ADA, gnat, rtems 6, ubuntu 22LTS
emanuel stiebler emu at e-bbes.com
Tue Oct 10 15:49:20 UTC 2023
On 2023-10-05 12:42, Frank Kühndel wrote:
> Hello Emanuel,
> I cannot say anything about your specific issue. I can just provide this
> information:
> Our CI/CD builds rtems-tools with ADA on Ubuntu 22.04 for RSB, Git
> commit 35c73203df1e0bc7f0935cfb37ebc6581d8f1103 for aarch64, arm, bfin,
> i386, m68k, mips, moxie, nios2, or1k, powerpc, riskv, sparc, x86_64. The
> other architectures seem to have problems. Moreover, ADA is only build
> but not tested.
> The big issue between building with and without ADA comes down to have
> Ubuntu specially setup for the RTEMS Source Builder to being able to
> build ADA. I need these packages:
> bzip2
> gcc-12
> g++-12
> gnat-12
> And I need the following links (all g** compiler tools must have the
> same version 12 and all must be available without the "-12" postfix):
> ln -s gcc /usr/bin/cc
> for exe in /usr/bin/gcc*12 /usr/bin/gcov*12 /usr/bin/g++*12; do
>     ln -s $exe ${exe%-12}
> done
This did the trick, at least I can get the tools to compile.
We probably should mention that somewhere in the ADA set ups.
One glitch I noticed, that as soon as ubuntu updates the compiler again,
the links get removed, so the soft links has to be made again.
THANKS, emanuel
