[PATCH] score: Unify <rtems/score/cpuatomic.h>
Thu May 25 05:51:17 UTC 2023
On 25.05.23 02:11, Chris Johns wrote:
> On 24/5/2023 11:00 pm, Sebastian Huber wrote:
>> All CPU ports use the same file.
>>   .../aarch64/include/rtems/score/cpuatomic.h   |  8 ++---
>>   .../cpu/arm/include/rtems/score/cpuatomic.h   | 11 +++++-
>>   .../cpu/bfin/include/rtems/score/cpuatomic.h  | 36 ++++++++++++++++---
>>   .../cpu/i386/include/rtems/score/cpuatomic.h  | 11 +++++-
>>   .../cpu/lm32/include/rtems/score/cpuatomic.h  | 36 ++++++++++++++++---
>>   .../cpu/m68k/include/rtems/score/cpuatomic.h  | 11 +++++-
>>   .../include/rtems/score/cpuatomic.h           |  7 ++--
>>   .../cpu/mips/include/rtems/score/cpuatomic.h  | 11 +++++-
>>   .../cpu/moxie/include/rtems/score/cpuatomic.h | 11 +++++-
>>   .../cpu/nios2/include/rtems/score/cpuatomic.h | 11 +++++-
>>   .../cpu/or1k/include/rtems/score/cpuatomic.h  | 11 +++++-
>>   .../powerpc/include/rtems/score/cpuatomic.h   | 11 +++++-
>>   .../cpu/riscv/include/rtems/score/cpuatomic.h | 33 +++++++++++------
>>   .../cpu/sh/include/rtems/score/cpuatomic.h    | 36 ++++++++++++++++---
>>   .../cpu/sparc/include/rtems/score/cpuatomic.h |  7 ++--
>>   .../sparc64/include/rtems/score/cpuatomic.h   | 11 +++++-
>>   .../cpu/v850/include/rtems/score/cpuatomic.h  | 11 +++++-
>>   .../x86_64/include/rtems/score/cpuatomic.h    | 36 ++++++++++++++++---
>>   18 files changed, 261 insertions(+), 48 deletions(-)
>> diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h
>> index ed8091d73c..772d496741 100644
>> --- a/cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h
>> +++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h
>> @@ -3,14 +3,14 @@
>>    * @file
>> - * @ingroup RTEMSScoreCPU
>> + * @ingroup RTEMSScoreAtomicCPU
>> - * @brief AArch64 Atomics support
>> + * @brief This header file provides interfaces of the atomic operations
>> + *   implementation using functions provided by the C11/C++11.
>> - * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
>> - * Written by Kinsey Moore<kinsey.moore at oarcorp.com>
>> + * Copyright (C) 2012, 2013 Deng Hengyi
> Is this change correct?
Yes, the file contains no copyrightable content from OAR. It hardly
contains any copyrightable content at all.
>>    * Redistribution and use in source and binary forms, with or without
>>    * modification, are permitted provided that the following conditions
>> diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/arm/include/rtems/score/cpuatomic.h
>> index 01bb99cda3..772d496741 100644
>> --- a/cpukit/score/cpu/arm/include/rtems/score/cpuatomic.h
>> +++ b/cpukit/score/cpu/arm/include/rtems/score/cpuatomic.h
>> @@ -1,7 +1,16 @@
>>   /* SPDX-License-Identifier: BSD-2-Clause */
>> + * @file
>> - * COPYRIGHT (c) 2012-2013 Deng Hengyi.
> Why are these lines changing? Can we edit this as the license clearly states it
> must be retained as is?
We have a copyright line template:
https://docs.rtems.org/branches/master/eng/coding-file-hdr.html#copyright-and-license-block
Independent of this, it seems we didn't have a permission from Deng
Hengyi to switch to BSD-2-Clause license:
https://devel.rtems.org/ticket/3053
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
