & Co. KG
.. Copyright (C) 2015, 2020 Sebastian Huber
.. index:: linkersets
diff --git a/c-user/message/directives.rst b/c-user/message/directives.rst
index d6e6eea..7039b2e 100644
--- a/c-user/message/directives.rst
+++ b/c-user/message/directives.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/message/index.rst b/c-user/message/index.rst
index 92ebdae..b797cd1 100644
--- a/c-user/message/index.rst
+++ b/c-user/message/index.rst
@@ -1,6 +1,6 @@
.. index:: messages
.. index:: message queues
diff --git a/c-user/message/introduction.rst b/c-user/message/introduction.rst
index 89fbfca..989cd33 100644
--- a/c-user/message/introduction.rst
+++ b/c-user/message/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/multiprocessing/directives.rst b/c-user/multiprocessing/directives.rst
index fc10640..a12599c 100644
--- a/c-user/multiprocessing/directives.rst
+++ b/c-user/multiprocessing/directives.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/multiprocessing/index.rst b/c-user/multiprocessing/index.rst
index 4ec4433..351105d 100644
--- a/c-user/multiprocessing/index.rst
+++ b/c-user/multiprocessing/index.rst
@@ -1,6 +1,6 @@
.. index:: multiprocessing
diff --git a/c-user/multiprocessing/introduction.rst b/c-user/multiprocessing/introduction.rst
index 742a034..45c90bd 100644
--- a/c-user/multiprocessing/introduction.rst
+++ b/c-user/multiprocessing/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/object-services/directives.rst b/c-user/object-services/directives.rst
index b6f1dbe..c692168 100644
--- a/c-user/object-services/directives.rst
+++ b/c-user/object-services/directives.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 1988, 2009 On-Line Applications Research Corporation (OAR)
diff --git a/c-user/object-services/index.rst b/c-user/object-services/index.rst
index 43a2c10..3218551 100644
--- a/c-user/object-services/index.rst
+++ b/c-user/object-services/index.rst
@@ -1,6 +1,6 @@
.. index:: object manipulation
diff --git a/c-user/object-services/introduction.rst b/c-user/object-services/introduction.rst
index d5a33a4..adff786 100644
--- a/c-user/object-services/introduction.rst
+++ b/c-user/object-services/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/partition/directives.rst b/c-user/partition/directives.rst
index af512f6..da5983c 100644
--- a/c-user/partition/directives.rst
+++ b/c-user/partition/directives.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/partition/index.rst b/c-user/partition/index.rst
index 1396e5c..652fdfa 100644
--- a/c-user/partition/index.rst
+++ b/c-user/partition/index.rst
@@ -1,6 +1,6 @@
.. index:: partitions
diff --git a/c-user/partition/introduction.rst b/c-user/partition/introduction.rst
index 2798658..ca26de9 100644
--- a/c-user/partition/introduction.rst
+++ b/c-user/partition/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/rate-monotonic/directives.rst b/c-user/rate-monotonic/directives.rst
index 50dcc13..f0467d1 100644
--- a/c-user/rate-monotonic/directives.rst
+++ b/c-user/rate-monotonic/directives.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 2017 Kuan-Hsun Chen
diff --git a/c-user/rate-monotonic/index.rst b/c-user/rate-monotonic/index.rst
index a703ca0..9c5b4b6 100644
--- a/c-user/rate-monotonic/index.rst
+++ b/c-user/rate-monotonic/index.rst
@@ -1,6 +1,6 @@
.. index:: rate mononitonic tasks
.. index:: periodic tasks
diff --git a/c-user/rate-monotonic/introduction.rst b/c-user/rate-monotonic/introduction.rst
index 9e3c6f0..b33b0b8 100644
--- a/c-user/rate-monotonic/introduction.rst
+++ b/c-user/rate-monotonic/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/region/directives.rst b/c-user/region/directives.rst
index 26f4623..557b89e 100644
--- a/c-user/region/directives.rst
+++ b/c-user/region/directives.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/region/index.rst b/c-user/region/index.rst
index f0be2f7..2fb01ec 100644
--- a/c-user/region/index.rst
+++ b/c-user/region/index.rst
@@ -1,6 +1,6 @@
.. index:: regions
diff --git a/c-user/region/introduction.rst b/c-user/region/introduction.rst
index 8075a84..ec44d2e 100644
--- a/c-user/region/introduction.rst
+++ b/c-user/region/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/rtems_data_types.rst b/c-user/rtems_data_types.rst
index 6b6757e..a311509 100644
--- a/c-user/rtems_data_types.rst
+++ b/c-user/rtems_data_types.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2008, 2021 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 2008, 2021 embedded brains GmbH & Co. KG
.. Copyright (C) 1988, 2017 On-Line Applications Research Corporation (OAR)
diff --git a/c-user/scheduling-concepts/directives.rst b/c-user/scheduling-concepts/directives.rst
index 7d365ad..115b4fa 100644
--- a/c-user/scheduling-concepts/directives.rst
+++ b/c-user/scheduling-concepts/directives.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2013, 2021 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 2013, 2021 embedded brains GmbH & Co. KG
diff --git a/c-user/scheduling-concepts/index.rst b/c-user/scheduling-concepts/index.rst
index 6b16f1b..ee9aa26 100644
--- a/c-user/scheduling-concepts/index.rst
+++ b/c-user/scheduling-concepts/index.rst
@@ -1,6 +1,6 @@
.. index:: scheduling
.. index:: task scheduling
diff --git a/c-user/scheduling-concepts/introduction.rst b/c-user/scheduling-concepts/introduction.rst
index 31de1c1..527d103 100644
--- a/c-user/scheduling-concepts/introduction.rst
+++ b/c-user/scheduling-concepts/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/self_contained_objects.rst b/c-user/self_contained_objects.rst
index 10d2b91..2001ba3 100644
--- a/c-user/self_contained_objects.rst
+++ b/c-user/self_contained_objects.rst
@@ -1,7 +1,7 @@
.. Copyright (C) 2014, 2017.
