Discussion: How to handle HALs, SDKs and libraries
    Christian MAUDERER
    christian.mauderer at embedded-brains.de
    Wed May 24 07:07:58 UTC 2023
Hello Chris,
On 2023-05-24 03:44, Chris Johns wrote:
> Hi Christian,
> Thanks for raising this topic. It is a tough one.
> On 24/5/2023 12:11 am, Kinsey Moore wrote:
>> On Tue, May 23, 2023 at 2:26 AM Christian MAUDERER
>> <christian.mauderer at embedded-brains.de
>> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>>      Hello,
>>      I recently updated the HAL in the i.MXRT BSP. I used the same approach
>>      that we use for a lot of similar cases: Import the sources into RTEMS
>>      and adapt them slightly so that they work for us. So basically a
>>      Clone-and-Own approach.
>>      During the discussion of the patches, some concerns were raised, whether
>>      we should find a better solution to handle HALs, SDKs and similar cases.
>>      We should start discussing a solution that can be used after the 6
>>      release so that maybe someone can start to work on a prototype.
>>      Some example cases are:
>>      - the mcux_sdk in the imxrt BSP
>>      - the hal in the stm32h7 BSP
>>      - general ARM CMSIS files
>>      - zlib
>>      - libfdt
>>      One solution could be to build these libraries external and only link
>>      RTEMS with them. There are disadvantages to this aproach:
>>      - Also in my experience, the API of the HALs / SDKs / libraries seems to
>>      be quite stable, it's possible that there are combinations where some
>>      unexpected change breaks a driver or makes it impossible to link the
>>      applications.
> Xilinx with the more complex devices like the Versal have been moving things
> about. The Versal SMC call set is fluid and the PM (platform manager) seems to
> functionally align to Xilinx tools releases plus Petalinux versions. For example
> there are stable defined API calls in Versal Linux (XRT/zocl) that depends on PM
> code that is commented in the code as "to be removed".
> When I first used the Zynq I used Xilinx's drivers like OAR is currently with
> the Microblaze. I could not release the results because of the license at the
> time. I quickly found the drivers lacked functionality for general use and broke
> under high loads and boundary conditions. The fixes are part of a project and
> cannot be released because the license at the time made it impossible. What I
> leant from the exercise is to not depend on their drivers.
That sounds like a quite bad case. So it's a good example for that
discussion. Thanks for bringing it up.
> I feel what we considered stable will depend on the origin of the code and that
> will be case by case.
Agreed.
>>      - BSPs rely on basic drivers from these libraries (like console or clock
>>      driver). If we link against the libraries, the testsuite wouldn't build
>>      any more without preinstalled libraries.
> Yes the mutual dependence if built externally and before RTEMS is not easy to
> solve. The idea of the HAL code being supplied as .h and a .a does let a user
> update the drivers without needing an RTEMS version update.
>>      Another solution could be to include libraties like that as submodules
>>      and build them using the RTEMS build system. We could clone the repos
>>      onto the RTEMS git server, and add necessary patches. Advantage would be
>>      that it is more similar to the process that we currently have. Another
>>      advantage is that we have a known-working version of the files. Upstream
>>      updates could be either merged or we could rebase our patches to a new
>>      version.
> See below for the problems this creates.
>>       From my point of view, the second option would be the better one
>>      especially because we have a tested, fixed version of the library
>>      instead telling the user to just use some random version that might or
>>      might not work.
> This is important. We need to define what a release is and it is a requirement
> we provide all code as tarball files. This implies the release process knows how
> to create the tarfiles.
>>      Regardless which aproach we use: We have to think about how to handle
>>      that on releases. In the link aproach (first case), we have to somehow
>>      archive source tar balls and some kind of build recipe. In the submodule
>>      aproach, we could checkout all submodules and pack the files into the
>>      RTEMS release tar ball. So I would expect that the second aproach has
>>      less impact here too.
>>      Comments? Improvements? Better suggestions?
