[RSB PATCH] gdb: Add options to contorl the python version
chrisj at rtems.org
chrisj at rtems.org
Wed Nov 29 20:52:14 UTC 2023
The options are:
--with-python2
--with-python3
--with-python-version
Closes #4973
source-builder/config/gdb-common-1.cfg | 19 +++++++++++++++++++
1 file changed, 19 insertions(+)
diff --git a/source-builder/config/gdb-common-1.cfg b/source-builder/config/gdb-common-1.cfg
index 0fea334..49bf673 100644
--- a/source-builder/config/gdb-common-1.cfg
+++ b/source-builder/config/gdb-common-1.cfg
@@ -44,6 +44,25 @@
# 3. Search for 'python3' and if not found search for 'python2'.
+# User options to help find a suitable python:
+# --with-python2 : name of a python2 command
+# --with-python3 : name of a python2 command
+# --with-python-version : name of a python command with a specific version
+# For example `--with-python-version=python3.6
+%if %{defined with_python2}
+ %define gdb-python2 %{with_python2}
+%endif
+%if %{defined with_python3}
+ %define gdb-python3 %{with_python3}
+%endif
+%if %{defined with_python_version}
+ %define gdb-python-version %{with_python_version}
+%endif
%if %{defined gdb-python2}
%define gdb-enable-python %{gdb_python2}
%else
2.19.1
