[PATCH] score: Unify <rtems/score/cpuatomic.h>
Kinsey Moore kinsey.moore at oarcorp.com
Thu May 25 01:40:02 UTC 2023
Is there any reason this isn't just being moved to a shared directory if
they're all being made identical?
On Wed, May 24, 2023 at 7:11 PM Chris Johns <chrisj at rtems.org> wrote:
> On 24/5/2023 11:00 pm, Sebastian Huber wrote:
> > All CPU ports use the same file.
> > - * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
> > - * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
> > + * Copyright (C) 2012, 2013 Deng Hengyi
> Is this change correct?
The file has absolutely trivial contents, so whether or not it matters I'm
willing to approve of the change if it actually provides some improvement
beyond making all the files identical. I don't see a point to making them
homogeneous as the sole change.
Kinsey
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230524/0d68da74/attachment.htm>
