[PATCH] fixed warning related to spstdc17
zack leung
zakthertemsdev at gmail.com
Wed Nov 1 02:07:10 UTC 2023
Sorry either I lack knowledge in C or lack knowledge in working with rtems.
Do you mean if rtems smp is defined then we make sure that scheduler
context base type is defined? I don't quite understand why it would be
!defined? And the changes you're referring to are not in the scheduler.h
file which is where the struct is defined.
On Mon, 30 Oct 2023 at 03:04, Sebastian Huber <
> On 29.10.23 02:44, zack leung wrote:
> > ./../../cpukit/include/rtems/score/schedulerpriority.h:87:21: error:
> > field 'Base' has incomplete type
> > 87 | Scheduler_Context Base;
> > ../../../cpukit/include/rtems/score/schedulersimple.h:89:21: error:
> > 89 | Scheduler_Context Base;
> > I get this error when using typedefs
> Yes, the
> typedef struct Scheduler_Context Scheduler_Context;
> only creates the typedef and the structure name. This is why I also wrote:
> Then you have to make sure that #if !defined(RTEMS_SMP) no objects of
> this type are used.
> For example:
> diff --git a/cpukit/include/rtems/score/schedulersimple.h
> b/cpukit/include/rtems/score/schedulersimple.h
> index d9acd3dea0..0db72b2a51 100644
> --- a/cpukit/include/rtems/score/schedulersimple.h
> +++ b/cpukit/include/rtems/score/schedulersimple.h
> @@ -83,10 +83,12 @@ extern "C" {
> * @brief Simple scheduler context.
> typedef struct {
> +#if !defined(RTEMS_SMP)
> * @brief Basic scheduler context.
> +#endif
> * @brief One ready queue for all ready threads.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20231031/f7facac8/attachment.htm>