-.. COMMENT: embedded brains GmbH.
+.. COMMENT: embedded brains GmbH & Co. KG
Self-Contained Objects
diff --git a/c-user/semaphore/directives.rst b/c-user/semaphore/directives.rst
index 94b83b8..a0d12a6 100644
--- a/c-user/semaphore/directives.rst
+++ b/c-user/semaphore/directives.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/semaphore/index.rst b/c-user/semaphore/index.rst
index a2dad4f..369bccd 100644
--- a/c-user/semaphore/index.rst
+++ b/c-user/semaphore/index.rst
@@ -1,6 +1,6 @@
.. index:: semaphores
.. index:: binary semaphores
diff --git a/c-user/semaphore/introduction.rst b/c-user/semaphore/introduction.rst
index 9c36834..ded0c3e 100644
--- a/c-user/semaphore/introduction.rst
+++ b/c-user/semaphore/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/signal/directives.rst b/c-user/signal/directives.rst
index b883b0a..9345132 100644
--- a/c-user/signal/directives.rst
+++ b/c-user/signal/directives.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/signal/index.rst b/c-user/signal/index.rst
index e418491..d52e098 100644
--- a/c-user/signal/index.rst
+++ b/c-user/signal/index.rst
@@ -1,6 +1,6 @@
.. index:: signals
diff --git a/c-user/signal/introduction.rst b/c-user/signal/introduction.rst
index 449022a..f6e0ded 100644
--- a/c-user/signal/introduction.rst
+++ b/c-user/signal/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/symmetric_multiprocessing_services.rst b/c-user/symmetric_multiprocessing_services.rst
index 9167ae9..aeecece 100644
--- a/c-user/symmetric_multiprocessing_services.rst
+++ b/c-user/symmetric_multiprocessing_services.rst
@@ -2,7 +2,7 @@
.. Copyright (C) 2014.
.. COMMENT: On-Line Applications Research Corporation (OAR).
-.. Copyright (C) 2017 embedded brains GmbH.
.. index:: Symmetric Multiprocessing
.. index:: SMP
diff --git a/c-user/task/background.rst b/c-user/task/background.rst
index e7085cb..c7645b1 100644
--- a/c-user/task/background.rst
+++ b/c-user/task/background.rst
@@ -1,6 +1,6 @@
Background
diff --git a/c-user/task/directives.rst b/c-user/task/directives.rst
index 76aa8dc..c082b51 100644
--- a/c-user/task/directives.rst
+++ b/c-user/task/directives.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/task/index.rst b/c-user/task/index.rst
index 7b22edf..f5e8a64 100644
--- a/c-user/task/index.rst
+++ b/c-user/task/index.rst
@@ -1,6 +1,6 @@
.. index:: tasks
diff --git a/c-user/task/introduction.rst b/c-user/task/introduction.rst
index 5d6eba4..6f5ff4d 100644
--- a/c-user/task/introduction.rst
+++ b/c-user/task/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/task/operations.rst b/c-user/task/operations.rst
index 524258e..6308d7b 100644
--- a/c-user/task/operations.rst
+++ b/c-user/task/operations.rst
@@ -1,6 +1,6 @@
Operations
diff --git a/c-user/timer/directives.rst b/c-user/timer/directives.rst
index 3c13675..2237b30 100644
--- a/c-user/timer/directives.rst
+++ b/c-user/timer/directives.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/timer/index.rst b/c-user/timer/index.rst
index 6557668..b149f30 100644
--- a/c-user/timer/index.rst
+++ b/c-user/timer/index.rst
@@ -1,6 +1,6 @@
.. index:: timers
diff --git a/c-user/timer/introduction.rst b/c-user/timer/introduction.rst
index 76db7ff..4f35972 100644
--- a/c-user/timer/introduction.rst
+++ b/c-user/timer/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/user-extensions/directives.rst b/c-user/user-extensions/directives.rst
index 78955ba..2c5648b 100644
--- a/c-user/user-extensions/directives.rst
+++ b/c-user/user-extensions/directives.rst
@@ -1,6 +1,6 @@
diff --git a/c-user/user-extensions/index.rst b/c-user/user-extensions/index.rst
index 56aa9c4..54b0649 100644
--- a/c-user/user-extensions/index.rst
+++ b/c-user/user-extensions/index.rst
@@ -1,6 +1,6 @@
.. index:: user extensions
diff --git a/c-user/user-extensions/introduction.rst b/c-user/user-extensions/introduction.rst
index 6284242..fab79e7 100644
--- a/c-user/user-extensions/introduction.rst
+++ b/c-user/user-extensions/introduction.rst
@@ -1,6 +1,6 @@
diff --git a/common/license.rst b/common/license.rst
index 9b88646..a8c093d 100644
--- a/common/license.rst
+++ b/common/license.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2019 embedded brains GmbH
+.. Copyright (C) 2019 embedded brains GmbH & Co. KG
This document is available under the
`Creative Commons Attribution-ShareAlike 4.0 International Public License <https://creativecommons.org/licenses/by-sa/4.0/legalcode>`_.
