[RSB 1/3] 6/7: Update Newlib
Joel Sherrill
joel at rtems.org
Mon Oct 9 23:28:34 UTC 2023
What caused all the recently posted tool build failures?
On Mon, Oct 9, 2023, 4:52 PM Chris Johns <chrisj at rtems.org> wrote:
> Ok to all patches in the series. Thanks for newlib changes for ARM, they
> will be
> nice to use.
> Chris
> On 10/10/2023 3:58 am, Sebastian Huber wrote:
> > Pick up latest changes from ARM/optimized-routines.
> > Close 4510.
> > rtems/config/tools/rtems-gcc-10-newlib-head.cfg | 4 ++--
> > rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg | 4 ++--
> > rtems/config/tools/rtems-gcc-12-newlib-head.cfg | 4 ++--
> > rtems/config/tools/rtems-gcc-13-newlib-head.cfg | 4 ++--
> > rtems/config/tools/rtems-gcc-head-newlib-head.cfg | 4 ++--
> > 5 files changed, 10 insertions(+), 10 deletions(-)
> > diff --git a/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
> b/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
> > index 1cbb301..06524d4 100644
> > --- a/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
> > +++ b/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
> > @@ -17,12 +17,12 @@
> > %patch add newlib -p1
> https://devel.rtems.org/raw-attachment/ticket/4510/0001-aarch64-Add-ILP32-ABI-support-in-assembly-v2.patch
> > %hash sha512 0001-aarch64-Add-ILP32-ABI-support-in-assembly-v2.patch
> 7ca237eabfd5b382713186e1fc290dfc999a353315795ecb8dd0d22fcd1ab7f5bf31f4329954adab91ad04c100dcac0e86d406fdbce8f82cf9dc23842c88caf6
> > -%define newlib_version a021448
> > +%define newlib_version fe5886a
> > %define newlib_external 1
> > %define newlib_expand_name
> sourceware-mirror-newlib-cygwin-%{newlib_version}
> > %source set newlib --rsb-file=newlib-%{newlib_version}.tar.gz
> https://codeload.github.com/RTEMS/sourceware-mirror-newlib-cygwin/tar.gz/%{newlib_version}
> > %hash sha512 newlib-%{newlib_version}.tar.gz \
> YiC/BsmRpq8XsN1hx4s2Rvcwys/4DRFB3F6vvd+lEMJWXXpt3knXT4BBZkP11bkEcpDFCV9EaOlTT3HA7C3pCg==
> w7yxW6iO3ademyF5TTj0pe9zt6WCsYa46+MOY/Rter2loQjJDEnj2AE0YxUhV4fGG+mE/Df3igJH3rzuQYeXwQ==
> > %define with_threads 1
> > %define with_plugin 0
> > diff --git a/rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg
> b/rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg
> > index 99e2a21..e457b75 100644
> > --- a/rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg
> > +++ b/rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg
> > @@ -20,12 +20,12 @@
> > diff --git a/rtems/config/tools/rtems-gcc-12-newlib-head.cfg
> b/rtems/config/tools/rtems-gcc-12-newlib-head.cfg
> > index 04616eb..75dfcb2 100644
> > --- a/rtems/config/tools/rtems-gcc-12-newlib-head.cfg
> > +++ b/rtems/config/tools/rtems-gcc-12-newlib-head.cfg
> > @@ -38,13 +38,13 @@
> KEmxHjYOqY4LTXCMZ3I60tbHusbR5GlnP0CLARHPAnhCnovDj9K3U43C1bsMxDDGRqD6fwtrEFoEgqVFX63IuQ==
> > # Comment above related to #4657 and patches ends here
> > %source set newlib --rsb-file=newlib-%{newlib_version}.tar.gz \
> > diff --git a/rtems/config/tools/rtems-gcc-13-newlib-head.cfg
> b/rtems/config/tools/rtems-gcc-13-newlib-head.cfg
> > index 03b99da..7f7e3e2 100644
> > --- a/rtems/config/tools/rtems-gcc-13-newlib-head.cfg
> > +++ b/rtems/config/tools/rtems-gcc-13-newlib-head.cfg
> > @@ -8,12 +8,12 @@
> > %hash sha512 %{gcc_expand_name}.tar.gz \
> 7uw8yZWdjboqa1k1KPJTsOutVN66EEdrQ+ylaxZCFIwOihRUrct1loZ2Y3LXCYPG9JFso0i+22XEIlx3WMlrTQ==
> > diff --git a/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
> b/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
> > index 6b180fe..8499568 100644
> > --- a/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
> > +++ b/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
> > @@ -8,12 +8,12 @@
> f5WirlDNok+Gz/0HWrXpwZGJLFPHxcCGEEDLrJI6WxC8V+No4Z+hrorzpRjNGYgnMv175xXJFoIRXoaENhVoJQ==
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20231009/13278093/attachment-0001.htm>
