[PATCH v2 3/9] bsps/leon3: Make GPTIMER fall back mandatory
Thu Oct 19 13:44:38 UTC 2023
Hello Martin,
thanks for the review.
On 19.10.23 12:22, Martin Åberg wrote:
> On 2023-10-13 13:00, Sebastian Huber wrote:
>> Hello Martin,
>> On 13.10.23 12:09, Martin Åberg wrote:
>>> What are the implications when using RTEMS_MULTIPROCESSING together
>>> with "use_gptimer"?
>>> In bsps/sparc/leon3/include/bsp/leon3.h, we have:
>>>  >  #if defined(RTEMS_MULTIPROCESSING)
>>>  >  #define LEON3_CLOCK_INDEX \
>>>  >    ( rtems_configuration_get_user_multiprocessing_table() ?
>>> LEON3_Cpu_Index : 0 )
>>>  >  #else
>>>  >  #define LEON3_CLOCK_INDEX 0
>>>  >  #endif
>>> Can LEON3_COUNTER_GPTIMER_INDEX of CPU0 be equal to LEON3_CLOCK_INDEX
>>> of CPU1 here?
>> The individual RTEMS instances could share the GPTIMER configured in
>> free-running mode.
> LEON3_Timer_Regs is probed in amba.c. There is a link time option to set
> GPTIMER core index (leon3_timer_core_index). Instances could have unique
> GPTIMER cores associated.
> The preprocessor symbols LEON3_CLOCK_INDEX (clock driver) and
> LEON3_COUNTER_GPTIMER_INDEX (timecounter) are used as subtimer index of
> the GPTIMER core LEON3_Timer_Regs.
> For CPU0 these are:
>    - LEON3_CLOCK_INDEX is 0 (equal to hardware processor index)
>    - LEON3_COUNTER_GPTIMER_INDEX is 1 (LEON3_CLOCK_INDEX+1)
> For CPU1 these are:
>    - LEON3_CLOCK_INDEX is 1 (equal to hardware processor index)
>    - LEON3_COUNTER_GPTIMER_INDEX is 2 (LEON3_CLOCK_INDEX+1)
> etc...
> In the case when LEON3_Timer_Regs is different on CPU0 and CPU1, there
> is no conflict but will leave low-numbered subtimers unused. (Behavior
> not introduced by this patch.)
> In the case when LEON3_Timer_Regs is equal on the CPU0 and CPU1
> instances, it appears there is now a conflict between
> CPU0:LEON3_COUNTER_GPTIMER_INDEX and CPU1:LEON3_CLOCK_INDEX.
Ok, I suggest to change the LEON3_CLOCK_INDEX definition to:
  * @brief This constant defines the index of the GPTIMER timer used by the
  *   clock driver.
   ( leon3_timer_core_index != 0 ? 0 : 2 * LEON3_Cpu_Index )
#else
#endif
  *   CPU counter if the CPU counter uses the GPTIMER.
#if defined(RTEMS_SMP)
#define LEON3_COUNTER_GPTIMER_INDEX ( LEON3_CLOCK_INDEX + 1 )
#else
#define LEON3_COUNTER_GPTIMER_INDEX LEON3_CLOCK_INDEX
#endif
The rtems_configuration_get_user_multiprocessing_table() is always !=
NULL if RTEMS_MULTIPROCESSING is defined.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
