[PATCH] build: Let the get-integer action return None
Sebastian Huber
Fri Oct 20 09:16:32 UTC 2023
If used with the format-and-define action, this will result in an
undefined define.
wscript | 2 ++
1 file changed, 2 insertions(+)
diff --git a/wscript b/wscript
index c8481d4fde..595dc09efd 100755
--- a/wscript
+++ b/wscript
@@ -1011,6 +1011,8 @@ class OptionItem(Item):
value = self.default_value(conf.env.ENABLE)
if value is None:
return value
+ if not value:
+ return None
try:
return eval(value)
except Exception as e:
2.35.3
