[PATCH] build: Remove enabled-by special case
Mon Sep 18 23:22:06 UTC 2023
Looks good.
Thanks
On 18/9/2023 8:26 pm, Sebastian Huber wrote:
> Doing the enabled-by processing just for the ldflags and just for the
> link custom commands is confusing.  Use an option instead which is
> intended to be used for such use cases.
>  spec/build/testsuites/libtests/dl07.yml       |  4 +---
>  spec/build/testsuites/libtests/dl08.yml       |  4 +---
>  spec/build/testsuites/libtests/dl09.yml       |  4 +---
>  spec/build/testsuites/libtests/grp.yml        |  2 ++
>  .../testsuites/libtests/optdlldflags.yml      | 22 +++++++++++++++++++
>  wscript                                       | 12 +++-------
>  6 files changed, 30 insertions(+), 18 deletions(-)
>  create mode 100644 spec/build/testsuites/libtests/optdlldflags.yml
> diff --git a/spec/build/testsuites/libtests/dl07.yml b/spec/build/testsuites/libtests/dl07.yml
> index e443f4ed29..5760f68b87 100644
> --- a/spec/build/testsuites/libtests/dl07.yml
> +++ b/spec/build/testsuites/libtests/dl07.yml
> @@ -33,9 +33,7 @@ enabled-by:
>  includes:
>  - testsuites/libtests/dl07
>  ldflags:
> -- enabled-by:
> -  - microblaze
> -  value: -u__extendsfdf2
> +- ${LIBDL_TESTS_LDFLAGS}
>  links: []
>  prepare-build: null
>  prepare-configure: null
> diff --git a/spec/build/testsuites/libtests/dl08.yml b/spec/build/testsuites/libtests/dl08.yml
> index 8e5eec77f2..ada6caf698 100644
> --- a/spec/build/testsuites/libtests/dl08.yml
> +++ b/spec/build/testsuites/libtests/dl08.yml
> @@ -38,9 +38,7 @@ enabled-by:
>  includes:
>  - testsuites/libtests/dl08
>  ldflags:
> -- enabled-by:
> -  - microblaze
>  links: []
>  prepare-build: null
> diff --git a/spec/build/testsuites/libtests/dl09.yml b/spec/build/testsuites/libtests/dl09.yml
> index 2d00286c15..ee0be57fb2 100644
> --- a/spec/build/testsuites/libtests/dl09.yml
> +++ b/spec/build/testsuites/libtests/dl09.yml
>  includes:
>  - testsuites/libtests/dl09
>  ldflags:
> -- enabled-by:
> -  - microblaze
>  links: []
>  prepare-build: null
> diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
> index c1a6209e99..eaf21751c4 100644
> --- a/spec/build/testsuites/libtests/grp.yml
> +++ b/spec/build/testsuites/libtests/grp.yml
> @@ -22,6 +22,8 @@ links:
>    uid: ../optgzip
>  - role: build-dependency
>    uid: ../optxz
> +- role: build-dependency
> +  uid: optdlldflags
>    uid: optrtemsld
> diff --git a/spec/build/testsuites/libtests/optdlldflags.yml b/spec/build/testsuites/libtests/optdlldflags.yml
> new file mode 100644
> index 0000000000..0d754c5270
> --- /dev/null
> +++ b/spec/build/testsuites/libtests/optdlldflags.yml
> @@ -0,0 +1,22 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +actions:
> +- get-string: null
> +- split: null
> +- env-assign: null
> +build-type: option
> +copyrights:
> +- Copyright (C) 2023 embedded brains GmbH & Co. KG
> +default:
> +- enabled-by: microblaze
> +  value:
> +  - -u__extendsfdf2
> +- enabled-by: true
> +  value: []
> +description: |
> +  Linker flags used to link libdl tests with a base image.  For example, it may
> +  be used to add undefined symbols which the linker has to resolve to pull in
> +  services required by loaded parts.
> +enabled-by: true
> +links: []
> +name: LIBDL_TESTS_LDFLAGS
> +type: build
> diff --git a/wscript b/wscript
> index 00b81b4874..65f90fc324 100755
> --- a/wscript
> +++ b/wscript
> @@ -360,7 +360,7 @@ class Item(object):
>              def __init__(self, item, bic, cmd, env, ldflags):
>                  super(link, self).__init__(self, env=env)
>                  self.cmd = cmd
> -                self.ldflags = bic.ldflags + ldflags
> +                self.ldflags = ldflags
>                  self.stlib = item.data["stlib"]
>                  self.use = (item.data["use-before"] + bic.use +
>                              item.data["use-after"])
> @@ -386,14 +386,8 @@ class Item(object):
> -        ldflags = []
> -        for ldflag in self.data["ldflags"]:
> -            if isinstance(ldflag, dict):
> -                if _is_enabled(bld.env.ENABLE, ldflag["enabled-by"]):
> -                    ldflags.append(ldflag["value"])
> -            else:
> -                ldflags.append(ldflag)
> -        tsk = link(self, bic, cmd, bld.env, ldflags)
> +        tsk = link(self, bic, cmd, bld.env,
> +                   bic.ldflags + self.substitute(bld, self.data["ldflags"]))
>          tsk.set_inputs([bld.bldnode.make_node(s) for s in source])
>          tsk.set_outputs(bld.bldnode.make_node(target))
>          bld.add_to_group(tsk)