diff --git a/common/version.py b/common/version.py
index bfe0e1b..792f69b 100644
--- a/common/version.py
+++ b/common/version.py
@@ -1,7 +1,7 @@
# RTEMS Documentation Project (http://www.rtems.org/)
# Copyright 2019, 2020 Chris Johns (chrisj at rtems.org)
-# Copyright (C) 2019 embedded brains GmbH
+# Copyright (C) 2019 embedded brains GmbH & Co. KG
# All rights reserved.
# This file is part of the RTEMS Documentation package in 'rtems-docs'.
diff --git a/cpu-supplement/epiphany.rst b/cpu-supplement/epiphany.rst
index c2b2d86..8b491d3 100644
--- a/cpu-supplement/epiphany.rst
+++ b/cpu-supplement/epiphany.rst
@@ -1,6 +1,6 @@
Epiphany Specific Information
diff --git a/cpu-supplement/index.rst b/cpu-supplement/index.rst
index 733ffcc..25b05dd 100644
--- a/cpu-supplement/index.rst
+++ b/cpu-supplement/index.rst
@@ -8,7 +8,7 @@ RTEMS CPU Architecture Supplement (|version|).
- | |copy| 2016, 2018 embedded brains GmbH
+ | |copy| 2016, 2018 embedded brains GmbH & Co. KG
| |copy| 2016, 2018 Sebastian Huber
| |copy| 2014, 2015 Hesham Almatary
diff --git a/cpu-supplement/riscv.rst b/cpu-supplement/riscv.rst
index 4d3fbaf..7b0961e 100644
--- a/cpu-supplement/riscv.rst
+++ b/cpu-supplement/riscv.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2018 embedded brains GmbH
+.. Copyright (C) 2018 embedded brains GmbH & Co. KG
RISC-V Specific Information
diff --git a/cpu-supplement/sparc.rst b/cpu-supplement/sparc.rst
index 11b63d9..c5b7210 100644
--- a/cpu-supplement/sparc.rst
+++ b/cpu-supplement/sparc.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 1988, 2002 On-Line Applications Research Corporation (OAR)
SPARC Specific Information
diff --git a/eng/build-system.rst b/eng/build-system.rst
index 89d27b2..11e8ba7 100644
--- a/eng/build-system.rst
+++ b/eng/build-system.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2019, 2020 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 2019, 2020 embedded brains GmbH & Co. KG
.. _BSPBuildSystem:
@@ -294,7 +294,7 @@ shows the GCC-specific ABI flags item of the ``sparc/leon3`` BSP family:
- env-append: null
build-type: option
copyrights:
- - Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ - Copyright (C) 2020 embedded brains GmbH & Co. KG
default:
- -mcpu=leon3
default-by-variant:
diff --git a/eng/coding-doxygen.rst b/eng/coding-doxygen.rst
index b2e6b61..efd543b 100644
--- a/eng/coding-doxygen.rst
+++ b/eng/coding-doxygen.rst
@@ -1,6 +1,6 @@
.. _DoxygenGuidelines:
diff --git a/eng/coding-file-hdr.rst b/eng/coding-file-hdr.rst
index 3167670..4fc17fd 100644
--- a/eng/coding-file-hdr.rst
+++ b/eng/coding-file-hdr.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2018, 2020 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 2018, 2020 embedded brains GmbH & Co. KG
.. Copyright (C) 2018, 2020 Sebastian Huber
.. _FileTemplates:
diff --git a/eng/doc-guide.rst b/eng/doc-guide.rst
index cdcd04f..f0de23f 100644
--- a/eng/doc-guide.rst
+++ b/eng/doc-guide.rst
@@ -1,6 +1,6 @@
.. _DocGuide:
diff --git a/eng/glossary.rst b/eng/glossary.rst
index 1b2f498..da23fea 100644
--- a/eng/glossary.rst
+++ b/eng/glossary.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2017, 2019 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 2017, 2019 embedded brains GmbH & Co. KG
Glossary
diff --git a/eng/index.rst b/eng/index.rst
index d5d6f85..a4d4563 100644
--- a/eng/index.rst
+++ b/eng/index.rst
@@ -11,7 +11,7 @@ RTEMS Software Engineering (|version|)
- | |copy| 2018, 2020 embedded brains GmbH
+ | |copy| 2018, 2020 embedded brains GmbH & Co. KG
| |copy| 2018, 2020 Sebastian Huber
