[PATCH 3/5] bsps/arm: Use interrupt entry for IPI
Wed May 24 13:05:48 UTC 2023
Avoid a dynamic memory allocation for the inter-processor interrupt.
 bsps/arm/shared/start/arm-a9mpcore-smp.c | 16 ++++++++++------
 1 file changed, 10 insertions(+), 6 deletions(-)
diff --git a/bsps/arm/shared/start/arm-a9mpcore-smp.c b/bsps/arm/shared/start/arm-a9mpcore-smp.c
index 703d3d9252..c99f68f9cf 100644
--- a/bsps/arm/shared/start/arm-a9mpcore-smp.c
+++ b/bsps/arm/shared/start/arm-a9mpcore-smp.c
@@ -41,20 +41,24 @@ uint32_t _CPU_SMP_Initialize(void)
   return arm_gic_irq_processor_count();
+static rtems_interrupt_entry arm_a9mpcore_ipi_entry =
+  RTEMS_INTERRUPT_ENTRY_INITIALIZER(
+    bsp_inter_processor_interrupt,
+    NULL,
+    "IPI"
 void _CPU_SMP_Finalize_initialization(uint32_t cpu_count)
   if (cpu_count > 0) {
     rtems_status_code sc;
-    sc = rtems_interrupt_handler_install(
+    sc = rtems_interrupt_entry_install(
       ARM_GIC_IRQ_SGI_0,
-      "IPI",
       RTEMS_INTERRUPT_UNIQUE,
-      bsp_inter_processor_interrupt,
-      NULL
+      &arm_a9mpcore_ipi_entry
-    _Assert(sc == RTEMS_SUCCESSFUL);
-    (void) sc;
+    _Assert_Unused_variable_equals(sc, RTEMS_SUCCESSFUL);
 #if defined(BSP_DATA_CACHE_ENABLED) || defined(BSP_INSTRUCTION_CACHE_ENABLED)
     /* Enable unified L2 cache */
2.35.3