>> I would definitely prefer the submodule approach over the linking approach to
>> avoid the test issues since some of these HALs bring core functionality. The
>> Xilinx driver framework (embeddedsw repo on Github) would be well-suited to the
>> submodule approach since it is already broken out into the shared driver space
>> because it can apply to at least 3 architectures (ARM, AArch64, MicroBlaze).
> I suggest you avoid making that repo a submodule of anything. The code in that
> repo is "over the wall" and there is no continuity. I have it as a submodule in
> my XRT repo and a Xilinx push of the next release of tools broke the code. What
> I had depended on was removed and moved somewhere else. The Xilinx updates are
> based on the release cycle of their tools and they do not respond to issues or
> PRs. They are free to make what ever changes they like and they do that
> internally and what appears externally is based on changes across their internal
> repos. To make things harder there is no consistent point they update these
> public repos so the code they removed did not reappear for a long time.
>> One issue with either approach is the need to modify the HAL source to suit
>> RTEMS. As far as I'm aware, there is no tooling in place in git for applying
>> patches to submodules and in the external build scenario we'd end up maintaining
>> a branch of the origin repo with patches applied. Upstreaming the changes would
>> be ideal, but I wouldn't expect them to accept RTEMS-specific patches. The
>> Xilinx NAND driver already requires a minor modification because that driver
>> doesn't expose an option and instead has a defined macro that determines how
>> many chip selects are usable to address different parts of the NAND chip.
>> Technically, this particular change could be worked around with some include
>> path trickery to leave the original sources unmodified, but many other changes
>> would not be suited by that type of workaround and it makes the source less
>> maintainable. We would need to come up with our own tooling for submodule patch
>> application and silencing of warnings about dirty submodule trees due to applied
>> patches.
> Direct dependence on external repos we do not control is a long term maintenance
> problem. Repos move and change [1] and this makes maintaining past releases a
> challenge. Who is responsible for the long term release branch maintenance?
> Without a working submnodule a release cannot be made and that is not great.
> Expecting the release manager to clean up is not going to work given the task is
> unfunded.
Let's make the dependencies indirect: We clone repos to git.rtems.org
and to our mirrors. Then we can either use a submodule URL starting with
git://git.rtems.org or even with a relative URL if we want to make
better use of the mirrors.
If necessary, that approach allows adding an RTEMS-branch that adds
patches. It's more similar to the clone and own we do now. But having a
clone of the original repo makes it a lot simpler to merge upstream
changes. Having an RTEMS-branch makes it easier to see what has been
changed for RTEMS.
We don't have to integrate automatic updates or similar. We only
maintain and keep a tested version. If a BSP maintainer or user wants to
upgrade, he pulls the changes from the upstream repo and merges them
into the branch that includes our patches.
That should even work for your extreme case of the Xilinx repo. We have
a tested version on our server. If someone wants to update, he has to
update, find out what Xilinx did break during their updates and adapt to
that. Then we can push that new version to our clone of the Xilinx repo.
> Submodules in rtems.git is a change in policy. We allow submodules in add-on
> packages like libbsd but it has never been something we have allowed with rtems.git.
I agree that it would be a change in policy. But that's the whole point
of the discussion: The current method makes it hard to maintain library
code. Do we find a better solution that either fits in current policies
or do we find sensible adaptions to the policies that are OK for everyone?
I don't see submodules as the only valid solution. But it's one that
looks promising to me, and therefore I brought it up. It is similar to
the approach that has worked well in libbsd. What I currently suggest
only tries to avoid the step of copying code between the upstream repo
and the local one like we do in libbsd.
Do you have a good alternative idea that would need less changes in policy?
Best regards
Christian
> Chris
> [1] All recently moved ... https://github.com/freedesktop
embedded brains GmbH & Co. KG
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
email:  christian.mauderer at embedded-brains.de
phone:  +49-89-18 94 741 - 18
mobile: +49-176-152 206 08
Registernummer: HRA 117265