| |copy| 1988, 2015 On-Line Applications Research Corporation (OAR)
diff --git a/eng/issue-tracking.rst b/eng/issue-tracking.rst
index 1039b41..790ae83 100644
--- a/eng/issue-tracking.rst
+++ b/eng/issue-tracking.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 2019 Sebastian Huber
.. Copyright (C) 2018 Joel Sherill
diff --git a/eng/mission.rst b/eng/mission.rst
index e1b0ec5..2c6aef1 100644
--- a/eng/mission.rst
+++ b/eng/mission.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 2015 Chris Johns
diff --git a/eng/preface.rst b/eng/preface.rst
index f6fda0c..68c84fb 100644
--- a/eng/preface.rst
+++ b/eng/preface.rst
@@ -1,6 +1,6 @@
Preface
diff --git a/eng/prequalification.rst b/eng/prequalification.rst
index 0dddb15..0d4561b 100644
--- a/eng/prequalification.rst
+++ b/eng/prequalification.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 2016, 2018 RTEMS Foundation, The RTEMS Documentation Project
diff --git a/eng/python-devel.rst b/eng/python-devel.rst
index b1e0fa6..f1502e4 100644
--- a/eng/python-devel.rst
+++ b/eng/python-devel.rst
@@ -1,6 +1,6 @@
.. _PythonDevelGuide:
diff --git a/eng/req/index.rst b/eng/req/index.rst
index f0d11b3..524835d 100644
--- a/eng/req/index.rst
+++ b/eng/req/index.rst
@@ -1,6 +1,6 @@
.. |E40| replace:: ECSS-E-ST-40C
diff --git a/eng/req/items.rst b/eng/req/items.rst
index 56835a7..4388c4c 100644
--- a/eng/req/items.rst
+++ b/eng/req/items.rst
@@ -1,6 +1,6 @@
+.. Copyright (C) 2019, 2023 embedded brains GmbH & Co. KG
@@ -339,7 +339,7 @@ Please have a look at the following example:
build-type: ada-test-program
cflags: []
copyrights:
cppflags: []
cxxflags: []
enabled-by: true
@@ -406,7 +406,7 @@ Please have a look at the following example:
build-type: bsp
cflags: []
copyrights:
cppflags: []
enabled-by: true
family: mybsp
@@ -476,7 +476,7 @@ Please have a look at the following example:
copyrights:
enabled-by: true
install-path: ${PREFIX}/lib/pkgconfig
links: []
@@ -565,7 +565,7 @@ Please have a look at the following example:
build-type: group
cflags: []
copyrights:
cppflags: []
cxxflags: []
enabled-by:
@@ -637,7 +637,7 @@ Please have a look at the following example:
cflags:
- -Wno-pointer-sign
copyrights:
cppflags: []
cxxflags: []
enabled-by: true
@@ -700,7 +700,7 @@ Please have a look at the following example:
build-type: objects
cflags: []
copyrights:
cppflags: []
cxxflags: []
enabled-by: true
@@ -772,7 +772,7 @@ Please have a look at the following example:
- define: null
build-type: option
copyrights:
- - Copyright (C) 2020, 2022 embedded brains GmbH (http://www.embedded-brains.de)
+ - Copyright (C) 2020, 2022 embedded brains GmbH & Co. KG
default:
- enabled-by:
- bsps/powerpc/motorola_powerpc
@@ -884,7 +884,7 @@ Please have a look at the following example:
SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
build-type: script
copyrights:
default: null
default-by-variant: []
do-build: |
@@ -944,7 +944,7 @@ Please have a look at the following example:
asflags: []
build-type: start-file
copyrights:
cppflags: []
enabled-by: true
includes: []
@@ -1020,7 +1020,7 @@ Please have a look at the following example:
build-type: test-program
cflags: []
copyrights:
cppflags: []
cxxflags: []
enabled-by: true
@@ -1741,7 +1741,7 @@ Please have a look at the following example:
copyrights:
enabled-by: true
functional-type: capability
links: []
@@ -1887,7 +1887,7 @@ Please have a look at the following example:
copyrights:
enabled-by: true
functional-type: action
links: []
@@ -2451,7 +2451,7 @@ Please have a look at the following example:
copyrights:
enabled-by: true
links:
