[PATCH] build: Add RTEMS_QUALIFIED
Fri Nov 3 14:08:36 UTC 2023
On Fri, Nov 3, 2023 at 3:58 AM Sebastian Huber <
> The goal of the RTEMS pre-qualification activity #3701 is a specified
> and validated subset of RTEMS.  For users of the pre-qualified subset of
> RTEMS it is important to not accidentally use not pre-qualified
> features.  One way to achieve this, is to build only the sources of the
> pre-qualified feature set. This customized build is enabled by the new
> build configuration option RTEMS_QUALIFIED.  If it is enabled, then only
> the pre-qualified subset of RTEMS is built and installed.
> Building with RTEMS_QUALIFIED enable is currently only supported for the
> sparc/leon3 BSP family.  To support an RTEMS_QUALIFIED enabled build,
> changes in the CPU port and the BSP are required to only use features of
> the pre-qualified feature set.
Where is this documented?
This is a very large patch. Are you assuming that if "not qualified" is
specified,
then it is in the qualified set?
Nothing below here. It is just too large to understand the pattern you are
attempting to apply and I cannot figure out if it is right or not. I
understand
tailoring to a qualified subset but not the details of what yaml/rtems
configuration
files is attempting to do. I can't tell if the changes are right or not.
> Update #4963.
>  cpukit/libcsupport/src/alloconly.c           |   89 ++
>  cpukit/libtest/testbeginend.c                |   20 +-
>  spec/build/bsps/obj.yml                      |   87 +-
>  spec/build/bsps/objextra.yml                 |   99 ++
>  spec/build/bsps/objgrlib.yml                 |  149 +--
>  spec/build/bsps/objgrlibextra.yml            |  141 +++
>  spec/build/bsps/objirq.yml                   |   16 +-
>  spec/build/bsps/objirqextra.yml              |   24 +
>  spec/build/bsps/objnosmp.yml                 |    4 +-
>  spec/build/bsps/optldflags.yml               |   11 +
>  spec/build/bsps/sparc/grp.yml                |    3 +-
>  spec/build/bsps/sparc/leon3/grp.yml          |    2 +
>  spec/build/bsps/sparc/leon3/obj.yml          |   25 +-
>  spec/build/bsps/sparc/leon3/objextra.yml     |   39 +
>  spec/build/bsps/sparc/objmem.yml             |    3 +-
>  spec/build/cpukit/cpuarm.yml                 |   11 +-
>  spec/build/cpukit/cpuarmextra.yml            |   18 +
>  spec/build/cpukit/cpuopts.yml                |    2 +
>  spec/build/cpukit/cpusparc.yml               |   23 +-
>  spec/build/cpukit/cpusparcextra.yml          |   28 +
>  spec/build/cpukit/libdebugger.yml            |    5 +-
>  spec/build/cpukit/libftpd.yml                |    3 +-
>  spec/build/cpukit/libftpfs.yml               |    3 +-
>  spec/build/cpukit/libjffs2.yml               |    3 +-
>  spec/build/cpukit/libmghttpd.yml             |    3 +-
>  spec/build/cpukit/librtemscpu.yml            | 1152 +-----------------
>  spec/build/cpukit/librtemscxx.yml            |    3 +-
>  spec/build/cpukit/librtemsdfltcfg.yml        |    3 +-
>  spec/build/cpukit/librtemstest.yml           |   20 +-
>  spec/build/cpukit/libtelnetd.yml             |    3 +-
>  spec/build/cpukit/libtftpfs.yml              |    3 +-
>  spec/build/cpukit/libz.yml                   |    3 +-
>  spec/build/cpukit/objdrvmgr.yml              |    7 +-
>  spec/build/cpukit/objextra.yml               | 1126 +++++++++++++++++
>  spec/build/cpukit/objgnat.yml                |    4 +-
>  spec/build/cpukit/objpci.yml                 |    4 +-
>  spec/build/cpukit/objqual.yml                |   14 +
>  spec/build/cpukit/objshell.yml               |    3 +-
>  spec/build/cpukit/objsmp.yml                 |   19 +-
>  spec/build/cpukit/objsmpextra.yml            |   25 +
>  spec/build/cpukit/objtestextra.yml           |   26 +
>  spec/build/cpukit/objtestqual.yml            |   37 +
>  spec/build/cpukit/objtestqualsmp.yml         |   18 +
>  spec/build/cpukit/objutf8.yml                |    3 +-
>  spec/build/cpukit/optexceptionextensions.yml |    2 +
>  spec/build/cpukit/optlibdl.yml               |   21 +-
>  spec/build/cpukit/optqual.yml                |   19 +
>  spec/build/testsuites/optada.yml             |    5 +-
>  spec/build/testsuites/optbenchmarks.yml      |    5 +-
>  spec/build/testsuites/optfs.yml              |    5 +-
>  spec/build/testsuites/optlib.yml             |    5 +-
>  spec/build/testsuites/optmp.yml              |    5 +-
>  spec/build/testsuites/optpsx.yml             |    5 +-
>  spec/build/testsuites/optpsxtm.yml           |    5 +-
>  spec/build/testsuites/optrhs.yml             |    5 +-
>  spec/build/testsuites/optsamples.yml         |    2 +
>  spec/build/testsuites/optsmp.yml             |    5 +-
>  spec/build/testsuites/optsp.yml              |    5 +-
>  spec/build/testsuites/opttm.yml              |    5 +-
>  59 files changed, 1935 insertions(+), 1448 deletions(-)
>  create mode 100644 cpukit/libcsupport/src/alloconly.c
>  create mode 100644 spec/build/bsps/objextra.yml
>  create mode 100644 spec/build/bsps/objgrlibextra.yml
>  create mode 100644 spec/build/bsps/objirqextra.yml
>  create mode 100644 spec/build/bsps/sparc/leon3/objextra.yml
>  create mode 100644 spec/build/cpukit/cpuarmextra.yml
>  create mode 100644 spec/build/cpukit/cpusparcextra.yml
>  create mode 100644 spec/build/cpukit/objextra.yml
>  create mode 100644 spec/build/cpukit/objqual.yml
>  create mode 100644 spec/build/cpukit/objsmpextra.yml
>  create mode 100644 spec/build/cpukit/objtestextra.yml
>  create mode 100644 spec/build/cpukit/objtestqual.yml
>  create mode 100644 spec/build/cpukit/objtestqualsmp.yml
>  create mode 100644 spec/build/cpukit/optqual.yml
> diff --git a/cpukit/libcsupport/src/alloconly.c
> b/cpukit/libcsupport/src/alloconly.c
> new file mode 100644
> index 0000000000..8ac09eac87
> --- /dev/null
> +++ b/cpukit/libcsupport/src/alloconly.c
> @@ -0,0 +1,89 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup libcsupport
> + * @brief This source file contains the implementations of rtems_malloc()
> and
> + *   posix_memalign() which do not support free().
> + * Copyright (C) 2021 embedded brains GmbH & Co. KG
This has posix_memalign.c in it which previously had an OAR copyright
in it. Please be more careful when splitting files and moving code to
preserve copyrights.
When we relicensed to BSD-2, this file was deemed to be OAR.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/malloc.h>
> +#include <errno.h>
> +#include <stdlib.h>
> +#include <rtems/score/memory.h>
> +void *rtems_malloc( size_t size )
> +  if ( size == 0 ) {
> +    return NULL;
> +  return _Memory_Allocate( _Memory_Get(), size, CPU_HEAP_ALIGNMENT );
> +int posix_memalign( void **memptr, size_t alignment, size_t size )
> +  void *p;
> +  RTEMS_OBFUSCATE_VARIABLE( memptr );
> +  if ( memptr == NULL ) {
> +    return EINVAL;
> +  *memptr = NULL;
> +  if ( alignment < sizeof (void *) ) {
> +    return EINVAL;
> +  if ( ( ( alignment - 1 ) & alignment ) != 0 ) {
> +    return EINVAL;
> +    return 0;
> +  p = _Memory_Allocate( _Memory_Get(), size, alignment );
> +  if ( p == NULL ) {
> +    return ENOMEM;
> +  *memptr = p;
> +  return 0;
> diff --git a/cpukit/libtest/testbeginend.c b/cpukit/libtest/testbeginend.c
> index d520a45e62..45fd1343fa 100644
> --- a/cpukit/libtest/testbeginend.c
> +++ b/cpukit/libtest/testbeginend.c
> @@ -41,9 +41,15 @@
>  #endif
>  #include <rtems/test-info.h>
> -#include <rtems/test-printer.h>
>  #include <rtems/version.h>
> +#if defined(RTEMS_QUALIFIED)
> +#include <rtems/bspIo.h>
> +#include <rtems/dev/io.h>
> +#else
> +#include <rtems/test-printer.h>
> +#endif
>  static const char* const test_state_strings[] =
>    "EXPECTED_PASS",
> @@ -55,8 +61,14 @@ static const char* const test_state_strings[] =
>  int rtems_test_begin(const char* name, const RTEMS_TEST_STATE state)
> +  return _IO_Printf(
> +    rtems_put_char,
> +    NULL,
> +#else
>    return rtems_printf(
>      &rtems_test_printer,
> +#endif
>      "\n\n*** BEGIN OF TEST %s ***\n"
>      "*** TEST VERSION: %s\n"
>      "*** TEST STATE: %s\n"
> @@ -92,8 +104,14 @@ int rtems_test_begin(const char* name, const
>  int rtems_test_end(const char* name)
> +    rtems_put_char,
> +    NULL,
> +#else
> +#endif
>      "\n*** END OF TEST %s ***\n\n", name
> diff --git a/spec/build/bsps/obj.yml b/spec/build/bsps/obj.yml
> index 6f76e9bb7c..f396bf1b0c 100644
> --- a/spec/build/bsps/obj.yml
> +++ b/spec/build/bsps/obj.yml
> @@ -11,98 +11,15 @@ install:
>  - destination: ${BSP_INCLUDEDIR}/bsp
>    source:
>    - bsps/include/bsp/bootcard.h
> -  - bsps/include/bsp/console-polled.h
> -  - bsps/include/bsp/console-termios.h
>    - bsps/include/bsp/default-initial-extension.h
>    - bsps/include/bsp/fatal.h
> -  - bsps/include/bsp/fdt.h
> -  - bsps/include/bsp/gpio.h
> -  - bsps/include/bsp/irq-default.h
> -  - bsps/include/bsp/irq-generic.h
> -  - bsps/include/bsp/irq-info.h
> -  - bsps/include/bsp/stackalloc.h
> -  - bsps/include/bsp/u-boot.h
> -  - bsps/include/bsp/uart-output-char.h
> -  - bsps/include/bsp/utility.h
> -- destination: ${BSP_INCLUDEDIR}/ofw
> -  source:
> -  - bsps/include/ofw/ofw.h
> -  - bsps/include/ofw/ofw_compat.h
> -- destination: ${BSP_INCLUDEDIR}/libchip
> -  source:
> -  - bsps/include/libchip/ata.h
> -  - bsps/include/libchip/ata_internal.h
> -  - bsps/include/libchip/disp_hcms29xx.h
> -  - bsps/include/libchip/ds1375-rtc.h
> -  - bsps/include/libchip/i2c-2b-eeprom.h
> -  - bsps/include/libchip/i2c-ds1621.h
> -  - bsps/include/libchip/i2c-sc620.h
> -  - bsps/include/libchip/icm7170.h
> -  - bsps/include/libchip/ide_ctrl.h
> -  - bsps/include/libchip/ide_ctrl_cfg.h
> -  - bsps/include/libchip/ide_ctrl_io.h
> -  - bsps/include/libchip/m48t08.h
> -  - bsps/include/libchip/mcp7940m-rtc.h
> -  - bsps/include/libchip/ns16550.h
> -  - bsps/include/libchip/ns16550_p.h
> -  - bsps/include/libchip/rtc.h
> -  - bsps/include/libchip/serial.h
> -  - bsps/include/libchip/sersupp.h
> -  - bsps/include/libchip/spi-flash-m25p40.h
> -  - bsps/include/libchip/spi-fram-fm25l256.h
> -  - bsps/include/libchip/spi-memdrv.h
> -  - bsps/include/libchip/spi-sd-card.h
> -  - bsps/include/libchip/wd80x3.h
> -- destination: ${BSP_INCLUDEDIR}/dev/serial
> -  source:
> -  - bsps/include/dev/serial/arm-pl011-regs.h
> -  - bsps/include/dev/serial/arm-pl011.h
> -- destination: ${BSP_INCLUDEDIR}/rtems/zilog
> -  source:
> -  - bsps/include/rtems/zilog/z8036.h
> -  - bsps/include/rtems/zilog/z8530.h
> -- destination: ${BSP_INCLUDEDIR}/arm/ti
> -  source:
> -  - bsps/include/arm/ti/ti_pinmux.h
> -  - bsps/include/arm/ti/ti_cpuid.h
>  links:
> +- role: build-dependency
> +  uid: objextra
>    uid: objmpci
>    uid: objnosmp
>  source:
> -- bsps/shared/dev/display/disp_hcms29xx.c
> -- bsps/shared/dev/display/font_hcms29xx.c
> -- bsps/shared/dev/i2c/i2c-2b-eeprom.c
> -- bsps/shared/dev/i2c/i2c-ds1621.c
> -- bsps/shared/dev/i2c/i2c-sc620.c
> -- bsps/shared/dev/i2c/spi-flash-m25p40.c
> -- bsps/shared/dev/i2c/spi-fram-fm25l256.c
> -- bsps/shared/dev/i2c/spi-memdrv.c
> -- bsps/shared/dev/i2c/spi-sd-card.c
> -- bsps/shared/dev/ide/ata.c
> -- bsps/shared/dev/ide/ata_util.c
> -- bsps/shared/dev/ide/ide_controller.c
> -- bsps/shared/dev/rtc/ds1375.c
> -- bsps/shared/dev/rtc/icm7170.c
> -- bsps/shared/dev/rtc/icm7170_reg.c
> -- bsps/shared/dev/rtc/icm7170_reg2.c
> -- bsps/shared/dev/rtc/icm7170_reg4.c
> -- bsps/shared/dev/rtc/icm7170_reg8.c
> -- bsps/shared/dev/rtc/m48t08.c
> -- bsps/shared/dev/rtc/m48t08_reg.c
> -- bsps/shared/dev/rtc/m48t08_reg2.c
> -- bsps/shared/dev/rtc/m48t08_reg4.c
> -- bsps/shared/dev/rtc/m48t08_reg8.c
> -- bsps/shared/dev/rtc/mcp7940m.c
> -- bsps/shared/dev/rtc/rtcprobe.c
> -- bsps/shared/dev/serial/arm-pl011.c
> -- bsps/shared/dev/serial/ns16550-context.c
> -- bsps/shared/dev/serial/ns16550.c
> -- bsps/shared/dev/serial/serprobe.c
> -- bsps/shared/ofw/ofw.c
> -- bsps/shared/rtems-version.c
>  - bsps/shared/start/bootcard.c
> -- bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c
> -- bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
>  type: build
> diff --git a/spec/build/bsps/objextra.yml b/spec/build/bsps/objextra.yml
> index 0000000000..c156210a21
> --- /dev/null
> +++ b/spec/build/bsps/objextra.yml
> @@ -0,0 +1,99 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +build-type: objects
> +cflags: []
> +copyrights:
> +- Copyright (C) 2020 embedded brains GmbH & Co. KG
> +cppflags: []
> +cxxflags: []
> +enabled-by:
> +  not: RTEMS_QUALIFIED
> +includes: []
> +install:
> +- destination: ${BSP_INCLUDEDIR}/bsp
> +  source:
> +  - bsps/include/bsp/console-polled.h
> +  - bsps/include/bsp/console-termios.h
> +  - bsps/include/bsp/fdt.h
> +  - bsps/include/bsp/gpio.h
> +  - bsps/include/bsp/stackalloc.h
> +  - bsps/include/bsp/u-boot.h
> +  - bsps/include/bsp/uart-output-char.h
> +  - bsps/include/bsp/utility.h
> +- destination: ${BSP_INCLUDEDIR}/ofw
> +  source:
> +  - bsps/include/ofw/ofw.h
> +  - bsps/include/ofw/ofw_compat.h
> +- destination: ${BSP_INCLUDEDIR}/libchip
> +  source:
> +  - bsps/include/libchip/ata.h
> +  - bsps/include/libchip/ata_internal.h
> +  - bsps/include/libchip/disp_hcms29xx.h
> +  - bsps/include/libchip/ds1375-rtc.h
> +  - bsps/include/libchip/i2c-2b-eeprom.h
> +  - bsps/include/libchip/i2c-ds1621.h
> +  - bsps/include/libchip/i2c-sc620.h
> +  - bsps/include/libchip/icm7170.h
> +  - bsps/include/libchip/ide_ctrl.h
> +  - bsps/include/libchip/ide_ctrl_cfg.h
> +  - bsps/include/libchip/ide_ctrl_io.h
> +  - bsps/include/libchip/m48t08.h
> +  - bsps/include/libchip/mcp7940m-rtc.h
> +  - bsps/include/libchip/ns16550.h
> +  - bsps/include/libchip/ns16550_p.h
> +  - bsps/include/libchip/rtc.h
> +  - bsps/include/libchip/serial.h
> +  - bsps/include/libchip/sersupp.h
> +  - bsps/include/libchip/spi-flash-m25p40.h
> +  - bsps/include/libchip/spi-fram-fm25l256.h
> +  - bsps/include/libchip/spi-memdrv.h
> +  - bsps/include/libchip/spi-sd-card.h
> +  - bsps/include/libchip/wd80x3.h
> +- destination: ${BSP_INCLUDEDIR}/dev/serial
> +  source:
> +  - bsps/include/dev/serial/arm-pl011-regs.h
> +  - bsps/include/dev/serial/arm-pl011.h
> +- destination: ${BSP_INCLUDEDIR}/rtems/zilog
> +  source:
> +  - bsps/include/rtems/zilog/z8036.h
> +  - bsps/include/rtems/zilog/z8530.h
> +- destination: ${BSP_INCLUDEDIR}/arm/ti
> +  source:
> +  - bsps/include/arm/ti/ti_pinmux.h
> +  - bsps/include/arm/ti/ti_cpuid.h
> +links: []
> +source:
> +- bsps/shared/dev/display/disp_hcms29xx.c
> +- bsps/shared/dev/display/font_hcms29xx.c
> +- bsps/shared/dev/i2c/i2c-2b-eeprom.c
> +- bsps/shared/dev/i2c/i2c-ds1621.c
> +- bsps/shared/dev/i2c/i2c-sc620.c
> +- bsps/shared/dev/i2c/spi-flash-m25p40.c
> +- bsps/shared/dev/i2c/spi-fram-fm25l256.c
> +- bsps/shared/dev/i2c/spi-memdrv.c
> +- bsps/shared/dev/i2c/spi-sd-card.c
> +- bsps/shared/dev/ide/ata.c
> +- bsps/shared/dev/ide/ata_util.c
> +- bsps/shared/dev/ide/ide_controller.c
> +- bsps/shared/dev/rtc/ds1375.c
> +- bsps/shared/dev/rtc/icm7170.c
> +- bsps/shared/dev/rtc/icm7170_reg.c
> +- bsps/shared/dev/rtc/icm7170_reg2.c
> +- bsps/shared/dev/rtc/icm7170_reg4.c
> +- bsps/shared/dev/rtc/icm7170_reg8.c
> +- bsps/shared/dev/rtc/m48t08.c
> +- bsps/shared/dev/rtc/m48t08_reg.c
> +- bsps/shared/dev/rtc/m48t08_reg2.c
> +- bsps/shared/dev/rtc/m48t08_reg4.c
> +- bsps/shared/dev/rtc/m48t08_reg8.c
> +- bsps/shared/dev/rtc/mcp7940m.c
> +- bsps/shared/dev/rtc/rtcprobe.c
> +- bsps/shared/dev/serial/arm-pl011.c
> +- bsps/shared/dev/serial/ns16550-context.c
> +- bsps/shared/dev/serial/ns16550.c
> +- bsps/shared/dev/serial/serprobe.c
> +- bsps/shared/ofw/ofw.c
> +- bsps/shared/rtems-version.c
> +- bsps/shared/start/bootcard.c
> +- bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c
> +- bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
> +type: build
> diff --git a/spec/build/bsps/objgrlib.yml b/spec/build/bsps/objgrlib.yml
> index 0a328d688f..8935ae1dc3 100644
> --- a/spec/build/bsps/objgrlib.yml
> +++ b/spec/build/bsps/objgrlib.yml
> @@ -10,133 +10,34 @@ includes: []
>  install:
>  - destination: ${BSP_INCLUDEDIR}/grlib
>    source:
> -  - bsps/include/grlib/ahbstat.h
> -  - bsps/include/grlib/ambapp.h
> -  - bsps/include/grlib/ambapp_bus.h
> -  - bsps/include/grlib/ambapp_bus_grlib.h
> -  - bsps/include/grlib/ambapp_ids.h
> +  - bsps/include/grlib/ahbstat-regs.h
> +  - bsps/include/grlib/ahbtrace-regs.h
>    - bsps/include/grlib/apbuart.h
> -  - bsps/include/grlib/apbuart_cons.h
> -  - bsps/include/grlib/apbuart_termios.h
> -  - bsps/include/grlib/b1553brm.h
> -  - bsps/include/grlib/b1553rt.h
> -  - bsps/include/grlib/bspcommon.h
> -  - bsps/include/grlib/canbtrs.h
> -  - bsps/include/grlib/canmux.h
> -  - bsps/include/grlib/cons.h
> -  - bsps/include/grlib/debug_defs.h
> -  - bsps/include/grlib/genirq.h
> -  - bsps/include/grlib/gpiolib.h
> -  - bsps/include/grlib/gptimer.h
> -  - bsps/include/grlib/gr1553b.h
> -  - bsps/include/grlib/gr1553bc.h
> -  - bsps/include/grlib/gr1553bc_list.h
> -  - bsps/include/grlib/gr1553bm.h
> -  - bsps/include/grlib/gr1553rt.h
> -  - bsps/include/grlib/gr_701.h
> -  - bsps/include/grlib/gr_cpci_gr740.h
> -  - bsps/include/grlib/gr_rasta_adcdac.h
> -  - bsps/include/grlib/gr_rasta_io.h
> -  - bsps/include/grlib/gr_rasta_spw_router.h
> -  - bsps/include/grlib/gr_rasta_tmtc.h
> -  - bsps/include/grlib/gr_tmtc_1553.h
> -  - bsps/include/grlib/gradcdac.h
> -  - bsps/include/grlib/grascs.h
> -  - bsps/include/grlib/grcan.h
> -  - bsps/include/grlib/grctm.h
> -  - bsps/include/grlib/grgpio.h
> -  - bsps/include/grlib/griommu.h
> -  - bsps/include/grlib/grlib.h
> -  - bsps/include/grlib/grlib_impl.h
> -  - bsps/include/grlib/grpci.h
> -  - bsps/include/grlib/grpci2.h
> -  - bsps/include/grlib/grpci2dma.h
> -  - bsps/include/grlib/grpwm.h
> -  - bsps/include/grlib/grslink.h
> -  - bsps/include/grlib/grspw.h
> -  - bsps/include/grlib/grspw_pkt.h
> -  - bsps/include/grlib/grspw_router.h
> -  - bsps/include/grlib/grtc.h
> -  - bsps/include/grlib/grtm.h
> -  - bsps/include/grlib/i2cmst.h
> -  - bsps/include/grlib/l2c.h
> -  - bsps/include/grlib/l4stat.h
> -  - bsps/include/grlib/mctrl.h
> -  - bsps/include/grlib/memscrub.h
> -  - bsps/include/grlib/occan.h
> -  - bsps/include/grlib/pcif.h
> -  - bsps/include/grlib/satcan.h
> -  - bsps/include/grlib/spictrl.h
> -  - bsps/include/grlib/spwcuc.h
> -  - bsps/include/grlib/spwtdp.h
> -  - bsps/include/grlib/tlib.h
> +  - bsps/include/grlib/apbuart-regs.h
> +  - bsps/include/grlib/dsu4-regs.h
> +  - bsps/include/grlib/ftmctrl-regs.h
> +  - bsps/include/grlib/gptimer-regs.h
> +  - bsps/include/grlib/gr1553b-regs.h
> +  - bsps/include/grlib/grcan-regs.h
> +  - bsps/include/grlib/grclkgate-regs.h
> +  - bsps/include/grlib/grethgbit-regs.h
> +  - bsps/include/grlib/grgpio-regs.h
> +  - bsps/include/grlib/griommu-regs.h
> +  - bsps/include/grlib/grpci2-regs.h
> +  - bsps/include/grlib/grspw2-regs.h
> +  - bsps/include/grlib/grspwrouter-regs.h
> +  - bsps/include/grlib/irqamp.h
> +  - bsps/include/grlib/irqamp-regs.h
> +  - bsps/include/grlib/l2cache-regs.h
> +  - bsps/include/grlib/l4stat-regs.h
> +  - bsps/include/grlib/memscrub-regs.h
> +  - bsps/include/grlib/mmctrl-regs.h
> +  - bsps/include/grlib/spictrl-regs.h
> +  - bsps/include/grlib/spwpnp-regs.h
> +  - bsps/include/grlib/spwtdp-regs.h
>  links:
> -  uid: objgrlibnosmp
> +  uid: objgrlibextra
>  source:
> -- bsps/shared/grlib/1553/b1553brm.c
> -- bsps/shared/grlib/1553/b1553rt.c
> -- bsps/shared/grlib/1553/gr1553b.c
> -- bsps/shared/grlib/1553/gr1553bc.c
> -- bsps/shared/grlib/1553/gr1553bm.c
> -- bsps/shared/grlib/1553/gr1553rt.c
> -- bsps/shared/grlib/amba/ahbstat.c
> -- bsps/shared/grlib/amba/ambapp.c
> -- bsps/shared/grlib/amba/ambapp_alloc.c
> -- bsps/shared/grlib/amba/ambapp_count.c
> -- bsps/shared/grlib/amba/ambapp_depth.c
> -- bsps/shared/grlib/amba/ambapp_find_by_idx.c
> -- bsps/shared/grlib/amba/ambapp_freq.c
> -- bsps/shared/grlib/amba/ambapp_names.c
> -- bsps/shared/grlib/amba/ambapp_old.c
> -- bsps/shared/grlib/amba/ambapp_parent.c
> -- bsps/shared/grlib/amba/ambapp_show.c
> -- bsps/shared/grlib/analog/gradcdac.c
> -- bsps/shared/grlib/ascs/grascs.c
> -- bsps/shared/grlib/btimer/gptimer.c
> -- bsps/shared/grlib/btimer/tlib.c
> -- bsps/shared/grlib/btimer/tlib_ckinit.c
