[PATCH 0/4] Improve Doxygen file comments
    Sebastian Huber
    Wed May 24 13:01:31 UTC 2023
Sebastian Huber (4):
  arm: Improve Doxygen file comments
  bsps: Improve Doxygen file comments
  bsps/arm: Improve Doxygen groups
  arm/xilinx-zynq: Improve Doxygen file comments
 bsps/arm/include/bsp/arm-a9mpcore-clock.h      | 16 ++++++++++++++++
 bsps/arm/include/bsp/arm-a9mpcore-irq.h        | 14 +++++++++++---
 bsps/arm/include/bsp/arm-a9mpcore-regs.h       | 18 +++++++++++++++---
 bsps/arm/include/bsp/arm-a9mpcore-start.h      | 14 +++++++++++---
 .../dev/cache/arm-data-cache-loop-set-way.h    | 11 +++++++++++
 bsps/arm/shared/cache/cache-cp15.h             |  7 ++++---
 bsps/arm/shared/cache/cache-l2c-310.c          | 15 +++++++++------
 bsps/arm/shared/clock/clock-a9mpcore.c         |  9 +++++++++
 .../cp15/arm-cp15-set-exception-handler.c      |  9 +++++++++
 .../arm/shared/cp15/arm-cp15-set-ttb-entries.c |  9 +++++++++
 bsps/arm/xilinx-zynq/console/console-config.c  | 12 ++++++++++--
 bsps/arm/xilinx-zynq/console/debug-console.c   | 13 +++++++++++--
 bsps/arm/xilinx-zynq/start/bspreset.c          | 12 ++++++++++--
 bsps/arm/xilinx-zynq/start/bspstart.c          | 13 +++++++++++--
 bsps/arm/xilinx-zynq/start/bspstarthooks.c     | 13 +++++++++++--
 bsps/arm/xilinx-zynq/start/bspstartmmu.c       | 13 +++++++++++--
 bsps/include/bsp/utility.h                     |  4 ++--
 bsps/shared/dev/irq/arm-gicv2.c                |  8 ++++++++
 bsps/shared/dev/serial/zynq-uart-polled.c      | 13 +++++++++++--
 bsps/shared/start/bspfatal-default.c           |  9 +++++++++
 cpukit/score/cpu/arm/__aeabi_read_tp.c         |  8 ++++++++
 cpukit/score/cpu/arm/__tls_get_addr.c          |  8 ++++++++
 cpukit/score/cpu/arm/arm-exception-default.c   |  9 +++++++++
 .../score/cpu/arm/arm-exception-frame-print.c  |  9 +++++++++
 cpukit/score/cpu/arm/armv4-sync-synchronize.c  |  8 ++++++++
 cpukit/score/cpu/arm/armv7-thread-idle.c       |  7 +++++--
 .../score/cpu/arm/armv7m-context-initialize.c  |  7 +++++--
 cpukit/score/cpu/arm/armv7m-context-restore.c  |  7 +++++--
 cpukit/score/cpu/arm/armv7m-context-switch.c   |  5 ++++-
 .../score/cpu/arm/armv7m-exception-default.c   |  9 +++++++++
 .../cpu/arm/armv7m-exception-handler-get.c     |  7 +++++--
 .../cpu/arm/armv7m-exception-handler-set.c     |  7 +++++--
 .../cpu/arm/armv7m-exception-priority-get.c    |  8 ++++++--
 .../arm/armv7m-exception-priority-handler.c    |  5 ++++-
 .../cpu/arm/armv7m-exception-priority-set.c    |  7 +++++--
 cpukit/score/cpu/arm/armv7m-initialize.c       |  4 +++-
 cpukit/score/cpu/arm/armv7m-isr-dispatch.c     |  5 ++++-
 cpukit/score/cpu/arm/armv7m-isr-enter-leave.c  |  7 +++++--
 cpukit/score/cpu/arm/armv7m-isr-level-get.c    |  6 ++++--
 cpukit/score/cpu/arm/armv7m-isr-level-set.c    |  6 ++++--
 .../score/cpu/arm/armv7m-isr-vector-install.c  |  7 +++++--
 .../cpu/arm/armv7m-multitasking-start-stop.c   |  5 ++++-
 cpukit/score/cpu/arm/cpu.c                     |  6 +++++-
 cpukit/score/cpu/arm/include/rtems/asm.h       |  5 ++++-
 .../score/cpu/arm/include/rtems/score/armv4.h  | 17 +++++++++++++++++
 .../score/cpu/arm/include/rtems/score/armv7m.h |  5 ++++-
 cpukit/score/cpu/arm/include/rtems/score/cpu.h |  5 ++++-
 .../cpu/arm/include/rtems/score/cpuimpl.h      |  5 ++++-
 .../cpu/arm/include/rtems/score/paravirt.h     |  6 +++---
 49 files changed, 363 insertions(+), 69 deletions(-)
2.35.3