- role: spec-member
diff --git a/eng/req/management.rst b/eng/req/management.rst
index 3450471..4fb379c 100644
--- a/eng/req/management.rst
+++ b/eng/req/management.rst
@@ -1,6 +1,6 @@
Requirement Management
diff --git a/eng/req/req-for-req.rst b/eng/req/req-for-req.rst
index 0c05ed6..5631b7d 100644
--- a/eng/req/req-for-req.rst
+++ b/eng/req/req-for-req.rst
@@ -1,6 +1,6 @@
Requirements for Requirements
diff --git a/eng/req/tooling.rst b/eng/req/tooling.rst
index 3ca166b..2853932 100644
--- a/eng/req/tooling.rst
+++ b/eng/req/tooling.rst
@@ -1,6 +1,6 @@
Tooling
diff --git a/eng/req/traceability.rst b/eng/req/traceability.rst
index 9376a5f..99c4931 100644
--- a/eng/req/traceability.rst
+++ b/eng/req/traceability.rst
@@ -1,6 +1,6 @@
.. _ReqEngTrace:
diff --git a/eng/stakeholders.rst b/eng/stakeholders.rst
index 756c462..184f890 100644
--- a/eng/stakeholders.rst
+++ b/eng/stakeholders.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 2018 RTEMS Foundation, The RTEMS Documentation Project
RTEMS Stakeholders
diff --git a/eng/test-framework.rst b/eng/test-framework.rst
index bc6d300..25bbad9 100644
--- a/eng/test-framework.rst
+++ b/eng/test-framework.rst
@@ -1,6 +1,6 @@
Software Test Framework
diff --git a/filesystem/index.rst b/filesystem/index.rst
index 64a2f1d..2fcfc95 100644
--- a/filesystem/index.rst
+++ b/filesystem/index.rst
@@ -9,7 +9,7 @@ RTEMS Filesystem Design Guide (|version|).
- | |copy| 2022 embedded brains GmbH (http://www.embedded-brains.de)
+ | |copy| 2022 embedded brains GmbH & Co. KG
.. include:: ../common/license.rst
diff --git a/images/eng/bld-bsp.dot b/images/eng/bld-bsp.dot
index 4e129c4..d9542e5 100644
--- a/images/eng/bld-bsp.dot
+++ b/images/eng/bld-bsp.dot
@@ -1,6 +1,6 @@
# SPDX-License-Identifier: CC-BY-SA-4.0
digraph {
size="4";
diff --git a/images/eng/bld-bsp2.dot b/images/eng/bld-bsp2.dot
index e71726b..84e3460 100644
--- a/images/eng/bld-bsp2.dot
+++ b/images/eng/bld-bsp2.dot
@@ -1,6 +1,6 @@
digraph {
size="4";
diff --git a/images/eng/bld-deps.dot b/images/eng/bld-deps.dot
index 74c6319..87e1a77 100644
--- a/images/eng/bld-deps.dot
+++ b/images/eng/bld-deps.dot
@@ -1,6 +1,6 @@
digraph {
size="8";
diff --git a/images/eng/bld-deps2.dot b/images/eng/bld-deps2.dot
index 86d79df..14c5a16 100644
--- a/images/eng/bld-deps2.dot
+++ b/images/eng/bld-deps2.dot
@@ -1,6 +1,6 @@
digraph {
size="4";
diff --git a/images/eng/req-add.puml b/images/eng/req-add.puml
index 46eb115..0ad17c6 100644
--- a/images/eng/req-add.puml
+++ b/images/eng/req-add.puml
@@ -1,6 +1,6 @@
' SPDX-License-Identifier: CC-BY-SA-4.0
-' Copyright (C) 2019, 2020 embedded brains GmbH (http://www.embedded-brains.de)
+' Copyright (C) 2019, 2020 embedded brains GmbH & Co. KG
@startuml
diff --git a/images/eng/req-modify.puml b/images/eng/req-modify.puml
index fd5a400..d5f37b2 100644
--- a/images/eng/req-modify.puml
+++ b/images/eng/req-modify.puml
@@ -1,6 +1,6 @@
@startuml
diff --git a/images/eng/req-spec-items.puml b/images/eng/req-spec-items.puml
index f837a85..9a1db91 100644
--- a/images/eng/req-spec-items.puml
+++ b/images/eng/req-spec-items.puml
@@ -1,6 +1,6 @@
-' Copyright (C) 2019 embedded brains GmbH
+' Copyright (C) 2019 embedded brains GmbH & Co. KG
@startuml
diff --git a/images/user/patch-review.puml b/images/user/patch-review.puml
index 8134859..432a8c8 100644
--- a/images/user/patch-review.puml
+++ b/images/user/patch-review.puml
@@ -1,6 +1,6 @@
@startuml
diff --git a/shell/index.rst b/shell/index.rst
index 0338807..63d8c14 100644
--- a/shell/index.rst
+++ b/shell/index.rst
@@ -11,7 +11,7 @@ RTEMS Shell Guide (|version|).
