[PATCH 06/34] bsps/grlib: Expand SpaceWire port bit fields
Sebastian Huber
Wed May 31 16:30:41 UTC 2023
Use the maximum width supported by the SpaceWire standard even if this
exceeds the configuration limits of a particular IP instance.
Update #4842.
bsps/include/grlib/spwpnp-regs.h | 2 +-
bsps/include/grlib/spwrmap-regs.h | 6 +++---
2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/bsps/include/grlib/spwpnp-regs.h b/bsps/include/grlib/spwpnp-regs.h
index 45550e3a79..00c688bc55 100644
--- a/bsps/include/grlib/spwpnp-regs.h
+++ b/bsps/include/grlib/spwpnp-regs.h
@@ -194,7 +194,7 @@ extern "C" {
#define SPWPNP_PNPACTLNK_ACTIVE_SHIFT 1
-#define SPWPNP_PNPACTLNK_ACTIVE_MASK 0x1ffeU
+#define SPWPNP_PNPACTLNK_ACTIVE_MASK 0xfffffffeU
#define SPWPNP_PNPACTLNK_ACTIVE_GET( _reg ) \
( ( ( _reg ) & SPWPNP_PNPACTLNK_ACTIVE_MASK ) >> \
SPWPNP_PNPACTLNK_ACTIVE_SHIFT )
diff --git a/bsps/include/grlib/spwrmap-regs.h b/bsps/include/grlib/spwrmap-regs.h
index 7a19f4a2d3..9a0ed203f3 100644
--- a/bsps/include/grlib/spwrmap-regs.h
+++ b/bsps/include/grlib/spwrmap-regs.h
@@ -751,7 +751,7 @@ extern "C" {
#define SPWRMAP_IPMASK_IE_SHIFT 0
-#define SPWRMAP_IPMASK_IE_MASK 0xfffffU
+#define SPWRMAP_IPMASK_IE_MASK 0xffffffffU
#define SPWRMAP_IPMASK_IE_GET( _reg ) \
( ( ( _reg ) & SPWRMAP_IPMASK_IE_MASK ) >> \
SPWRMAP_IPMASK_IE_SHIFT )
@@ -774,7 +774,7 @@ extern "C" {
#define SPWRMAP_PIP_IP_SHIFT 0
-#define SPWRMAP_PIP_IP_MASK 0xfffffU
+#define SPWRMAP_PIP_IP_MASK 0xffffffffU
#define SPWRMAP_PIP_IP_GET( _reg ) \
( ( ( _reg ) & SPWRMAP_PIP_IP_MASK ) >> \
SPWRMAP_PIP_IP_SHIFT )
@@ -953,7 +953,7 @@ extern "C" {
#define SPWRMAP_LRUNSTAT_LR_SHIFT 1
-#define SPWRMAP_LRUNSTAT_LR_MASK 0x7fffeU
+#define SPWRMAP_LRUNSTAT_LR_MASK 0xfffffffeU
#define SPWRMAP_LRUNSTAT_LR_GET( _reg ) \
( ( ( _reg ) & SPWRMAP_LRUNSTAT_LR_MASK ) >> \
SPWRMAP_LRUNSTAT_LR_SHIFT )
2.35.3