> -- bsps/shared/grlib/can/canbtrs.c
> -- bsps/shared/grlib/can/canmux.c
> -- bsps/shared/grlib/can/grcan.c
> -- bsps/shared/grlib/can/grcanfd.c
> -- bsps/shared/grlib/can/grcanstd.c
> -- bsps/shared/grlib/can/occan.c
> -- bsps/shared/grlib/can/satcan.c
> -- bsps/shared/grlib/drvmgr/ambapp_bus.c
> -- bsps/shared/grlib/drvmgr/ambapp_bus_grlib.c
> -- bsps/shared/grlib/drvmgr/get_resarray_count.c
> -- bsps/shared/grlib/gpio/gpiolib.c
> -- bsps/shared/grlib/gpio/grgpio.c
> -- bsps/shared/grlib/i2c/i2cmst.c
> -- bsps/shared/grlib/iommu/griommu.c
> -- bsps/shared/grlib/irq/genirq.c
> -- bsps/shared/grlib/l2c/l2c.c
> -- bsps/shared/grlib/mem/mctrl.c
> -- bsps/shared/grlib/pci/gr_701.c
> -- bsps/shared/grlib/pci/gr_rasta_adcdac.c
> -- bsps/shared/grlib/pci/gr_rasta_io.c
> -- bsps/shared/grlib/pci/gr_rasta_spw_router.c
> -- bsps/shared/grlib/pci/gr_rasta_tmtc.c
> -- bsps/shared/grlib/pci/gr_tmtc_1553.c
> -- bsps/shared/grlib/pci/grpci.c
> -- bsps/shared/grlib/pci/grpci2.c
> -- bsps/shared/grlib/pci/grpci2dma.c
> -- bsps/shared/grlib/pci/pcif.c
> -- bsps/shared/grlib/pwm/grpwm.c
> -- bsps/shared/grlib/scrub/memscrub.c
> -- bsps/shared/grlib/slink/grslink.c
> -- bsps/shared/grlib/spi/spictrl.c
> -- bsps/shared/grlib/spw/grspw_pkt.c
> -- bsps/shared/grlib/spw/grspw_router.c
> -- bsps/shared/grlib/spw/spwtdp.c
> -- bsps/shared/grlib/stat/l4stat.c
> -- bsps/shared/grlib/time/grctm.c
> -- bsps/shared/grlib/time/spwcuc.c
> -- bsps/shared/grlib/tmtc/grtc.c
> -- bsps/shared/grlib/tmtc/grtm.c
> -- bsps/shared/grlib/uart/apbuart_cons.c
>  - bsps/shared/grlib/uart/apbuart_polled.c
> -- bsps/shared/grlib/uart/apbuart_termios.c
> -- bsps/shared/grlib/uart/cons.c
>  type: build
> diff --git a/spec/build/bsps/objgrlibextra.yml
> b/spec/build/bsps/objgrlibextra.yml
> index 0000000000..f7d9923035
> --- /dev/null
> +++ b/spec/build/bsps/objgrlibextra.yml
> @@ -0,0 +1,141 @@
> +cflags: []
> +copyrights:
> +cppflags: []
> +cxxflags: []
> +enabled-by:
> +includes: []
> +install:
> +- destination: ${BSP_INCLUDEDIR}/grlib
> +  source:
> +  - bsps/include/grlib/ahbstat.h
> +  - bsps/include/grlib/ambapp.h
> +  - bsps/include/grlib/ambapp_bus.h
> +  - bsps/include/grlib/ambapp_bus_grlib.h
> +  - bsps/include/grlib/ambapp_ids.h
> +  - bsps/include/grlib/apbuart_cons.h
> +  - bsps/include/grlib/apbuart_termios.h
> +  - bsps/include/grlib/b1553brm.h
> +  - bsps/include/grlib/b1553rt.h
> +  - bsps/include/grlib/bspcommon.h
> +  - bsps/include/grlib/canbtrs.h
> +  - bsps/include/grlib/canmux.h
> +  - bsps/include/grlib/cons.h
> +  - bsps/include/grlib/debug_defs.h
> +  - bsps/include/grlib/genirq.h
> +  - bsps/include/grlib/gpiolib.h
> +  - bsps/include/grlib/gptimer.h
> +  - bsps/include/grlib/gr1553b.h
> +  - bsps/include/grlib/gr1553bc.h
> +  - bsps/include/grlib/gr1553bc_list.h
> +  - bsps/include/grlib/gr1553bm.h
> +  - bsps/include/grlib/gr1553rt.h
> +  - bsps/include/grlib/gr_701.h
> +  - bsps/include/grlib/gr_cpci_gr740.h
> +  - bsps/include/grlib/gr_rasta_adcdac.h
> +  - bsps/include/grlib/gr_rasta_io.h
> +  - bsps/include/grlib/gr_rasta_spw_router.h
> +  - bsps/include/grlib/gr_rasta_tmtc.h
> +  - bsps/include/grlib/gr_tmtc_1553.h
> +  - bsps/include/grlib/gradcdac.h
> +  - bsps/include/grlib/grascs.h
> +  - bsps/include/grlib/grcan.h
> +  - bsps/include/grlib/grctm.h
> +  - bsps/include/grlib/grgpio.h
> +  - bsps/include/grlib/griommu.h
> +  - bsps/include/grlib/grlib.h
> +  - bsps/include/grlib/grlib_impl.h
> +  - bsps/include/grlib/grpci.h
> +  - bsps/include/grlib/grpci2.h
> +  - bsps/include/grlib/grpci2dma.h
> +  - bsps/include/grlib/grpwm.h
> +  - bsps/include/grlib/grslink.h
> +  - bsps/include/grlib/grspw.h
> +  - bsps/include/grlib/grspw_pkt.h
> +  - bsps/include/grlib/grspw_router.h
> +  - bsps/include/grlib/grtc.h
> +  - bsps/include/grlib/grtm.h
> +  - bsps/include/grlib/i2cmst.h
> +  - bsps/include/grlib/l2c.h
> +  - bsps/include/grlib/l4stat.h
> +  - bsps/include/grlib/mctrl.h
> +  - bsps/include/grlib/memscrub.h
> +  - bsps/include/grlib/occan.h
> +  - bsps/include/grlib/pcif.h
> +  - bsps/include/grlib/satcan.h
> +  - bsps/include/grlib/spictrl.h
> +  - bsps/include/grlib/spwcuc.h
> +  - bsps/include/grlib/spwtdp.h
> +  - bsps/include/grlib/tlib.h
> +links:
> +  uid: objgrlibnosmp
> +source:
> +- bsps/shared/grlib/1553/b1553brm.c
> +- bsps/shared/grlib/1553/b1553rt.c
> +- bsps/shared/grlib/1553/gr1553b.c
> +- bsps/shared/grlib/1553/gr1553bc.c
> +- bsps/shared/grlib/1553/gr1553bm.c
> +- bsps/shared/grlib/1553/gr1553rt.c
> +- bsps/shared/grlib/amba/ahbstat.c
> +- bsps/shared/grlib/amba/ambapp.c
> +- bsps/shared/grlib/amba/ambapp_alloc.c
> +- bsps/shared/grlib/amba/ambapp_count.c
> +- bsps/shared/grlib/amba/ambapp_depth.c
> +- bsps/shared/grlib/amba/ambapp_find_by_idx.c
> +- bsps/shared/grlib/amba/ambapp_freq.c
> +- bsps/shared/grlib/amba/ambapp_names.c
> +- bsps/shared/grlib/amba/ambapp_old.c
> +- bsps/shared/grlib/amba/ambapp_parent.c
> +- bsps/shared/grlib/amba/ambapp_show.c
> +- bsps/shared/grlib/analog/gradcdac.c
> +- bsps/shared/grlib/ascs/grascs.c
> +- bsps/shared/grlib/btimer/gptimer.c
> +- bsps/shared/grlib/btimer/tlib.c
> +- bsps/shared/grlib/btimer/tlib_ckinit.c
> +- bsps/shared/grlib/can/canbtrs.c
> +- bsps/shared/grlib/can/canmux.c
> +- bsps/shared/grlib/can/grcan.c
> +- bsps/shared/grlib/can/grcanfd.c
> +- bsps/shared/grlib/can/grcanstd.c
> +- bsps/shared/grlib/can/occan.c
> +- bsps/shared/grlib/can/satcan.c
> +- bsps/shared/grlib/drvmgr/ambapp_bus.c
> +- bsps/shared/grlib/drvmgr/ambapp_bus_grlib.c
> +- bsps/shared/grlib/drvmgr/get_resarray_count.c
> +- bsps/shared/grlib/gpio/gpiolib.c
> +- bsps/shared/grlib/gpio/grgpio.c
> +- bsps/shared/grlib/i2c/i2cmst.c
> +- bsps/shared/grlib/iommu/griommu.c
> +- bsps/shared/grlib/irq/genirq.c
> +- bsps/shared/grlib/l2c/l2c.c
> +- bsps/shared/grlib/mem/mctrl.c
> +- bsps/shared/grlib/pci/gr_701.c
> +- bsps/shared/grlib/pci/gr_rasta_adcdac.c
> +- bsps/shared/grlib/pci/gr_rasta_io.c
> +- bsps/shared/grlib/pci/gr_rasta_spw_router.c
> +- bsps/shared/grlib/pci/gr_rasta_tmtc.c
> +- bsps/shared/grlib/pci/gr_tmtc_1553.c
> +- bsps/shared/grlib/pci/grpci.c
> +- bsps/shared/grlib/pci/grpci2.c
> +- bsps/shared/grlib/pci/grpci2dma.c
> +- bsps/shared/grlib/pci/pcif.c
> +- bsps/shared/grlib/pwm/grpwm.c
> +- bsps/shared/grlib/scrub/memscrub.c
> +- bsps/shared/grlib/slink/grslink.c
> +- bsps/shared/grlib/spi/spictrl.c
> +- bsps/shared/grlib/spw/grspw_pkt.c
> +- bsps/shared/grlib/spw/grspw_router.c
> +- bsps/shared/grlib/spw/spwtdp.c
> +- bsps/shared/grlib/stat/l4stat.c
> +- bsps/shared/grlib/time/grctm.c
> +- bsps/shared/grlib/time/spwcuc.c
> +- bsps/shared/grlib/tmtc/grtc.c
> +- bsps/shared/grlib/tmtc/grtm.c
> +- bsps/shared/grlib/uart/apbuart_cons.c
> +- bsps/shared/grlib/uart/apbuart_termios.c
> +- bsps/shared/grlib/uart/cons.c
> +type: build
> diff --git a/spec/build/bsps/objirq.yml b/spec/build/bsps/objirq.yml
> index 2a817649d3..dbb0a13e19 100644
> --- a/spec/build/bsps/objirq.yml
> +++ b/spec/build/bsps/objirq.yml
> @@ -7,21 +7,19 @@ cppflags: []
>  cxxflags: []
>  enabled-by: true
>  includes: []
> -install: []
> -links: []
> +install:
> +  source:
> +  - bsps/include/bsp/irq-generic.h
> +links:
> +  uid: objirqextra
>  source:
>  - bsps/shared/irq/irq-affinity.c
>  - bsps/shared/irq/irq-raise-clear.c
>  - bsps/shared/irq/irq-enable-disable.c
>  - bsps/shared/irq/irq-entry-remove.c
>  - bsps/shared/irq/irq-generic.c
> -- bsps/shared/irq/irq-handler-install.c
>  - bsps/shared/irq/irq-handler-iterate.c
> -- bsps/shared/irq/irq-handler-remove.c
> -- bsps/shared/irq/irq-info.c
> -- bsps/shared/irq/irq-legacy.c
>  - bsps/shared/irq/irq-lock.c
> -- bsps/shared/irq/irq-record.c
> -- bsps/shared/irq/irq-server.c
> -- bsps/shared/irq/irq-shell.c
>  type: build
> diff --git a/spec/build/bsps/objirqextra.yml
> b/spec/build/bsps/objirqextra.yml
> index 0000000000..7353ad9ae9
> --- /dev/null
> +++ b/spec/build/bsps/objirqextra.yml
> @@ -0,0 +1,24 @@
> +cflags: []
> +copyrights:
> +cppflags: []
> +cxxflags: []
> +enabled-by:
> +includes: []
> +install:
> +  source:
> +  - bsps/include/bsp/irq-default.h
> +  - bsps/include/bsp/irq-info.h
> +links: []
> +source:
> +- bsps/shared/irq/irq-info.c
> +- bsps/shared/irq/irq-handler-install.c
> +- bsps/shared/irq/irq-handler-remove.c
> +- bsps/shared/irq/irq-legacy.c
> +- bsps/shared/irq/irq-server.c
> +- bsps/shared/irq/irq-shell.c
> +type: build
> diff --git a/spec/build/bsps/objnosmp.yml b/spec/build/bsps/objnosmp.yml
> index b33cf25f00..274121801e 100644
> --- a/spec/build/bsps/objnosmp.yml
> +++ b/spec/build/bsps/objnosmp.yml
> @@ -6,7 +6,9 @@ copyrights:
>  cppflags: []
>  cxxflags: []
>  enabled-by:
> -  not: RTEMS_SMP
> +  not:
> +  - RTEMS_QUALIFIED
> +  - RTEMS_SMP
>  includes: []
>  install:
> diff --git a/spec/build/bsps/optldflags.yml
> b/spec/build/bsps/optldflags.yml
> index b12b718b1c..fb970f44dd 100644
> --- a/spec/build/bsps/optldflags.yml
> +++ b/spec/build/bsps/optldflags.yml
> @@ -8,6 +8,17 @@ build-type: option
>  copyrights:
>  default:
> +- enabled-by: RTEMS_QUALIFIED
> +  value:
> +  - -nodefaultlibs
> +  - -Wl,--start-group
> +  - -lrtemscpu
> +  - -lrtemsbsp
> +  - -lgcc
> +  - -lc
> +  - -latomic
> +  - -Wl,--end-group
> +  - -Wl,--gc-sections
>  - enabled-by: true
>    value:
>    - -Wl,--gc-sections
> diff --git a/spec/build/bsps/sparc/grp.yml b/spec/build/bsps/sparc/grp.yml
> index f59b3995f8..4615a33557 100644
> --- a/spec/build/bsps/sparc/grp.yml
> +++ b/spec/build/bsps/sparc/grp.yml
> @@ -5,7 +5,8 @@ copyrights:
>  cppflags: []
>  cxxflags: []
> -enabled-by: true
> +enabled-by:
>  includes: []
>  install:
> diff --git a/spec/build/bsps/sparc/leon3/grp.yml
> b/spec/build/bsps/sparc/leon3/grp.yml
> index a995ccc60a..0e2792c3a6 100644
> --- a/spec/build/bsps/sparc/leon3/grp.yml
> +++ b/spec/build/bsps/sparc/leon3/grp.yml
> @@ -28,6 +28,8 @@ links:
>    uid: abi
>    uid: obj
> +  uid: objextra
>    uid: objmpci
> diff --git a/spec/build/bsps/sparc/leon3/obj.yml
> b/spec/build/bsps/sparc/leon3/obj.yml
> index f8feab3b3b..1cb6743137 100644
> --- a/spec/build/bsps/sparc/leon3/obj.yml
> +++ b/spec/build/bsps/sparc/leon3/obj.yml
> @@ -10,9 +10,7 @@ includes: []
>  install:
>    source:
> -  - bsps/sparc/leon3/include/amba.h
>    - bsps/sparc/leon3/include/bsp.h
> -  - bsps/sparc/leon3/include/leon.h
>    source:
>    - bsps/sparc/leon3/include/bsp/gr740-bootstrap-regs.h
> @@ -21,7 +19,9 @@ install:
>    - bsps/sparc/leon3/include/bsp/irq.h
>    - bsps/sparc/leon3/include/bsp/irqimpl.h
>    - bsps/sparc/leon3/include/bsp/leon3.h
> -  - bsps/sparc/leon3/include/bsp/watchdog.h
> +  source:
> +  - bsps/sparc/include/grlib/io.h
>  - destination: ${BSP_LIBDIR}
>    source:
>    - bsps/sparc/leon3/start/linkcmds.gr712rc
> @@ -32,33 +32,16 @@ install:
>    - bsps/sparc/shared/start/linkcmds.base
>  links: []
>  source:
> -- bsps/shared/dev/getentropy/getentropy-cpucounter.c
> -- bsps/shared/dev/serial/console-termios.c
>  - bsps/shared/irq/irq-default-handler.c
> -- bsps/shared/start/bspreset-empty.c
> -- bsps/shared/start/sbrk.c
> -- bsps/sparc/leon3/btimer/btimer.c
> -- bsps/sparc/leon3/btimer/watchdog.c
>  - bsps/sparc/leon3/clock/ckinit.c
> -- bsps/sparc/leon3/console/console.c
>  - bsps/sparc/leon3/console/printk_support.c
> -- bsps/sparc/leon3/gnatsupp/gnatsupp.c
> -- bsps/sparc/leon3/start/amba.c
>  - bsps/sparc/leon3/start/bspclean.c
> -- bsps/sparc/leon3/start/bspdelay.c
>  - bsps/sparc/leon3/start/bspidle.S
>  - bsps/sparc/leon3/start/bspstart.c
>  - bsps/sparc/leon3/start/cache.c
>  - bsps/sparc/leon3/start/cpucounter.c
> -- bsps/sparc/leon3/start/drvmgr_def_drivers.c
>  - bsps/sparc/leon3/start/eirq.c
>  - bsps/sparc/leon3/start/gettargethash.c
> -- bsps/sparc/leon3/start/setvec.c
> -- bsps/sparc/shared/gnatcommon.c
>  - bsps/sparc/shared/irq/bsp_isr_handler.c
> -- bsps/sparc/shared/pci/gr_cpci_gr740.c
> -- bsps/sparc/shared/pci/gr_leon4_n2x.c
> -- bsps/sparc/shared/pci/pci_memreg_sparc_be.c
> -- bsps/sparc/shared/pci/pci_memreg_sparc_le.c
> -- bsps/sparc/shared/start/bsp_fatal_exit.c
> +- bsps/sparc/shared/start/bspgetworkarea.c
>  type: build
> diff --git a/spec/build/bsps/sparc/leon3/objextra.yml
> b/spec/build/bsps/sparc/leon3/objextra.yml
> index 0000000000..73083c0ab8
> --- /dev/null
> +++ b/spec/build/bsps/sparc/leon3/objextra.yml
> @@ -0,0 +1,39 @@
> +cflags: []
> +copyrights:
> +cppflags: []
> +cxxflags: []
> +enabled-by:
> +includes: []
> +install:
> +  source:
> +  - bsps/sparc/leon3/include/leon.h
> +  source:
> +  - bsps/sparc/leon3/include/bsp/watchdog.h
> +links: []
> +source:
> +- bsps/shared/dev/getentropy/getentropy-cpucounter.c
> +- bsps/shared/dev/serial/console-termios.c
> +- bsps/shared/start/bspreset-empty.c
> +- bsps/shared/start/sbrk.c
> +- bsps/sparc/leon3/btimer/btimer.c
> +- bsps/sparc/leon3/btimer/watchdog.c
> +- bsps/sparc/leon3/console/console.c
> +- bsps/sparc/leon3/gnatsupp/gnatsupp.c
> +- bsps/sparc/leon3/start/amba.c
> +- bsps/sparc/leon3/start/bspdelay.c
> +- bsps/sparc/leon3/start/cpucounter.c
> +- bsps/sparc/leon3/start/drvmgr_def_drivers.c
> +- bsps/sparc/leon3/start/setvec.c
> +- bsps/sparc/shared/gnatcommon.c
> +- bsps/sparc/shared/pci/gr_cpci_gr740.c
> +- bsps/sparc/shared/pci/gr_leon4_n2x.c
> +- bsps/sparc/shared/pci/pci_memreg_sparc_be.c
> +- bsps/sparc/shared/pci/pci_memreg_sparc_le.c
> +- bsps/sparc/shared/start/bsp_fatal_exit.c
> +type: build
> diff --git a/spec/build/bsps/sparc/objmem.yml
> b/spec/build/bsps/sparc/objmem.yml
> index 4c1602efda..7d2474a12b 100644
> --- a/spec/build/bsps/sparc/objmem.yml
> +++ b/spec/build/bsps/sparc/objmem.yml
>  - Copyright (C) 2021 embedded brains GmbH & Co. KG
>  cppflags: []
>  cxxflags: []
> -enabled-by: true
> +enabled-by:
>  includes: []
>  install: []
>  links: []
> diff --git a/spec/build/cpukit/cpuarm.yml b/spec/build/cpukit/cpuarm.yml
> index 5b140e46bb..aa524a4bf5 100644
> --- a/spec/build/cpukit/cpuarm.yml
> +++ b/spec/build/cpukit/cpuarm.yml
> @@ -5,8 +5,7 @@ copyrights:
>  cppflags: []
>  cxxflags: []
> -enabled-by:
> -- arm
> +enabled-by: arm
>  includes: []
>  install:
>  - destination: ${BSP_INCLUDEDIR}/libcpu
> @@ -27,17 +26,15 @@ install:
>    - cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h
>    - cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
>    - cpukit/score/cpu/arm/include/rtems/score/paravirt.h
> -links: []
> +links:
> +  uid: cpuarmextra
>  source:
>  - cpukit/score/cpu/arm/__aeabi_read_tp.c
>  - cpukit/score/cpu/arm/__tls_get_addr.c
> -- cpukit/score/cpu/arm/aarch32-psma-init-default.c
> -- cpukit/score/cpu/arm/aarch32-psma-init.c
>  - cpukit/score/cpu/arm/arm-context-validate.S
>  - cpukit/score/cpu/arm/arm-context-volatile-clobber.S
>  - cpukit/score/cpu/arm/arm-exception-default.c
> -- cpukit/score/cpu/arm/arm-exception-frame-print.c
> -- cpukit/score/cpu/arm/arm_exc_abort.S
>  - cpukit/score/cpu/arm/arm_exc_interrupt.S
>  - cpukit/score/cpu/arm/armv4-exception-default.S
>  - cpukit/score/cpu/arm/armv4-sync-synchronize.c
> diff --git a/spec/build/cpukit/cpuarmextra.yml
> b/spec/build/cpukit/cpuarmextra.yml
> index 0000000000..5d43d1ffca
> --- /dev/null
> +++ b/spec/build/cpukit/cpuarmextra.yml
> @@ -0,0 +1,18 @@
> +cflags: []
> +copyrights:
> +cppflags: []
> +cxxflags: []
> +enabled-by:
> +includes: []
> +install: []
> +links: []
> +source:
> +- cpukit/score/cpu/arm/aarch32-psma-init-default.c
> +- cpukit/score/cpu/arm/aarch32-psma-init.c
> +- cpukit/score/cpu/arm/arm-exception-frame-print.c
> +- cpukit/score/cpu/arm/arm_exc_abort.S
> +type: build
> diff --git a/spec/build/cpukit/cpuopts.yml b/spec/build/cpukit/cpuopts.yml
> index 1d28ace552..c9c366b92a 100644
> --- a/spec/build/cpukit/cpuopts.yml
> +++ b/spec/build/cpukit/cpuopts.yml
> @@ -15,6 +15,8 @@ links:
>    uid: optarchbits
>    uid: optclang
> +  uid: optqual
>    uid: optarflags
> diff --git a/spec/build/cpukit/cpusparc.yml
> b/spec/build/cpukit/cpusparc.yml
> index 42406bcd95..eb22c56414 100644
> --- a/spec/build/cpukit/cpusparc.yml
> +++ b/spec/build/cpukit/cpusparc.yml
> @@ -5,39 +5,26 @@ copyrights:
>  cppflags: []
>  cxxflags: []
> -enabled-by:
> -- sparc
> +enabled-by: sparc
>  includes: []
>  install:
> -- destination: ${BSP_INCLUDEDIR}/libcpu
> -  source:
> -  - cpukit/score/cpu/sparc/include/libcpu/access.h
> -  - cpukit/score/cpu/sparc/include/libcpu/byteorder.h
> -  - cpukit/score/cpu/sparc/include/libcpu/grlib-tn-0018.h
> -- destination: ${BSP_INCLUDEDIR}/machine
> -  source:
> -  - cpukit/score/cpu/sparc/include/machine/elf_machdep.h
>    source:
>    - cpukit/score/cpu/sparc/include/rtems/asm.h
>  - destination: ${BSP_INCLUDEDIR}/rtems/score
>    source:
> +  - cpukit/score/cpu/sparc/include/libcpu/grlib-tn-0018.h
>    - cpukit/score/cpu/sparc/include/rtems/score/cpu.h
>    - cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h
>    - cpukit/score/cpu/sparc/include/rtems/score/sparc.h
> -links: []
> +links:
> +  uid: cpusparcextra
>  source:
>  - cpukit/score/cpu/no_cpu/cpuidle.c
> -- cpukit/score/cpu/sparc/access_le.c
>  - cpukit/score/cpu/sparc/cpu.c
>  - cpukit/score/cpu/sparc/cpu_asm.S
> -- cpukit/score/cpu/sparc/sparc-access.S
>  - cpukit/score/cpu/sparc/sparc-bad-trap.S
> -- cpukit/score/cpu/sparc/sparc-context-validate.S
> -- cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S
> -- cpukit/score/cpu/sparc/sparc-exception-frame-print.c
> -- cpukit/score/cpu/sparc/sparc-isr-handler.S
> -- cpukit/score/cpu/sparc/sparc-isr-install.c
>  - cpukit/score/cpu/sparc/syscall.S
>  - cpukit/score/cpu/sparc/window.S
>  type: build
> diff --git a/spec/build/cpukit/cpusparcextra.yml
> b/spec/build/cpukit/cpusparcextra.yml
> index 0000000000..d1aadf0e7f
> --- /dev/null
> +++ b/spec/build/cpukit/cpusparcextra.yml
> @@ -0,0 +1,28 @@
> +cflags: []
> +copyrights:
> +cppflags: []
> +cxxflags: []
> +enabled-by:
> +includes: []
> +install:
> +- destination: ${BSP_INCLUDEDIR}/libcpu
> +  source:
> +  - cpukit/score/cpu/sparc/include/libcpu/access.h
> +  - cpukit/score/cpu/sparc/include/libcpu/byteorder.h
> +- destination: ${BSP_INCLUDEDIR}/machine
> +  source:
> +  - cpukit/score/cpu/sparc/include/machine/elf_machdep.h
> +links: []
> +source:
> +- cpukit/score/cpu/sparc/access_le.c
> +- cpukit/score/cpu/sparc/sparc-access.S
> +- cpukit/score/cpu/sparc/sparc-context-validate.S
> +- cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S
> +- cpukit/score/cpu/sparc/sparc-exception-frame-print.c
> +- cpukit/score/cpu/sparc/sparc-isr-handler.S
> +- cpukit/score/cpu/sparc/sparc-isr-install.c
> +type: build
> diff --git a/spec/build/cpukit/libdebugger.yml
> b/spec/build/cpukit/libdebugger.yml
> index bc9db7b8d6..d42b9abbe9 100644
> --- a/spec/build/cpukit/libdebugger.yml
> +++ b/spec/build/cpukit/libdebugger.yml
> @@ -7,7 +7,10 @@ copyrights:
>  cppflags: []
>  cxxflags:
>  - ${COVERAGE_COMPILER_FLAGS}
> -enabled-by: BUILD_LIBDEBUGGER
> +enabled-by:
> +  and:
> +  - BUILD_LIBDEBUGGER
> +  - not: RTEMS_QUALIFIED
>  includes: []
>  install: []
>  install-path: ${BSP_LIBDIR}
> diff --git a/spec/build/cpukit/libftpd.yml b/spec/build/cpukit/libftpd.yml
> index 3983ac6bed..150d0d6653 100644
> --- a/spec/build/cpukit/libftpd.yml
> +++ b/spec/build/cpukit/libftpd.yml
>  cppflags: []
>  cxxflags: []
> -enabled-by: true
> +enabled-by:
>  includes: []
>  install:
> diff --git a/spec/build/cpukit/libftpfs.yml
> b/spec/build/cpukit/libftpfs.yml
> index cc9b9f7980..b550a22fe1 100644
> --- a/spec/build/cpukit/libftpfs.yml
> +++ b/spec/build/cpukit/libftpfs.yml
> @@ -7,7 +7,8 @@ copyrights:
>  cppflags: []
>  cxxflags:
> -enabled-by: true
> +enabled-by:
>  includes: []
>  install:
> diff --git a/spec/build/cpukit/libjffs2.yml
> b/spec/build/cpukit/libjffs2.yml
> index f7c74d8f21..cc2f2f47c9 100644
> --- a/spec/build/cpukit/libjffs2.yml
> +++ b/spec/build/cpukit/libjffs2.yml
> @@ -8,7 +8,8 @@ copyrights:
>  cppflags: []
>  cxxflags:
> -enabled-by: true
> +enabled-by:
>  includes:
>  - cpukit/libfs/src/jffs2/include
>  install:
> diff --git a/spec/build/cpukit/libmghttpd.yml
> b/spec/build/cpukit/libmghttpd.yml
> index c6cbe0a8be..988bedb8ef 100644
> --- a/spec/build/cpukit/libmghttpd.yml
> +++ b/spec/build/cpukit/libmghttpd.yml
>  cppflags: []
>  cxxflags:
> -enabled-by: true
