[PATCH 03/34] bsps/grlib: Fix FTMCTRL - MCFG1 bit fields
Wed May 31 16:30:38 UTC 2023
There was an off by one error in all bit fields.  Add the R flag.
Update #4842.
 bsps/include/grlib/ftmctrl-regs.h | 127 ++++++++++++++++--------------
 1 file changed, 70 insertions(+), 57 deletions(-)
diff --git a/bsps/include/grlib/ftmctrl-regs.h b/bsps/include/grlib/ftmctrl-regs.h
index 6de7d49fd6..fb4203270c 100644
--- a/bsps/include/grlib/ftmctrl-regs.h
+++ b/bsps/include/grlib/ftmctrl-regs.h
@@ -82,59 +82,61 @@ extern "C" {
-#define FTMCTRL_MCFG1_PBRDY 0x80000000U
-#define FTMCTRL_MCFG1_ABRDY 0x40000000U
-#define FTMCTRL_MCFG1_IOBUSW 0x20000000U
-#define FTMCTRL_MCFG1_IBRDY_SHIFT 27
-#define FTMCTRL_MCFG1_IBRDY_MASK 0x18000000U
-#define FTMCTRL_MCFG1_IBRDY_GET( _reg ) \
-  ( ( ( _reg ) & FTMCTRL_MCFG1_IBRDY_MASK ) >> \
-    FTMCTRL_MCFG1_IBRDY_SHIFT )
-#define FTMCTRL_MCFG1_IBRDY_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~FTMCTRL_MCFG1_IBRDY_MASK ) | \
-    ( ( ( _val ) << FTMCTRL_MCFG1_IBRDY_SHIFT ) & \
-      FTMCTRL_MCFG1_IBRDY_MASK ) )
-#define FTMCTRL_MCFG1_IBRDY( _val ) \
-#define FTMCTRL_MCFG1_BEXCN 0x4000000U
-#define FTMCTRL_MCFG1_IO_WAITSTATES 0x1000000U
-#define FTMCTRL_MCFG1_IOEN_SHIFT 20
-#define FTMCTRL_MCFG1_IOEN_MASK 0xf00000U
-#define FTMCTRL_MCFG1_IOEN_GET( _reg ) \
-  ( ( ( _reg ) & FTMCTRL_MCFG1_IOEN_MASK ) >> \
-    FTMCTRL_MCFG1_IOEN_SHIFT )
-#define FTMCTRL_MCFG1_IOEN_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~FTMCTRL_MCFG1_IOEN_MASK ) | \
-    ( ( ( _val ) << FTMCTRL_MCFG1_IOEN_SHIFT ) & \
-      FTMCTRL_MCFG1_IOEN_MASK ) )
-#define FTMCTRL_MCFG1_IOEN( _val ) \
-#define FTMCTRL_MCFG1_ROMBANKSZ 0x80000U
-#define FTMCTRL_MCFG1_PWEN_SHIFT 14
-#define FTMCTRL_MCFG1_PWEN_MASK 0x3c000U
-#define FTMCTRL_MCFG1_PWEN_GET( _reg ) \
-  ( ( ( _reg ) & FTMCTRL_MCFG1_PWEN_MASK ) >> \
-    FTMCTRL_MCFG1_PWEN_SHIFT )
-#define FTMCTRL_MCFG1_PWEN_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~FTMCTRL_MCFG1_PWEN_MASK ) | \
-    ( ( ( _val ) << FTMCTRL_MCFG1_PWEN_SHIFT ) & \
-      FTMCTRL_MCFG1_PWEN_MASK ) )
-#define FTMCTRL_MCFG1_PWEN( _val ) \
-#define FTMCTRL_MCFG1_PROM_WIDTH_SHIFT 12
-#define FTMCTRL_MCFG1_PROM_WIDTH_MASK 0x3000U
+#define FTMCTRL_MCFG1_PBRDY 0x40000000U
+#define FTMCTRL_MCFG1_ABRDY 0x20000000U
+#define FTMCTRL_MCFG1_IOBUSW_SHIFT 27
+#define FTMCTRL_MCFG1_IOBUSW_MASK 0x18000000U
+#define FTMCTRL_MCFG1_IOBUSW_GET( _reg ) \
+  ( ( ( _reg ) & FTMCTRL_MCFG1_IOBUSW_MASK ) >> \
+    FTMCTRL_MCFG1_IOBUSW_SHIFT )
+#define FTMCTRL_MCFG1_IOBUSW_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~FTMCTRL_MCFG1_IOBUSW_MASK ) | \
