[RSB 1/3] 6/7: Update Newlib
Tue Nov 21 12:39:03 UTC 2023
Pick up fixes for ARM/optimized-routines and the memory reclamation at thread
exit.
Update #4510.
Update #4967.
 rtems/config/tools/rtems-gcc-10-newlib-head.cfg   | 4 ++--
 rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg | 4 ++--
 rtems/config/tools/rtems-gcc-12-newlib-head.cfg   | 4 ++--
 rtems/config/tools/rtems-gcc-13-newlib-head.cfg   | 4 ++--
 rtems/config/tools/rtems-gcc-13.2-newlib-head.cfg | 4 ++--
 rtems/config/tools/rtems-gcc-head-newlib-head.cfg | 4 ++--
 6 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/rtems/config/tools/rtems-gcc-10-newlib-head.cfg b/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
index 6668bc6..387e8c9 100644
--- a/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
+++ b/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
@@ -14,12 +14,12 @@
 %patch add gcc -p1 https://devel.rtems.org/raw-attachment/ticket/4215/0001-nios2-Remove-custom-instruction-warnings.patch
 %hash sha512 0001-nios2-Remove-custom-instruction-warnings.patch afd8a5e6bdcc5b75d5fbbf558bdf56ccac400521a6eec9d88cc95f6be67c481f2dbf8faa0f6ddc1e4ac7c56a84938714d80e46e9cf80ec4b8fcd739986449881
-%define newlib_version fbc5496
+%define newlib_version 3cacedb
 %define newlib_external 1
 %define newlib_expand_name sourceware-mirror-newlib-cygwin-%{newlib_version}
 %source set newlib --rsb-file=newlib-%{newlib_version}.tar.gz https://codeload.github.com/RTEMS/sourceware-mirror-newlib-cygwin/tar.gz/%{newlib_version}
 %hash sha512 newlib-%{newlib_version}.tar.gz \
-  AFwyCjHHXfddx/lUcJbmcxSFOYtfj8cshzthqF9B2OtZxxxN/NQ8O+znhUPKDv20KjOBEMGh4VHpoiFBjZOrmA==
+  ia0ce+bdENUO3qYj00jrZB8FjSejmTWuRqEdNE8nI2llf30mh8leUn5fCoHB0Oa7rRVBjEu3n0F12ZK9skuegQ==
 %define with_threads 1
 %define with_plugin 0
diff --git a/rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg b/rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg
index dae3d2a..b37af1e 100644
--- a/rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg
+++ b/rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg
@@ -17,12 +17,12 @@
diff --git a/rtems/config/tools/rtems-gcc-12-newlib-head.cfg b/rtems/config/tools/rtems-gcc-12-newlib-head.cfg
index 9fe1ddd..4a0c6d1 100644
--- a/rtems/config/tools/rtems-gcc-12-newlib-head.cfg
+++ b/rtems/config/tools/rtems-gcc-12-newlib-head.cfg
@@ -34,13 +34,13 @@
         KEmxHjYOqY4LTXCMZ3I60tbHusbR5GlnP0CLARHPAnhCnovDj9K3U43C1bsMxDDGRqD6fwtrEFoEgqVFX63IuQ==
 # Comment above related to #4657 and patches ends here
 %source set newlib --rsb-file=newlib-%{newlib_version}.tar.gz \
diff --git a/rtems/config/tools/rtems-gcc-13-newlib-head.cfg b/rtems/config/tools/rtems-gcc-13-newlib-head.cfg
index 7d5f610..5529563 100644
--- a/rtems/config/tools/rtems-gcc-13-newlib-head.cfg
+++ b/rtems/config/tools/rtems-gcc-13-newlib-head.cfg
@@ -8,12 +8,12 @@
 %hash sha512 %{gcc_expand_name}.tar.gz \
   nKBXN9Qt/9CRYDVOp1geQdshXDP/kvr82RV1fE1LVIxNCbAVvhRmqz1p5kycg24T3TNGHPN58RySceaYgc6sCw==
diff --git a/rtems/config/tools/rtems-gcc-13.2-newlib-head.cfg b/rtems/config/tools/rtems-gcc-13.2-newlib-head.cfg
index c12a83e..86e0135 100644
--- a/rtems/config/tools/rtems-gcc-13.2-newlib-head.cfg
+++ b/rtems/config/tools/rtems-gcc-13.2-newlib-head.cfg
@@ -6,12 +6,12 @@
 %hash sha512 gcc-%{gcc_version}.tar.xz \
   2Z5IJqcNsEUERn40np+67apYcHZs2nxcq1DN6+3EvnVevKW3ieEjKjSiC+GgtgCX3pKA7+R723HHMlHjCwhiog==
diff --git a/rtems/config/tools/rtems-gcc-head-newlib-head.cfg b/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
index 68c4f32..c65576e 100644
--- a/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
+++ b/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
@@ -8,12 +8,12 @@
   /xNCazIZxy7diP2R1RUChqhEuQIZdD4otPeHyN48g1LiFbgPaUNZ167RDPCXkQEVVf31g/LvYFqicxeXMwj8cQ==
2.35.3