> +enabled-by:
>  includes: []
>  install:
>  - destination: ${BSP_INCLUDEDIR}/mghttpd
> diff --git a/spec/build/cpukit/librtemscpu.yml
> b/spec/build/cpukit/librtemscpu.yml
> index 9202c31715..17c9aed375 100644
> --- a/spec/build/cpukit/librtemscpu.yml
> +++ b/spec/build/cpukit/librtemscpu.yml
> @@ -12,184 +12,16 @@ includes: []
>  install:
>    source:
> -  - cpukit/include/aio.h
> -  - cpukit/include/crypt.h
> -  - cpukit/include/dlfcn.h
> -  - cpukit/include/endian.h
> -  - cpukit/include/fdt.h
> -  - cpukit/include/libfdt.h
> -  - cpukit/include/libfdt_env.h
> -  - cpukit/include/link.h
> -  - cpukit/include/link_elf.h
> -  - cpukit/include/md4.h
> -  - cpukit/include/md5.h
> -  - cpukit/include/memory.h
> -  - cpukit/include/mqueue.h
> -  - cpukit/include/poll.h
>    - cpukit/include/rtems.h
>    - cpukit/include/sha224.h
>    - cpukit/include/sha256.h
> -  - cpukit/include/sha384.h
> -  - cpukit/include/sha512.h
> -  - cpukit/include/sha512t.h
> -  - cpukit/include/xz.h
> -- destination: ${BSP_INCLUDEDIR}/arpa
> -  source:
> -  - cpukit/include/arpa/ftp.h
> -- destination: ${BSP_INCLUDEDIR}/dev/i2c
> -  source:
> -  - cpukit/include/dev/i2c/eeprom.h
> -  - cpukit/include/dev/i2c/fpga-i2c-slave.h
> -  - cpukit/include/dev/i2c/gpio-nxp-pca9535.h
> -  - cpukit/include/dev/i2c/i2c.h
> -  - cpukit/include/dev/i2c/sensor-lm75a.h
> -  - cpukit/include/dev/i2c/switch-nxp-pca9548a.h
> -  - cpukit/include/dev/i2c/ti-ads-16bit-adc.h
> -  - cpukit/include/dev/i2c/ti-lm25066a.h
> -  - cpukit/include/dev/i2c/ti-tmp112.h
> -  - cpukit/include/dev/i2c/xilinx-axi-i2c.h
> -  source:
> -  - cpukit/include/dev/serial/sc16is752.h
> -- destination: ${BSP_INCLUDEDIR}/dev/spi
> -  source:
> -  - cpukit/include/dev/spi/spi.h
> -- destination: ${BSP_INCLUDEDIR}/dev/flash
> -  source:
> -  - cpukit/include/dev/flash/flashdev.h
> -- destination: ${BSP_INCLUDEDIR}/linux
> -  source:
> -  - cpukit/include/linux/i2c-dev.h
> -  - cpukit/include/linux/i2c.h
> -  - cpukit/include/linux/rbtree.h
> -- destination: ${BSP_INCLUDEDIR}/linux/spi
> -  source:
> -  - cpukit/include/linux/spi/spidev.h
>    source:
>    - cpukit/include/machine/_kernel_cpuset.h
> -  - cpukit/include/machine/_kernel_in.h
> -  - cpukit/include/machine/_kernel_in6.h
> -  - cpukit/include/machine/_kernel_mman.h
>    - cpukit/include/machine/_kernel_param.h
>    - cpukit/include/machine/_kernel_time.h
>    - cpukit/include/machine/_kernel_types.h
> -  - cpukit/include/machine/_kernel_uio.h
>    - cpukit/include/machine/_timecounter.h
> -  source:
> -  - cpukit/include/rtems/assoc.h
> -  - cpukit/include/rtems/bdbuf.h
> -  - cpukit/include/rtems/bdpart.h
> -  - cpukit/include/rtems/blkdev.h
> -  - cpukit/include/rtems/bsd.h
> -  - cpukit/include/rtems/bspIo.h
> -  - cpukit/include/rtems/bspcmdline.h
> -  - cpukit/include/rtems/btimer.h
> -  - cpukit/include/rtems/capture-cli.h
> -  - cpukit/include/rtems/capture.h
> -  - cpukit/include/rtems/captureimpl.h
> -  - cpukit/include/rtems/cbs.h
> -  - cpukit/include/rtems/chain.h
> -  - cpukit/include/rtems/clockdrv.h
> -  - cpukit/include/rtems/concat.h
> -  - cpukit/include/rtems/confdefs.h
> -  - cpukit/include/rtems/config.h
> -  - cpukit/include/rtems/console.h
> -  - cpukit/include/rtems/counter.h
> -  - cpukit/include/rtems/cpuuse.h
> -  - cpukit/include/rtems/deviceio.h
> -  - cpukit/include/rtems/devnull.h
> -  - cpukit/include/rtems/devzero.h
> -  - cpukit/include/rtems/diskdevs.h
> -  - cpukit/include/rtems/dosfs.h
> -  - cpukit/include/rtems/dumpbuf.h
> -  - cpukit/include/rtems/endian.h
> -  - cpukit/include/rtems/error.h
> -  - cpukit/include/rtems/extension.h
> -  - cpukit/include/rtems/extensiondata.h
> -  - cpukit/include/rtems/extensionimpl.h
> -  - cpukit/include/rtems/fatal.h
> -  - cpukit/include/rtems/fb.h
> -  - cpukit/include/rtems/flashdisk.h
> -  - cpukit/include/rtems/framebuffer.h
> -  - cpukit/include/rtems/fs.h
> -  - cpukit/include/rtems/fsmount.h
> -  - cpukit/include/rtems/ide_part_table.h
> -  - cpukit/include/rtems/imfs.h
> -  - cpukit/include/rtems/imfsimpl.h
> -  - cpukit/include/rtems/init.h
> -  - cpukit/include/rtems/inttypes.h
> -  - cpukit/include/rtems/io.h
> -  - cpukit/include/rtems/ioimpl.h
> -  - cpukit/include/rtems/iosupp.h
> -  - cpukit/include/rtems/irq-extension.h
> -  - cpukit/include/rtems/irq.h
> -  - cpukit/include/rtems/libcsupport.h
> -  - cpukit/include/rtems/libi2c.h
> -  - cpukit/include/rtems/libio.h
> -  - cpukit/include/rtems/libio_.h
> -  - cpukit/include/rtems/linkersets.h
> -  - cpukit/include/rtems/malloc.h
> -  - cpukit/include/rtems/media.h
> -  - cpukit/include/rtems/monitor.h
> -  - cpukit/include/rtems/mouse_parser.h
> -  - cpukit/include/rtems/mptables.h
> -  - cpukit/include/rtems/mw_uid.h
> -  - cpukit/include/rtems/nvdisk-sram.h
> -  - cpukit/include/rtems/nvdisk.h
> -  - cpukit/include/rtems/passwd.h
> -  - cpukit/include/rtems/pci.h
> -  - cpukit/include/rtems/pipe.h
> -  - cpukit/include/rtems/print.h
> -  - cpukit/include/rtems/printer.h
> -  - cpukit/include/rtems/profiling.h
> -  - cpukit/include/rtems/pty.h
> -  - cpukit/include/rtems/qreslib.h
> -  - cpukit/include/rtems/ramdisk.h
> -  - cpukit/include/rtems/rbheap.h
> -  - cpukit/include/rtems/rbtree.h
> -  - cpukit/include/rtems/record.h
> -  - cpukit/include/rtems/recordclient.h
> -  - cpukit/include/rtems/recorddata.h
> -  - cpukit/include/rtems/recorddump.h
> -  - cpukit/include/rtems/recordserver.h
> -  - cpukit/include/rtems/regulator.h
> -  - cpukit/include/rtems/regulatorimpl.h
> -  - cpukit/include/rtems/ringbuf.h
> -  - cpukit/include/rtems/rtc.h
> -  - cpukit/include/rtems/rtems-debugger-remote-tcp.h
> -  - cpukit/include/rtems/rtems-debugger.h
> -  - cpukit/include/rtems/rtems-fdt-shell.h
> -  - cpukit/include/rtems/rtems-fdt.h
> -  - cpukit/include/rtems/rtems-rfs-format.h
> -  - cpukit/include/rtems/rtems-rfs-shell.h
> -  - cpukit/include/rtems/rtems-rfs.h
> -  - cpukit/include/rtems/rtemsdialer.h
> -  - cpukit/include/rtems/scheduler.h
> -  - cpukit/include/rtems/serial_mouse.h
> -  - cpukit/include/rtems/seterr.h
> -  - cpukit/include/rtems/shell.h
> -  - cpukit/include/rtems/shellconfig.h
> -  - cpukit/include/rtems/sparse-disk.h
> -  - cpukit/include/rtems/spurious.h
> -  - cpukit/include/rtems/stackchk.h
> -  - cpukit/include/rtems/status-checks.h
> -  - cpukit/include/rtems/stdio-redirect.h
> -  - cpukit/include/rtems/stringto.h
> -  - cpukit/include/rtems/sysinit.h
> -  - cpukit/include/rtems/termiostypes.h
> -  - cpukit/include/rtems/termiosdevice.h
> -  - cpukit/include/rtems/thread.h
> -  - cpukit/include/rtems/timecounter.h
> -  - cpukit/include/rtems/timespec.h
> -  - cpukit/include/rtems/tm27-default.h
> -  - cpukit/include/rtems/tod.h
> -  - cpukit/include/rtems/untar.h
> -  - cpukit/include/rtems/userenv.h
> -  - cpukit/include/rtems/version.h
> -  - cpukit/include/rtems/vmeintr.h
> -  - cpukit/include/rtems/watchdogdrv.h
>  - destination: ${BSP_INCLUDEDIR}/rtems/confdefs
>    source:
>    - cpukit/include/rtems/confdefs/bdbuf.h
> @@ -215,58 +47,39 @@ install:
>    - cpukit/include/rtems/confdefs/unlimited.h
>    - cpukit/include/rtems/confdefs/wkspace.h
>    - cpukit/include/rtems/confdefs/wkspacesupport.h
> -- destination: ${BSP_INCLUDEDIR}/rtems/debugger
>    source:
> -  - cpukit/include/rtems/debugger/rtems-debugger-bsp.h
> -  - cpukit/include/rtems/debugger/rtems-debugger-remote.h
> -  - cpukit/include/rtems/debugger/rtems-debugger-server.h
> +  - cpukit/include/rtems/bspIo.h
> +  - cpukit/include/rtems/chain.h
> +  - cpukit/include/rtems/clockdrv.h
> +  - cpukit/include/rtems/confdefs.h
> +  - cpukit/include/rtems/config.h
> +  - cpukit/include/rtems/counter.h
> +  - cpukit/include/rtems/cpuuse.h
> +  - cpukit/include/rtems/extension.h
> +  - cpukit/include/rtems/extensiondata.h
> +  - cpukit/include/rtems/extensionimpl.h
> +  - cpukit/include/rtems/fatal.h
> +  - cpukit/include/rtems/init.h
> +  - cpukit/include/rtems/io.h
> +  - cpukit/include/rtems/irq-extension.h
> +  - cpukit/include/rtems/libcsupport.h
> +  - cpukit/include/rtems/linkersets.h
> +  - cpukit/include/rtems/malloc.h
> +  - cpukit/include/rtems/print.h
> +  - cpukit/include/rtems/seterr.h
> +  - cpukit/include/rtems/scheduler.h
> +  - cpukit/include/rtems/sysinit.h
> +  - cpukit/include/rtems/timecounter.h
> +  - cpukit/include/rtems/thread.h
> +  - cpukit/include/rtems/version.h
>  - destination: ${BSP_INCLUDEDIR}/rtems/dev
>    source:
>    - cpukit/include/rtems/dev/io.h
>  - destination: ${BSP_INCLUDEDIR}/rtems/posix
>    source:
> -  - cpukit/include/rtems/posix/aio_misc.h
> -  - cpukit/include/rtems/posix/barrierimpl.h
> -  - cpukit/include/rtems/posix/condimpl.h
> -  - cpukit/include/rtems/posix/key.h
> -  - cpukit/include/rtems/posix/mmanimpl.h
> -  - cpukit/include/rtems/posix/mqueue.h
> -  - cpukit/include/rtems/posix/mqueueimpl.h
> -  - cpukit/include/rtems/posix/muteximpl.h
>    - cpukit/include/rtems/posix/posixapi.h
> -  - cpukit/include/rtems/posix/priorityimpl.h
> -  - cpukit/include/rtems/posix/psignal.h
> -  - cpukit/include/rtems/posix/psignalimpl.h
> -  - cpukit/include/rtems/posix/pthread.h
> -  - cpukit/include/rtems/posix/pthreadattrimpl.h
> -  - cpukit/include/rtems/posix/pthreadimpl.h
> -  - cpukit/include/rtems/posix/rwlockimpl.h
> -  - cpukit/include/rtems/posix/semaphore.h
> -  - cpukit/include/rtems/posix/semaphoreimpl.h
> -  - cpukit/include/rtems/posix/shm.h
> -  - cpukit/include/rtems/posix/shmimpl.h
> -  - cpukit/include/rtems/posix/sigset.h
>    - cpukit/include/rtems/posix/spinlockimpl.h
> -  - cpukit/include/rtems/posix/threadsup.h
> -  - cpukit/include/rtems/posix/timer.h
> -  - cpukit/include/rtems/posix/timerimpl.h
> -- destination: ${BSP_INCLUDEDIR}/rtems/rfs
> -  source:
> -  - cpukit/include/rtems/rfs/rtems-rfs-bitmaps.h
> -  - cpukit/include/rtems/rfs/rtems-rfs-block-pos.h
> -  - cpukit/include/rtems/rfs/rtems-rfs-block.h
> -  - cpukit/include/rtems/rfs/rtems-rfs-buffer.h
> -  - cpukit/include/rtems/rfs/rtems-rfs-data.h
> -  - cpukit/include/rtems/rfs/rtems-rfs-dir-hash.h
> -  - cpukit/include/rtems/rfs/rtems-rfs-dir.h
> -  - cpukit/include/rtems/rfs/rtems-rfs-file-system-fwd.h
> -  - cpukit/include/rtems/rfs/rtems-rfs-file-system.h
> -  - cpukit/include/rtems/rfs/rtems-rfs-file.h
> -  - cpukit/include/rtems/rfs/rtems-rfs-group.h
> -  - cpukit/include/rtems/rfs/rtems-rfs-inode.h
> -  - cpukit/include/rtems/rfs/rtems-rfs-link.h
> -  - cpukit/include/rtems/rfs/rtems-rfs-mutex.h
> -  - cpukit/include/rtems/rfs/rtems-rfs-trace.h
>  - destination: ${BSP_INCLUDEDIR}/rtems/rtems
>    source:
>    - cpukit/include/rtems/rtems/asr.h
> @@ -286,15 +99,12 @@ install:
>    - cpukit/include/rtems/rtems/event.h
>    - cpukit/include/rtems/rtems/eventdata.h
>    - cpukit/include/rtems/rtems/eventimpl.h
> -  - cpukit/include/rtems/rtems/eventmp.h
>    - cpukit/include/rtems/rtems/intr.h
>    - cpukit/include/rtems/rtems/message.h
>    - cpukit/include/rtems/rtems/messagedata.h
>    - cpukit/include/rtems/rtems/messageimpl.h
>    - cpukit/include/rtems/rtems/modes.h
>    - cpukit/include/rtems/rtems/modesimpl.h
> -  - cpukit/include/rtems/rtems/mp.h
> -  - cpukit/include/rtems/rtems/msgmp.h
>    - cpukit/include/rtems/rtems/object.h
>    - cpukit/include/rtems/rtems/objectimpl.h
>    - cpukit/include/rtems/rtems/options.h
> @@ -302,7 +112,6 @@ install:
>    - cpukit/include/rtems/rtems/part.h
>    - cpukit/include/rtems/rtems/partdata.h
>    - cpukit/include/rtems/rtems/partimpl.h
> -  - cpukit/include/rtems/rtems/partmp.h
>    - cpukit/include/rtems/rtems/ratemon.h
>    - cpukit/include/rtems/rtems/ratemondata.h
>    - cpukit/include/rtems/rtems/ratemonimpl.h
> @@ -313,14 +122,11 @@ install:
>    - cpukit/include/rtems/rtems/sem.h
>    - cpukit/include/rtems/rtems/semdata.h
>    - cpukit/include/rtems/rtems/semimpl.h
> -  - cpukit/include/rtems/rtems/semmp.h
>    - cpukit/include/rtems/rtems/signal.h
>    - cpukit/include/rtems/rtems/signalimpl.h
> -  - cpukit/include/rtems/rtems/signalmp.h
>    - cpukit/include/rtems/rtems/status.h
>    - cpukit/include/rtems/rtems/statusimpl.h
>    - cpukit/include/rtems/rtems/support.h
> -  - cpukit/include/rtems/rtems/taskmp.h
>    - cpukit/include/rtems/rtems/tasks.h
>    - cpukit/include/rtems/rtems/tasksdata.h
>    - cpukit/include/rtems/rtems/tasksimpl.h
> @@ -346,11 +152,11 @@ install:
>    - cpukit/include/rtems/score/coremsgimpl.h
>    - cpukit/include/rtems/score/coremutex.h
>    - cpukit/include/rtems/score/coremuteximpl.h
> -  - cpukit/include/rtems/score/corerwlockimpl.h
>    - cpukit/include/rtems/score/coresem.h
>    - cpukit/include/rtems/score/coresemimpl.h
>    - cpukit/include/rtems/score/exception.h
>    - cpukit/include/rtems/score/freechain.h
> +  - cpukit/include/rtems/score/freechainimpl.h
>    - cpukit/include/rtems/score/hash.h
>    - cpukit/include/rtems/score/heap.h
>    - cpukit/include/rtems/score/heapimpl.h
> @@ -360,8 +166,6 @@ install:
>    - cpukit/include/rtems/score/isrlevel.h
>    - cpukit/include/rtems/score/isrlock.h
>    - cpukit/include/rtems/score/memory.h
> -  - cpukit/include/rtems/score/mpci.h
> -  - cpukit/include/rtems/score/mpciimpl.h
>    - cpukit/include/rtems/score/mppkt.h
>    - cpukit/include/rtems/score/mrsp.h
>    - cpukit/include/rtems/score/mrspimpl.h
> @@ -369,10 +173,7 @@ install:
>    - cpukit/include/rtems/score/object.h
>    - cpukit/include/rtems/score/objectdata.h
>    - cpukit/include/rtems/score/objectimpl.h
> -  - cpukit/include/rtems/score/objectmp.h
> -  - cpukit/include/rtems/score/onceimpl.h
>    - cpukit/include/rtems/score/percpu.h
> -  - cpukit/include/rtems/score/percpudata.h
>    - cpukit/include/rtems/score/priority.h
>    - cpukit/include/rtems/score/prioritybitmap.h
>    - cpukit/include/rtems/score/prioritybitmapimpl.h
> @@ -383,8 +184,6 @@ install:
>    - cpukit/include/rtems/score/rbtree.h
>    - cpukit/include/rtems/score/rbtreeimpl.h
>    - cpukit/include/rtems/score/scheduler.h
> -  - cpukit/include/rtems/score/schedulercbs.h
> -  - cpukit/include/rtems/score/schedulercbsimpl.h
>    - cpukit/include/rtems/score/scheduleredf.h
>    - cpukit/include/rtems/score/scheduleredfimpl.h
>    - cpukit/include/rtems/score/scheduleredfsmp.h
> @@ -392,16 +191,11 @@ install:
>    - cpukit/include/rtems/score/schedulernode.h
>    - cpukit/include/rtems/score/schedulernodeimpl.h
>    - cpukit/include/rtems/score/schedulerpriority.h
> -  - cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h
>    - cpukit/include/rtems/score/schedulerpriorityimpl.h
> -  - cpukit/include/rtems/score/schedulerprioritysmp.h
> -  - cpukit/include/rtems/score/schedulerprioritysmpimpl.h
>    - cpukit/include/rtems/score/schedulersimple.h
>    - cpukit/include/rtems/score/schedulersimpleimpl.h
> -  - cpukit/include/rtems/score/schedulersimplesmp.h
>    - cpukit/include/rtems/score/schedulersmp.h
>    - cpukit/include/rtems/score/schedulersmpimpl.h
> -  - cpukit/include/rtems/score/schedulerstrongapa.h
>    - cpukit/include/rtems/score/scheduleruniimpl.h
>    - cpukit/include/rtems/score/semaphoreimpl.h
>    - cpukit/include/rtems/score/smp.h
> @@ -423,7 +217,6 @@ install:
>    - cpukit/include/rtems/score/threaddispatch.h
>    - cpukit/include/rtems/score/threadidledata.h
>    - cpukit/include/rtems/score/threadimpl.h
> -  - cpukit/include/rtems/score/threadmp.h
>    - cpukit/include/rtems/score/threadq.h
>    - cpukit/include/rtems/score/threadqimpl.h
>    - cpukit/include/rtems/score/threadqops.h
> @@ -440,29 +233,17 @@ install:
>    - cpukit/include/rtems/score/watchdog.h
>    - cpukit/include/rtems/score/watchdogimpl.h
>    - cpukit/include/rtems/score/watchdogticks.h
> -  - cpukit/include/rtems/score/wkspace.h
>    - cpukit/include/rtems/score/wkspacedata.h
> -- destination: ${BSP_INCLUDEDIR}/rtems/trace
> -  source:
> -  - cpukit/include/rtems/trace/rtems-trace-buffer-vars.h
>  - destination: ${BSP_INCLUDEDIR}/sys
>    source:
> -  - cpukit/include/sys/_ffcounter.h
> -  - cpukit/include/sys/cdefs_elf.h
>    - cpukit/include/sys/endian.h
> -  - cpukit/include/sys/event.h
> -  - cpukit/include/sys/exec_elf.h
> -  - cpukit/include/sys/poll.h
> +  - cpukit/include/sys/_ffcounter.h
>    - cpukit/include/sys/priority.h
>    - cpukit/include/sys/statvfs.h
>    - cpukit/include/sys/timeffc.h
>    - cpukit/include/sys/timepps.h
>    - cpukit/include/sys/timetc.h
>    - cpukit/include/sys/timex.h
> -  - cpukit/include/sys/utsname.h
> -- destination: ${BSP_INCLUDEDIR}/uuid
> -  source:
> -  - cpukit/include/uuid/uuid.h
>  links:
> @@ -501,6 +282,8 @@ links:
>    uid: cpuv850
>    uid: cpux8664
> +  uid: objextra
>    uid: objdl
> @@ -515,6 +298,8 @@ links:
>    uid: objpci
>    uid: objpsxsgnl
> +  uid: objqual
>    uid: objshell
> @@ -524,705 +309,35 @@ links:
>    uid: vckey
>  source:
> -- cpukit/compression/xz/xz_crc32.c
> -- cpukit/compression/xz/xz_dec_lzma2.c
> -- cpukit/compression/xz/xz_dec_stream.c
> -- cpukit/dev/flash/flashdev.c
> -- cpukit/dev/i2c/eeprom.c
> -- cpukit/dev/i2c/fpga-i2c-slave.c
> -- cpukit/dev/i2c/gpio-nxp-pca9535.c
> -- cpukit/dev/i2c/i2c-bus.c
> -- cpukit/dev/i2c/i2c-dev.c
> -- cpukit/dev/i2c/sensor-lm75a.c
> -- cpukit/dev/i2c/switch-nxp-pca9548a.c
> -- cpukit/dev/i2c/ti-ads-16bit-adc.c
> -- cpukit/dev/i2c/ti-lm25066a.c
> -- cpukit/dev/i2c/ti-tmp112.c
> -- cpukit/dev/i2c/xilinx-axi-i2c.c
> -- cpukit/dev/iobase64.c
> -- cpukit/dev/ioprintf.c
>  - cpukit/dev/iorelax.c
> -- cpukit/dev/iovprintf.c
> -- cpukit/dev/serial/sc16is752-spi.c
> -- cpukit/dev/serial/sc16is752.c
> -- cpukit/dev/spi/spi-bus.c
> -- cpukit/dtc/libfdt/fdt.c
> -- cpukit/dtc/libfdt/fdt_addresses.c
> -- cpukit/dtc/libfdt/fdt_empty_tree.c
> -- cpukit/dtc/libfdt/fdt_ro.c
> -- cpukit/dtc/libfdt/fdt_rw.c
> -- cpukit/dtc/libfdt/fdt_strerror.c
> -- cpukit/dtc/libfdt/fdt_sw.c
> -- cpukit/dtc/libfdt/fdt_wip.c
> -- cpukit/libblock/src/bdbuf.c
> -- cpukit/libblock/src/bdpart-create.c
> -- cpukit/libblock/src/bdpart-dump.c
> -- cpukit/libblock/src/bdpart-read.c
> -- cpukit/libblock/src/bdpart-register.c
> -- cpukit/libblock/src/bdpart-sort.c
> -- cpukit/libblock/src/bdpart-write.c
> -- cpukit/libblock/src/blkdev-blkstats.c
> -- cpukit/libblock/src/blkdev-imfs.c
> -- cpukit/libblock/src/blkdev-ioctl.c
> -- cpukit/libblock/src/blkdev-ops.c
> -- cpukit/libblock/src/blkdev-print-stats.c
> -- cpukit/libblock/src/blkdev.c
> -- cpukit/libblock/src/diskdevs-init.c
> -- cpukit/libblock/src/diskdevs.c
> -- cpukit/libblock/src/flashdisk.c
> -- cpukit/libblock/src/ide_part_table.c
> -- cpukit/libblock/src/media-desc.c
> -- cpukit/libblock/src/media-dev-ident.c
> -- cpukit/libblock/src/media-path.c
> -- cpukit/libblock/src/media-server.c
> -- cpukit/libblock/src/media.c
> -- cpukit/libblock/src/nvdisk-sram.c
> -- cpukit/libblock/src/nvdisk.c
> -- cpukit/libblock/src/ramdisk-config.c
> -- cpukit/libblock/src/ramdisk-driver.c
> -- cpukit/libblock/src/ramdisk-init.c
> -- cpukit/libblock/src/ramdisk-register.c
> -- cpukit/libblock/src/sparse-disk.c
> -- cpukit/libcrypt/crypt-md5.c
> -- cpukit/libcrypt/crypt-sha256.c
> -- cpukit/libcrypt/crypt-sha512.c
> -- cpukit/libcrypt/crypt.c
> -- cpukit/libcrypt/misc.c
> -- cpukit/libcsupport/src/__assert.c
> -- cpukit/libcsupport/src/__getpid.c
> -- cpukit/libcsupport/src/__gettod.c
> -- cpukit/libcsupport/src/__times.c
> -- cpukit/libcsupport/src/__usrenv.c
> -- cpukit/libcsupport/src/_calloc_r.c
> -- cpukit/libcsupport/src/_free_r.c
> -- cpukit/libcsupport/src/_malloc_r.c
> -- cpukit/libcsupport/src/_realloc_r.c
> -- cpukit/libcsupport/src/_rename_r.c
> -- cpukit/libcsupport/src/access.c
> -- cpukit/libcsupport/src/alignedalloc.c
> -- cpukit/libcsupport/src/arc4random_getentropy_fail.c
> -- cpukit/libcsupport/src/assoc32tostring.c
> -- cpukit/libcsupport/src/assoclocalbyname.c
> -- cpukit/libcsupport/src/assoclocalbyremote.c
> -- cpukit/libcsupport/src/assoclocalbyremotebitfield.c
> -- cpukit/libcsupport/src/assocnamebad.c
> -- cpukit/libcsupport/src/assocnamebylocal.c
> -- cpukit/libcsupport/src/assocnamebylocalbitfield.c
> -- cpukit/libcsupport/src/assocnamebyremote.c
> -- cpukit/libcsupport/src/assocnamebyremotebitfield.c
> -- cpukit/libcsupport/src/assocptrbylocal.c
> -- cpukit/libcsupport/src/assocptrbyname.c
