[RSB PATCH] 6: Merge the MacOS M silicon patch from gcc-12 to gcc-13
Cedric Berger
cedric at precidata.com
Mon Nov 27 07:43:43 UTC 2023
Hello,
On 24.11.2023 08:36, Sebastian Huber wrote:
> Would updating to ISL 0.26 and MPC 1.3.1 fix this issue also?
I just tried in on my fully up-to-date M1 Pro (macOS Sonoma 14.1.1,
Xcode 15.0.1)
Short answer: everything works well without issues (configure, make, check)
I just installed the following packages successively:
- https://gmplib.org/download/gmp/gmp-6.3.0.tar.xz
- https://www.mpfr.org/mpfr-current/mpfr-4.2.1.tar.gz
- https://ftp.gnu.org/gnu/mpc/mpc-1.3.1.tar.gz
- https://libisl.sourceforge.io/isl-0.26.tar.gz
by simply extracting the archive and doing:
./configure
make
make check
sudo make install
And everything went fine with just a couple of warnings:
- during make check for the first 3 packages:
libtool: warning: '-no-install' is ignored for aarch64-apple-darwin23.1.0
libtool: warning: assuming '-no-fast-install' instead
- at the end of libisl make:
ld: warning: -bind_at_load is deprecated on macOS
warning: /Library/Developer/CommandLineTools/usr/bin/ranlib: archive
library: libdep.a the table of contents is empty (no object file members
in the library define global symbols)
So it seems that updating to the lastest packages would fix all
outstanding M1 macOS issues witout any extra patches needed.
Cedric
