[PATCH 2/5] build: Use CSafeLoader if available
Mon May 22 08:29:34 UTC 2023
On 22.05.23 01:48, Chris Johns wrote:
>> The support for the CSafeLoader is just about 60 lines of additional code.
>> It would be a nice improvement for systems supporting this feature. I don't have
>> time to work on adding PyYAML with libyaml to the RTEMS Tools right now and I
>> think this would open another maintenance issues. If someone would be unable to
>> get a yaml module with a CSafeLoader, then he would be no longer able to build
>> RTEMS.
> It is not about the size of the implementation, it is about making 2 classes of
> performance, those with and those without csafe. I am a firm believer all
> developers and especially core developers need to be using the exact same tools
> and code our community users are using. We did not always do this and it
> resulted in the developers being disconnected from the user experience and I
> decided I would do what I could to avoid this happening again.
I really don't see the issue here. It is just the way to load the items
from the file system. This is a very isolated task in the build and
having two ways to do this is not a big deal from my point of view.
> In regards to PyYAML there are a few basic issues with it that I am not sure
> about. The package can be built without support for the C library even if it is
> installed. I cannot tell if a pip installed version is using the C YAML package
> or not. I would like more certainty across our supported hosts before agreeing
> to us using it.
I think it is just too complicated to make sure that the user has a
PyYAML with the CSafeLoader available when RTEMS is built. A more robust
approach is a fall back to the current implementation if needed.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