| |copy| 2016, 2019 Chris Johns
- | |copy| 2016, 2017 embedded brains GmbH
+ | |copy| 2016, 2017 embedded brains GmbH & Co. KG
| |copy| 2016, 2017 Sebastian Huber
diff --git a/user/bld/index.rst b/user/bld/index.rst
index 18092d2..805a3a0 100644
--- a/user/bld/index.rst
+++ b/user/bld/index.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 2019, 2020 Sebastian Huber
.. index:: BSP build system
diff --git a/user/bsps/arm/altera-cyclone-v.rst b/user/bsps/arm/altera-cyclone-v.rst
index eaa02e3..12e563e 100644
--- a/user/bsps/arm/altera-cyclone-v.rst
+++ b/user/bsps/arm/altera-cyclone-v.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 2017, 2019 Sebastian Huber
altera-cyclone-v (Intel Cyclone V)
diff --git a/user/bsps/arm/fvp.rst b/user/bsps/arm/fvp.rst
index a1e186a..b938e30 100644
--- a/user/bsps/arm/fvp.rst
+++ b/user/bsps/arm/fvp.rst
@@ -1,6 +1,6 @@
-.. Copyright (C) 2022 embedded brains GmbH
+.. Copyright (C) 2022 embedded brains GmbH & Co. KG
fvp (Fixed Virtual Platform)
diff --git a/user/bsps/arm/imx.rst b/user/bsps/arm/imx.rst
index f0ac928..47ad503 100644
--- a/user/bsps/arm/imx.rst
+++ b/user/bsps/arm/imx.rst
@@ -1,6 +1,6 @@
imx (NXP i.MX)
diff --git a/user/bsps/arm/imxrt.rst b/user/bsps/arm/imxrt.rst
index b4f37fd..3df233f 100644
--- a/user/bsps/arm/imxrt.rst
+++ b/user/bsps/arm/imxrt.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 2020 Christian Mauderer
imxrt (NXP i.MXRT)
diff --git a/user/bsps/arm/lpc24xx.rst b/user/bsps/arm/lpc24xx.rst
index ecf1d84..f287dc8 100644
--- a/user/bsps/arm/lpc24xx.rst
+++ b/user/bsps/arm/lpc24xx.rst
@@ -1,6 +1,6 @@
lpc24xx (NXP LPC17XX/LPC24XX/LPC40XX)
diff --git a/user/bsps/arm/realview-pbx-a9.rst b/user/bsps/arm/realview-pbx-a9.rst
index 15d1fbf..bbe0269 100644
--- a/user/bsps/arm/realview-pbx-a9.rst
+++ b/user/bsps/arm/realview-pbx-a9.rst
@@ -1,6 +1,6 @@
realview-pbx-a9
diff --git a/user/bsps/arm/stm32h7.rst b/user/bsps/arm/stm32h7.rst
index 6257e0d..cdf4d43 100644
--- a/user/bsps/arm/stm32h7.rst
+++ b/user/bsps/arm/stm32h7.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 2022 Karel Gardas <karel at functional.vision>
diff --git a/user/bsps/arm/xilinx-zynqmp.rst b/user/bsps/arm/xilinx-zynqmp.rst
index 9a605bb..fa60470 100644
--- a/user/bsps/arm/xilinx-zynqmp.rst
+++ b/user/bsps/arm/xilinx-zynqmp.rst
@@ -1,6 +1,6 @@
xilinx-zynqmp
diff --git a/user/bsps/bsps-aarch64.rst b/user/bsps/bsps-aarch64.rst
index f3aa15c..f99843a 100644
--- a/user/bsps/bsps-aarch64.rst
+++ b/user/bsps/bsps-aarch64.rst
@@ -1,6 +1,6 @@
aarch64 (AArch64)
diff --git a/user/bsps/bsps-arm.rst b/user/bsps/bsps-arm.rst
index d9b5d01..e06fa6f 100644
--- a/user/bsps/bsps-arm.rst
+++ b/user/bsps/bsps-arm.rst
@@ -1,6 +1,6 @@
arm (ARM)
diff --git a/user/bsps/bsps-bfin.rst b/user/bsps/bsps-bfin.rst
index db7f721..eeb426e 100644
--- a/user/bsps/bsps-bfin.rst
+++ b/user/bsps/bsps-bfin.rst
@@ -1,6 +1,6 @@
bfin (Blackfin)
diff --git a/user/bsps/bsps-i386.rst b/user/bsps/bsps-i386.rst
index 0b273ee..81f5fd8 100644
--- a/user/bsps/bsps-i386.rst
+++ b/user/bsps/bsps-i386.rst
@@ -1,6 +1,6 @@
i386
diff --git a/user/bsps/bsps-lm32.rst b/user/bsps/bsps-lm32.rst
index 2db5b12..98ffb91 100644
--- a/user/bsps/bsps-lm32.rst
+++ b/user/bsps/bsps-lm32.rst
@@ -1,6 +1,6 @@
