[PATCH 2/3] cpukit/jffs2: Implement JFFS2 spinlocks
Sebastian Huber
Fri Oct 13 07:57:28 UTC 2023
On 06.10.23 22:09, Kinsey Moore wrote:
> This provides a non-noop implementation of spinlocks for JFFS2 in terms
> of RTEMS mutexes. POSIX spinlocks are not appropriate for the types of
> actions that occur during a held JFFS2 spinlock and can cause bad
> dispatch level conditions.
I think you are about to open a can of worms. So far, we had only one
global lock for the complete JFFS2 instance. If you really want to start
using the JFFS2 internal locking, then this should done thoroughly and
not case by case from one issue to the next. All this delayed write
stuff is currently not covered by tests.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
