[PATCH rtems v1] score/src/pheap*: Remove unreferenced methods
Joel Sherrill
joel at rtems.org
Mon May 22 13:47:48 UTC 2023
* _Protected_heap_Get_block_size
* _Protected_heap_Iterate
* _Protected_heap_Resize_block
Closes #4909.
cpukit/include/rtems/score/protectedheap.h | 69 ------------------------------
cpukit/score/src/pheapgetblocksize.c | 56 ------------------------
cpukit/score/src/pheapiterate.c | 52 ----------------------
cpukit/score/src/pheapresizeblock.c | 60 --------------------------
spec/build/cpukit/librtemscpu.yml | 3 --
5 files changed, 240 deletions(-)
delete mode 100644 cpukit/score/src/pheapgetblocksize.c
delete mode 100644 cpukit/score/src/pheapiterate.c
delete mode 100644 cpukit/score/src/pheapresizeblock.c
diff --git a/cpukit/include/rtems/score/protectedheap.h b/cpukit/include/rtems/score/protectedheap.h
index 884d7e1..2871085 100644
--- a/cpukit/include/rtems/score/protectedheap.h
+++ b/cpukit/include/rtems/score/protectedheap.h
@@ -163,59 +163,6 @@ static inline void *_Protected_heap_Allocate(
- * @brief Returns the size of the allocatable memory area.
- * The size value may be greater than the initially requested size in
- * _Heap_Allocate_aligned_with_boundary().
- * Inappropriate values for @a addr will not corrupt the heap, but may yield
- * invalid size values.
- * This method first locks the allocator and after the operation, unlocks it again.
- * @param heap The heap to operate upon.
- * @param addr The starting address of the allocatable memory area.
- * @param[out] size Stores the size of the allocatable memory area after the method call.
- * @retval true The operation was successful.
- * @retval false The operation was not successful.
-bool _Protected_heap_Get_block_size(
- Heap_Control *heap,
- void *addr,
- uintptr_t *size
- * @brief Resizes the block of the allocated memory area.
- * Inappropriate values for @a addr may corrupt the heap.
- * This method first locks the allocator and after the resize, unlocks it again.
- * @param[in, out] heap The heap to operate upon.
- * @param addr The starting address of the allocated memory area to be resized.
- * @param size The least possible size for the new memory area. Resize may be
- * impossible and depends on the current heap usage.
- * @param[out] old_size Stores the size available for allocation in the current
- * block before the resize after the method call.
- * @param[out] new_size Stores the size available for allocation in the resized
- * block after the method call. In the case of an unsuccessful resize,
- * zero is returned in this parameter
- * @retval HEAP_RESIZE_SUCCESSFUL The resize was successful.
- * @retval HEAP_RESIZE_UNSATISFIED The least possible size @a size was too big.
- * Resize not possible.
- * @retval HEAP_RESIZE_FATAL_ERROR The block starting at @a addr is not part of
- * the heap.
-bool _Protected_heap_Resize_block(
- void *addr,
- uintptr_t size
* @brief Frees the allocated memory area.
* Inappropriate values for @a addr may corrupt the heap. This method first locks
@@ -245,22 +192,6 @@ bool _Protected_heap_Free( Heap_Control *heap, void *addr );
bool _Protected_heap_Walk( Heap_Control *heap, int source, bool dump );
- * @brief Iterates over all blocks of the heap.
- * @param[in, out] heap The heap to iterate over.
- * @param visitor This will be called for each heap block with
- * the argument @a visitor_arg.
- * @param[in, out] visitor_arg The argument for all calls of @a visitor.
-void _Protected_heap_Iterate(
- Heap_Block_visitor visitor,
- void *visitor_arg
* @brief Returns information about used and free blocks for the heap.
diff --git a/cpukit/score/src/pheapgetblocksize.c b/cpukit/score/src/pheapgetblocksize.c
deleted file mode 100644
index c53a66b..0000000
--- a/cpukit/score/src/pheapgetblocksize.c
+++ /dev/null
@@ -1,56 +0,0 @@
-/* SPDX-License-Identifier: BSD-2-Clause */
- * @file
- * @ingroup RTEMSScoreProtHeap
- * @brief This source file contains the implementation of
- * _Protected_heap_Get_block_size().
- * COPYRIGHT (c) 1989-2007.
- * On-Line Applications Research Corporation (OAR).
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in the
- * documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
- * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
- * POSSIBILITY OF SUCH DAMAGE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/score/protectedheap.h>
- Heap_Control *the_heap,
- void *starting_address,
- uintptr_t *size
- bool status;
- _RTEMS_Lock_allocator();
- status = _Heap_Size_of_alloc_area( the_heap, starting_address, size );
- _RTEMS_Unlock_allocator();
- return status;
diff --git a/cpukit/score/src/pheapiterate.c b/cpukit/score/src/pheapiterate.c
index a709e80..0000000
--- a/cpukit/score/src/pheapiterate.c
+++ /dev/null
@@ -1,52 +0,0 @@
- * @file
- * _Protected_heap_Iterate().
- * Copyright (c) 2011 embedded brains GmbH. All rights reserved.
- * are met:
-#endif
- void *visitor_arg
- _Heap_Iterate( heap, visitor, visitor_arg );
diff --git a/cpukit/score/src/pheapresizeblock.c b/cpukit/score/src/pheapresizeblock.c
index ffd765e..0000000
--- a/cpukit/score/src/pheapresizeblock.c
+++ /dev/null
@@ -1,60 +0,0 @@
- * @file
- * _Protected_heap_Resize_block().
- * are met:
-#endif
- uintptr_t size
- Heap_Resize_status status;
- uintptr_t old_mem_size;
- uintptr_t avail_mem_size;
- status = _Heap_Resize_block(
- the_heap, starting_address, size, &old_mem_size, &avail_mem_size );
- return (status == HEAP_RESIZE_SUCCESSFUL);
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 133a300..8218b6e 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1482,12 +1482,9 @@ source:
- cpukit/score/src/pheapallocate.c
- cpukit/score/src/pheapextend.c
- cpukit/score/src/pheapfree.c
-- cpukit/score/src/pheapgetblocksize.c
- cpukit/score/src/pheapgetfreeinfo.c
- cpukit/score/src/pheapgetinfo.c
- cpukit/score/src/pheapgetsize.c
-- cpukit/score/src/pheapiterate.c
-- cpukit/score/src/pheapresizeblock.c
- cpukit/score/src/pheapwalk.c
- cpukit/score/src/processormaskcopy.c
- cpukit/score/src/profilingisrentryexit.c
1.8.3.1