lm32 (LatticeMicro32)
diff --git a/user/bsps/bsps-m68k.rst b/user/bsps/bsps-m68k.rst
index bdb516b..a820d96 100644
--- a/user/bsps/bsps-m68k.rst
+++ b/user/bsps/bsps-m68k.rst
@@ -1,6 +1,6 @@
m68k (Motorola 68000 / ColdFire)
diff --git a/user/bsps/bsps-microblaze.rst b/user/bsps/bsps-microblaze.rst
index 32aad90..c240bdb 100644
--- a/user/bsps/bsps-microblaze.rst
+++ b/user/bsps/bsps-microblaze.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
microblaze (MicroBlaze)
diff --git a/user/bsps/bsps-mips.rst b/user/bsps/bsps-mips.rst
index 9f83811..f90732a 100644
--- a/user/bsps/bsps-mips.rst
+++ b/user/bsps/bsps-mips.rst
@@ -1,6 +1,6 @@
mips (MIPS)
diff --git a/user/bsps/bsps-moxie.rst b/user/bsps/bsps-moxie.rst
index eab88cc..8548777 100644
--- a/user/bsps/bsps-moxie.rst
+++ b/user/bsps/bsps-moxie.rst
@@ -1,6 +1,6 @@
moxie
diff --git a/user/bsps/bsps-nios2.rst b/user/bsps/bsps-nios2.rst
index ad21dd3..5280025 100644
--- a/user/bsps/bsps-nios2.rst
+++ b/user/bsps/bsps-nios2.rst
@@ -1,6 +1,6 @@
nios2 (Nios II)
diff --git a/user/bsps/bsps-or1k.rst b/user/bsps/bsps-or1k.rst
index 6295c23..e7d9a10 100644
--- a/user/bsps/bsps-or1k.rst
+++ b/user/bsps/bsps-or1k.rst
@@ -1,6 +1,6 @@
or1k (OpenRISC 1000)
diff --git a/user/bsps/bsps-powerpc.rst b/user/bsps/bsps-powerpc.rst
index 3d1ce88..6b63936 100644
--- a/user/bsps/bsps-powerpc.rst
+++ b/user/bsps/bsps-powerpc.rst
@@ -1,6 +1,6 @@
powerpc (PowerPC)
diff --git a/user/bsps/bsps-riscv.rst b/user/bsps/bsps-riscv.rst
index b4bdf7b..263796e 100644
--- a/user/bsps/bsps-riscv.rst
+++ b/user/bsps/bsps-riscv.rst
@@ -1,6 +1,6 @@
riscv (RISC-V)
diff --git a/user/bsps/bsps-sh.rst b/user/bsps/bsps-sh.rst
index b147251..8c245c4 100644
--- a/user/bsps/bsps-sh.rst
+++ b/user/bsps/bsps-sh.rst
@@ -1,6 +1,6 @@
sh (SuperH)
diff --git a/user/bsps/bsps-sparc.rst b/user/bsps/bsps-sparc.rst
index 3ffd079..325c7fa 100644
--- a/user/bsps/bsps-sparc.rst
+++ b/user/bsps/bsps-sparc.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 2020 Chris Johns
sparc (SPARC / LEON)
diff --git a/user/bsps/bsps-sparc64.rst b/user/bsps/bsps-sparc64.rst
index e7be4ea..7b598b7 100644
--- a/user/bsps/bsps-sparc64.rst
+++ b/user/bsps/bsps-sparc64.rst
@@ -1,6 +1,6 @@
sparc64 (SPARC V9)
diff --git a/user/bsps/bsps-v850.rst b/user/bsps/bsps-v850.rst
index 39973db..220ccc0 100644
--- a/user/bsps/bsps-v850.rst
+++ b/user/bsps/bsps-v850.rst
@@ -1,6 +1,6 @@
v850 (V850)
diff --git a/user/bsps/bsps-x86_64.rst b/user/bsps/bsps-x86_64.rst
index a7f7326..38d84e4 100644
--- a/user/bsps/bsps-x86_64.rst
+++ b/user/bsps/bsps-x86_64.rst
@@ -1,7 +1,7 @@
.. Copyright (C) 2018 Amaan Cheval <amaan.cheval at gmail.com>
x86_64
diff --git a/user/bsps/index.rst b/user/bsps/index.rst
index bf590e0..5c1b3b7 100644
--- a/user/bsps/index.rst
+++ b/user/bsps/index.rst
@@ -1,6 +1,6 @@
.. _BSPs:
diff --git a/user/hardware/architectures.rst b/user/hardware/architectures.rst
index b604782..2e0cb9e 100644
--- a/user/hardware/architectures.rst
+++ b/user/hardware/architectures.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 2016 Chris Johns <chrisj at rtems.org>
diff --git a/user/index.rst b/user/index.rst
index 38ade81..5b7f3ce 100644
--- a/user/index.rst
+++ b/user/index.rst
@@ -18,7 +18,7 @@ RTEMS User Manual (|version|).
