[PATCH 1/2] cpukit/jffs2: Set extracted nodes off-chain
Thu Sep 21 14:47:49 UTC 2023
On 20.09.23 20:35, Kinsey Moore wrote:
> @@ -1306,8 +1307,22 @@ static void process_delayed_work(void)
>   	while (!rtems_chain_is_tail(&process_work_chain, node)) {
>   		work = (struct delayed_work*) node;
>   		rtems_chain_node* next_node = rtems_chain_next(node);
> +		 * Don't leave extracted node exposed to other operations
> +		 * under RTEMS_DEBUG
> +#ifdef RTEMS_DEBUG
> +		mutex_lock(&delayed_work_mutex);
> +#endif
>   		rtems_chain_extract(node);
> +#ifdef RTEMS_DEBUG
> +		node->next = node;
> +		mutex_unlock(&delayed_work_mutex);
> +#endif
>   		work->callback(&work->work);
> +		rtems_chain_set_off_chain(node);
>   		node = next_node;
This change makes no sense to me. The code should work regardless if
RTEMS_DEBUG is defined or not.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
