[PATCH] validation: Check stack of interrupted context
Thu Sep 21 14:44:53 UTC 2023
Check the stack of the interrupted context during the multitasking
start.
Update #4955.
 .../testsuites/validation/validation-intr.yml |   3 +
 testsuites/validation/tc-score-isr.c          | 225 ++++++++++++++++++
 2 files changed, 228 insertions(+)
 create mode 100644 testsuites/validation/tc-score-isr.c
diff --git a/spec/build/testsuites/validation/validation-intr.yml b/spec/build/testsuites/validation/validation-intr.yml
index 1383aba2b3..2c478e6484 100644
--- a/spec/build/testsuites/validation/validation-intr.yml
+++ b/spec/build/testsuites/validation/validation-intr.yml
@@ -9,8 +9,10 @@ enabled-by: true
 features: c cprogram
 includes: []
 ldflags:
+- -Wl,--wrap=bsp_interrupt_dispatch
 - -Wl,--wrap=bsp_interrupt_handler_default
 - -Wl,--wrap=bsp_interrupt_spurious
+- -Wl,--wrap=_SPARC_Interrupt_dispatch
 links: []
 source:
 - testsuites/validation/tc-bsp-interrupt-handler-dispatch-unchecked.c
@@ -27,6 +29,7 @@ source:
 - testsuites/validation/tc-intr-vector-disable.c
 - testsuites/validation/tc-intr-vector-enable.c
 - testsuites/validation/tc-intr-vector-is-enabled.c
+- testsuites/validation/tc-score-isr.c
 - testsuites/validation/ts-validation-intr.c
 stlib: []
 target: testsuites/validation/ts-validation-intr.exe
diff --git a/testsuites/validation/tc-score-isr.c b/testsuites/validation/tc-score-isr.c
new file mode 100644
index 0000000000..4374b1b130
--- /dev/null
+++ b/testsuites/validation/tc-score-isr.c
@@ -0,0 +1,225 @@
+ * @file
+ * @ingroup ScoreIsrValIsr
+ * Copyright (C) 2023 embedded brains GmbH & Co. KG
+ * are met:
+ * This file is part of the RTEMS quality process and was automatically
+ * generated.  If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual.  The manual is provided as a part of
+ * a release.  For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <rtems/sysinit.h>
+#include <rtems/score/percpu.h>
+#include <rtems/score/thread.h>
+#include "tx-support.h"
+#include <rtems/test.h>
+ * @defgroup ScoreIsrValIsr spec:/score/isr/val/isr
+ * @ingroup TestsuitesValidationIntr
+ * @brief Tests general interrupt support behaviour.
+ * This test case performs the following actions:
+ * - Submit an ISR request during system initialization.  Check the stack of
+ *   the interrupted context while the ISR request is serviced.  Store the
+ *   result of the check in interrupted_stack_at_multitasking_start_is_valid.
+ *   - Check that stack of the interrupted context was valid when an interrupt
+ *     was serviced during the multitasking start.
+static uintptr_t interrupted_stack_at_multitasking_start;
+static bool interrupted_stack_at_multitasking_start_is_valid;
+#if defined(__aarch64__)
+void __real_bsp_interrupt_dispatch( void );
+void __wrap_bsp_interrupt_dispatch( void );
+  if ( interrupted_stack_at_multitasking_start == 0 ) {
+    uintptr_t             sp;
+    rtems_interrupt_level level;
+    rtems_interrupt_local_disable( level );
+    __asm__ volatile (
+      "msr spsel, #0\n"
+      "mov %0, sp\n"
+      "msr spsel, #1"
+      : "=r" ( sp )
+    rtems_interrupt_local_enable( level );
+    interrupted_stack_at_multitasking_start = sp;
+  __real_bsp_interrupt_dispatch();
+#endif
+#if defined(ARM_MULTILIB_ARCH_V4)
+  register uintptr_t sp __asm__( "9" );
+#endif
+#if defined(__sparc__)
+void __real__SPARC_Interrupt_dispatch( uint32_t irq );
+static RTEMS_USED void InterruptDispatch( uint32_t irq, uintptr_t sp )
+  __real__SPARC_Interrupt_dispatch( irq );
+__asm__ (
+  "\t.section\t\".text\"\n"
+  "\t.align\t4\n"
+  "\t.globl\t__wrap__SPARC_Interrupt_dispatch\n"
+  "\t.type\t__wrap__SPARC_Interrupt_dispatch, #function\n"
+  "__wrap__SPARC_Interrupt_dispatch:\n"
+  "\tmov\t%fp, %o1\n"
+  "\tor\t%o7, %g0, %g1\n"
+  "\tcall\tInterruptDispatch, 0\n"
+  "\t or\t%g1, %g0, %o7\n"
+  "\t.previous\n"
+#endif
+static void ISRHandler( void *arg )
+  uintptr_t begin;
+  uintptr_t end;
+  (void) arg;
+#if defined(RTEMS_SMP)
+  Per_CPU_Control *cpu_self;
+  cpu_self = _Per_CPU_Get();
+  begin = (uintptr_t) &cpu_self->Interrupt_frame;
+  end = begin + sizeof( cpu_self->Interrupt_frame );
+#else
+  Thread_Control *executing;
+  executing = GetExecuting();
+  begin = (uintptr_t) executing->Start.Initial_stack.area;
+  end = begin + executing->Start.Initial_stack.size;
+#endif
+  interrupted_stack_at_multitasking_start_is_valid =
+    ( begin <= interrupted_stack_at_multitasking_start &&
+      interrupted_stack_at_multitasking_start < end );
+static CallWithinISRRequest isr_request = {
+  .handler = ISRHandler
+static void SubmitISRRequest( void )
+  CallWithinISRSubmit( &isr_request );
+RTEMS_SYSINIT_ITEM(
+  SubmitISRRequest,
+  RTEMS_SYSINIT_DEVICE_DRIVERS,
+  RTEMS_SYSINIT_ORDER_MIDDLE
+ * @brief Submit an ISR request during system initialization.  Check the stack
+ *   of the interrupted context while the ISR request is serviced.  Store the
+static void ScoreIsrValIsr_Action_0( void )
+   * The actions are performed during system initialization and the
+   * multitasking start.
+   * Check that stack of the interrupted context was valid when an interrupt
+  T_true( interrupted_stack_at_multitasking_start_is_valid );
+ * @fn void T_case_body_ScoreIsrValIsr( void )
+T_TEST_CASE( ScoreIsrValIsr )
+  ScoreIsrValIsr_Action_0();
2.35.3