> -- cpukit/libcsupport/src/assocptrbyremote.c
> -- cpukit/libcsupport/src/assocremotebylocal.c
> -- cpukit/libcsupport/src/assocremotebylocalbitfield.c
> -- cpukit/libcsupport/src/assocremotebyname.c
> -- cpukit/libcsupport/src/assocthreadstatestostring.c
> -- cpukit/libcsupport/src/base_fs.c
> -- cpukit/libcsupport/src/cachealignedalloc.c
> -- cpukit/libcsupport/src/cachecoherentalloc.c
> -- cpukit/libcsupport/src/calloc.c
> -- cpukit/libcsupport/src/cfgetispeed.c
> -- cpukit/libcsupport/src/cfgetospeed.c
> -- cpukit/libcsupport/src/cfmakeraw.c
> -- cpukit/libcsupport/src/cfmakesane.c
> -- cpukit/libcsupport/src/cfsetispeed.c
> -- cpukit/libcsupport/src/cfsetospeed.c
> -- cpukit/libcsupport/src/cfsetspeed.c
> -- cpukit/libcsupport/src/chdir.c
> -- cpukit/libcsupport/src/chmod.c
> -- cpukit/libcsupport/src/chown.c
> -- cpukit/libcsupport/src/chroot.c
> -- cpukit/libcsupport/src/clock.c
> -- cpukit/libcsupport/src/clonenode.c
> -- cpukit/libcsupport/src/close.c
> -- cpukit/libcsupport/src/consolesimple.c
> -- cpukit/libcsupport/src/consolesimpleread.c
> -- cpukit/libcsupport/src/consolesimpletask.c
> -- cpukit/libcsupport/src/ctermid.c
> -- cpukit/libcsupport/src/dup.c
> -- cpukit/libcsupport/src/dup2.c
> -- cpukit/libcsupport/src/error.c
> -- cpukit/libcsupport/src/fchdir.c
> -- cpukit/libcsupport/src/fchmod.c
> -- cpukit/libcsupport/src/fchown.c
> -- cpukit/libcsupport/src/fcntl.c
> -- cpukit/libcsupport/src/fdatasync.c
> -- cpukit/libcsupport/src/flockfile.c
> -- cpukit/libcsupport/src/fpathconf.c
> -- cpukit/libcsupport/src/free.c
> -- cpukit/libcsupport/src/freenode.c
> -- cpukit/libcsupport/src/fstat.c
> -- cpukit/libcsupport/src/fsync.c
> -- cpukit/libcsupport/src/ftruncate.c
> -- cpukit/libcsupport/src/ftrylockfile.c
> -- cpukit/libcsupport/src/funlockfile.c
> -- cpukit/libcsupport/src/gcovfork.c
>  - cpukit/libcsupport/src/getchark.c
> -- cpukit/libcsupport/src/getdents.c
> -- cpukit/libcsupport/src/getegid.c
> -- cpukit/libcsupport/src/geteuid.c
> -- cpukit/libcsupport/src/getgid.c
> -- cpukit/libcsupport/src/getgrent.c
> -- cpukit/libcsupport/src/getgrnam.c
> -- cpukit/libcsupport/src/getgroups.c
> -- cpukit/libcsupport/src/getlogin.c
> -- cpukit/libcsupport/src/getpagesize.c
> -- cpukit/libcsupport/src/getpgrp.c
> -- cpukit/libcsupport/src/getpid.c
> -- cpukit/libcsupport/src/getppid.c
> -- cpukit/libcsupport/src/getpwent.c
> -- cpukit/libcsupport/src/getreentglobal.c
> -- cpukit/libcsupport/src/getrusage.c
> -- cpukit/libcsupport/src/getuid.c
> -- cpukit/libcsupport/src/ioctl.c
> -- cpukit/libcsupport/src/isatty_r.c
> -- cpukit/libcsupport/src/issetugid.c
> -- cpukit/libcsupport/src/kill_noposix.c
> -- cpukit/libcsupport/src/lchown.c
> -- cpukit/libcsupport/src/libio.c
> -- cpukit/libcsupport/src/libio_exit.c
> -- cpukit/libcsupport/src/libio_init.c
> -- cpukit/libcsupport/src/libiozeroiops.c
> -- cpukit/libcsupport/src/link.c
> -- cpukit/libcsupport/src/lseek.c
> -- cpukit/libcsupport/src/lstat.c
> -- cpukit/libcsupport/src/malloc.c
> -- cpukit/libcsupport/src/malloc_deferred.c
> -- cpukit/libcsupport/src/malloc_dirtier.c
> -- cpukit/libcsupport/src/malloc_walk.c
> -- cpukit/libcsupport/src/mallocdirtydefault.c
> -- cpukit/libcsupport/src/mallocextenddefault.c
> -- cpukit/libcsupport/src/mallocfreespace.c
> -- cpukit/libcsupport/src/mallocgetheapptr.c
> -- cpukit/libcsupport/src/mallocheap.c
> -- cpukit/libcsupport/src/mallocinfo.c
> -- cpukit/libcsupport/src/mallocsetheapptr.c
> -- cpukit/libcsupport/src/mkdir.c
> -- cpukit/libcsupport/src/mkfifo.c
> -- cpukit/libcsupport/src/mknod.c
> -- cpukit/libcsupport/src/mount-mgr.c
> -- cpukit/libcsupport/src/mount-mktgt.c
> -- cpukit/libcsupport/src/mount.c
> -- cpukit/libcsupport/src/newlibc_exit.c
> -- cpukit/libcsupport/src/newlibc_reent.c
> -- cpukit/libcsupport/src/open.c
> -- cpukit/libcsupport/src/open_dev_console.c
> -- cpukit/libcsupport/src/pathconf.c
> -- cpukit/libcsupport/src/posix_devctl.c
> -- cpukit/libcsupport/src/posix_memalign.c
> -- cpukit/libcsupport/src/print_fprintf.c
> -- cpukit/libcsupport/src/print_printf.c
> -- cpukit/libcsupport/src/printerfprintfputc.c
> -- cpukit/libcsupport/src/printertask.c
> -- cpukit/libcsupport/src/printf_plugin.c
> -- cpukit/libcsupport/src/printk.c
> -- cpukit/libcsupport/src/printk_plugin.c
> -- cpukit/libcsupport/src/privateenv.c
> -- cpukit/libcsupport/src/putk.c
> -- cpukit/libcsupport/src/pwdgrp.c
> -- cpukit/libcsupport/src/read.c
> -- cpukit/libcsupport/src/readlink.c
> -- cpukit/libcsupport/src/readv.c
> -- cpukit/libcsupport/src/realloc.c
> -- cpukit/libcsupport/src/realpath.c
> -- cpukit/libcsupport/src/resource_snapshot.c
> -- cpukit/libcsupport/src/rmdir.c
>  - cpukit/libcsupport/src/rtemscalloc.c
> -- cpukit/libcsupport/src/rtems_heap_extend.c
> -- cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c
> -- cpukit/libcsupport/src/rtems_heap_greedy.c
> -- cpukit/libcsupport/src/rtems_heap_null_extend.c
> -- cpukit/libcsupport/src/rtems_heap_sbrk_greedy.c
> -- cpukit/libcsupport/src/rtems_memalign.c
> -- cpukit/libcsupport/src/rtems_mkdir.c
>  - cpukit/libcsupport/src/rtems_put_char.c
>  - cpukit/libcsupport/src/rtems_putc.c
> -- cpukit/libcsupport/src/setegid.c
> -- cpukit/libcsupport/src/seteuid.c
> -- cpukit/libcsupport/src/setgid.c
> -- cpukit/libcsupport/src/setgroups.c
> -- cpukit/libcsupport/src/setpgid.c
> -- cpukit/libcsupport/src/setsid.c
> -- cpukit/libcsupport/src/setuid.c
> -- cpukit/libcsupport/src/stat.c
> -- cpukit/libcsupport/src/statvfs.c
> -- cpukit/libcsupport/src/sup_fs_check_permissions.c
> -- cpukit/libcsupport/src/sup_fs_deviceio.c
> -- cpukit/libcsupport/src/sup_fs_eval_path.c
> -- cpukit/libcsupport/src/sup_fs_eval_path_generic.c
> -- cpukit/libcsupport/src/sup_fs_exist_in_same_instance.c
> -- cpukit/libcsupport/src/sup_fs_location.c
> -- cpukit/libcsupport/src/sup_fs_mount_iterate.c
> -- cpukit/libcsupport/src/sup_fs_next_token.c
> -- cpukit/libcsupport/src/symlink.c
> -- cpukit/libcsupport/src/sync.c
> -- cpukit/libcsupport/src/tcdrain.c
> -- cpukit/libcsupport/src/tcflow.c
> -- cpukit/libcsupport/src/tcflush.c
> -- cpukit/libcsupport/src/tcgetattr.c
> -- cpukit/libcsupport/src/tcgetpgrp.c
> -- cpukit/libcsupport/src/tcsendbreak.c
> -- cpukit/libcsupport/src/tcsetattr.c
> -- cpukit/libcsupport/src/tcsetpgrp.c
> -- cpukit/libcsupport/src/termios.c
> -- cpukit/libcsupport/src/termios_baud2index.c
> -- cpukit/libcsupport/src/termios_baud2num.c
> -- cpukit/libcsupport/src/termios_baudtable.c
> -- cpukit/libcsupport/src/termios_num2baud.c
> -- cpukit/libcsupport/src/termios_posix_isig_handler.c
> -- cpukit/libcsupport/src/termios_setbestbaud.c
> -- cpukit/libcsupport/src/termios_setinitialbaud.c
> -- cpukit/libcsupport/src/termiosinitialize.c
> -- cpukit/libcsupport/src/truncate.c
> -- cpukit/libcsupport/src/uenvgetgroups.c
> -- cpukit/libcsupport/src/umask.c
> -- cpukit/libcsupport/src/unlink.c
> -- cpukit/libcsupport/src/unmount.c
> -- cpukit/libcsupport/src/utime.c
> -- cpukit/libcsupport/src/utimes.c
> -- cpukit/libcsupport/src/futimens.c
> -- cpukit/libcsupport/src/utimensat.c
> -- cpukit/libcsupport/src/utsname.c
> -- cpukit/libcsupport/src/vprintk.c
> -- cpukit/libcsupport/src/write.c
> -- cpukit/libcsupport/src/write_r.c
> -- cpukit/libcsupport/src/writev.c
> -- cpukit/libfs/src/defaults/default_are_nodes_equal.c
> -- cpukit/libfs/src/defaults/default_chown.c
> -- cpukit/libfs/src/defaults/default_clone.c
> -- cpukit/libfs/src/defaults/default_close.c
> -- cpukit/libfs/src/defaults/default_eval_path.c
> -- cpukit/libfs/src/defaults/default_fchmod.c
> -- cpukit/libfs/src/defaults/default_fcntl.c
> -- cpukit/libfs/src/defaults/default_freenode.c
> -- cpukit/libfs/src/defaults/default_fstat.c
> -- cpukit/libfs/src/defaults/default_fsunmount.c
> -- cpukit/libfs/src/defaults/default_fsync.c
> -- cpukit/libfs/src/defaults/default_fsync_success.c
> -- cpukit/libfs/src/defaults/default_ftruncate.c
> -- cpukit/libfs/src/defaults/default_ftruncate_directory.c
> -- cpukit/libfs/src/defaults/default_handlers.c
> -- cpukit/libfs/src/defaults/default_ioctl.c
> -- cpukit/libfs/src/defaults/default_kqfilter.c
> -- cpukit/libfs/src/defaults/default_link.c
> -- cpukit/libfs/src/defaults/default_lock_and_unlock.c
> -- cpukit/libfs/src/defaults/default_lseek.c
> -- cpukit/libfs/src/defaults/default_lseek_directory.c
> -- cpukit/libfs/src/defaults/default_lseek_file.c
> -- cpukit/libfs/src/defaults/default_mknod.c
> -- cpukit/libfs/src/defaults/default_mmap.c
> -- cpukit/libfs/src/defaults/default_mount.c
> -- cpukit/libfs/src/defaults/default_open.c
> -- cpukit/libfs/src/defaults/default_ops.c
> -- cpukit/libfs/src/defaults/default_poll.c
> -- cpukit/libfs/src/defaults/default_read.c
> -- cpukit/libfs/src/defaults/default_readlink.c
> -- cpukit/libfs/src/defaults/default_readv.c
> -- cpukit/libfs/src/defaults/default_rename.c
> -- cpukit/libfs/src/defaults/default_rmnod.c
> -- cpukit/libfs/src/defaults/default_statvfs.c
> -- cpukit/libfs/src/defaults/default_symlink.c
> -- cpukit/libfs/src/defaults/default_unmount.c
> -- cpukit/libfs/src/defaults/default_utimens.c
> -- cpukit/libfs/src/defaults/default_write.c
> -- cpukit/libfs/src/defaults/default_writev.c
> -- cpukit/libfs/src/dosfs/fat.c
> -- cpukit/libfs/src/dosfs/fat_fat_operations.c
> -- cpukit/libfs/src/dosfs/fat_file.c
> -- cpukit/libfs/src/dosfs/msdos_conv.c
> -- cpukit/libfs/src/dosfs/msdos_conv_default.c
> -- cpukit/libfs/src/dosfs/msdos_conv_utf8.c
> -- cpukit/libfs/src/dosfs/msdos_create.c
> -- cpukit/libfs/src/dosfs/msdos_dir.c
> -- cpukit/libfs/src/dosfs/msdos_eval.c
> -- cpukit/libfs/src/dosfs/msdos_file.c
> -- cpukit/libfs/src/dosfs/msdos_format.c
> -- cpukit/libfs/src/dosfs/msdos_free.c
> -- cpukit/libfs/src/dosfs/msdos_fsunmount.c
> -- cpukit/libfs/src/dosfs/msdos_handlers_dir.c
> -- cpukit/libfs/src/dosfs/msdos_handlers_file.c
> -- cpukit/libfs/src/dosfs/msdos_init.c
> -- cpukit/libfs/src/dosfs/msdos_initsupp.c
> -- cpukit/libfs/src/dosfs/msdos_misc.c
> -- cpukit/libfs/src/dosfs/msdos_mknod.c
> -- cpukit/libfs/src/dosfs/msdos_rename.c
> -- cpukit/libfs/src/dosfs/msdos_rmnod.c
> -- cpukit/libfs/src/dosfs/msdos_statvfs.c
> -- cpukit/libfs/src/imfs/deviceio.c
> -- cpukit/libfs/src/imfs/imfs_add_node.c
> -- cpukit/libfs/src/imfs/imfs_chown.c
> -- cpukit/libfs/src/imfs/imfs_config.c
> -- cpukit/libfs/src/imfs/imfs_creat.c
> -- cpukit/libfs/src/imfs/imfs_dir.c
> -- cpukit/libfs/src/imfs/imfs_dir_default.c
> -- cpukit/libfs/src/imfs/imfs_dir_minimal.c
> -- cpukit/libfs/src/imfs/imfs_eval.c
> -- cpukit/libfs/src/imfs/imfs_eval_devfs.c
> -- cpukit/libfs/src/imfs/imfs_fchmod.c
> -- cpukit/libfs/src/imfs/imfs_fifo.c
> -- cpukit/libfs/src/imfs/imfs_fsunmount.c
> -- cpukit/libfs/src/imfs/imfs_handlers_device.c
> -- cpukit/libfs/src/imfs/imfs_init.c
> -- cpukit/libfs/src/imfs/imfs_initsupp.c
> -- cpukit/libfs/src/imfs/imfs_linfile.c
> -- cpukit/libfs/src/imfs/imfs_link.c
> -- cpukit/libfs/src/imfs/imfs_load_tar.c
> -- cpukit/libfs/src/imfs/imfs_make_generic_node.c
> -- cpukit/libfs/src/imfs/imfs_make_linfile.c
> -- cpukit/libfs/src/imfs/imfs_memfile.c
> -- cpukit/libfs/src/imfs/imfs_mknod.c
> -- cpukit/libfs/src/imfs/imfs_mount.c
> -- cpukit/libfs/src/imfs/imfs_node.c
> -- cpukit/libfs/src/imfs/imfs_node_destroy_default.c
> -- cpukit/libfs/src/imfs/imfs_rename.c
> -- cpukit/libfs/src/imfs/imfs_rmnod.c
> -- cpukit/libfs/src/imfs/imfs_stat.c
> -- cpukit/libfs/src/imfs/imfs_stat_file.c
> -- cpukit/libfs/src/imfs/imfs_symlink.c
> -- cpukit/libfs/src/imfs/imfs_unmount.c
> -- cpukit/libfs/src/imfs/imfs_utimens.c
> -- cpukit/libfs/src/imfs/ioman.c
> -- cpukit/libfs/src/pipe/fifo.c
> -- cpukit/libfs/src/pipe/pipe.c
> -- cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
> -- cpukit/libfs/src/rfs/rtems-rfs-block.c
> -- cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c
> -- cpukit/libfs/src/rfs/rtems-rfs-buffer.c
> -- cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c
> -- cpukit/libfs/src/rfs/rtems-rfs-dir.c
> -- cpukit/libfs/src/rfs/rtems-rfs-file-system.c
> -- cpukit/libfs/src/rfs/rtems-rfs-file.c
> -- cpukit/libfs/src/rfs/rtems-rfs-format.c
> -- cpukit/libfs/src/rfs/rtems-rfs-group.c
> -- cpukit/libfs/src/rfs/rtems-rfs-inode.c
> -- cpukit/libfs/src/rfs/rtems-rfs-link.c
> -- cpukit/libfs/src/rfs/rtems-rfs-mutex.c
> -- cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
> -- cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
> -- cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
> -- cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c
> -- cpukit/libfs/src/rfs/rtems-rfs-rtems.c
> -- cpukit/libfs/src/rfs/rtems-rfs-shell.c
> -- cpukit/libfs/src/rfs/rtems-rfs-trace.c
> -- cpukit/libi2c/libi2c.c
> -- cpukit/libmd/md4.c
> -- cpukit/libmd/md5.c
> -- cpukit/libmd/sha256c.c
> -- cpukit/libmd/sha512c.c
> -- cpukit/libmisc/bspcmdline/bspcmdline_get.c
> -- cpukit/libmisc/bspcmdline/bspcmdline_getparam.c
> -- cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c
> -- cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c
> -- cpukit/libmisc/capture/capture-cli.c
> -- cpukit/libmisc/capture/capture.c
> -- cpukit/libmisc/capture/capture_buffer.c
> -- cpukit/libmisc/capture/capture_support.c
> -- cpukit/libmisc/capture/capture_user_extension.c
> -- cpukit/libmisc/capture/rtems-trace-buffer-default.c
> -- cpukit/libmisc/capture/rtems-trace-buffer-vars.c
> -- cpukit/libmisc/cpuuse/cpuinforeport.c
>  - cpukit/libmisc/cpuuse/cpuusagedata.c
> -- cpukit/libmisc/cpuuse/cpuusagereport.c
>  - cpukit/libmisc/cpuuse/cpuusagereset.c
> -- cpukit/libmisc/cpuuse/cpuusagetop.c
> -- cpukit/libmisc/devnull/devnull.c
> -- cpukit/libmisc/devnull/devzero.c
> -- cpukit/libmisc/dumpbuf/dumpbuf.c
> -- cpukit/libmisc/fb/mw_print.c
> -- cpukit/libmisc/fb/mw_uid.c
> -- cpukit/libmisc/fsmount/fsmount.c
> -- cpukit/libmisc/monitor/mon-command.c
> -- cpukit/libmisc/monitor/mon-config.c
> -- cpukit/libmisc/monitor/mon-driver.c
> -- cpukit/libmisc/monitor/mon-editor.c
> -- cpukit/libmisc/monitor/mon-extension.c
> -- cpukit/libmisc/monitor/mon-itask.c
> -- cpukit/libmisc/monitor/mon-manager.c
> -- cpukit/libmisc/monitor/mon-monitor.c
> -- cpukit/libmisc/monitor/mon-object.c
> -- cpukit/libmisc/monitor/mon-part.c
> -- cpukit/libmisc/monitor/mon-prmisc.c
> -- cpukit/libmisc/monitor/mon-queue.c
> -- cpukit/libmisc/monitor/mon-region.c
> -- cpukit/libmisc/monitor/mon-sema.c
> -- cpukit/libmisc/monitor/mon-server.c
> -- cpukit/libmisc/monitor/mon-symbols.c
> -- cpukit/libmisc/monitor/mon-task.c
> -- cpukit/libmisc/mouse/mouse_parser.c
> -- cpukit/libmisc/mouse/serial_mouse.c
> -- cpukit/libmisc/redirector/stdio-redirect.c
> -- cpukit/libmisc/regulator/regulator.c
> -- cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c
> -- cpukit/libmisc/rtems-fdt/rtems-fdt.c
> -- cpukit/libmisc/stackchk/check.c
> -- cpukit/libmisc/stringto/stringtodouble.c
> -- cpukit/libmisc/stringto/stringtofloat.c
> -- cpukit/libmisc/stringto/stringtoint.c
> -- cpukit/libmisc/stringto/stringtolong.c
> -- cpukit/libmisc/stringto/stringtolongdouble.c
> -- cpukit/libmisc/stringto/stringtolonglong.c
> -- cpukit/libmisc/stringto/stringtopointer.c
> -- cpukit/libmisc/stringto/stringtounsignedchar.c
> -- cpukit/libmisc/stringto/stringtounsignedint.c
> -- cpukit/libmisc/stringto/stringtounsignedlong.c
> -- cpukit/libmisc/stringto/stringtounsignedlonglong.c
> -- cpukit/libmisc/untar/untar.c
> -- cpukit/libmisc/untar/untar_tgz.c
> -- cpukit/libmisc/untar/untar_txz.c
> -- cpukit/libmisc/uuid/clear.c
> -- cpukit/libmisc/uuid/compare.c
> -- cpukit/libmisc/uuid/copy.c
> -- cpukit/libmisc/uuid/gen_uuid.c
> -- cpukit/libmisc/uuid/isnull.c
> -- cpukit/libmisc/uuid/pack.c
> -- cpukit/libmisc/uuid/parse.c
> -- cpukit/libmisc/uuid/unpack.c
> -- cpukit/libmisc/uuid/unparse.c
> -- cpukit/libmisc/uuid/uuid_time.c
> -- cpukit/libstdthreads/call_once.c
> -- cpukit/libstdthreads/cnd.c
> -- cpukit/libstdthreads/mtx.c
> -- cpukit/libstdthreads/thrd.c
> -- cpukit/libstdthreads/tss.c
> -- cpukit/libtrace/record/record-client.c
> -- cpukit/libtrace/record/record-dump-base64.c
> -- cpukit/libtrace/record/record-dump-fatal.c
> -- cpukit/libtrace/record/record-dump-zbase64.c
> -- cpukit/libtrace/record/record-dump-zfatal.c
> -- cpukit/libtrace/record/record-dump.c
> -- cpukit/libtrace/record/record-server.c
> -- cpukit/libtrace/record/record-stream-header.c
> -- cpukit/libtrace/record/record-sysinit.c
> -- cpukit/libtrace/record/record-text.c
> -- cpukit/libtrace/record/record-userext.c
> -- cpukit/libtrace/record/record-util.c
> -- cpukit/libtrace/record/record.c
> -- cpukit/posix/src/_execve.c
> -- cpukit/posix/src/aio_suspend.c
> -- cpukit/posix/src/barrierattrdestroy.c
> -- cpukit/posix/src/barrierattrgetpshared.c
> -- cpukit/posix/src/barrierattrinit.c
> -- cpukit/posix/src/barrierattrsetpshared.c
> -- cpukit/posix/src/cancel.c
> -- cpukit/posix/src/cleanuppush.c
> -- cpukit/posix/src/clockgetcpuclockid.c
> -- cpukit/posix/src/clockgetres.c
> -- cpukit/posix/src/clockgettime.c
>  - cpukit/posix/src/clocknanosleep.c
> -- cpukit/posix/src/clocksettime.c
> -- cpukit/posix/src/condattrdestroy.c
> -- cpukit/posix/src/condattrgetclock.c
> -- cpukit/posix/src/condattrgetpshared.c
> -- cpukit/posix/src/condattrinit.c
> -- cpukit/posix/src/condattrsetclock.c
> -- cpukit/posix/src/condattrsetpshared.c
> -- cpukit/posix/src/condbroadcast.c
> -- cpukit/posix/src/conddefaultattributes.c
> -- cpukit/posix/src/conddestroy.c
> -- cpukit/posix/src/condinit.c
> -- cpukit/posix/src/condsignal.c
> -- cpukit/posix/src/condsignalsupp.c
> -- cpukit/posix/src/condtimedwait.c
> -- cpukit/posix/src/condwait.c
> -- cpukit/posix/src/condwaitsupp.c
> -- cpukit/posix/src/confstr.c
> -- cpukit/posix/src/fork.c
> -- cpukit/posix/src/key.c
> -- cpukit/posix/src/keycreate.c
> -- cpukit/posix/src/keydelete.c
> -- cpukit/posix/src/keygetspecific.c
> -- cpukit/posix/src/keysetspecific.c
> -- cpukit/posix/src/keyzerokvp.c
> -- cpukit/posix/src/lio_listio.c
> -- cpukit/posix/src/mlock.c
> -- cpukit/posix/src/mlockall.c
> -- cpukit/posix/src/mmap.c
> -- cpukit/posix/src/mprotect.c
> -- cpukit/posix/src/mqueue.c
> -- cpukit/posix/src/mqueueclose.c
> -- cpukit/posix/src/mqueueconfig.c
> -- cpukit/posix/src/mqueuedeletesupp.c
> -- cpukit/posix/src/mqueuegetattr.c
> -- cpukit/posix/src/mqueueopen.c
> -- cpukit/posix/src/mqueuereceive.c
> -- cpukit/posix/src/mqueuerecvsupp.c
> -- cpukit/posix/src/mqueuesend.c
> -- cpukit/posix/src/mqueuesendsupp.c
> -- cpukit/posix/src/mqueuesetattr.c
> -- cpukit/posix/src/mqueuetimedreceive.c
> -- cpukit/posix/src/mqueuetimedsend.c
> -- cpukit/posix/src/mqueueunlink.c
> -- cpukit/posix/src/msync.c
> -- cpukit/posix/src/munlock.c
> -- cpukit/posix/src/munlockall.c
> -- cpukit/posix/src/munmap.c
> -- cpukit/posix/src/mutexattrdestroy.c
> -- cpukit/posix/src/mutexattrgetprioceiling.c
> -- cpukit/posix/src/mutexattrgetprotocol.c
> -- cpukit/posix/src/mutexattrgetpshared.c
> -- cpukit/posix/src/mutexattrgettype.c
> -- cpukit/posix/src/mutexattrinit.c
> -- cpukit/posix/src/mutexattrsetprioceiling.c
> -- cpukit/posix/src/mutexattrsetprotocol.c
> -- cpukit/posix/src/mutexattrsetpshared.c
> -- cpukit/posix/src/mutexattrsettype.c
> -- cpukit/posix/src/mutexdestroy.c
> -- cpukit/posix/src/mutexgetprioceiling.c
> -- cpukit/posix/src/mutexinit.c
> -- cpukit/posix/src/mutexlock.c
> -- cpukit/posix/src/mutexlocksupp.c
> -- cpukit/posix/src/mutexsetprioceiling.c
> -- cpukit/posix/src/mutextimedlock.c
> -- cpukit/posix/src/mutextrylock.c
> -- cpukit/posix/src/mutexunlock.c
> -- cpukit/posix/src/nanosleep.c
> -- cpukit/posix/src/pbarrierdestroy.c
> -- cpukit/posix/src/pbarrierinit.c
> -- cpukit/posix/src/pbarrierwait.c
> -- cpukit/posix/src/posix_madvise.c
> -- cpukit/posix/src/prwlockdestroy.c
> -- cpukit/posix/src/prwlockinit.c
> -- cpukit/posix/src/prwlockrdlock.c
> -- cpukit/posix/src/prwlocktimedrdlock.c
> -- cpukit/posix/src/prwlocktimedwrlock.c
> -- cpukit/posix/src/prwlocktryrdlock.c
> -- cpukit/posix/src/prwlocktrywrlock.c
> -- cpukit/posix/src/prwlockunlock.c
> -- cpukit/posix/src/prwlockwrlock.c
> -- cpukit/posix/src/psignalconfig.c
> -- cpukit/posix/src/pspindestroy.c
> -- cpukit/posix/src/pspininit.c
> -- cpukit/posix/src/pspinlock.c
