[PATCH 18/34] bsp/leon3: Add LEON3_GPTIMER_BASE
Wed May 31 16:30:53 UTC 2023
 bsps/sparc/leon3/include/bsp/leon3.h          |  4 ++++
 bsps/sparc/leon3/start/amba.c                 |  4 ++++
 spec/build/bsps/sparc/leon3/grp.yml           |  2 ++
 .../build/bsps/sparc/leon3/optgptimerbase.yml | 20 +++++++++++++++++++
 4 files changed, 30 insertions(+)
 create mode 100644 spec/build/bsps/sparc/leon3/optgptimerbase.yml
diff --git a/bsps/sparc/leon3/include/bsp/leon3.h b/bsps/sparc/leon3/include/bsp/leon3.h
index 649d8ab41e..5c75cd3634 100644
--- a/bsps/sparc/leon3/include/bsp/leon3.h
+++ b/bsps/sparc/leon3/include/bsp/leon3.h
@@ -269,7 +269,11 @@ static inline uint32_t bsp_irq_fixup( uint32_t irq )
  * @brief This pointer provides the GPTIMER register block address.
+#if defined(LEON3_GPTIMER_BASE)
+#define LEON3_Timer_Regs ((gptimer *) LEON3_GPTIMER_BASE)
+#else
 extern gptimer *LEON3_Timer_Regs;
+#endif
  * @brief This pointer provides the GPTIMER device information block.
diff --git a/bsps/sparc/leon3/start/amba.c b/bsps/sparc/leon3/start/amba.c
index d4494224c4..36b988e90b 100644
--- a/bsps/sparc/leon3/start/amba.c
+++ b/bsps/sparc/leon3/start/amba.c
@@ -119,8 +119,10 @@ RTEMS_SYSINIT_ITEM(
 irqamp *LEON3_IrqCtrl_Regs;
 struct ambapp_dev *LEON3_IrqCtrl_Adev;
+#if !defined(LEON3_GPTIMER_BASE)
 struct ambapp_dev *LEON3_Timer_Adev;
+#endif
  *  amba_initialize
@@ -166,6 +168,7 @@ static void amba_initialize(void)
     LEON3_IrqCtrl_Regs += icsel;
   /* find GP Timer */
   adev = (void *)ambapp_for_each(plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
                                  VENDOR_GAISLER, GAISLER_GPTIMER,
@@ -189,6 +192,7 @@ static void amba_initialize(void)
     if (leon3_timer_prescaler)
       grlib_store_32(&LEON3_Timer_Regs->sreload, leon3_timer_prescaler);
+#endif
 RTEMS_SYSINIT_ITEM(
diff --git a/spec/build/bsps/sparc/leon3/grp.yml b/spec/build/bsps/sparc/leon3/grp.yml
index 48da9acba8..fa4adae840 100644
--- a/spec/build/bsps/sparc/leon3/grp.yml
+++ b/spec/build/bsps/sparc/leon3/grp.yml
@@ -34,6 +34,8 @@ links:
   uid: objsmp
 - role: build-dependency
   uid: optapbuartbase
+- role: build-dependency
+  uid: optgptimerbase
   uid: optconirq
diff --git a/spec/build/bsps/sparc/leon3/optgptimerbase.yml b/spec/build/bsps/sparc/leon3/optgptimerbase.yml
new file mode 100644
index 0000000000..b2158208a0
--- /dev/null
+++ b/spec/build/bsps/sparc/leon3/optgptimerbase.yml
@@ -0,0 +1,20 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+copyrights:
+- Copyright (C) 2021 embedded brains GmbH & Co. KG
+actions:
+- get-integer: null
+- format-and-define: null
+build-type: option
+default:
+- enabled-by: sparc/gr712rc
+  value: 0x80000300
+- enabled-by: sparc/gr740
+  value: 0xff908000
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: LEON3_GPTIMER_BASE
+description: |
+  This option defines the base address of the GPTIMER register block used by
+  the clock driver.
+type: build
2.35.3
