[PATCH rtems-libbsd] ipsec-tools: Fix copying fd_set prior to select
Chris Johns
chrisj at rtems.org
Tue May 23 23:13:15 UTC 2023
On 23/5/2023 5:30 pm, Christian MAUDERER wrote:
> Hello Chris,
> On 2023-05-23 08:53, Chris Johns wrote:
>> On 23/5/2023 4:25 pm, Christian MAUDERER wrote:
>>> Hello Chris,
>>> On 2023-05-23 03:36, Chris Johns wrote:
>>>> Hi,
>>>> I have been resolving this by adding:
>>>> #define preset_mask *preset_mask_prealloc
>>>> #define active_mask *active_mask_prealloc
>>>> as the assignment logic works as is. It does not catch FD_ZERO which is a shame
>>>> but is helps avoid us adding a special case.
>>> Thanks for the suggestion. I used that solution already in the file during the
>>> initial port. But it doesn't work in this case (and maybe we should check other
>>> cases in libbsd too). It only copies the first element of the array of fd_sets.
>>> The variables / defines are (in the patched version - see [1]):
>>> static fd_set *allocated_preset_mask, *allocated_active_mask;
>>> static struct fd_monitor *allocated_fd_monitors;
>>> #define preset_mask (*allocated_preset_mask)
>>> #define active_mask (*allocated_active_mask)
>>> #define fd_monitors (allocated_fd_monitors)
>>> They are allocated as follows (see [2]):
>>> allocated_preset_mask = calloc(sizeof(fd_set),
>>> howmany(rtems_libio_number_iops, sizeof(fd_set) * 8));
>>> allocated_active_mask = calloc(sizeof(fd_set),
>>> allocated_fd_monitors = calloc(
>>> rtems_libio_number_iops, sizeof(struct fd_monitor));
>>> So basically it's a bunch of arrays of fd_sets. If I now use the following
>>> (unpatched) assignment:
>>> active_mask = preset_mask;
>>> After the preprocessor the line will be
>>> (*allocated_active_mask) = (*allocated_preset_mask);
>>> Which copies only the first element. That's why I had to add the memcpy. Did I
>>> miss some better solution?
>> I am using this in ntpd which I checked yesterday:
>> #ifdef __rtems__
>> #include <rtems/libio_.h>
>> static size_t rtems_ntpd_fds_size;
>> static int rtems_fd_set_alloc(fd_set **setp) {
>> if (*setp == NULL) {
>> rtems_ntpd_fds_size = sizeof(fd_set) *
>> (howmany(rtems_libio_number_iops, sizeof(fd_set) * 8));
>> *setp = malloc(rtems_ntpd_fds_size);
>> errno = ENOMEM;
>> return -1;
>> memset(*setp, 0, rtems_ntpd_fds_size);
>> return 0;
>> #define activefds (*activefds_prealloc)
>> static fd_set *activefds_prealloc;
>> #define rtems_activefds_alloc() rtems_fd_set_alloc(&activefds_prealloc)
>> #else /* __rtems__ */
>> static fd_set activefds;
>> #endif /* __rtems__ */
>> and:
>> #if __rtems__
>> #define rdfdes (*rdfdes_prealloc)
>> static fd_set *rdfdes_prealloc;
>> fd_set rdfdes;
>> int nfound;
>> #if __rtems__
>> if (rtems_fd_set_alloc(&rdfdes_prealloc) < 0) {
>> return;
>> memset(rdfdes_prealloc, 0, rtems_ntpd_fds_size);
>> FD_ZERO(&set);
>> with:
>> ++handler_calls;
>> rdfdes = activefds;
> But isn't that line resolving to
> (*rdfdes_prealloc) = (*activefds_prealloc);
> That would also copy only the first element.
>> Stepping:
>> Thread 9 hit Breakpoint 1, _ntp_io_handler () at
>> ../../bsd/freebsd/contrib/ntp/ntpd/ntp_io.c:3727
>> 3727 rdfdes = activefds;
>> (gdb) x /8bx activefds_prealloc
>> 0x1083e650: 0x20 0x44 0x05 0x20 0x00 0x40 0x00 0x00
>> (gdb) x /8bx rdfdes_prealloc
>> 0x108353a0: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
>> (gdb) n
>> 3736 t1.tv_usec = 0;
>> 0x108353a0: 0x20 0x44 0x05 0x20 0x00 0x40 0x00 0x00
>> Looks ok to me.
> fd_set is 64 bit wide. So a copy of the first 64 bit works. Does it still work
> if you have 256 files in the system?
Good question. I have not checked but I will.
FYI EPICS has set its limit to 64 because of this issue with select. I suspect
they do not want to hack their select calls like this and I understand them
taking that position.