> -- cpukit/posix/src/pspinunlock.c
> -- cpukit/posix/src/psxnametoid.c
> -- cpukit/posix/src/psxpriorityisvalid.c
> -- cpukit/posix/src/psxsemaphore.c
> -- cpukit/posix/src/psxsemaphoreconfig.c
> -- cpukit/posix/src/psxtimerconfig.c
> -- cpukit/posix/src/psxtransschedparam.c
> -- cpukit/posix/src/pthread.c
> -- cpukit/posix/src/pthreadatfork.c
> -- cpukit/posix/src/pthreadattrdefault.c
> -- cpukit/posix/src/pthreadattrdestroy.c
> -- cpukit/posix/src/pthreadattrgetaffinitynp.c
> -- cpukit/posix/src/pthreadattrgetdetachstate.c
> -- cpukit/posix/src/pthreadattrgetguardsize.c
> -- cpukit/posix/src/pthreadattrgetinheritsched.c
> -- cpukit/posix/src/pthreadattrgetschedparam.c
> -- cpukit/posix/src/pthreadattrgetschedpolicy.c
> -- cpukit/posix/src/pthreadattrgetscope.c
> -- cpukit/posix/src/pthreadattrgetstack.c
> -- cpukit/posix/src/pthreadattrgetstackaddr.c
> -- cpukit/posix/src/pthreadattrgetstacksize.c
> -- cpukit/posix/src/pthreadattrinit.c
> -- cpukit/posix/src/pthreadattrsetaffinitynp.c
> -- cpukit/posix/src/pthreadattrsetdetachstate.c
> -- cpukit/posix/src/pthreadattrsetguardsize.c
> -- cpukit/posix/src/pthreadattrsetinheritsched.c
> -- cpukit/posix/src/pthreadattrsetschedparam.c
> -- cpukit/posix/src/pthreadattrsetschedpolicy.c
> -- cpukit/posix/src/pthreadattrsetscope.c
> -- cpukit/posix/src/pthreadattrsetstack.c
> -- cpukit/posix/src/pthreadattrsetstackaddr.c
> -- cpukit/posix/src/pthreadattrsetstacksize.c
> -- cpukit/posix/src/pthreadconcurrency.c
> -- cpukit/posix/src/pthreadconfig.c
> -- cpukit/posix/src/pthreadcreate.c
> -- cpukit/posix/src/pthreaddetach.c
> -- cpukit/posix/src/pthreadequal.c
> -- cpukit/posix/src/pthreadexit.c
> -- cpukit/posix/src/pthreadgetaffinitynp.c
> -- cpukit/posix/src/pthreadgetattrnp.c
> -- cpukit/posix/src/pthreadgetcpuclockid.c
> -- cpukit/posix/src/pthreadgetnamenp.c
> -- cpukit/posix/src/pthreadgetschedparam.c
> -- cpukit/posix/src/pthreadinitthreads.c
> -- cpukit/posix/src/pthreadjoin.c
> -- cpukit/posix/src/pthreadonce.c
> -- cpukit/posix/src/pthreadsetaffinitynp.c
> -- cpukit/posix/src/pthreadsetnamenp.c
> -- cpukit/posix/src/pthreadsetschedparam.c
> -- cpukit/posix/src/pthreadsetschedprio.c
> -- cpukit/posix/src/rwlockattrdestroy.c
> -- cpukit/posix/src/rwlockattrgetpshared.c
> -- cpukit/posix/src/rwlockattrinit.c
> -- cpukit/posix/src/rwlockattrsetpshared.c
> -- cpukit/posix/src/sched_getparam.c
> -- cpukit/posix/src/sched_getprioritymax.c
> -- cpukit/posix/src/sched_getprioritymin.c
> -- cpukit/posix/src/sched_getscheduler.c
> -- cpukit/posix/src/sched_rr_get_interval.c
> -- cpukit/posix/src/sched_setparam.c
> -- cpukit/posix/src/sched_setscheduler.c
> -- cpukit/posix/src/sched_yield.c
> -- cpukit/posix/src/semaphoredeletesupp.c
> -- cpukit/posix/src/semclose.c
> -- cpukit/posix/src/semdestroy.c
> -- cpukit/posix/src/semgetvalue.c
> -- cpukit/posix/src/seminit.c
> -- cpukit/posix/src/semopen.c
> -- cpukit/posix/src/sempost.c
> -- cpukit/posix/src/semtimedwait.c
> -- cpukit/posix/src/semtrywait.c
> -- cpukit/posix/src/semunlink.c
> -- cpukit/posix/src/semwait.c
> -- cpukit/posix/src/setcancelstate.c
> -- cpukit/posix/src/setcanceltype.c
> -- cpukit/posix/src/shm.c
> -- cpukit/posix/src/shmconfig.c
> -- cpukit/posix/src/shmheap.c
> -- cpukit/posix/src/shmopen.c
> -- cpukit/posix/src/shmops.c
> -- cpukit/posix/src/shmunlink.c
> -- cpukit/posix/src/shmwkspace.c
> -- cpukit/posix/src/sigaddset.c
> -- cpukit/posix/src/sigdelset.c
> -- cpukit/posix/src/sigemptyset.c
> -- cpukit/posix/src/sigfillset.c
> -- cpukit/posix/src/sigismember.c
> -- cpukit/posix/src/sigprocmask.c
> -- cpukit/posix/src/sysconf.c
> -- cpukit/posix/src/testcancel.c
> -- cpukit/posix/src/vfork.c
> -- cpukit/posix/src/wait.c
> -- cpukit/posix/src/waitpid.c
>  - cpukit/rtems/src/barrier.c
>  - cpukit/rtems/src/barriercreate.c
>  - cpukit/rtems/src/barrierdelete.c
>  - cpukit/rtems/src/barrierident.c
>  - cpukit/rtems/src/barrierrelease.c
>  - cpukit/rtems/src/barrierwait.c
> -- cpukit/rtems/src/clockgetsecondssinceepoch.c
>  - cpukit/rtems/src/clockgettickssinceboot.c
>  - cpukit/rtems/src/clockgettickspersecond.c
>  - cpukit/rtems/src/clockgettod.c
> -- cpukit/rtems/src/clockgettodtimeval.c
>  - cpukit/rtems/src/clockgetuptime.c
> -- cpukit/rtems/src/clockgetuptimenanoseconds.c
> -- cpukit/rtems/src/clockgetuptimeseconds.c
> -- cpukit/rtems/src/clockgetuptimetimeval.c
>  - cpukit/rtems/src/clockset.c
> -- cpukit/rtems/src/clocktick.c
>  - cpukit/rtems/src/clocktodtoseconds.c
>  - cpukit/rtems/src/clocktodvalidate.c
>  - cpukit/rtems/src/dpmem.c
> -- cpukit/rtems/src/dpmemcreate.c
> -- cpukit/rtems/src/dpmemdelete.c
> -- cpukit/rtems/src/dpmemexternal2internal.c
> -- cpukit/rtems/src/dpmemident.c
> -- cpukit/rtems/src/dpmeminternal2external.c
>  - cpukit/rtems/src/eventreceive.c
>  - cpukit/rtems/src/eventseize.c
>  - cpukit/rtems/src/eventsend.c
>  - cpukit/rtems/src/eventsurrender.c
> -- cpukit/rtems/src/getapiconfig.c
> -- cpukit/rtems/src/intrbody.c
> -- cpukit/rtems/src/intrcatch.c
> -- cpukit/rtems/src/modes.c
>  - cpukit/rtems/src/msg.c
>  - cpukit/rtems/src/msgqbroadcast.c
>  - cpukit/rtems/src/msgqconstruct.c
> -- cpukit/rtems/src/msgqcreate.c
>  - cpukit/rtems/src/msgqdelete.c
>  - cpukit/rtems/src/msgqflush.c
>  - cpukit/rtems/src/msgqgetnumberpending.c
> @@ -1240,44 +355,14 @@ source:
>  - cpukit/rtems/src/ratemoncancel.c
>  - cpukit/rtems/src/ratemoncreate.c
>  - cpukit/rtems/src/ratemondelete.c
> -- cpukit/rtems/src/ratemongetstatistics.c
>  - cpukit/rtems/src/ratemongetstatus.c
>  - cpukit/rtems/src/ratemonident.c
>  - cpukit/rtems/src/ratemonperiod.c
> -- cpukit/rtems/src/ratemonreportstatistics.c
> -- cpukit/rtems/src/ratemonresetall.c
> -- cpukit/rtems/src/ratemonresetstatistics.c
>  - cpukit/rtems/src/ratemontimeout.c
>  - cpukit/rtems/src/region.c
> -- cpukit/rtems/src/regioncreate.c
> -- cpukit/rtems/src/regiondelete.c
> -- cpukit/rtems/src/regionextend.c
> -- cpukit/rtems/src/regiongetfreeinfo.c
> -- cpukit/rtems/src/regiongetinfo.c
> -- cpukit/rtems/src/regiongetsegment.c
> -- cpukit/rtems/src/regiongetsegmentsize.c
> -- cpukit/rtems/src/regionident.c
> -- cpukit/rtems/src/regionprocessqueue.c
> -- cpukit/rtems/src/regionresizesegment.c
> -- cpukit/rtems/src/regionreturnsegment.c
> -- cpukit/rtems/src/rtemsbuildid.c
> +- cpukit/rtems/src/rtemsnametoid.c
>  - cpukit/rtems/src/rtemsbuildname.c
>  - cpukit/rtems/src/rtemsmaxprio.c
> -- cpukit/rtems/src/rtemsnametoid.c
> -- cpukit/rtems/src/rtemsobjectapimaximumclass.c
> -- cpukit/rtems/src/rtemsobjectapiminimumclass.c
> -- cpukit/rtems/src/rtemsobjectgetapiclassname.c
> -- cpukit/rtems/src/rtemsobjectgetapiname.c
> -- cpukit/rtems/src/rtemsobjectgetclassicname.c
> -- cpukit/rtems/src/rtemsobjectgetclassinfo.c
> -- cpukit/rtems/src/rtemsobjectgetname.c
> -- cpukit/rtems/src/rtemsobjectidapimaximum.c
> -- cpukit/rtems/src/rtemsobjectidapiminimum.c
> -- cpukit/rtems/src/rtemsobjectidgetapi.c
> -- cpukit/rtems/src/rtemsobjectidgetclass.c
> -- cpukit/rtems/src/rtemsobjectidgetindex.c
> -- cpukit/rtems/src/rtemsobjectidgetnode.c
> -- cpukit/rtems/src/rtemsobjectsetname.c
>  - cpukit/rtems/src/rtemstimer.c
>  - cpukit/rtems/src/scheduleraddprocessor.c
>  - cpukit/rtems/src/schedulergetmaxprio.c
> @@ -1287,8 +372,6 @@ source:
>  - cpukit/rtems/src/schedulerident.c
>  - cpukit/rtems/src/scheduleridentbyprocessor.c
>  - cpukit/rtems/src/scheduleridentbyprocessorset.c
> -- cpukit/rtems/src/schedulermapfromposix.c
> -- cpukit/rtems/src/schedulermaptoposix.c
>  - cpukit/rtems/src/schedulerremoveprocessor.c
>  - cpukit/rtems/src/sem.c
>  - cpukit/rtems/src/semcreate.c
> @@ -1301,12 +384,11 @@ source:
>  - cpukit/rtems/src/signalcatch.c
>  - cpukit/rtems/src/signalsend.c
>  - cpukit/rtems/src/statustext.c
> -- cpukit/rtems/src/statustoerrno.c
>  - cpukit/rtems/src/systemeventreceive.c
>  - cpukit/rtems/src/systemeventsend.c
> +- cpukit/rtems/src/taskcreate.c
>  - cpukit/rtems/src/taskconstruct.c
>  - cpukit/rtems/src/taskconstructuser.c
> -- cpukit/rtems/src/taskcreate.c
>  - cpukit/rtems/src/taskdelete.c
>  - cpukit/rtems/src/taskexit.c
>  - cpukit/rtems/src/taskgetaffinity.c
> @@ -1314,7 +396,6 @@ source:
>  - cpukit/rtems/src/taskgetscheduler.c
>  - cpukit/rtems/src/taskident.c
>  - cpukit/rtems/src/taskinitdefault.c
> -- cpukit/rtems/src/taskinitusers.c
>  - cpukit/rtems/src/taskissuspended.c
>  - cpukit/rtems/src/taskiterate.c
>  - cpukit/rtems/src/taskmode.c
> @@ -1333,199 +414,69 @@ source:
>  - cpukit/rtems/src/timerdelete.c
>  - cpukit/rtems/src/timerfireafter.c
>  - cpukit/rtems/src/timerfirewhen.c
> -- cpukit/rtems/src/timergetinfo.c
>  - cpukit/rtems/src/timerident.c
>  - cpukit/rtems/src/timerreset.c
>  - cpukit/rtems/src/timerserver.c
>  - cpukit/rtems/src/timerserverfireafter.c
>  - cpukit/rtems/src/timerserverfirewhen.c
> -- cpukit/rtems/src/workspace.c
> -- cpukit/rtems/src/workspacegreedy.c
> -- cpukit/sapi/src/chainappendnotify.c
> -- cpukit/sapi/src/chaingetnotify.c
> -- cpukit/sapi/src/chaingetwait.c
> -- cpukit/sapi/src/chainprependnotify.c
> -- cpukit/sapi/src/chainprotected.c
> -- cpukit/sapi/src/cpucounterconverter.c
> -- cpukit/sapi/src/delaynano.c
> -- cpukit/sapi/src/delayticks.c
>  - cpukit/sapi/src/exinit.c
> -- cpukit/sapi/src/exshutdown.c
>  - cpukit/sapi/src/extension.c
>  - cpukit/sapi/src/extensioncreate.c
>  - cpukit/sapi/src/extensiondelete.c
>  - cpukit/sapi/src/extensionident.c
> -- cpukit/sapi/src/fatal.c
> -- cpukit/sapi/src/fatalsrctext.c
> -- cpukit/sapi/src/getbuildlabel.c
>  - cpukit/sapi/src/getconfigmax.c
> -- cpukit/sapi/src/getcopyrightnotice.c
> -- cpukit/sapi/src/getversionstring.c
> -- cpukit/sapi/src/interrtext.c
> -- cpukit/sapi/src/io.c
> -- cpukit/sapi/src/ioclose.c
> -- cpukit/sapi/src/iocontrol.c
> -- cpukit/sapi/src/iodefault.c
> -- cpukit/sapi/src/ioinitialize.c
> -- cpukit/sapi/src/ioopen.c
> -- cpukit/sapi/src/ioread.c
> -- cpukit/sapi/src/ioregisterdriver.c
> -- cpukit/sapi/src/iounregisterdriver.c
> -- cpukit/sapi/src/iowrite.c
> -- cpukit/sapi/src/panic.c
> -- cpukit/sapi/src/profilingiterate.c
> -- cpukit/sapi/src/profilingreportxml.c
> -- cpukit/sapi/src/rbheap.c
> -- cpukit/sapi/src/rbtree.c
> -- cpukit/sapi/src/rbtreefind.c
> -- cpukit/sapi/src/sapirbtreeinsert.c
> -- cpukit/sapi/src/sysinitverbose.c
> -- cpukit/sapi/src/tcsimpleinstall.c
> -- cpukit/sapi/src/version.c
>  - cpukit/score/src/allocatormutex.c
>  - cpukit/score/src/apimutexisowner.c
>  - cpukit/score/src/apimutexlock.c
>  - cpukit/score/src/apimutexunlock.c
>  - cpukit/score/src/chain.c
> -- cpukit/score/src/chainnodecount.c
> -- cpukit/score/src/condition.c
> -- cpukit/score/src/configstackspacesize.c
>  - cpukit/score/src/corebarrier.c
>  - cpukit/score/src/corebarrierwait.c
>  - cpukit/score/src/coremsg.c
>  - cpukit/score/src/coremsgbroadcast.c
>  - cpukit/score/src/coremsgclose.c
>  - cpukit/score/src/coremsgflush.c
> -- cpukit/score/src/coremsgflushwait.c
>  - cpukit/score/src/coremsginsert.c
>  - cpukit/score/src/coremsgseize.c
>  - cpukit/score/src/coremsgsubmit.c
> -- cpukit/score/src/coremsgwkspace.c
>  - cpukit/score/src/coremutexseize.c
> -- cpukit/score/src/corerwlock.c
> -- cpukit/score/src/corerwlockobtainread.c
> -- cpukit/score/src/corerwlockobtainwrite.c
> -- cpukit/score/src/corerwlockrelease.c
>  - cpukit/score/src/coresem.c
>  - cpukit/score/src/coretod.c
> -- cpukit/score/src/coretodcheck.c
>  - cpukit/score/src/coretodhookdata.c
>  - cpukit/score/src/coretodhookregister.c
>  - cpukit/score/src/coretodhookrun.c
>  - cpukit/score/src/coretodhookunregister.c
>  - cpukit/score/src/coretodset.c
> -- cpukit/score/src/debugisthreaddispatchingallowed.c
> -- cpukit/score/src/debugunreachable.c
> -- cpukit/score/src/freechain.c
>  - cpukit/score/src/futex.c
>  - cpukit/score/src/hash.c
> -- cpukit/score/src/heap.c
> -- cpukit/score/src/heapallocate.c
> -- cpukit/score/src/heapextend.c
> -- cpukit/score/src/heapfree.c
> -- cpukit/score/src/heapgetfreeinfo.c
> -- cpukit/score/src/heapgetinfo.c
> -- cpukit/score/src/heapgreedy.c
> -- cpukit/score/src/heapiterate.c
> -- cpukit/score/src/heapnoextend.c
> -- cpukit/score/src/heapresizeblock.c
> -- cpukit/score/src/heapsizeofuserarea.c
> -- cpukit/score/src/heapwalk.c
>  - cpukit/score/src/interr.c
>  - cpukit/score/src/isr.c
>  - cpukit/score/src/isrisinprogress.c
> -- cpukit/score/src/isrvectortable.c
> -- cpukit/score/src/iterateoverthreads.c
> -- cpukit/score/src/kern_ntptime.c
>  - cpukit/score/src/kern_tc.c
> -- cpukit/score/src/libatomic.c
> -- cpukit/score/src/log2table.c
>  - cpukit/score/src/memoryallocate.c
> -- cpukit/score/src/memorydirtyfreeareas.c
> -- cpukit/score/src/memoryfill.c
> -- cpukit/score/src/memorynoinit.c
> -- cpukit/score/src/memoryzerobeforeuse.c
> -- cpukit/score/src/memoryzerofreeareas.c
>  - cpukit/score/src/mutex.c
> -- cpukit/score/src/objectactivecount.c
>  - cpukit/score/src/objectallocate.c
>  - cpukit/score/src/objectallocatenone.c
>  - cpukit/score/src/objectallocatestatic.c
> -- cpukit/score/src/objectallocateunlimited.c
> -- cpukit/score/src/objectapimaximumclass.c
>  - cpukit/score/src/objectclose.c
> -- cpukit/score/src/objectextendinformation.c
> -- cpukit/score/src/objectfree.c
>  - cpukit/score/src/objectfreenothing.c
>  - cpukit/score/src/objectfreestatic.c
> -- cpukit/score/src/objectgetinfo.c
> -- cpukit/score/src/objectgetinfoid.c
>  - cpukit/score/src/objectgetlocal.c
> -- cpukit/score/src/objectgetnameasstring.c
> -- cpukit/score/src/objectgetnext.c
>  - cpukit/score/src/objectgetnoprotection.c
> -- cpukit/score/src/objectidtoname.c
>  - cpukit/score/src/objectinitializeinformation.c
> -- cpukit/score/src/objectnamespaceremove.c
>  - cpukit/score/src/objectnametoid.c
> -- cpukit/score/src/objectnametoidstring.c
> -- cpukit/score/src/objectsetname.c
> -- cpukit/score/src/objectshrinkinformation.c
> -- cpukit/score/src/once.c
>  - cpukit/score/src/percpu.c
>  - cpukit/score/src/percpuasm.c
> -- cpukit/score/src/percpudata.c
> -- cpukit/score/src/pheapallocate.c
> -- cpukit/score/src/pheapextend.c
> -- cpukit/score/src/pheapfree.c
> -- cpukit/score/src/pheapgetfreeinfo.c
> -- cpukit/score/src/pheapgetinfo.c
> -- cpukit/score/src/pheapgetsize.c
> -- cpukit/score/src/pheapwalk.c
>  - cpukit/score/src/processormaskcopy.c
> -- cpukit/score/src/profilingisrentryexit.c
> -- cpukit/score/src/rbtreeappend.c
>  - cpukit/score/src/rbtreeextract.c
>  - cpukit/score/src/rbtreeinsert.c
> -- cpukit/score/src/rbtreeiterate.c
>  - cpukit/score/src/rbtreemax.c
>  - cpukit/score/src/rbtreemin.c
> -- cpukit/score/src/rbtreenext.c
> -- cpukit/score/src/rbtreepostorder.c
> -- cpukit/score/src/rbtreeprepend.c
> -- cpukit/score/src/rbtreeprev.c
> -- cpukit/score/src/rbtreereplace.c
> -- cpukit/score/src/sched.c
>  - cpukit/score/src/scheduler.c
> -- cpukit/score/src/schedulercbs.c
> -- cpukit/score/src/schedulercbsattachthread.c
> -- cpukit/score/src/schedulercbscleanup.c
> -- cpukit/score/src/schedulercbscreateserver.c
> -- cpukit/score/src/schedulercbsdestroyserver.c
> -- cpukit/score/src/schedulercbsdetachthread.c
> -- cpukit/score/src/schedulercbsgetapprovedbudget.c
> -- cpukit/score/src/schedulercbsgetexecutiontime.c
> -- cpukit/score/src/schedulercbsgetparameters.c
> -- cpukit/score/src/schedulercbsgetremainingbudget.c
> -- cpukit/score/src/schedulercbsgetserverid.c
> -- cpukit/score/src/schedulercbsnodeinit.c
> -- cpukit/score/src/schedulercbsreleasejob.c
> -- cpukit/score/src/schedulercbssetparameters.c
> -- cpukit/score/src/schedulercbsunblock.c
>  - cpukit/score/src/schedulerdefaultmappriority.c
>  - cpukit/score/src/schedulerdefaultnodedestroy.c
> -- cpukit/score/src/schedulerdefaultnodeinit.c
>  - cpukit/score/src/schedulerdefaultreleasejob.c
> -- cpukit/score/src/schedulerdefaultschedule.c
>  - cpukit/score/src/schedulerdefaultstartidle.c
> -- cpukit/score/src/scheduleredf.c
> -- cpukit/score/src/scheduleredfblock.c
> -- cpukit/score/src/scheduleredfchangepriority.c
> -- cpukit/score/src/scheduleredfnodeinit.c
> -- cpukit/score/src/scheduleredfreleasejob.c
> -- cpukit/score/src/scheduleredfschedule.c
> -- cpukit/score/src/scheduleredfunblock.c
> -- cpukit/score/src/scheduleredfyield.c
>  - cpukit/score/src/schedulergetaffinity.c
>  - cpukit/score/src/schedulerpriority.c
>  - cpukit/score/src/schedulerpriorityblock.c
> @@ -1534,29 +485,14 @@ source:
>  - cpukit/score/src/schedulerpriorityunblock.c
>  - cpukit/score/src/schedulerpriorityyield.c
>  - cpukit/score/src/schedulersetaffinity.c
> -- cpukit/score/src/schedulersimple.c
> -- cpukit/score/src/schedulersimpleblock.c
> -- cpukit/score/src/schedulersimplechangepriority.c
> -- cpukit/score/src/schedulersimpleschedule.c
> -- cpukit/score/src/schedulersimpleunblock.c
> -- cpukit/score/src/schedulersimpleyield.c
> -- cpukit/score/src/semaphore.c
> -- cpukit/score/src/smpbarrierwait.c
> -- cpukit/score/src/stackallocator.c
>  - cpukit/score/src/stackallocatorforidle.c
> -- cpukit/score/src/stackallocatorforidlewkspace.c
> -- cpukit/score/src/stackallocatorfree.c
> -- cpukit/score/src/stackallocatorinit.c
>  - cpukit/score/src/thread.c
> -- cpukit/score/src/threadallocateunlimited.c
>  - cpukit/score/src/threadchangepriority.c
>  - cpukit/score/src/threadclearstate.c
>  - cpukit/score/src/threadcreateidle.c
>  - cpukit/score/src/threaddispatch.c
>  - cpukit/score/src/threadentryadaptoridle.c
>  - cpukit/score/src/threadentryadaptornumeric.c
> -- cpukit/score/src/threadentryadaptorpointer.c
> -- cpukit/score/src/threadexhausttimeslice.c
>  - cpukit/score/src/threadget.c
>  - cpukit/score/src/threadgetcputimeused.c
>  - cpukit/score/src/threadgetcputimeusedafterreset.c
> @@ -1565,14 +501,9 @@ source:
>  - cpukit/score/src/threadinitialize.c
>  - cpukit/score/src/threaditerate.c
>  - cpukit/score/src/threadloadenv.c
> -- cpukit/score/src/threadname.c
> -- cpukit/score/src/threadplaindispatch.c
>  - cpukit/score/src/threadq.c
>  - cpukit/score/src/threadqenqueue.c
> -- cpukit/score/src/threadqextract.c
> -- cpukit/score/src/threadqfirst.c
>  - cpukit/score/src/threadqflush.c
> -- cpukit/score/src/threadqgetnameandid.c
>  - cpukit/score/src/threadqops.c
>  - cpukit/score/src/threadqtimeout.c
>  - cpukit/score/src/threadresettimeslice.c
> @@ -1585,18 +516,7 @@ source:
>  - cpukit/score/src/threadstart.c
>  - cpukit/score/src/threadstartmultitasking.c
>  - cpukit/score/src/threadtimeout.c
> -- cpukit/score/src/threadwaitgetid.c
>  - cpukit/score/src/threadyield.c
> -- cpukit/score/src/timespecaddto.c
> -- cpukit/score/src/timespecdivide.c
> -- cpukit/score/src/timespecisnonnegative.c
> -- cpukit/score/src/timespecdividebyinteger.c
> -- cpukit/score/src/timespecfromticks.c
> -- cpukit/score/src/timespecgetasnanoseconds.c
> -- cpukit/score/src/timespecisvalid.c
> -- cpukit/score/src/timespeclessthan.c
> -- cpukit/score/src/timespecsubtract.c
> -- cpukit/score/src/timespectoticks.c
>  - cpukit/score/src/tlsallocsize.c
>  - cpukit/score/src/userext.c
>  - cpukit/score/src/userextaddset.c
> @@ -1607,12 +527,6 @@ source:
>  - cpukit/score/src/watchdogtick.c
>  - cpukit/score/src/watchdogtickssinceboot.c
>  - cpukit/score/src/watchdogtimeslicedefault.c
> -- cpukit/score/src/wkspaceallocate.c
> -- cpukit/score/src/wkspace.c
> -- cpukit/score/src/wkspacefree.c
> -- cpukit/score/src/wkspaceisunifieddefault.c
>  - cpukit/score/src/wkspacemallocinitdefault.c
> -- cpukit/score/src/wkspacemallocinitunified.c
> -- cpukit/score/src/wkstringduplicate.c
>  target: rtemscpu
>  type: build
> diff --git a/spec/build/cpukit/librtemscxx.yml
> b/spec/build/cpukit/librtemscxx.yml
> index 97d65a1599..95fec77c96 100644
> --- a/spec/build/cpukit/librtemscxx.yml
> +++ b/spec/build/cpukit/librtemscxx.yml
> @@ -8,7 +8,8 @@ cppflags: []
>  cxxflags:
>  - -std=c++17
> -enabled-by: true
> +enabled-by:
> +  not: RTEMS_QUALIFIED
>  includes: []
>  install:
> diff --git a/spec/build/cpukit/librtemsdfltcfg.yml
> b/spec/build/cpukit/librtemsdfltcfg.yml
> index 2d5722fa2c..cb6e135130 100644
> --- a/spec/build/cpukit/librtemsdfltcfg.yml
> +++ b/spec/build/cpukit/librtemsdfltcfg.yml
>  cppflags: []
>  cxxflags:
> -enabled-by: true
> +enabled-by:
>  includes: []
>  install: []
> diff --git a/spec/build/cpukit/librtemstest.yml
> b/spec/build/cpukit/librtemstest.yml
