[PATCH 33/34] bsp/leon3: Add specialized target hash
Sebastian Huber
Wed May 31 16:31:08 UTC 2023
bsps/sparc/leon3/start/gettargethash.c | 71 ++++++++++++++++++++++++++
spec/build/bsps/sparc/leon3/obj.yml | 2 +-
2 files changed, 72 insertions(+), 1 deletion(-)
create mode 100644 bsps/sparc/leon3/start/gettargethash.c
diff --git a/bsps/sparc/leon3/start/gettargethash.c b/bsps/sparc/leon3/start/gettargethash.c
new file mode 100644
index 0000000000..c51031dc4f
--- /dev/null
+++ b/bsps/sparc/leon3/start/gettargethash.c
@@ -0,0 +1,71 @@
+ * @file
+ * @ingroup RTEMSBSPsSPARCLEON3
+ * @brief This source file contains the sparc/leon3 implementation of
+ * rtems_get_target_hash().
+ * Copyright (C) 2021, 2022 embedded brains GmbH & Co. KG
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <rtems/config.h>
+#include <rtems/counter.h>
+#include <rtems/sysinit.h>
+#include <rtems/score/hash.h>
+#include <bsp/leon3.h>
+static Hash_Control bsp_target_hash;
+static void bsp_target_hash_initialize( void )
+ Hash_Context context;
+ uint32_t frequency;
+ _Hash_Initialize( &context );
+ frequency = rtems_counter_frequency();
+ _Hash_Add_data( &context, &frequency, sizeof( frequency ) );
+ frequency = leon3_processor_local_bus_frequency();
+ _Hash_Finalize( &context, &bsp_target_hash );
+const char *rtems_get_target_hash( void )
+ return _Hash_Get_string( &bsp_target_hash );
+RTEMS_SYSINIT_ITEM(
+ bsp_target_hash_initialize,
+ RTEMS_SYSINIT_TARGET_HASH,
+ RTEMS_SYSINIT_ORDER_SECOND
diff --git a/spec/build/bsps/sparc/leon3/obj.yml b/spec/build/bsps/sparc/leon3/obj.yml
index 6eb4df0ed7..74e1f1df27 100644
--- a/spec/build/bsps/sparc/leon3/obj.yml
+++ b/spec/build/bsps/sparc/leon3/obj.yml
@@ -31,7 +31,6 @@ source:
- bsps/shared/dev/serial/console-termios.c
- bsps/shared/irq/irq-default-handler.c
- bsps/shared/start/bspreset-empty.c
-- bsps/shared/start/gettargethash-default.c
- bsps/shared/start/sbrk.c
- bsps/sparc/leon3/btimer/btimer.c
- bsps/sparc/leon3/btimer/watchdog.c
@@ -48,6 +47,7 @@ source:
- bsps/sparc/leon3/start/cpucounter.c
- bsps/sparc/leon3/start/drvmgr_def_drivers.c
- bsps/sparc/leon3/start/eirq.c
+- bsps/sparc/leon3/start/gettargethash.c
- bsps/sparc/leon3/start/setvec.c
- bsps/sparc/shared/gnatcommon.c
- bsps/sparc/shared/irq/bsp_isr_handler.c
2.35.3