| |copy| 2018 Shashvat Jain
| |copy| 2018 Vidushi Vashishth
| |copy| 2017 Tanu Hari Dixit
- | |copy| 2016, 2019 embedded brains GmbH
+ | |copy| 2016, 2019 embedded brains GmbH & Co. KG
| |copy| 2016, 2019 Sebastian Huber
| |copy| 2012, 2022 Chris Johns
| |copy| 2012, 2020 Gedare Bloom
diff --git a/user/migration/v4_11-to-v5.rst b/user/migration/v4_11-to-v5.rst
index bde84c2..2dc97ec 100644
--- a/user/migration/v4_11-to-v5.rst
+++ b/user/migration/v4_11-to-v5.rst
@@ -1,7 +1,7 @@
.. _Migration_4_11_to_5:
diff --git a/user/migration/v5-to-v6.rst b/user/migration/v5-to-v6.rst
index 079f640..98c7366 100644
--- a/user/migration/v5-to-v6.rst
+++ b/user/migration/v5-to-v6.rst
@@ -1,6 +1,6 @@
.. _Migration_5_to_6:
diff --git a/user/start/bsp-build.rst b/user/start/bsp-build.rst
index 585d009..c62b6ba 100644
--- a/user/start/bsp-build.rst
+++ b/user/start/bsp-build.rst
@@ -1,6 +1,6 @@
.. _QuickStartBSPBuild:
diff --git a/user/start/bsp-test.rst b/user/start/bsp-test.rst
index 575f19e..a354663 100644
--- a/user/start/bsp-test.rst
+++ b/user/start/bsp-test.rst
@@ -1,6 +1,6 @@
.. _QuickStartBSPTest:
diff --git a/user/start/prefixes.rst b/user/start/prefixes.rst
index 826ce85..aee7440 100644
--- a/user/start/prefixes.rst
+++ b/user/start/prefixes.rst
@@ -1,6 +1,6 @@
diff --git a/user/start/preparation.rst b/user/start/preparation.rst
index 3670885..4bfc214 100644
--- a/user/start/preparation.rst
+++ b/user/start/preparation.rst
@@ -1,7 +1,7 @@
.. Copyright (C) 2018 Shashvat Jain
.. Copyright (C) 2020 Gedare Bloom
diff --git a/user/start/sources.rst b/user/start/sources.rst
index 6585e3d..a6e66df 100644
--- a/user/start/sources.rst
+++ b/user/start/sources.rst
@@ -1,6 +1,6 @@
diff --git a/user/start/tools.rst b/user/start/tools.rst
index 2706f71..3656867 100644
--- a/user/start/tools.rst
+++ b/user/start/tools.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 2020 Utkarsh Rai
diff --git a/user/support/bugs.rst b/user/support/bugs.rst
index d75c9b4..02788d9 100644
--- a/user/support/bugs.rst
+++ b/user/support/bugs.rst
@@ -1,6 +1,6 @@
.. Copyright (C) 2015 Chris Johns <chrisj at rtems.org>
.. Copyright (C) 2012 Gedare Bloom
diff --git a/user/support/contrib.rst b/user/support/contrib.rst
index c42d41b..5d61b46 100644
--- a/user/support/contrib.rst
+++ b/user/support/contrib.rst
@@ -1,6 +1,6 @@
diff --git a/user/support/index.rst b/user/support/index.rst
index 6147c06..5320488 100644
--- a/user/support/index.rst
+++ b/user/support/index.rst
@@ -1,6 +1,6 @@
.. index:: support
diff --git a/user/support/support-project.rst b/user/support/support-project.rst
index b782029..4aef902 100644
--- a/user/support/support-project.rst
+++ b/user/support/support-project.rst
@@ -1,6 +1,6 @@
diff --git a/user/tracing/eventrecording.rst b/user/tracing/eventrecording.rst
index b5561cc..c011000 100644
--- a/user/tracing/eventrecording.rst
+++ b/user/tracing/eventrecording.rst
@@ -1,6 +1,6 @@
.. _EventRecording:
2.35.3