> index fbce36aace..9fe7b50b40 100644
> --- a/spec/build/cpukit/librtemstest.yml
> +++ b/spec/build/cpukit/librtemstest.yml
> @@ -16,40 +16,34 @@ install:
>    - cpukit/include/rtems/test-printer.h
>    - cpukit/include/rtems/test-scheduler.h
> -links: []
> +links:
> +- role: build-dependency
> +  uid: objtestextra
> +  uid: objtestqual
> +  uid: objtestqualsmp
>  source:
>  - cpukit/libtest/gcovdumpinfobase64.c
>  - cpukit/libtest/gcovdumpinfo.c
>  - cpukit/libtest/gcovinfoset.c
>  - cpukit/libtest/t-test-busy-tick.c
>  - cpukit/libtest/t-test-busy.c
> -- cpukit/libtest/t-test-checks-eno.c
> -- cpukit/libtest/t-test-checks-psx.c
>  - cpukit/libtest/t-test-checks.c
>  - cpukit/libtest/t-test-hash-sha256.c
>  - cpukit/libtest/t-test-interrupt.c
>  - cpukit/libtest/t-test-rtems-context.c
> -- cpukit/libtest/t-test-rtems-fds.c
> -- cpukit/libtest/t-test-rtems-heap.c
>  - cpukit/libtest/t-test-rtems-measure.c
>  - cpukit/libtest/t-test-rtems-memory.c
>  - cpukit/libtest/t-test-rtems-objs.c
> -- cpukit/libtest/t-test-rtems-posix-keys.c
>  - cpukit/libtest/t-test-rtems.c
>  - cpukit/libtest/t-test-scheduler.c
>  - cpukit/libtest/t-test-thread-switch.c
>  - cpukit/libtest/t-test-time.c
>  - cpukit/libtest/t-test.c
>  - cpukit/libtest/testbeginend.c
> -- cpukit/libtest/testbusy.c
> -- cpukit/libtest/testexit.c
> -- cpukit/libtest/testextension.c
>  - cpukit/libtest/testgcovcpufatalhalt.c
>  - cpukit/libtest/testgcovbspreset.c
>  - cpukit/libtest/testgcovdumpinfo.c
> -- cpukit/libtest/testparallel.c
> -- cpukit/libtest/testprinter.c
> -- cpukit/libtest/testrun.c
> -- cpukit/libtest/testwrappers.c
>  target: rtemstest
>  type: build
> diff --git a/spec/build/cpukit/libtelnetd.yml
> b/spec/build/cpukit/libtelnetd.yml
> index adfda2ba30..2509221d9a 100644
> --- a/spec/build/cpukit/libtelnetd.yml
> +++ b/spec/build/cpukit/libtelnetd.yml
>  cppflags: []
>  cxxflags:
> -enabled-by: true
> +enabled-by:
>  includes:
>  - cpukit/libnetworking
>  install:
> diff --git a/spec/build/cpukit/libtftpfs.yml
> b/spec/build/cpukit/libtftpfs.yml
> index c20ce2c7b7..1e68e696be 100644
> --- a/spec/build/cpukit/libtftpfs.yml
> +++ b/spec/build/cpukit/libtftpfs.yml
>  cppflags: []
>  cxxflags:
> -enabled-by: true
> +enabled-by:
>  includes:
>  install:
> diff --git a/spec/build/cpukit/libz.yml b/spec/build/cpukit/libz.yml
> index 86b261957d..d2627e679f 100644
> --- a/spec/build/cpukit/libz.yml
> +++ b/spec/build/cpukit/libz.yml
>  cppflags: []
>  cxxflags:
>  - ${COVERAGE_COMPILER_FLAGS}
> -enabled-by: true
> +enabled-by:
>  includes: []
>  install:
> diff --git a/spec/build/cpukit/objdrvmgr.yml
> b/spec/build/cpukit/objdrvmgr.yml
> index aeacbf989b..34311d11e0 100644
> --- a/spec/build/cpukit/objdrvmgr.yml
> +++ b/spec/build/cpukit/objdrvmgr.yml
> @@ -6,8 +6,11 @@ copyrights:
>  cppflags: []
>  cxxflags: []
>  enabled-by:
> -- riscv
> -- sparc
> +  and:
> +  - or:
> +    - riscv
> +    - sparc
> +  - not: RTEMS_QUALIFIED
>  includes: []
>  install:
>  - destination: ${BSP_INCLUDEDIR}/drvmgr
> diff --git a/spec/build/cpukit/objextra.yml
> b/spec/build/cpukit/objextra.yml
> new file mode 100644
> index 0000000000..0b6b47b4a0
> --- /dev/null
> +++ b/spec/build/cpukit/objextra.yml
> @@ -0,0 +1,1126 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +build-type: objects
> +cflags: []
> +copyrights:
> +- Copyright (C) 2020 embedded brains GmbH & Co. KG
> +cppflags: []
> +cxxflags: []
> +enabled-by:
> +includes: []
> +install:
> +- destination: ${BSP_INCLUDEDIR}
> +  source:
> +  - cpukit/include/aio.h
> +  - cpukit/include/crypt.h
> +  - cpukit/include/dlfcn.h
> +  - cpukit/include/endian.h
> +  - cpukit/include/fdt.h
> +  - cpukit/include/libfdt.h
> +  - cpukit/include/libfdt_env.h
> +  - cpukit/include/link.h
> +  - cpukit/include/link_elf.h
> +  - cpukit/include/md4.h
> +  - cpukit/include/md5.h
> +  - cpukit/include/memory.h
> +  - cpukit/include/mqueue.h
> +  - cpukit/include/poll.h
> +  - cpukit/include/sha384.h
> +  - cpukit/include/sha512.h
> +  - cpukit/include/sha512t.h
> +  - cpukit/include/xz.h
> +- destination: ${BSP_INCLUDEDIR}/arpa
> +  source:
> +  - cpukit/include/arpa/ftp.h
> +- destination: ${BSP_INCLUDEDIR}/dev/i2c
> +  source:
> +  - cpukit/include/dev/i2c/eeprom.h
> +  - cpukit/include/dev/i2c/fpga-i2c-slave.h
> +  - cpukit/include/dev/i2c/gpio-nxp-pca9535.h
> +  - cpukit/include/dev/i2c/i2c.h
> +  - cpukit/include/dev/i2c/sensor-lm75a.h
> +  - cpukit/include/dev/i2c/switch-nxp-pca9548a.h
> +  - cpukit/include/dev/i2c/ti-ads-16bit-adc.h
> +  - cpukit/include/dev/i2c/ti-lm25066a.h
> +  - cpukit/include/dev/i2c/ti-tmp112.h
> +  - cpukit/include/dev/i2c/xilinx-axi-i2c.h
> +- destination: ${BSP_INCLUDEDIR}/dev/serial
> +  source:
> +  - cpukit/include/dev/serial/sc16is752.h
> +- destination: ${BSP_INCLUDEDIR}/dev/spi
> +  source:
> +  - cpukit/include/dev/spi/spi.h
> +- destination: ${BSP_INCLUDEDIR}/dev/flash
> +  source:
> +  - cpukit/include/dev/flash/flashdev.h
> +- destination: ${BSP_INCLUDEDIR}/linux
> +  source:
> +  - cpukit/include/linux/i2c-dev.h
> +  - cpukit/include/linux/i2c.h
> +  - cpukit/include/linux/rbtree.h
> +- destination: ${BSP_INCLUDEDIR}/linux/spi
> +  source:
> +  - cpukit/include/linux/spi/spidev.h
> +- destination: ${BSP_INCLUDEDIR}/machine
> +  source:
> +  - cpukit/include/machine/_kernel_in.h
> +  - cpukit/include/machine/_kernel_in6.h
> +  - cpukit/include/machine/_kernel_mman.h
> +  - cpukit/include/machine/_kernel_uio.h
> +- destination: ${BSP_INCLUDEDIR}/rtems
> +  source:
> +  - cpukit/include/rtems/assoc.h
> +  - cpukit/include/rtems/bdbuf.h
> +  - cpukit/include/rtems/bdpart.h
> +  - cpukit/include/rtems/blkdev.h
> +  - cpukit/include/rtems/bsd.h
> +  - cpukit/include/rtems/bspcmdline.h
> +  - cpukit/include/rtems/btimer.h
> +  - cpukit/include/rtems/capture-cli.h
> +  - cpukit/include/rtems/capture.h
> +  - cpukit/include/rtems/captureimpl.h
> +  - cpukit/include/rtems/cbs.h
> +  - cpukit/include/rtems/concat.h
> +  - cpukit/include/rtems/console.h
> +  - cpukit/include/rtems/deviceio.h
> +  - cpukit/include/rtems/devnull.h
> +  - cpukit/include/rtems/devzero.h
> +  - cpukit/include/rtems/diskdevs.h
> +  - cpukit/include/rtems/dosfs.h
> +  - cpukit/include/rtems/dumpbuf.h
> +  - cpukit/include/rtems/endian.h
> +  - cpukit/include/rtems/error.h
> +  - cpukit/include/rtems/fb.h
> +  - cpukit/include/rtems/flashdisk.h
> +  - cpukit/include/rtems/framebuffer.h
> +  - cpukit/include/rtems/fs.h
> +  - cpukit/include/rtems/fsmount.h
> +  - cpukit/include/rtems/ide_part_table.h
> +  - cpukit/include/rtems/imfs.h
> +  - cpukit/include/rtems/imfsimpl.h
> +  - cpukit/include/rtems/inttypes.h
> +  - cpukit/include/rtems/ioimpl.h
> +  - cpukit/include/rtems/iosupp.h
> +  - cpukit/include/rtems/irq.h
> +  - cpukit/include/rtems/libi2c.h
> +  - cpukit/include/rtems/libio_.h
> +  - cpukit/include/rtems/libio.h
> +  - cpukit/include/rtems/mallocinitone.h
> +  - cpukit/include/rtems/media.h
> +  - cpukit/include/rtems/monitor.h
> +  - cpukit/include/rtems/mouse_parser.h
> +  - cpukit/include/rtems/mptables.h
> +  - cpukit/include/rtems/mw_uid.h
> +  - cpukit/include/rtems/nvdisk-sram.h
> +  - cpukit/include/rtems/nvdisk.h
> +  - cpukit/include/rtems/passwd.h
> +  - cpukit/include/rtems/pci.h
> +  - cpukit/include/rtems/pipe.h
> +  - cpukit/include/rtems/printer.h
> +  - cpukit/include/rtems/profiling.h
> +  - cpukit/include/rtems/pty.h
> +  - cpukit/include/rtems/qreslib.h
> +  - cpukit/include/rtems/ramdisk.h
> +  - cpukit/include/rtems/rbheap.h
> +  - cpukit/include/rtems/rbtree.h
> +  - cpukit/include/rtems/record.h
> +  - cpukit/include/rtems/recordclient.h
> +  - cpukit/include/rtems/recorddata.h
> +  - cpukit/include/rtems/recorddump.h
> +  - cpukit/include/rtems/recordserver.h
> +  - cpukit/include/rtems/regulator.h
> +  - cpukit/include/rtems/regulatorimpl.h
> +  - cpukit/include/rtems/ringbuf.h
> +  - cpukit/include/rtems/rtc.h
> +  - cpukit/include/rtems/rtems-debugger-remote-tcp.h
> +  - cpukit/include/rtems/rtems-debugger.h
> +  - cpukit/include/rtems/rtems-fdt-shell.h
> +  - cpukit/include/rtems/rtems-fdt.h
> +  - cpukit/include/rtems/rtems-rfs-format.h
> +  - cpukit/include/rtems/rtems-rfs-shell.h
> +  - cpukit/include/rtems/rtems-rfs.h
> +  - cpukit/include/rtems/rtemsdialer.h
> +  - cpukit/include/rtems/serial_mouse.h
> +  - cpukit/include/rtems/shell.h
> +  - cpukit/include/rtems/shellconfig.h
> +  - cpukit/include/rtems/sparse-disk.h
> +  - cpukit/include/rtems/spurious.h
> +  - cpukit/include/rtems/stackchk.h
> +  - cpukit/include/rtems/status-checks.h
> +  - cpukit/include/rtems/stdio-redirect.h
> +  - cpukit/include/rtems/stringto.h
> +  - cpukit/include/rtems/termiostypes.h
> +  - cpukit/include/rtems/termiosdevice.h
> +  - cpukit/include/rtems/timespec.h
> +  - cpukit/include/rtems/tm27-default.h
> +  - cpukit/include/rtems/tod.h
> +  - cpukit/include/rtems/untar.h
> +  - cpukit/include/rtems/userenv.h
> +  - cpukit/include/rtems/vmeintr.h
> +  - cpukit/include/rtems/watchdogdrv.h
> +- destination: ${BSP_INCLUDEDIR}/rtems/debugger
> +  source:
> +  - cpukit/include/rtems/debugger/rtems-debugger-bsp.h
> +  - cpukit/include/rtems/debugger/rtems-debugger-remote.h
> +  - cpukit/include/rtems/debugger/rtems-debugger-server.h
> +- destination: ${BSP_INCLUDEDIR}/rtems/posix
> +  source:
> +  - cpukit/include/rtems/posix/aio_misc.h
> +  - cpukit/include/rtems/posix/barrierimpl.h
> +  - cpukit/include/rtems/posix/condimpl.h
> +  - cpukit/include/rtems/posix/key.h
> +  - cpukit/include/rtems/posix/keyimpl.h
> +  - cpukit/include/rtems/posix/mmanimpl.h
> +  - cpukit/include/rtems/posix/mqueue.h
> +  - cpukit/include/rtems/posix/mqueueimpl.h
> +  - cpukit/include/rtems/posix/muteximpl.h
> +  - cpukit/include/rtems/posix/priorityimpl.h
> +  - cpukit/include/rtems/posix/psignal.h
> +  - cpukit/include/rtems/posix/psignalimpl.h
> +  - cpukit/include/rtems/posix/pthread.h
> +  - cpukit/include/rtems/posix/pthreadattrimpl.h
> +  - cpukit/include/rtems/posix/pthreadimpl.h
> +  - cpukit/include/rtems/posix/rwlockimpl.h
> +  - cpukit/include/rtems/posix/semaphore.h
> +  - cpukit/include/rtems/posix/semaphoreimpl.h
> +  - cpukit/include/rtems/posix/shm.h
> +  - cpukit/include/rtems/posix/shmimpl.h
> +  - cpukit/include/rtems/posix/sigset.h
> +  - cpukit/include/rtems/posix/threadsup.h
> +  - cpukit/include/rtems/posix/timer.h
> +  - cpukit/include/rtems/posix/timerimpl.h
> +- destination: ${BSP_INCLUDEDIR}/rtems/rfs
> +  source:
> +  - cpukit/include/rtems/rfs/rtems-rfs-bitmaps.h
> +  - cpukit/include/rtems/rfs/rtems-rfs-block-pos.h
> +  - cpukit/include/rtems/rfs/rtems-rfs-block.h
> +  - cpukit/include/rtems/rfs/rtems-rfs-buffer.h
> +  - cpukit/include/rtems/rfs/rtems-rfs-data.h
> +  - cpukit/include/rtems/rfs/rtems-rfs-dir-hash.h
> +  - cpukit/include/rtems/rfs/rtems-rfs-dir.h
> +  - cpukit/include/rtems/rfs/rtems-rfs-file-system-fwd.h
> +  - cpukit/include/rtems/rfs/rtems-rfs-file-system.h
> +  - cpukit/include/rtems/rfs/rtems-rfs-file.h
> +  - cpukit/include/rtems/rfs/rtems-rfs-group.h
> +  - cpukit/include/rtems/rfs/rtems-rfs-inode.h
> +  - cpukit/include/rtems/rfs/rtems-rfs-link.h
> +  - cpukit/include/rtems/rfs/rtems-rfs-mutex.h
> +  - cpukit/include/rtems/rfs/rtems-rfs-trace.h
> +- destination: ${BSP_INCLUDEDIR}/rtems/rtems
> +  source:
> +  - cpukit/include/rtems/rtems/eventmp.h
> +  - cpukit/include/rtems/rtems/mp.h
> +  - cpukit/include/rtems/rtems/msgmp.h
> +  - cpukit/include/rtems/rtems/partmp.h
> +  - cpukit/include/rtems/rtems/semmp.h
> +  - cpukit/include/rtems/rtems/signalmp.h
> +  - cpukit/include/rtems/rtems/taskmp.h
> +- destination: ${BSP_INCLUDEDIR}/rtems/score
> +  source:
> +  - cpukit/include/rtems/score/corerwlockimpl.h
> +  - cpukit/include/rtems/score/mpci.h
> +  - cpukit/include/rtems/score/mpciimpl.h
> +  - cpukit/include/rtems/score/objectmp.h
> +  - cpukit/include/rtems/score/onceimpl.h
> +  - cpukit/include/rtems/score/percpudata.h
> +  - cpukit/include/rtems/score/schedulercbs.h
> +  - cpukit/include/rtems/score/schedulercbsimpl.h
> +  - cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h
> +  - cpukit/include/rtems/score/schedulerprioritysmp.h
> +  - cpukit/include/rtems/score/schedulerprioritysmpimpl.h
> +  - cpukit/include/rtems/score/schedulersimplesmp.h
> +  - cpukit/include/rtems/score/schedulerstrongapa.h
> +  - cpukit/include/rtems/score/threadmp.h
> +  - cpukit/include/rtems/score/wkspace.h
> +  - cpukit/include/rtems/score/wkspaceinitone.h
> +- destination: ${BSP_INCLUDEDIR}/rtems/trace
> +  source:
> +  - cpukit/include/rtems/trace/rtems-trace-buffer-vars.h
> +- destination: ${BSP_INCLUDEDIR}/sys
> +  source:
> +  - cpukit/include/sys/cdefs_elf.h
> +  - cpukit/include/sys/event.h
> +  - cpukit/include/sys/exec_elf.h
> +  - cpukit/include/sys/poll.h
> +  - cpukit/include/sys/utsname.h
> +- destination: ${BSP_INCLUDEDIR}/uuid
> +  source:
> +  - cpukit/include/uuid/uuid.h
> +links: []
> +source:
> +- cpukit/compression/xz/xz_crc32.c
> +- cpukit/compression/xz/xz_dec_lzma2.c
> +- cpukit/compression/xz/xz_dec_stream.c
> +- cpukit/dev/flash/flashdev.c
> +- cpukit/dev/i2c/eeprom.c
> +- cpukit/dev/i2c/fpga-i2c-slave.c
> +- cpukit/dev/i2c/gpio-nxp-pca9535.c
> +- cpukit/dev/i2c/i2c-bus.c
> +- cpukit/dev/i2c/i2c-dev.c
> +- cpukit/dev/i2c/sensor-lm75a.c
> +- cpukit/dev/i2c/switch-nxp-pca9548a.c
> +- cpukit/dev/i2c/ti-ads-16bit-adc.c
> +- cpukit/dev/i2c/ti-lm25066a.c
> +- cpukit/dev/i2c/ti-tmp112.c
> +- cpukit/dev/i2c/xilinx-axi-i2c.c
> +- cpukit/dev/iobase64.c
> +- cpukit/dev/ioprintf.c
> +- cpukit/dev/iovprintf.c
> +- cpukit/dev/serial/sc16is752-spi.c
> +- cpukit/dev/serial/sc16is752.c
> +- cpukit/dev/spi/spi-bus.c
> +- cpukit/dtc/libfdt/fdt.c
> +- cpukit/dtc/libfdt/fdt_addresses.c
> +- cpukit/dtc/libfdt/fdt_empty_tree.c
> +- cpukit/dtc/libfdt/fdt_ro.c
> +- cpukit/dtc/libfdt/fdt_rw.c
> +- cpukit/dtc/libfdt/fdt_strerror.c
> +- cpukit/dtc/libfdt/fdt_sw.c
> +- cpukit/dtc/libfdt/fdt_wip.c
> +- cpukit/libblock/src/bdbuf.c
> +- cpukit/libblock/src/bdpart-create.c
> +- cpukit/libblock/src/bdpart-dump.c
> +- cpukit/libblock/src/bdpart-read.c
> +- cpukit/libblock/src/bdpart-register.c
> +- cpukit/libblock/src/bdpart-sort.c
> +- cpukit/libblock/src/bdpart-write.c
> +- cpukit/libblock/src/blkdev-blkstats.c
> +- cpukit/libblock/src/blkdev-imfs.c
> +- cpukit/libblock/src/blkdev-ioctl.c
> +- cpukit/libblock/src/blkdev-ops.c
> +- cpukit/libblock/src/blkdev-print-stats.c
> +- cpukit/libblock/src/blkdev.c
> +- cpukit/libblock/src/diskdevs-init.c
> +- cpukit/libblock/src/diskdevs.c
> +- cpukit/libblock/src/flashdisk.c
> +- cpukit/libblock/src/ide_part_table.c
> +- cpukit/libblock/src/media-desc.c
> +- cpukit/libblock/src/media-dev-ident.c
> +- cpukit/libblock/src/media-path.c
> +- cpukit/libblock/src/media-server.c
> +- cpukit/libblock/src/media.c
> +- cpukit/libblock/src/nvdisk-sram.c
> +- cpukit/libblock/src/nvdisk.c
> +- cpukit/libblock/src/ramdisk-config.c
> +- cpukit/libblock/src/ramdisk-driver.c
> +- cpukit/libblock/src/ramdisk-init.c
> +- cpukit/libblock/src/ramdisk-register.c
> +- cpukit/libblock/src/sparse-disk.c
> +- cpukit/libcrypt/crypt-md5.c
> +- cpukit/libcrypt/crypt-sha256.c
> +- cpukit/libcrypt/crypt-sha512.c
> +- cpukit/libcrypt/crypt.c
> +- cpukit/libcrypt/misc.c
> +- cpukit/libcsupport/src/__assert.c
> +- cpukit/libcsupport/src/__getpid.c
> +- cpukit/libcsupport/src/__gettod.c
> +- cpukit/libcsupport/src/__times.c
> +- cpukit/libcsupport/src/__usrenv.c
> +- cpukit/libcsupport/src/_calloc_r.c
> +- cpukit/libcsupport/src/_free_r.c
> +- cpukit/libcsupport/src/_malloc_r.c
> +- cpukit/libcsupport/src/_realloc_r.c
> +- cpukit/libcsupport/src/_rename_r.c
> +- cpukit/libcsupport/src/access.c
> +- cpukit/libcsupport/src/alignedalloc.c
> +- cpukit/libcsupport/src/arc4random_getentropy_fail.c
> +- cpukit/libcsupport/src/assoc32tostring.c
> +- cpukit/libcsupport/src/assoclocalbyname.c
> +- cpukit/libcsupport/src/assoclocalbyremote.c
> +- cpukit/libcsupport/src/assoclocalbyremotebitfield.c
> +- cpukit/libcsupport/src/assocnamebad.c
> +- cpukit/libcsupport/src/assocnamebylocal.c
> +- cpukit/libcsupport/src/assocnamebylocalbitfield.c
> +- cpukit/libcsupport/src/assocnamebyremote.c
> +- cpukit/libcsupport/src/assocnamebyremotebitfield.c
> +- cpukit/libcsupport/src/assocptrbylocal.c
> +- cpukit/libcsupport/src/assocptrbyname.c
> +- cpukit/libcsupport/src/assocptrbyremote.c
> +- cpukit/libcsupport/src/assocremotebylocal.c
> +- cpukit/libcsupport/src/assocremotebylocalbitfield.c
> +- cpukit/libcsupport/src/assocremotebyname.c
> +- cpukit/libcsupport/src/assocthreadstatestostring.c
> +- cpukit/libcsupport/src/base_fs.c
> +- cpukit/libcsupport/src/cachealignedalloc.c
> +- cpukit/libcsupport/src/cachecoherentalloc.c
> +- cpukit/libcsupport/src/calloc.c
> +- cpukit/libcsupport/src/cfgetispeed.c
> +- cpukit/libcsupport/src/cfgetospeed.c
> +- cpukit/libcsupport/src/cfmakeraw.c
> +- cpukit/libcsupport/src/cfmakesane.c
> +- cpukit/libcsupport/src/cfsetispeed.c
> +- cpukit/libcsupport/src/cfsetospeed.c
> +- cpukit/libcsupport/src/cfsetspeed.c
> +- cpukit/libcsupport/src/chdir.c
> +- cpukit/libcsupport/src/chmod.c
> +- cpukit/libcsupport/src/chown.c
> +- cpukit/libcsupport/src/chroot.c
> +- cpukit/libcsupport/src/clock.c
> +- cpukit/libcsupport/src/clonenode.c
> +- cpukit/libcsupport/src/close.c
> +- cpukit/libcsupport/src/consolesimple.c
> +- cpukit/libcsupport/src/consolesimpleread.c
> +- cpukit/libcsupport/src/consolesimpletask.c
> +- cpukit/libcsupport/src/ctermid.c
> +- cpukit/libcsupport/src/dup.c
> +- cpukit/libcsupport/src/dup2.c
> +- cpukit/libcsupport/src/error.c
> +- cpukit/libcsupport/src/fchdir.c
> +- cpukit/libcsupport/src/fchmod.c
> +- cpukit/libcsupport/src/fchown.c
> +- cpukit/libcsupport/src/fcntl.c
> +- cpukit/libcsupport/src/fdatasync.c
> +- cpukit/libcsupport/src/flockfile.c
> +- cpukit/libcsupport/src/fpathconf.c
> +- cpukit/libcsupport/src/free.c
> +- cpukit/libcsupport/src/freenode.c
> +- cpukit/libcsupport/src/fstat.c
> +- cpukit/libcsupport/src/fsync.c
> +- cpukit/libcsupport/src/ftruncate.c
> +- cpukit/libcsupport/src/ftrylockfile.c
> +- cpukit/libcsupport/src/funlockfile.c
> +- cpukit/libcsupport/src/futimens.c
> +- cpukit/libcsupport/src/gcovfork.c
> +- cpukit/libcsupport/src/getdents.c
> +- cpukit/libcsupport/src/getegid.c
> +- cpukit/libcsupport/src/geteuid.c
> +- cpukit/libcsupport/src/getgid.c
> +- cpukit/libcsupport/src/getgrent.c
> +- cpukit/libcsupport/src/getgrnam.c
> +- cpukit/libcsupport/src/getgroups.c
> +- cpukit/libcsupport/src/getlogin.c
> +- cpukit/libcsupport/src/getpagesize.c
> +- cpukit/libcsupport/src/getpgrp.c
> +- cpukit/libcsupport/src/getpid.c
> +- cpukit/libcsupport/src/getppid.c
> +- cpukit/libcsupport/src/getpwent.c
> +- cpukit/libcsupport/src/getreentglobal.c
> +- cpukit/libcsupport/src/getrusage.c
> +- cpukit/libcsupport/src/getuid.c
> +- cpukit/libcsupport/src/ioctl.c
> +- cpukit/libcsupport/src/isatty_r.c
> +- cpukit/libcsupport/src/issetugid.c
> +- cpukit/libcsupport/src/kill_noposix.c
> +- cpukit/libcsupport/src/lchown.c
> +- cpukit/libcsupport/src/libio.c
> +- cpukit/libcsupport/src/libio_exit.c
> +- cpukit/libcsupport/src/libio_init.c
> +- cpukit/libcsupport/src/libiozeroiops.c
> +- cpukit/libcsupport/src/link.c
> +- cpukit/libcsupport/src/lseek.c
> +- cpukit/libcsupport/src/lstat.c
> +- cpukit/libcsupport/src/malloc.c
> +- cpukit/libcsupport/src/malloc_deferred.c
> +- cpukit/libcsupport/src/malloc_dirtier.c
> +- cpukit/libcsupport/src/malloc_walk.c
> +- cpukit/libcsupport/src/mallocdirtydefault.c
> +- cpukit/libcsupport/src/mallocextenddefault.c
> +- cpukit/libcsupport/src/mallocfreespace.c
> +- cpukit/libcsupport/src/mallocgetheapptr.c
> +- cpukit/libcsupport/src/mallocheap.c
> +- cpukit/libcsupport/src/mallocinfo.c
> +- cpukit/libcsupport/src/mallocsetheapptr.c
> +- cpukit/libcsupport/src/mkdir.c
> +- cpukit/libcsupport/src/mkfifo.c
> +- cpukit/libcsupport/src/mknod.c
> +- cpukit/libcsupport/src/mount-mgr.c
> +- cpukit/libcsupport/src/mount-mktgt.c
> +- cpukit/libcsupport/src/mount.c
> +- cpukit/libcsupport/src/newlibc_exit.c
> +- cpukit/libcsupport/src/newlibc_reent.c
> +- cpukit/libcsupport/src/open.c
> +- cpukit/libcsupport/src/open_dev_console.c
