[PATCH] 6: Use GCC 13.2
Mon Nov 27 00:29:20 UTC 2023
On 24/11/2023 6:33 pm, Sebastian Huber wrote:
> On 24.11.23 02:08, Chris Johns wrote:
>> On 24/11/2023 8:22 am, Chris Johns wrote:
>>> On 23/11/2023 5:55 pm, Sebastian Huber wrote:> I built all BSPs with GCC 13.2
>>> and Binutils 2.41. It was successful and it fixed
>>>> some microblaze build problems which I had for several months. So, I checked it
>>>> in.
>>> Thanks for the testing and for sorting this out.
>>> I would like to run some major apps through this version over the next week to
>>> make sure there are no regressions. I do not expect any but it is worth doing.
>> The build of master failed on MacOS Somona M2. The error is:
>> mkdir ./mpc
>> Configuring in ./mpc
>> configure: creating cache ./config.cache
>> checking for a BSD-compatible install... /usr/bin/install -c
>> checking whether build environment is sane... yes
>> checking for a thread-safe mkdir -p... ../../gcc-13.2.0/mpc/build-aux/install-sh
>> -c -d
>> checking for gawk... awk
>> checking whether /Applications/Xcode.app/Contents/Developer/usr/bin/make sets
>> $(MAKE)... yes
>> supports nested variables... yes
>> checking whether to enable maintainer-specific portions of Makefiles... no
>> Invalid configuration `arm64-apple-darwin23.0.0': machine `arm64-apple' not
>> recognized
>> configure: error: /bin/sh ../../gcc-13.2.0/mpc/build-aux/config.sub
>> arm64-apple-darwin23.0.0 failed
>> The MacOS support I worked on has been ignored. Why was it not brought across or
>> raised?
>> Have all the patches in the rtems-gcc-12-newlib-head.cfg been resolved?
> I don't ignore any macOS support. If this is missing, then this is a normal
> oversight caused by various reasons.
Understood and I was just wondering if something had changed I did not know about.
