[PATCH] build: Add RTEMS_QUALIFIED
Mon Nov 6 00:14:57 UTC 2023
On 4/11/2023 1:31 am, Sebastian Huber wrote:
> On 03.11.23 15:08, Joel Sherrill wrote:
>> On Fri, Nov 3, 2023 at 3:58 AM Sebastian Huber
>> <sebastian.huber at embedded-brains.de
>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>     The goal of the RTEMS pre-qualification activity #3701 is a specified
>>     and validated subset of RTEMS.  For users of the pre-qualified subset of
>>     RTEMS it is important to not accidentally use not pre-qualified
>>     features.  One way to achieve this, is to build only the sources of the
>>     pre-qualified feature set. This customized build is enabled by the new
>>     build configuration option RTEMS_QUALIFIED.  If it is enabled, then only
>>     the pre-qualified subset of RTEMS is built and installed.
>>     Building with RTEMS_QUALIFIED enable is currently only supported for the
>>     sparc/leon3 BSP family.  To support an RTEMS_QUALIFIED enabled build,
>>     changes in the CPU port and the BSP are required to only use features of
>>     the pre-qualified feature set.
>> Where is this documented?
> You mean a documentation of what needs to be done to create pre-qualified BSP? I
> don't have it available yet. A good place to add this would be the how-to
> section in the RTEMS Software Engineering manual.
>> This is a very large patch. Are you assuming that if "not qualified" is
>> specified,
>> then it is in the qualified set?
> No, the logic is reversed. Everything is built by default. Some parts are only
> enabled if RTEMS_QUALIFIED is not enabled, for example
> (spec/build/cpukit/objextra.yml):
> enabled-by:
>   not: RTEMS_QUALIFIED
It seems counter intuitive to me. I have no idea about qual work but my limited
understanding is everything is controlled yet this is the inverse of that and
anything anyone adds will by default be qualified?