> +- cpukit/libcsupport/src/pathconf.c
> +- cpukit/libcsupport/src/posix_devctl.c
> +- cpukit/libcsupport/src/posix_memalign.c
> +- cpukit/libcsupport/src/print_fprintf.c
> +- cpukit/libcsupport/src/print_printf.c
> +- cpukit/libcsupport/src/printerfprintfputc.c
> +- cpukit/libcsupport/src/printertask.c
> +- cpukit/libcsupport/src/printf_plugin.c
> +- cpukit/libcsupport/src/printk.c
> +- cpukit/libcsupport/src/printk_plugin.c
> +- cpukit/libcsupport/src/privateenv.c
> +- cpukit/libcsupport/src/putk.c
> +- cpukit/libcsupport/src/pwdgrp.c
> +- cpukit/libcsupport/src/read.c
> +- cpukit/libcsupport/src/readlink.c
> +- cpukit/libcsupport/src/readv.c
> +- cpukit/libcsupport/src/realloc.c
> +- cpukit/libcsupport/src/realpath.c
> +- cpukit/libcsupport/src/resource_snapshot.c
> +- cpukit/libcsupport/src/rmdir.c
> +- cpukit/libcsupport/src/rtems_heap_extend.c
> +- cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c
> +- cpukit/libcsupport/src/rtems_heap_greedy.c
> +- cpukit/libcsupport/src/rtems_heap_null_extend.c
> +- cpukit/libcsupport/src/rtems_heap_sbrk_greedy.c
> +- cpukit/libcsupport/src/rtems_memalign.c
> +- cpukit/libcsupport/src/rtems_mkdir.c
> +- cpukit/libcsupport/src/setegid.c
> +- cpukit/libcsupport/src/seteuid.c
> +- cpukit/libcsupport/src/setgid.c
> +- cpukit/libcsupport/src/setgroups.c
> +- cpukit/libcsupport/src/setpgid.c
> +- cpukit/libcsupport/src/setsid.c
> +- cpukit/libcsupport/src/setuid.c
> +- cpukit/libcsupport/src/stat.c
> +- cpukit/libcsupport/src/statvfs.c
> +- cpukit/libcsupport/src/sup_fs_check_permissions.c
> +- cpukit/libcsupport/src/sup_fs_deviceio.c
> +- cpukit/libcsupport/src/sup_fs_eval_path.c
> +- cpukit/libcsupport/src/sup_fs_eval_path_generic.c
> +- cpukit/libcsupport/src/sup_fs_exist_in_same_instance.c
> +- cpukit/libcsupport/src/sup_fs_location.c
> +- cpukit/libcsupport/src/sup_fs_mount_iterate.c
> +- cpukit/libcsupport/src/sup_fs_next_token.c
> +- cpukit/libcsupport/src/symlink.c
> +- cpukit/libcsupport/src/sync.c
> +- cpukit/libcsupport/src/tcdrain.c
> +- cpukit/libcsupport/src/tcflow.c
> +- cpukit/libcsupport/src/tcflush.c
> +- cpukit/libcsupport/src/tcgetattr.c
> +- cpukit/libcsupport/src/tcgetpgrp.c
> +- cpukit/libcsupport/src/tcsendbreak.c
> +- cpukit/libcsupport/src/tcsetattr.c
> +- cpukit/libcsupport/src/tcsetpgrp.c
> +- cpukit/libcsupport/src/termios.c
> +- cpukit/libcsupport/src/termios_baud2index.c
> +- cpukit/libcsupport/src/termios_baud2num.c
> +- cpukit/libcsupport/src/termios_baudtable.c
> +- cpukit/libcsupport/src/termios_num2baud.c
> +- cpukit/libcsupport/src/termios_posix_isig_handler.c
> +- cpukit/libcsupport/src/termios_setbestbaud.c
> +- cpukit/libcsupport/src/termios_setinitialbaud.c
> +- cpukit/libcsupport/src/termiosinitialize.c
> +- cpukit/libcsupport/src/truncate.c
> +- cpukit/libcsupport/src/uenvgetgroups.c
> +- cpukit/libcsupport/src/umask.c
> +- cpukit/libcsupport/src/unlink.c
> +- cpukit/libcsupport/src/unmount.c
> +- cpukit/libcsupport/src/utime.c
> +- cpukit/libcsupport/src/utimensat.c
> +- cpukit/libcsupport/src/utimes.c
> +- cpukit/libcsupport/src/utsname.c
> +- cpukit/libcsupport/src/vprintk.c
> +- cpukit/libcsupport/src/write.c
> +- cpukit/libcsupport/src/write_r.c
> +- cpukit/libcsupport/src/writev.c
> +- cpukit/libfs/src/defaults/default_are_nodes_equal.c
> +- cpukit/libfs/src/defaults/default_chown.c
> +- cpukit/libfs/src/defaults/default_clone.c
> +- cpukit/libfs/src/defaults/default_close.c
> +- cpukit/libfs/src/defaults/default_eval_path.c
> +- cpukit/libfs/src/defaults/default_fchmod.c
> +- cpukit/libfs/src/defaults/default_fcntl.c
> +- cpukit/libfs/src/defaults/default_freenode.c
> +- cpukit/libfs/src/defaults/default_fstat.c
> +- cpukit/libfs/src/defaults/default_fsunmount.c
> +- cpukit/libfs/src/defaults/default_fsync.c
> +- cpukit/libfs/src/defaults/default_fsync_success.c
> +- cpukit/libfs/src/defaults/default_ftruncate.c
> +- cpukit/libfs/src/defaults/default_ftruncate_directory.c
> +- cpukit/libfs/src/defaults/default_handlers.c
> +- cpukit/libfs/src/defaults/default_ioctl.c
> +- cpukit/libfs/src/defaults/default_kqfilter.c
> +- cpukit/libfs/src/defaults/default_link.c
> +- cpukit/libfs/src/defaults/default_lock_and_unlock.c
> +- cpukit/libfs/src/defaults/default_lseek.c
> +- cpukit/libfs/src/defaults/default_lseek_directory.c
> +- cpukit/libfs/src/defaults/default_lseek_file.c
> +- cpukit/libfs/src/defaults/default_mknod.c
> +- cpukit/libfs/src/defaults/default_mmap.c
> +- cpukit/libfs/src/defaults/default_mount.c
> +- cpukit/libfs/src/defaults/default_open.c
> +- cpukit/libfs/src/defaults/default_ops.c
> +- cpukit/libfs/src/defaults/default_poll.c
> +- cpukit/libfs/src/defaults/default_read.c
> +- cpukit/libfs/src/defaults/default_readlink.c
> +- cpukit/libfs/src/defaults/default_readv.c
> +- cpukit/libfs/src/defaults/default_rename.c
> +- cpukit/libfs/src/defaults/default_rmnod.c
> +- cpukit/libfs/src/defaults/default_statvfs.c
> +- cpukit/libfs/src/defaults/default_symlink.c
> +- cpukit/libfs/src/defaults/default_unmount.c
> +- cpukit/libfs/src/defaults/default_utimens.c
> +- cpukit/libfs/src/defaults/default_write.c
> +- cpukit/libfs/src/defaults/default_writev.c
> +- cpukit/libfs/src/dosfs/fat.c
> +- cpukit/libfs/src/dosfs/fat_fat_operations.c
> +- cpukit/libfs/src/dosfs/fat_file.c
> +- cpukit/libfs/src/dosfs/msdos_conv.c
> +- cpukit/libfs/src/dosfs/msdos_conv_default.c
> +- cpukit/libfs/src/dosfs/msdos_conv_utf8.c
> +- cpukit/libfs/src/dosfs/msdos_create.c
> +- cpukit/libfs/src/dosfs/msdos_dir.c
> +- cpukit/libfs/src/dosfs/msdos_eval.c
> +- cpukit/libfs/src/dosfs/msdos_file.c
> +- cpukit/libfs/src/dosfs/msdos_format.c
> +- cpukit/libfs/src/dosfs/msdos_free.c
> +- cpukit/libfs/src/dosfs/msdos_fsunmount.c
> +- cpukit/libfs/src/dosfs/msdos_handlers_dir.c
> +- cpukit/libfs/src/dosfs/msdos_handlers_file.c
> +- cpukit/libfs/src/dosfs/msdos_init.c
> +- cpukit/libfs/src/dosfs/msdos_initsupp.c
> +- cpukit/libfs/src/dosfs/msdos_misc.c
> +- cpukit/libfs/src/dosfs/msdos_mknod.c
> +- cpukit/libfs/src/dosfs/msdos_rename.c
> +- cpukit/libfs/src/dosfs/msdos_rmnod.c
> +- cpukit/libfs/src/dosfs/msdos_statvfs.c
> +- cpukit/libfs/src/imfs/deviceio.c
> +- cpukit/libfs/src/imfs/imfs_add_node.c
> +- cpukit/libfs/src/imfs/imfs_chown.c
> +- cpukit/libfs/src/imfs/imfs_config.c
> +- cpukit/libfs/src/imfs/imfs_creat.c
> +- cpukit/libfs/src/imfs/imfs_dir.c
> +- cpukit/libfs/src/imfs/imfs_dir_default.c
> +- cpukit/libfs/src/imfs/imfs_dir_minimal.c
> +- cpukit/libfs/src/imfs/imfs_eval.c
> +- cpukit/libfs/src/imfs/imfs_eval_devfs.c
> +- cpukit/libfs/src/imfs/imfs_fchmod.c
> +- cpukit/libfs/src/imfs/imfs_fifo.c
> +- cpukit/libfs/src/imfs/imfs_fsunmount.c
> +- cpukit/libfs/src/imfs/imfs_handlers_device.c
> +- cpukit/libfs/src/imfs/imfs_init.c
> +- cpukit/libfs/src/imfs/imfs_initsupp.c
> +- cpukit/libfs/src/imfs/imfs_linfile.c
> +- cpukit/libfs/src/imfs/imfs_link.c
> +- cpukit/libfs/src/imfs/imfs_load_tar.c
> +- cpukit/libfs/src/imfs/imfs_make_generic_node.c
> +- cpukit/libfs/src/imfs/imfs_make_linfile.c
> +- cpukit/libfs/src/imfs/imfs_memfile.c
> +- cpukit/libfs/src/imfs/imfs_mknod.c
> +- cpukit/libfs/src/imfs/imfs_mount.c
> +- cpukit/libfs/src/imfs/imfs_node.c
> +- cpukit/libfs/src/imfs/imfs_node_destroy_default.c
> +- cpukit/libfs/src/imfs/imfs_rename.c
> +- cpukit/libfs/src/imfs/imfs_rmnod.c
> +- cpukit/libfs/src/imfs/imfs_stat.c
> +- cpukit/libfs/src/imfs/imfs_stat_file.c
> +- cpukit/libfs/src/imfs/imfs_symlink.c
> +- cpukit/libfs/src/imfs/imfs_unmount.c
> +- cpukit/libfs/src/imfs/imfs_utimens.c
> +- cpukit/libfs/src/imfs/ioman.c
> +- cpukit/libfs/src/pipe/fifo.c
> +- cpukit/libfs/src/pipe/pipe.c
> +- cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
> +- cpukit/libfs/src/rfs/rtems-rfs-block.c
> +- cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c
> +- cpukit/libfs/src/rfs/rtems-rfs-buffer.c
> +- cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c
> +- cpukit/libfs/src/rfs/rtems-rfs-dir.c
> +- cpukit/libfs/src/rfs/rtems-rfs-file-system.c
> +- cpukit/libfs/src/rfs/rtems-rfs-file.c
> +- cpukit/libfs/src/rfs/rtems-rfs-format.c
> +- cpukit/libfs/src/rfs/rtems-rfs-group.c
> +- cpukit/libfs/src/rfs/rtems-rfs-inode.c
> +- cpukit/libfs/src/rfs/rtems-rfs-link.c
> +- cpukit/libfs/src/rfs/rtems-rfs-mutex.c
> +- cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
> +- cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
> +- cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
> +- cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c
> +- cpukit/libfs/src/rfs/rtems-rfs-rtems.c
> +- cpukit/libfs/src/rfs/rtems-rfs-shell.c
> +- cpukit/libfs/src/rfs/rtems-rfs-trace.c
> +- cpukit/libi2c/libi2c.c
> +- cpukit/libmd/md4.c
> +- cpukit/libmd/md5.c
> +- cpukit/libmd/sha256c.c
> +- cpukit/libmd/sha512c.c
> +- cpukit/libmisc/bspcmdline/bspcmdline_get.c
> +- cpukit/libmisc/bspcmdline/bspcmdline_getparam.c
> +- cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c
> +- cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c
> +- cpukit/libmisc/capture/capture-cli.c
> +- cpukit/libmisc/capture/capture.c
> +- cpukit/libmisc/capture/capture_buffer.c
> +- cpukit/libmisc/capture/capture_support.c
> +- cpukit/libmisc/capture/capture_user_extension.c
> +- cpukit/libmisc/capture/rtems-trace-buffer-default.c
> +- cpukit/libmisc/capture/rtems-trace-buffer-vars.c
> +- cpukit/libmisc/cpuuse/cpuinforeport.c
> +- cpukit/libmisc/cpuuse/cpuusagereport.c
> +- cpukit/libmisc/cpuuse/cpuusagetop.c
> +- cpukit/libmisc/devnull/devnull.c
> +- cpukit/libmisc/devnull/devzero.c
> +- cpukit/libmisc/dumpbuf/dumpbuf.c
> +- cpukit/libmisc/fb/mw_print.c
> +- cpukit/libmisc/fb/mw_uid.c
> +- cpukit/libmisc/fsmount/fsmount.c
> +- cpukit/libmisc/monitor/mon-command.c
> +- cpukit/libmisc/monitor/mon-config.c
> +- cpukit/libmisc/monitor/mon-driver.c
> +- cpukit/libmisc/monitor/mon-editor.c
> +- cpukit/libmisc/monitor/mon-extension.c
> +- cpukit/libmisc/monitor/mon-itask.c
> +- cpukit/libmisc/monitor/mon-manager.c
> +- cpukit/libmisc/monitor/mon-monitor.c
> +- cpukit/libmisc/monitor/mon-object.c
> +- cpukit/libmisc/monitor/mon-part.c
> +- cpukit/libmisc/monitor/mon-prmisc.c
> +- cpukit/libmisc/monitor/mon-queue.c
> +- cpukit/libmisc/monitor/mon-region.c
> +- cpukit/libmisc/monitor/mon-sema.c
> +- cpukit/libmisc/monitor/mon-server.c
> +- cpukit/libmisc/monitor/mon-symbols.c
> +- cpukit/libmisc/monitor/mon-task.c
> +- cpukit/libmisc/mouse/mouse_parser.c
> +- cpukit/libmisc/mouse/serial_mouse.c
> +- cpukit/libmisc/redirector/stdio-redirect.c
> +- cpukit/libmisc/regulator/regulator.c
> +- cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c
> +- cpukit/libmisc/rtems-fdt/rtems-fdt.c
> +- cpukit/libmisc/stackchk/check.c
> +- cpukit/libmisc/stringto/stringtodouble.c
> +- cpukit/libmisc/stringto/stringtofloat.c
> +- cpukit/libmisc/stringto/stringtoint.c
> +- cpukit/libmisc/stringto/stringtolong.c
> +- cpukit/libmisc/stringto/stringtolongdouble.c
> +- cpukit/libmisc/stringto/stringtolonglong.c
> +- cpukit/libmisc/stringto/stringtopointer.c
> +- cpukit/libmisc/stringto/stringtounsignedchar.c
> +- cpukit/libmisc/stringto/stringtounsignedint.c
> +- cpukit/libmisc/stringto/stringtounsignedlong.c
> +- cpukit/libmisc/stringto/stringtounsignedlonglong.c
> +- cpukit/libmisc/untar/untar.c
> +- cpukit/libmisc/untar/untar_tgz.c
> +- cpukit/libmisc/untar/untar_txz.c
> +- cpukit/libmisc/uuid/clear.c
> +- cpukit/libmisc/uuid/compare.c
> +- cpukit/libmisc/uuid/copy.c
> +- cpukit/libmisc/uuid/gen_uuid.c
> +- cpukit/libmisc/uuid/isnull.c
> +- cpukit/libmisc/uuid/pack.c
> +- cpukit/libmisc/uuid/parse.c
> +- cpukit/libmisc/uuid/unpack.c
> +- cpukit/libmisc/uuid/unparse.c
> +- cpukit/libmisc/uuid/uuid_time.c
> +- cpukit/libstdthreads/call_once.c
> +- cpukit/libstdthreads/cnd.c
> +- cpukit/libstdthreads/mtx.c
> +- cpukit/libstdthreads/thrd.c
> +- cpukit/libstdthreads/tss.c
> +- cpukit/libtrace/record/record-client.c
> +- cpukit/libtrace/record/record-dump-base64.c
> +- cpukit/libtrace/record/record-dump-fatal.c
> +- cpukit/libtrace/record/record-dump-zbase64.c
> +- cpukit/libtrace/record/record-dump-zfatal.c
> +- cpukit/libtrace/record/record-dump.c
> +- cpukit/libtrace/record/record-server.c
> +- cpukit/libtrace/record/record-stream-header.c
> +- cpukit/libtrace/record/record-sysinit.c
> +- cpukit/libtrace/record/record-text.c
> +- cpukit/libtrace/record/record-userext.c
> +- cpukit/libtrace/record/record-util.c
> +- cpukit/libtrace/record/record.c
> +- cpukit/posix/src/_execve.c
> +- cpukit/posix/src/aio_suspend.c
> +- cpukit/posix/src/barrierattrdestroy.c
> +- cpukit/posix/src/barrierattrgetpshared.c
> +- cpukit/posix/src/barrierattrinit.c
> +- cpukit/posix/src/barrierattrsetpshared.c
> +- cpukit/posix/src/cancel.c
> +- cpukit/posix/src/cleanuppush.c
> +- cpukit/posix/src/clockgetcpuclockid.c
> +- cpukit/posix/src/clockgetres.c
> +- cpukit/posix/src/clockgettime.c
> +- cpukit/posix/src/clocksettime.c
> +- cpukit/posix/src/condattrdestroy.c
> +- cpukit/posix/src/condattrgetclock.c
> +- cpukit/posix/src/condattrgetpshared.c
> +- cpukit/posix/src/condattrinit.c
> +- cpukit/posix/src/condattrsetclock.c
> +- cpukit/posix/src/condattrsetpshared.c
> +- cpukit/posix/src/condbroadcast.c
> +- cpukit/posix/src/conddefaultattributes.c
> +- cpukit/posix/src/conddestroy.c
> +- cpukit/posix/src/condinit.c
> +- cpukit/posix/src/condsignal.c
> +- cpukit/posix/src/condsignalsupp.c
> +- cpukit/posix/src/condtimedwait.c
> +- cpukit/posix/src/condwait.c
> +- cpukit/posix/src/condwaitsupp.c
> +- cpukit/posix/src/confstr.c
> +- cpukit/posix/src/fork.c
> +- cpukit/posix/src/key.c
> +- cpukit/posix/src/keycreate.c
> +- cpukit/posix/src/keydelete.c
> +- cpukit/posix/src/keygetspecific.c
> +- cpukit/posix/src/keysetspecific.c
> +- cpukit/posix/src/keyzerokvp.c
> +- cpukit/posix/src/lio_listio.c
> +- cpukit/posix/src/mlock.c
> +- cpukit/posix/src/mlockall.c
> +- cpukit/posix/src/mmap.c
> +- cpukit/posix/src/mprotect.c
> +- cpukit/posix/src/mqueue.c
> +- cpukit/posix/src/mqueueclose.c
> +- cpukit/posix/src/mqueueconfig.c
> +- cpukit/posix/src/mqueuedeletesupp.c
> +- cpukit/posix/src/mqueuegetattr.c
> +- cpukit/posix/src/mqueueopen.c
> +- cpukit/posix/src/mqueuereceive.c
> +- cpukit/posix/src/mqueuerecvsupp.c
> +- cpukit/posix/src/mqueuesend.c
> +- cpukit/posix/src/mqueuesendsupp.c
> +- cpukit/posix/src/mqueuesetattr.c
> +- cpukit/posix/src/mqueuetimedreceive.c
> +- cpukit/posix/src/mqueuetimedsend.c
> +- cpukit/posix/src/mqueueunlink.c
> +- cpukit/posix/src/msync.c
> +- cpukit/posix/src/munlock.c
> +- cpukit/posix/src/munlockall.c
> +- cpukit/posix/src/munmap.c
> +- cpukit/posix/src/mutexattrdestroy.c
> +- cpukit/posix/src/mutexattrgetprioceiling.c
> +- cpukit/posix/src/mutexattrgetprotocol.c
> +- cpukit/posix/src/mutexattrgetpshared.c
> +- cpukit/posix/src/mutexattrgettype.c
> +- cpukit/posix/src/mutexattrinit.c
> +- cpukit/posix/src/mutexattrsetprioceiling.c
> +- cpukit/posix/src/mutexattrsetprotocol.c
> +- cpukit/posix/src/mutexattrsetpshared.c
> +- cpukit/posix/src/mutexattrsettype.c
> +- cpukit/posix/src/mutexdestroy.c
> +- cpukit/posix/src/mutexgetprioceiling.c
> +- cpukit/posix/src/mutexinit.c
> +- cpukit/posix/src/mutexlock.c
> +- cpukit/posix/src/mutexlocksupp.c
> +- cpukit/posix/src/mutexsetprioceiling.c
> +- cpukit/posix/src/mutextimedlock.c
> +- cpukit/posix/src/mutextrylock.c
> +- cpukit/posix/src/mutexunlock.c
> +- cpukit/posix/src/nanosleep.c
> +- cpukit/posix/src/pbarrierdestroy.c
> +- cpukit/posix/src/pbarrierinit.c
> +- cpukit/posix/src/pbarrierwait.c
> +- cpukit/posix/src/posix_madvise.c
> +- cpukit/posix/src/prwlockdestroy.c
> +- cpukit/posix/src/prwlockinit.c
> +- cpukit/posix/src/prwlockrdlock.c
> +- cpukit/posix/src/prwlocktimedrdlock.c
> +- cpukit/posix/src/prwlocktimedwrlock.c
> +- cpukit/posix/src/prwlocktryrdlock.c
> +- cpukit/posix/src/prwlocktrywrlock.c
> +- cpukit/posix/src/prwlockunlock.c
> +- cpukit/posix/src/prwlockwrlock.c
> +- cpukit/posix/src/psignalconfig.c
> +- cpukit/posix/src/pspindestroy.c
> +- cpukit/posix/src/pspininit.c
> +- cpukit/posix/src/pspinlock.c
> +- cpukit/posix/src/pspinunlock.c
> +- cpukit/posix/src/psxnametoid.c
> +- cpukit/posix/src/psxpriorityisvalid.c
> +- cpukit/posix/src/psxsemaphore.c
> +- cpukit/posix/src/psxsemaphoreconfig.c
> +- cpukit/posix/src/psxtimerconfig.c
> +- cpukit/posix/src/psxtransschedparam.c
> +- cpukit/posix/src/pthread.c
> +- cpukit/posix/src/pthreadatfork.c
> +- cpukit/posix/src/pthreadattrdefault.c
> +- cpukit/posix/src/pthreadattrdestroy.c
> +- cpukit/posix/src/pthreadattrgetaffinitynp.c
> +- cpukit/posix/src/pthreadattrgetdetachstate.c
> +- cpukit/posix/src/pthreadattrgetguardsize.c
> +- cpukit/posix/src/pthreadattrgetinheritsched.c
> +- cpukit/posix/src/pthreadattrgetschedparam.c
> +- cpukit/posix/src/pthreadattrgetschedpolicy.c
> +- cpukit/posix/src/pthreadattrgetscope.c
> +- cpukit/posix/src/pthreadattrgetstack.c
> +- cpukit/posix/src/pthreadattrgetstackaddr.c
> +- cpukit/posix/src/pthreadattrgetstacksize.c
> +- cpukit/posix/src/pthreadattrinit.c
> +- cpukit/posix/src/pthreadattrsetaffinitynp.c
> +- cpukit/posix/src/pthreadattrsetdetachstate.c
> +- cpukit/posix/src/pthreadattrsetguardsize.c
> +- cpukit/posix/src/pthreadattrsetinheritsched.c
> +- cpukit/posix/src/pthreadattrsetschedparam.c
> +- cpukit/posix/src/pthreadattrsetschedpolicy.c
> +- cpukit/posix/src/pthreadattrsetscope.c
> +- cpukit/posix/src/pthreadattrsetstack.c
> +- cpukit/posix/src/pthreadattrsetstackaddr.c
> +- cpukit/posix/src/pthreadattrsetstacksize.c
> +- cpukit/posix/src/pthreadconcurrency.c
> +- cpukit/posix/src/pthreadconfig.c
> +- cpukit/posix/src/pthreadcreate.c
> +- cpukit/posix/src/pthreaddetach.c
> +- cpukit/posix/src/pthreadequal.c
> +- cpukit/posix/src/pthreadexit.c
> +- cpukit/posix/src/pthreadgetaffinitynp.c
> +- cpukit/posix/src/pthreadgetattrnp.c
> +- cpukit/posix/src/pthreadgetcpuclockid.c
> +- cpukit/posix/src/pthreadgetnamenp.c
> +- cpukit/posix/src/pthreadgetschedparam.c
> +- cpukit/posix/src/pthreadinitthreads.c
> +- cpukit/posix/src/pthreadjoin.c
> +- cpukit/posix/src/pthreadonce.c
> +- cpukit/posix/src/pthreadsetaffinitynp.c
> +- cpukit/posix/src/pthreadsetnamenp.c
> +- cpukit/posix/src/pthreadsetschedparam.c
> +- cpukit/posix/src/pthreadsetschedprio.c
> +- cpukit/posix/src/rwlockattrdestroy.c
> +- cpukit/posix/src/rwlockattrgetpshared.c
> +- cpukit/posix/src/rwlockattrinit.c
> +- cpukit/posix/src/rwlockattrsetpshared.c
> +- cpukit/posix/src/sched_getparam.c
> +- cpukit/posix/src/sched_getprioritymax.c
> +- cpukit/posix/src/sched_getprioritymin.c
> +- cpukit/posix/src/sched_getscheduler.c
> +- cpukit/posix/src/sched_rr_get_interval.c
> +- cpukit/posix/src/sched_setparam.c
> +- cpukit/posix/src/sched_setscheduler.c
> +- cpukit/posix/src/sched_yield.c
> +- cpukit/posix/src/semaphoredeletesupp.c
> +- cpukit/posix/src/semclose.c
> +- cpukit/posix/src/semdestroy.c
> +- cpukit/posix/src/semgetvalue.c
> +- cpukit/posix/src/seminit.c
> +- cpukit/posix/src/semopen.c
> +- cpukit/posix/src/sempost.c
> +- cpukit/posix/src/semtimedwait.c
> +- cpukit/posix/src/semtrywait.c
> +- cpukit/posix/src/semunlink.c
> +- cpukit/posix/src/semwait.c
> +- cpukit/posix/src/setcancelstate.c
> +- cpukit/posix/src/setcanceltype.c
> +- cpukit/posix/src/shm.c
> +- cpukit/posix/src/shmconfig.c
> +- cpukit/posix/src/shmheap.c
> +- cpukit/posix/src/shmopen.c
> +- cpukit/posix/src/shmops.c
> +- cpukit/posix/src/shmunlink.c
> +- cpukit/posix/src/shmwkspace.c
> +- cpukit/posix/src/sigaddset.c
> +- cpukit/posix/src/sigdelset.c
> +- cpukit/posix/src/sigemptyset.c
> +- cpukit/posix/src/sigfillset.c
> +- cpukit/posix/src/sigismember.c
> +- cpukit/posix/src/sigprocmask.c
> +- cpukit/posix/src/sysconf.c
> +- cpukit/posix/src/testcancel.c
> +- cpukit/posix/src/vfork.c
> +- cpukit/posix/src/wait.c
> +- cpukit/posix/src/waitpid.c
> +- cpukit/rtems/src/clockgetsecondssinceepoch.c
> +- cpukit/rtems/src/clockgettodtimeval.c
> +- cpukit/rtems/src/clockgetuptimenanoseconds.c
> +- cpukit/rtems/src/clockgetuptimeseconds.c
> +- cpukit/rtems/src/clockgetuptimetimeval.c
> +- cpukit/rtems/src/clocktick.c
> +- cpukit/rtems/src/dpmemcreate.c
> +- cpukit/rtems/src/dpmemdelete.c
> +- cpukit/rtems/src/dpmemexternal2internal.c
