[PATCH rtems v2 3/3] bsps/imxrt1166: Disable video_mux
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Nov 21 14:54:35 UTC 2023
The pinctrl-0 of the video_mux might overwrite pin settings done by
other peripherals. Disabling it by default prevents unexpected pin
settings.
 bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.c   | 10 ++++++----
 bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.dts |  1 +
 2 files changed, 7 insertions(+), 4 deletions(-)
diff --git a/bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.c b/bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.c
index 78e7feda09..e312902ff9 100644
--- a/bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.c
+++ b/bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.c
@@ -7,10 +7,10 @@
 #include <sys/types.h>
 const unsigned char imxrt_dtb[] __attribute__(( __aligned__(8) )) = {
-  0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x70, 0xf2, 0x00, 0x00, 0x00, 0x38,
-  0x00, 0x00, 0x6a, 0xa8, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
+  0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x71, 0x0a, 0x00, 0x00, 0x00, 0x38,
+  0x00, 0x00, 0x6a, 0xc0, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
   0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x0a,
-  0x00, 0x00, 0x6a, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x6a, 0x88, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
@@ -1836,7 +1836,9 @@ const unsigned char imxrt_dtb[] __attribute__(( __aligned__(8) )) = {
   0x40, 0x81, 0x80, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03,
   0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x04, 0xd2, 0x00, 0x00, 0x00, 0x5f,
   0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
-  0x00, 0x00, 0x05, 0x02, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x05, 0x02, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x04, 0xb3, 0x64, 0x69, 0x73, 0x61,
+  0x62, 0x6c, 0x65, 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
   0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x61, 0x69, 0x70, 0x73,
   0x2d, 0x62, 0x75, 0x73, 0x40, 0x34, 0x30, 0x63, 0x30, 0x30, 0x30, 0x30,
   0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x18,
diff --git a/bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.dts b/bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.dts
index c961abcd37..0cce861716 100644
--- a/bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.dts
+++ b/bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.dts
@@ -125,6 +125,7 @@
 &video_mux {
 	pinctrl-0 = <&pinctrl_video_mux>;
+	status = "disabled";
 &usbotg1 {
2.35.3