+    ( ( ( _val ) << FTMCTRL_MCFG1_IOBUSW_SHIFT ) & \
+      FTMCTRL_MCFG1_IOBUSW_MASK ) )
+#define FTMCTRL_MCFG1_IOBUSW( _val ) \
+#define FTMCTRL_MCFG1_IBRDY 0x4000000U
+#define FTMCTRL_MCFG1_BEXCN 0x2000000U
+#define FTMCTRL_MCFG1_IO_WAITSTATES_SHIFT 20
+#define FTMCTRL_MCFG1_IO_WAITSTATES_MASK 0xf00000U
+#define FTMCTRL_MCFG1_IO_WAITSTATES_GET( _reg ) \
+  ( ( ( _reg ) & FTMCTRL_MCFG1_IO_WAITSTATES_MASK ) >> \
+    FTMCTRL_MCFG1_IO_WAITSTATES_SHIFT )
+#define FTMCTRL_MCFG1_IO_WAITSTATES_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~FTMCTRL_MCFG1_IO_WAITSTATES_MASK ) | \
+    ( ( ( _val ) << FTMCTRL_MCFG1_IO_WAITSTATES_SHIFT ) & \
+      FTMCTRL_MCFG1_IO_WAITSTATES_MASK ) )
+#define FTMCTRL_MCFG1_IO_WAITSTATES( _val ) \
+#define FTMCTRL_MCFG1_IOEN 0x80000U
+#define FTMCTRL_MCFG1_R 0x40000U
+#define FTMCTRL_MCFG1_ROMBANKSZ_SHIFT 14
+#define FTMCTRL_MCFG1_ROMBANKSZ_MASK 0x3c000U
+#define FTMCTRL_MCFG1_ROMBANKSZ_GET( _reg ) \
+  ( ( ( _reg ) & FTMCTRL_MCFG1_ROMBANKSZ_MASK ) >> \
+    FTMCTRL_MCFG1_ROMBANKSZ_SHIFT )
+#define FTMCTRL_MCFG1_ROMBANKSZ_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~FTMCTRL_MCFG1_ROMBANKSZ_MASK ) | \
+    ( ( ( _val ) << FTMCTRL_MCFG1_ROMBANKSZ_SHIFT ) & \
+      FTMCTRL_MCFG1_ROMBANKSZ_MASK ) )
+#define FTMCTRL_MCFG1_ROMBANKSZ( _val ) \
+#define FTMCTRL_MCFG1_PWEN 0x800U
+#define FTMCTRL_MCFG1_PROM_WIDTH_SHIFT 8
+#define FTMCTRL_MCFG1_PROM_WIDTH_MASK 0x300U
 #define FTMCTRL_MCFG1_PROM_WIDTH_GET( _reg ) \
   ( ( ( _reg ) & FTMCTRL_MCFG1_PROM_WIDTH_MASK ) >> \
     FTMCTRL_MCFG1_PROM_WIDTH_SHIFT )
@@ -146,10 +148,21 @@ extern "C" {
   ( ( ( _val ) << FTMCTRL_MCFG1_PROM_WIDTH_SHIFT ) & \
-#define FTMCTRL_MCFG1_PROM_WRITE_WS 0x800U
-#define FTMCTRL_MCFG1_PROM_READ_WS_SHIFT 8
-#define FTMCTRL_MCFG1_PROM_READ_WS_MASK 0x300U
+#define FTMCTRL_MCFG1_PROM_WRITE_WS_SHIFT 4
+#define FTMCTRL_MCFG1_PROM_WRITE_WS_MASK 0xf0U
+#define FTMCTRL_MCFG1_PROM_WRITE_WS_GET( _reg ) \
+  ( ( ( _reg ) & FTMCTRL_MCFG1_PROM_WRITE_WS_MASK ) >> \
+    FTMCTRL_MCFG1_PROM_WRITE_WS_SHIFT )
+#define FTMCTRL_MCFG1_PROM_WRITE_WS_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~FTMCTRL_MCFG1_PROM_WRITE_WS_MASK ) | \
+    ( ( ( _val ) << FTMCTRL_MCFG1_PROM_WRITE_WS_SHIFT ) & \
+      FTMCTRL_MCFG1_PROM_WRITE_WS_MASK ) )
+#define FTMCTRL_MCFG1_PROM_WRITE_WS( _val ) \
+#define FTMCTRL_MCFG1_PROM_READ_WS_SHIFT 0
+#define FTMCTRL_MCFG1_PROM_READ_WS_MASK 0xfU
 #define FTMCTRL_MCFG1_PROM_READ_WS_GET( _reg ) \
   ( ( ( _reg ) & FTMCTRL_MCFG1_PROM_READ_WS_MASK ) >> \
     FTMCTRL_MCFG1_PROM_READ_WS_SHIFT )
2.35.3