> +- cpukit/rtems/src/dpmemident.c
> +- cpukit/rtems/src/dpmeminternal2external.c
> +- cpukit/rtems/src/getapiconfig.c
> +- cpukit/rtems/src/intrbody.c
> +- cpukit/rtems/src/intrcatch.c
> +- cpukit/rtems/src/modes.c
> +- cpukit/rtems/src/msgqcreate.c
> +- cpukit/rtems/src/ratemongetstatistics.c
> +- cpukit/rtems/src/ratemonreportstatistics.c
> +- cpukit/rtems/src/ratemonresetall.c
> +- cpukit/rtems/src/ratemonresetstatistics.c
> +- cpukit/rtems/src/regioncreate.c
> +- cpukit/rtems/src/regiondelete.c
> +- cpukit/rtems/src/regionextend.c
> +- cpukit/rtems/src/regiongetfreeinfo.c
> +- cpukit/rtems/src/regiongetinfo.c
> +- cpukit/rtems/src/regiongetsegment.c
> +- cpukit/rtems/src/regiongetsegmentsize.c
> +- cpukit/rtems/src/regionident.c
> +- cpukit/rtems/src/regionprocessqueue.c
> +- cpukit/rtems/src/regionresizesegment.c
> +- cpukit/rtems/src/regionreturnsegment.c
> +- cpukit/rtems/src/rtemsbuildid.c
> +- cpukit/rtems/src/rtemsobjectapimaximumclass.c
> +- cpukit/rtems/src/rtemsobjectapiminimumclass.c
> +- cpukit/rtems/src/rtemsobjectgetapiclassname.c
> +- cpukit/rtems/src/rtemsobjectgetapiname.c
> +- cpukit/rtems/src/rtemsobjectgetclassicname.c
> +- cpukit/rtems/src/rtemsobjectgetclassinfo.c
> +- cpukit/rtems/src/rtemsobjectgetname.c
> +- cpukit/rtems/src/rtemsobjectidapimaximum.c
> +- cpukit/rtems/src/rtemsobjectidapiminimum.c
> +- cpukit/rtems/src/rtemsobjectidgetapi.c
> +- cpukit/rtems/src/rtemsobjectidgetclass.c
> +- cpukit/rtems/src/rtemsobjectidgetindex.c
> +- cpukit/rtems/src/rtemsobjectidgetnode.c
> +- cpukit/rtems/src/rtemsobjectsetname.c
> +- cpukit/rtems/src/schedulermapfromposix.c
> +- cpukit/rtems/src/schedulermaptoposix.c
> +- cpukit/rtems/src/statustoerrno.c
> +- cpukit/rtems/src/taskinitusers.c
> +- cpukit/rtems/src/timergetinfo.c
> +- cpukit/rtems/src/workspace.c
> +- cpukit/rtems/src/workspacegreedy.c
> +- cpukit/sapi/src/chainappendnotify.c
> +- cpukit/sapi/src/chaingetnotify.c
> +- cpukit/sapi/src/chaingetwait.c
> +- cpukit/sapi/src/chainprependnotify.c
> +- cpukit/sapi/src/chainprotected.c
> +- cpukit/sapi/src/cpucounterconverter.c
> +- cpukit/sapi/src/delaynano.c
> +- cpukit/sapi/src/delayticks.c
> +- cpukit/sapi/src/exshutdown.c
> +- cpukit/sapi/src/fatal.c
> +- cpukit/sapi/src/fatalsrctext.c
> +- cpukit/sapi/src/getbuildlabel.c
> +- cpukit/sapi/src/getcopyrightnotice.c
> +- cpukit/sapi/src/getversionstring.c
> +- cpukit/sapi/src/interrtext.c
> +- cpukit/sapi/src/io.c
> +- cpukit/sapi/src/ioclose.c
> +- cpukit/sapi/src/iocontrol.c
> +- cpukit/sapi/src/iodefault.c
> +- cpukit/sapi/src/ioinitialize.c
> +- cpukit/sapi/src/ioopen.c
> +- cpukit/sapi/src/ioread.c
> +- cpukit/sapi/src/ioregisterdriver.c
> +- cpukit/sapi/src/iounregisterdriver.c
> +- cpukit/sapi/src/iowrite.c
> +- cpukit/sapi/src/panic.c
> +- cpukit/sapi/src/profilingiterate.c
> +- cpukit/sapi/src/profilingreportxml.c
> +- cpukit/sapi/src/rbheap.c
> +- cpukit/sapi/src/rbtree.c
> +- cpukit/sapi/src/rbtreefind.c
> +- cpukit/sapi/src/sapirbtreeinsert.c
> +- cpukit/sapi/src/sysinitverbose.c
> +- cpukit/sapi/src/tcsimpleinstall.c
> +- cpukit/sapi/src/version.c
> +- cpukit/score/src/chainnodecount.c
> +- cpukit/score/src/condition.c
> +- cpukit/score/src/configstackspacesize.c
> +- cpukit/score/src/coremsgflushwait.c
> +- cpukit/score/src/coremsgwkspace.c
> +- cpukit/score/src/corerwlock.c
> +- cpukit/score/src/corerwlockobtainread.c
> +- cpukit/score/src/corerwlockobtainwrite.c
> +- cpukit/score/src/corerwlockrelease.c
> +- cpukit/score/src/coretodcheck.c
> +- cpukit/score/src/debugisthreaddispatchingallowed.c
> +- cpukit/score/src/debugunreachable.c
> +- cpukit/score/src/freechain.c
> +- cpukit/score/src/hash.c
> +- cpukit/score/src/heap.c
> +- cpukit/score/src/heapallocate.c
> +- cpukit/score/src/heapextend.c
> +- cpukit/score/src/heapfree.c
> +- cpukit/score/src/heapgetfreeinfo.c
> +- cpukit/score/src/heapgetinfo.c
> +- cpukit/score/src/heapgreedy.c
> +- cpukit/score/src/heapiterate.c
> +- cpukit/score/src/heapnoextend.c
> +- cpukit/score/src/heapresizeblock.c
> +- cpukit/score/src/heapsizeofuserarea.c
> +- cpukit/score/src/heapwalk.c
> +- cpukit/score/src/isrvectortable.c
> +- cpukit/score/src/iterateoverthreads.c
> +- cpukit/score/src/kern_ntptime.c
> +- cpukit/score/src/libatomic.c
> +- cpukit/score/src/log2table.c
> +- cpukit/score/src/memorydirtyfreeareas.c
> +- cpukit/score/src/memoryfill.c
> +- cpukit/score/src/memorynoinit.c
> +- cpukit/score/src/memoryzerobeforeuse.c
> +- cpukit/score/src/memoryzerofreeareas.c
> +- cpukit/score/src/objectactivecount.c
> +- cpukit/score/src/objectallocateunlimited.c
> +- cpukit/score/src/objectapimaximumclass.c
> +- cpukit/score/src/objectclose.c
> +- cpukit/score/src/objectextendinformation.c
> +- cpukit/score/src/objectfree.c
> +- cpukit/score/src/objectgetinfo.c
> +- cpukit/score/src/objectgetinfoid.c
> +- cpukit/score/src/objectgetnameasstring.c
> +- cpukit/score/src/objectgetnext.c
> +- cpukit/score/src/objectidtoname.c
> +- cpukit/score/src/objectnamespaceremove.c
> +- cpukit/score/src/objectnametoidstring.c
> +- cpukit/score/src/objectsetname.c
> +- cpukit/score/src/objectshrinkinformation.c
> +- cpukit/score/src/once.c
> +- cpukit/score/src/percpudata.c
> +- cpukit/score/src/pheapallocate.c
> +- cpukit/score/src/pheapextend.c
> +- cpukit/score/src/pheapfree.c
> +- cpukit/score/src/pheapgetfreeinfo.c
> +- cpukit/score/src/pheapgetinfo.c
> +- cpukit/score/src/pheapgetsize.c
> +- cpukit/score/src/pheapwalk.c
> +- cpukit/score/src/profilingisrentryexit.c
> +- cpukit/score/src/rbtreeappend.c
> +- cpukit/score/src/rbtreeiterate.c
> +- cpukit/score/src/rbtreenext.c
> +- cpukit/score/src/rbtreepostorder.c
> +- cpukit/score/src/rbtreeprepend.c
> +- cpukit/score/src/rbtreeprev.c
> +- cpukit/score/src/rbtreereplace.c
> +- cpukit/score/src/sched.c
> +- cpukit/score/src/schedulercbs.c
> +- cpukit/score/src/schedulercbsattachthread.c
> +- cpukit/score/src/schedulercbscleanup.c
> +- cpukit/score/src/schedulercbscreateserver.c
> +- cpukit/score/src/schedulercbsdestroyserver.c
> +- cpukit/score/src/schedulercbsdetachthread.c
> +- cpukit/score/src/schedulercbsgetapprovedbudget.c
> +- cpukit/score/src/schedulercbsgetexecutiontime.c
> +- cpukit/score/src/schedulercbsgetparameters.c
> +- cpukit/score/src/schedulercbsgetremainingbudget.c
> +- cpukit/score/src/schedulercbsgetserverid.c
> +- cpukit/score/src/schedulercbsnodeinit.c
> +- cpukit/score/src/schedulercbsreleasejob.c
> +- cpukit/score/src/schedulercbssetparameters.c
> +- cpukit/score/src/schedulercbsunblock.c
> +- cpukit/score/src/schedulerdefaultnodeinit.c
> +- cpukit/score/src/schedulerdefaultschedule.c
> +- cpukit/score/src/scheduleredf.c
> +- cpukit/score/src/scheduleredfblock.c
> +- cpukit/score/src/scheduleredfchangepriority.c
> +- cpukit/score/src/scheduleredfnodeinit.c
> +- cpukit/score/src/scheduleredfreleasejob.c
> +- cpukit/score/src/scheduleredfschedule.c
> +- cpukit/score/src/scheduleredfunblock.c
> +- cpukit/score/src/scheduleredfyield.c
> +- cpukit/score/src/schedulersimple.c
> +- cpukit/score/src/schedulersimpleblock.c
> +- cpukit/score/src/schedulersimplechangepriority.c
> +- cpukit/score/src/schedulersimpleschedule.c
> +- cpukit/score/src/schedulersimpleunblock.c
> +- cpukit/score/src/schedulersimpleyield.c
> +- cpukit/score/src/semaphore.c
> +- cpukit/score/src/smpbarrierwait.c
> +- cpukit/score/src/stackallocator.c
> +- cpukit/score/src/stackallocatorforidlewkspace.c
> +- cpukit/score/src/stackallocatorfree.c
> +- cpukit/score/src/stackallocatorinit.c
> +- cpukit/score/src/threadallocateunlimited.c
> +- cpukit/score/src/threadentryadaptorpointer.c
> +- cpukit/score/src/threadexhausttimeslice.c
> +- cpukit/score/src/threadname.c
> +- cpukit/score/src/threadplaindispatch.c
> +- cpukit/score/src/threadqextract.c
> +- cpukit/score/src/threadqfirst.c
> +- cpukit/score/src/threadqgetnameandid.c
> +- cpukit/score/src/threadwaitgetid.c
> +- cpukit/score/src/threadyield.c
> +- cpukit/score/src/timespecaddto.c
> +- cpukit/score/src/timespecdivide.c
> +- cpukit/score/src/timespecdividebyinteger.c
> +- cpukit/score/src/timespecfromticks.c
> +- cpukit/score/src/timespecgetasnanoseconds.c
> +- cpukit/score/src/timespecisnonnegative.c
> +- cpukit/score/src/timespecisvalid.c
> +- cpukit/score/src/timespeclessthan.c
> +- cpukit/score/src/timespecsubtract.c
> +- cpukit/score/src/timespectoticks.c
> +- cpukit/score/src/wkspace.c
> +- cpukit/score/src/wkspaceallocate.c
> +- cpukit/score/src/wkspacefree.c
> +- cpukit/score/src/wkspaceisunifieddefault.c
> +- cpukit/score/src/wkspacemallocinitunified.c
> +- cpukit/score/src/wkstringduplicate.c
> +type: build
> diff --git a/spec/build/cpukit/objgnat.yml b/spec/build/cpukit/objgnat.yml
> index 2280be9471..81b9b5ad1b 100644
> --- a/spec/build/cpukit/objgnat.yml
> +++ b/spec/build/cpukit/objgnat.yml
> @@ -6,7 +6,9 @@ copyrights:
>  cppflags: []
>  cxxflags: []
>  enabled-by:
> -- __RTEMS_ADA__
> +  and:
> +    - __RTEMS_ADA__
>  includes: []
>  install: []
>  links: []
> diff --git a/spec/build/cpukit/objpci.yml b/spec/build/cpukit/objpci.yml
> index dc8a1be8c6..4127e55ffc 100644
> --- a/spec/build/cpukit/objpci.yml
> +++ b/spec/build/cpukit/objpci.yml
>  cppflags: []
>  cxxflags: []
>  enabled-by:
> -- sparc
> +  and:
> +    - sparc
>  includes: []
>  install:
>  - destination: ${BSP_INCLUDEDIR}/pci
> diff --git a/spec/build/cpukit/objqual.yml b/spec/build/cpukit/objqual.yml
> index 0000000000..4d31384235
> --- /dev/null
> +++ b/spec/build/cpukit/objqual.yml
> @@ -0,0 +1,14 @@
> +cflags: []
> +copyrights:
> +- Copyright (C) 2021 embedded brains GmbH & Co. KG
> +cppflags: []
> +cxxflags: []
> +enabled-by: RTEMS_QUALIFIED
> +includes: []
> +install: []
> +links: []
> +source:
> +- cpukit/libcsupport/src/alloconly.c
> +type: build
> diff --git a/spec/build/cpukit/objshell.yml
> b/spec/build/cpukit/objshell.yml
> index 2eaf4e17cf..3a108a92f2 100644
> --- a/spec/build/cpukit/objshell.yml
> +++ b/spec/build/cpukit/objshell.yml
> @@ -5,7 +5,8 @@ copyrights:
>  cppflags: []
>  cxxflags: []
> -enabled-by: true
> +enabled-by:
>  includes: []
>  install: []
>  links: []
> diff --git a/spec/build/cpukit/objsmp.yml b/spec/build/cpukit/objsmp.yml
> index 41686e0f5e..3ab74a95b2 100644
> --- a/spec/build/cpukit/objsmp.yml
> +++ b/spec/build/cpukit/objsmp.yml
> @@ -8,28 +8,23 @@ cxxflags: []
>  enabled-by: RTEMS_SMP
>  includes: []
>  install: []
> -links: []
> +links:
> +  uid: objsmpextra
>  source:
>  - cpukit/score/src/percpujobs.c
> -- cpukit/score/src/percpustatewait.c
> -- cpukit/score/src/profilingsmplock.c
>  - cpukit/score/src/schedulerdefaultmakecleansticky.c
> -- cpukit/score/src/schedulerdefaultpinunpin.c
>  - cpukit/score/src/schedulerdefaultpinunpindonothing.c
>  - cpukit/score/src/schedulerdefaultsetaffinity.c
>  - cpukit/score/src/scheduleredfsmp.c
> -- cpukit/score/src/schedulerpriorityaffinitysmp.c
> -- cpukit/score/src/schedulerprioritysmp.c
> -- cpukit/score/src/schedulersimplesmp.c
>  - cpukit/score/src/schedulersmp.c
> -- cpukit/score/src/schedulersmpstartidle.c
> -- cpukit/score/src/schedulerstrongapa.c
> -- cpukit/score/src/smpbroadcastaction.c
>  - cpukit/score/src/smp.c
>  - cpukit/score/src/smplock.c
>  - cpukit/score/src/smpmulticastaction.c
>  - cpukit/score/src/smpothercastaction.c
> -- cpukit/score/src/smpsynchronize.c
> -- cpukit/score/src/smpunicastaction.c
>  - cpukit/score/src/threadunpin.c
>  type: build
> diff --git a/spec/build/cpukit/objsmpextra.yml
> b/spec/build/cpukit/objsmpextra.yml
> index 0000000000..81ed2595c3
> --- /dev/null
> +++ b/spec/build/cpukit/objsmpextra.yml
> @@ -0,0 +1,25 @@
> +cflags: []
> +copyrights:
> +cppflags: []
> +cxxflags: []
> +enabled-by:
> +includes: []
> +install: []
> +links: []
> +source:
> +- cpukit/score/src/percpustatewait.c
> +- cpukit/score/src/profilingsmplock.c
> +- cpukit/score/src/schedulerdefaultpinunpin.c
> +- cpukit/score/src/schedulerpriorityaffinitysmp.c
> +- cpukit/score/src/schedulerprioritysmp.c
> +- cpukit/score/src/schedulersimplesmp.c
> +- cpukit/score/src/schedulersmpstartidle.c
> +- cpukit/score/src/schedulerstrongapa.c
> +- cpukit/score/src/smpbroadcastaction.c
> +- cpukit/score/src/smpsynchronize.c
> +- cpukit/score/src/smpunicastaction.c
> +type: build
> diff --git a/spec/build/cpukit/objtestextra.yml
> b/spec/build/cpukit/objtestextra.yml
> index 0000000000..6399faeb5c
> --- /dev/null
> +++ b/spec/build/cpukit/objtestextra.yml
> @@ -0,0 +1,26 @@
> +cflags: []
> +copyrights:
> +cppflags: []
> +cxxflags: []
> +enabled-by:
> +includes: []
> +install: []
> +links: []
> +source:
> +- cpukit/libtest/testbusy.c
> +- cpukit/libtest/testexit.c
> +- cpukit/libtest/testextension.c
> +- cpukit/libtest/testparallel.c
> +- cpukit/libtest/testprinter.c
> +- cpukit/libtest/testrun.c
> +- cpukit/libtest/testwrappers.c
> +- cpukit/libtest/t-test-checks-eno.c
> +- cpukit/libtest/t-test-checks-psx.c
> +- cpukit/libtest/t-test-rtems-fds.c
> +- cpukit/libtest/t-test-rtems-heap.c
> +- cpukit/libtest/t-test-rtems-posix-keys.c
> +type: build
> diff --git a/spec/build/cpukit/objtestqual.yml
> b/spec/build/cpukit/objtestqual.yml
> index 0000000000..728ae99efd
> --- /dev/null
> +++ b/spec/build/cpukit/objtestqual.yml
> @@ -0,0 +1,37 @@
> +cflags: []
> +copyrights:
> +cppflags: []
> +cxxflags: []
> +includes:
> +- ${BSP_INCLUDES}
> +install: []
> +links: []
> +source:
> +- bsps/shared/rtems-version.c
> +- cpukit/score/src/rbtreemax.c
> +type: build
> diff --git a/spec/build/cpukit/objtestqualsmp.yml
> b/spec/build/cpukit/objtestqualsmp.yml
> index 0000000000..1a4f9f2101
> --- /dev/null
> +++ b/spec/build/cpukit/objtestqualsmp.yml
> @@ -0,0 +1,18 @@
> +cflags: []
> +copyrights:
> +cppflags: []
> +cxxflags: []
> +enabled-by:
> +  and:
> +  - RTEMS_SMP
> +  - RTEMS_QUALIFIED
> +includes: []
> +install: []
> +links: []
> +source:
> +type: build
> diff --git a/spec/build/cpukit/objutf8.yml b/spec/build/cpukit/objutf8.yml
> index ec1bb72f26..0538c6bf66 100644
> --- a/spec/build/cpukit/objutf8.yml
> +++ b/spec/build/cpukit/objutf8.yml
>  cppflags: []
>  cxxflags: []
> -enabled-by: true
> +enabled-by:
>  includes: []
>  install:
>  - destination: ${BSP_INCLUDEDIR}/utf8proc
> diff --git a/spec/build/cpukit/optexceptionextensions.yml
> b/spec/build/cpukit/optexceptionextensions.yml
> index a9a9bb735c..f1eb3eca5f 100644
> --- a/spec/build/cpukit/optexceptionextensions.yml
> +++ b/spec/build/cpukit/optexceptionextensions.yml
> @@ -7,6 +7,8 @@ build-type: option
>  copyrights:
>  - Copyright (C) 2021 On-Line Applications Research (OAR)
>  default:
> +- enabled-by: RTEMS_QUALIFIED
> +  value: false
>  - enabled-by: true
>    value: true
>  description: |
> diff --git a/spec/build/cpukit/optlibdl.yml
> b/spec/build/cpukit/optlibdl.yml
> index cb45d0e70c..2ea582e4cc 100644
> --- a/spec/build/cpukit/optlibdl.yml
> +++ b/spec/build/cpukit/optlibdl.yml
> @@ -8,15 +8,18 @@ copyrights:
>  default: []
>  description: ''
>  enabled-by:
> -- aarch64
> -- arm
> -- i386
> -- m68k
> -- microblaze
> -- mips
> -- moxie
> -- powerpc
> -- sparc
> +  and:
> +  - or:
> +    - aarch64
> +    - arm
> +    - i386
> +    - m68k
> +    - microblaze
> +    - mips
> +    - moxie
> +    - powerpc
> +    - sparc
>  links: []
>  type: build
> diff --git a/spec/build/cpukit/optqual.yml b/spec/build/cpukit/optqual.yml
> index 0000000000..65d51c6d9e
> --- /dev/null
> +++ b/spec/build/cpukit/optqual.yml
> @@ -0,0 +1,19 @@
> +actions:
> +- get-boolean: null
> +- env-enable: null
> +- define-condition: null
> +build-type: option
> +copyrights:
> +- Copyright (C) 2020, 2023 embedded brains GmbH & Co. KG
> +default:
> +- enabled-by: true
> +  value: false
> +description: |
> +  If this option is enabled, then only the pre-qualified feature subset of
> +  RTEMS is built.  For the pre-qualified feature set of RTEMS, a
> specification
> +  with associated validation tests exists.
> +enabled-by: true
> +links: []
> +name: RTEMS_QUALIFIED
> +type: build
> diff --git a/spec/build/testsuites/optada.yml
> b/spec/build/testsuites/optada.yml
> index a2b2b791c5..7f9715d812 100644
> --- a/spec/build/testsuites/optada.yml
> +++ b/spec/build/testsuites/optada.yml
> @@ -6,7 +6,10 @@ build-type: option
>  copyrights:
>  default:
> -- enabled-by: BUILD_TESTS
> +- enabled-by:
> +    and:
> +    - BUILD_TESTS
>    value: true
>  - enabled-by: true
>    value: false
> diff --git a/spec/build/testsuites/optbenchmarks.yml
> b/spec/build/testsuites/optbenchmarks.yml
> index 0d6bce5a85..12b2ac8ac2 100644
> --- a/spec/build/testsuites/optbenchmarks.yml
> +++ b/spec/build/testsuites/optbenchmarks.yml
>  copyrights:
>  default:
> +- enabled-by:
> +    and:
> +    - BUILD_TESTS
>    value: true
>  - enabled-by: true
>    value: false
> diff --git a/spec/build/testsuites/optfs.yml
> b/spec/build/testsuites/optfs.yml
> index 6a2e657b03..39fc4cbcbf 100644
> --- a/spec/build/testsuites/optfs.yml
> +++ b/spec/build/testsuites/optfs.yml
>  copyrights:
>  default:
> +- enabled-by:
> +    and:
> +    - BUILD_TESTS
>    value: true
>  - enabled-by: true
>    value: false
> diff --git a/spec/build/testsuites/optlib.yml
> b/spec/build/testsuites/optlib.yml
> index 556f43cda4..2a9ce5a111 100644
> --- a/spec/build/testsuites/optlib.yml
> +++ b/spec/build/testsuites/optlib.yml
>  copyrights:
>  default:
> +- enabled-by:
> +    and:
> +    - BUILD_TESTS
>    value: true
>  - enabled-by: true
>    value: false
> diff --git a/spec/build/testsuites/optmp.yml
> b/spec/build/testsuites/optmp.yml
> index 4a2d83287f..a9a6e22016 100644
> --- a/spec/build/testsuites/optmp.yml
> +++ b/spec/build/testsuites/optmp.yml
>  copyrights:
>  default:
> +- enabled-by:
> +    and:
> +    - BUILD_TESTS
>    value: true
>  - enabled-by: true
>    value: false
> diff --git a/spec/build/testsuites/optpsx.yml
> b/spec/build/testsuites/optpsx.yml
> index 6bd1460000..09408cc3c4 100644
> --- a/spec/build/testsuites/optpsx.yml
> +++ b/spec/build/testsuites/optpsx.yml
>  copyrights:
>  default:
> +- enabled-by:
> +    and:
> +    - BUILD_TESTS
>    value: true
>  - enabled-by: true
>    value: false
> diff --git a/spec/build/testsuites/optpsxtm.yml
> b/spec/build/testsuites/optpsxtm.yml
> index 78d8e97dd9..b491255986 100644
> --- a/spec/build/testsuites/optpsxtm.yml
> +++ b/spec/build/testsuites/optpsxtm.yml
>  copyrights:
>  default:
> +- enabled-by:
> +    and:
> +    - BUILD_TESTS
>    value: true
>  - enabled-by: true
>    value: false
> diff --git a/spec/build/testsuites/optrhs.yml
> b/spec/build/testsuites/optrhs.yml
> index da7ccda793..2c63a11bc0 100644
> --- a/spec/build/testsuites/optrhs.yml
> +++ b/spec/build/testsuites/optrhs.yml
>  copyrights:
>  default:
> +- enabled-by:
> +    and:
> +    - BUILD_TESTS
>    value: true
>  - enabled-by: true
>    value: false
> diff --git a/spec/build/testsuites/optsamples.yml
> b/spec/build/testsuites/optsamples.yml
> index 80b09c5613..a82840fa47 100644
> --- a/spec/build/testsuites/optsamples.yml
> +++ b/spec/build/testsuites/optsamples.yml
> @@ -6,6 +6,8 @@ build-type: option
>  copyrights:
>  default:
> +  value: false
>  - enabled-by: true
>    value: true
>  description: |
> diff --git a/spec/build/testsuites/optsmp.yml
> b/spec/build/testsuites/optsmp.yml
> index ec4288c197..f3f4180442 100644
> --- a/spec/build/testsuites/optsmp.yml
> +++ b/spec/build/testsuites/optsmp.yml
>  copyrights:
>  default:
> +- enabled-by:
> +    and:
> +    - BUILD_TESTS
>    value: true
>  - enabled-by: true
>    value: false
> diff --git a/spec/build/testsuites/optsp.yml
> b/spec/build/testsuites/optsp.yml
> index eec479b132..4e9c7f6ba2 100644
> --- a/spec/build/testsuites/optsp.yml
> +++ b/spec/build/testsuites/optsp.yml
>  copyrights:
>  default:
> +- enabled-by:
> +    and:
> +    - BUILD_TESTS
>    value: true
>  - enabled-by: true
>    value: false
> diff --git a/spec/build/testsuites/opttm.yml
> b/spec/build/testsuites/opttm.yml
> index 99ea70a96b..eaca9fdebb 100644
> --- a/spec/build/testsuites/opttm.yml
> +++ b/spec/build/testsuites/opttm.yml
>  copyrights:
>  default:
> +- enabled-by:
> +    and:
> +    - BUILD_TESTS
>    value: true
>  - enabled-by: true
>    value: false
> 2.35.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20231103/347d626a/attachment-0001.htm>
