[PATCH rtems_waf] Allow vendor field in toolchain target triplet
    Martin Erik Werner
    martinerikwerner.aac at gmail.com
    Wed May 24 17:30:11 UTC 2023
Rework the splitting of arch and bsp to rely on the last field in the
arch section starting with "rtems", instead of relying on the arch being
exactly two fields in size.
This makes sure that toolchains with a vendor field in their target
triplet can be used with this build system.
Toolchains produced by the RTEMS source builder tend to omit the vendor
field, but for example the SPARC LEON/ERC32 toolchain provided by
Gaisler through the RCC package does include a vendor field.
 rtems.py | 8 ++++++--
 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/rtems.py b/rtems.py
index 0b24645..076560d 100644
--- a/rtems.py
+++ b/rtems.py
@@ -858,11 +858,15 @@ def _check_arch_bsps(req, config, path, archs, version):
 def _arch_from_arch_bsp(arch_bsp):
-    return '-'.join(arch_bsp.split('-')[:2])
+    fields = arch_bsp.split('-')
+    rtems_field_index = next(i for i, field in enumerate(fields) if field.startswith('rtems'))
+    return '-'.join(fields[:(rtems_field_index + 1)])
 def _bsp_from_arch_bsp(arch_bsp):
-    return '-'.join(arch_bsp.split('-')[2:])
+    return '-'.join(fields[rtems_field_index:])
 def _pkgconfig_path(path):
2.30.2
