[PATCH] fixed warning related to spstdc17
zack leung
zakthertemsdev at gmail.com
Sun Oct 29 01:44:52 UTC 2023
./../../cpukit/include/rtems/score/schedulerpriority.h:87:21: error: field
'Base' has incomplete type
87 | Scheduler_Context Base;
../../../cpukit/include/rtems/score/schedulersimple.h:89:21: error: field
89 | Scheduler_Context Base;
I get this error when using typedefs
#if defined(RTEMS_SMP)
typedef struct Scheduler_Context {
* @brief Lock to protect this scheduler instance.
ISR_lock_Control Lock;
* @brief The set of processors owned by this scheduler instance.
Processor_mask Processors;
} Scheduler_Context;
#endif
#if !defined(RTEMS_SMP)
typedef struct Scheduler_Context Scheduler_Context;
#endif
or
#else
#endif
On Fri, 27 Oct 2023 at 01:40, Sebastian Huber <
> On 27.10.23 03:43, zack leung wrote:
> > ping
> > On Tue, 24 Oct 2023 at 22:17, zack leung <zakthertemsdev at gmail.com
> > <mailto:zakthertemsdev at gmail.com>> wrote:
> > that didn't work but i'm thinking of defining a char array that is
> > equal to the size of the processor lock and the isr lock?
> This is a bit complicated and still leads to a size increase.
> > i figured
> > that the processor lock is 64 bits and isr lock is a one bit?
> > I'm confused on how to make an api define do you have a file i can
> > look at?
> Maybe you try to fix the Scheduler_Context warning first. It is easier
> to fix. I am pretty sure that this approach works:
> Get rid of the empty structures is to just provide typedefs, for example:
> #else
> #endif
> Then you have to make sure that #if !defined(RTEMS_SMP) no objects of
> this type are used.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20231028/85952bc3/attachment.htm>
