[PATCH 3/4] bsps/arm: Improve Doxygen groups
Wed May 24 13:01:34 UTC 2023
 bsps/arm/include/bsp/arm-a9mpcore-clock.h | 16 ++++++++++++++++
 bsps/arm/include/bsp/arm-a9mpcore-irq.h   | 14 +++++++++++---
 bsps/arm/include/bsp/arm-a9mpcore-regs.h  | 18 +++++++++++++++---
 bsps/arm/include/bsp/arm-a9mpcore-start.h | 14 +++++++++++---
 bsps/arm/shared/clock/clock-a9mpcore.c    |  9 +++++++++
 5 files changed, 62 insertions(+), 9 deletions(-)
diff --git a/bsps/arm/include/bsp/arm-a9mpcore-clock.h b/bsps/arm/include/bsp/arm-a9mpcore-clock.h
index 80e3ca4934..811a2037bd 100644
--- a/bsps/arm/include/bsp/arm-a9mpcore-clock.h
+++ b/bsps/arm/include/bsp/arm-a9mpcore-clock.h
@@ -1,5 +1,13 @@
 /* SPDX-License-Identifier: BSD-2-Clause */
+ * @file
+ * @ingroup A9MPCoreSupport
+ * @brief This header file provides the interfaces of the @ref A9MPCoreSupport.
  * Copyright (c) 2013 Chris Johns <chrisj at rtems.org>.  All rights reserved.
@@ -34,6 +42,12 @@
 extern "C" {
 #endif /* __cplusplus */
+ * @addtogroup A9MPCoreSupport
  * Return the peripheral clock. For systems such as the zynq this
  * is controlled by the PL logic generation and can vary. Provide this
@@ -41,6 +55,8 @@ extern "C" {
 uint32_t a9mpcore_clock_periphclk(void);
 #ifdef __cplusplus
diff --git a/bsps/arm/include/bsp/arm-a9mpcore-irq.h b/bsps/arm/include/bsp/arm-a9mpcore-irq.h
index 543433919a..6cf1ae122a 100644
--- a/bsps/arm/include/bsp/arm-a9mpcore-irq.h
+++ b/bsps/arm/include/bsp/arm-a9mpcore-irq.h
@@ -1,11 +1,11 @@
- *  @file
+ * @file
- *  @ingroup RTEMSBSPsARMShared
- *  @brief ARM_A9MPCORE_IRQ Support
@@ -40,12 +40,20 @@
 extern "C" {
 #define A9MPCORE_IRQ_GT 27
 #define A9MPCORE_IRQ_NFIQ 28
 #define A9MPCORE_IRQ_PT 29
 #define A9MPCORE_IRQ_PW 30
 #define A9MPCORE_IRQ_NIRQ 31
 #ifdef __cplusplus
diff --git a/bsps/arm/include/bsp/arm-a9mpcore-regs.h b/bsps/arm/include/bsp/arm-a9mpcore-regs.h
index df6ba5871c..d577b59877 100644
--- a/bsps/arm/include/bsp/arm-a9mpcore-regs.h
+++ b/bsps/arm/include/bsp/arm-a9mpcore-regs.h
@@ -1,11 +1,11 @@
- *  @file
+ * @file
- *  @brief ARM_A9MPCORE_REGS Support
@@ -38,6 +38,16 @@
 #include <bsp/utility.h>
+ * @defgroup A9MPCoreSupport Cortex-A9 MPCore Support
+ * @ingroup RTEMSBSPsARMShared
+ * @brief This group contains support interfaces for the Cortex-A9 MPCore.
 typedef struct {
   uint32_t ctrl;
 #define A9MPCORE_SCU_CTRL_SCU_EN BSP_BIT32(0)
@@ -143,4 +153,6 @@ typedef struct {
   a9mpcore_idist idist;
 } a9mpcore;
 #endif /* LIBBSP_ARM_SHARED_ARM_A9MPCORE_REGS_H */
diff --git a/bsps/arm/include/bsp/arm-a9mpcore-start.h b/bsps/arm/include/bsp/arm-a9mpcore-start.h
index 1f225adf52..807f22d657 100644
--- a/bsps/arm/include/bsp/arm-a9mpcore-start.h
+++ b/bsps/arm/include/bsp/arm-a9mpcore-start.h
@@ -1,11 +1,11 @@
- *  @file
+ * @file
- *  @brief A9MPCORE_START Support
@@ -51,6 +51,12 @@
 extern "C" {
 BSP_START_TEXT_SECTION static inline void arm_a9mpcore_start_scu_invalidate(
   volatile a9mpcore_scu *scu,
   uint32_t cpu_id,
@@ -188,6 +194,8 @@ BSP_START_TEXT_SECTION static inline void arm_a9mpcore_start_hook_1(void)
   arm_a9mpcore_start_global_timer();
 #ifdef __cplusplus
diff --git a/bsps/arm/shared/clock/clock-a9mpcore.c b/bsps/arm/shared/clock/clock-a9mpcore.c
index 85e8485f4f..15c5d8b067 100644
--- a/bsps/arm/shared/clock/clock-a9mpcore.c
+++ b/bsps/arm/shared/clock/clock-a9mpcore.c
@@ -1,5 +1,14 @@
+ * @file
+ * @brief This source file contains the Clock Driver for Cortex-A9 MPCore
+ * compatible devices.
  * Copyright (C) 2013, 2016 embedded brains GmbH & Co. KG
2.35.3
