[PATCH] bsps/aarch64/zynqmp/nand: Erase using offset
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Oct 18 20:40:18 UTC 2023
Prefer use of XNandPsu_Erase instead of XNandPsu_EraseBlock since the
XNandPsu driver does not expose the primitives necessary to ensure
device readiness after the operation is complete.
bsps/aarch64/xilinx-zynqmp/jffs2_xnandpsu.c | 8 +-------
1 file changed, 1 insertion(+), 7 deletions(-)
diff --git a/bsps/aarch64/xilinx-zynqmp/jffs2_xnandpsu.c b/bsps/aarch64/xilinx-zynqmp/jffs2_xnandpsu.c
index ab0eb1ccd5..b8c5140436 100644
--- a/bsps/aarch64/xilinx-zynqmp/jffs2_xnandpsu.c
+++ b/bsps/aarch64/xilinx-zynqmp/jffs2_xnandpsu.c
@@ -106,20 +106,14 @@ static int flash_erase(
XNandPsu *nandpsu = get_flash_control(super)->nandpsu;
rtems_status_code sc;
uint32_t BlockSize = nandpsu->Geometry.BlockSize;
- uint32_t DeviceSize = nandpsu->Geometry.DeviceSize;
- uint32_t BlockIndex;
- uint32_t DeviceIndex;
if (offset > nandpsu->Geometry.DeviceSize) {
return -EIO;
- DeviceIndex = offset / DeviceSize;
- BlockIndex = (offset % DeviceSize) / BlockSize;
/* Perform erase operation. */
rtems_mutex_lock(&(get_flash_control(super)->access_lock));
- sc = XNandPsu_EraseBlock(nandpsu, DeviceIndex, BlockIndex);
+ sc = XNandPsu_Erase(nandpsu, RTEMS_ALIGN_DOWN(offset, BlockSize), BlockSize);
rtems_mutex_unlock(&(get_flash_control(super)->access_lock));
if (sc ) {
return -EIO;
2.39.2
