[PATCH 1/2] cpukit/jffs2: Set extracted nodes off-chain
Thu Sep 21 15:01:24 UTC 2023
On 21.09.23 16:52, Kinsey Moore wrote:
> On Thu, Sep 21, 2023 at 9:47 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 20.09.23 20:35, Kinsey Moore wrote:
>      > @@ -1306,8 +1307,22 @@ static void process_delayed_work(void)
>      >       while (!rtems_chain_is_tail(&process_work_chain, node)) {
>      >               work = (struct delayed_work*) node;
>      >               rtems_chain_node* next_node = rtems_chain_next(node);
>      > +              * Don't leave extracted node exposed to other
>     operations
>      > +              * under RTEMS_DEBUG
>      > +#ifdef RTEMS_DEBUG
>      > +             mutex_lock(&delayed_work_mutex);
>      > +#endif
>      >               rtems_chain_extract(node);
>      > +#ifdef RTEMS_DEBUG
>      > +             node->next = node;
>      > +             mutex_unlock(&delayed_work_mutex);
>      > +#endif
>      >               work->callback(&work->work);
>      > +             rtems_chain_set_off_chain(node);
>      >               node = next_node;
>     This change makes no sense to me. The code should work regardless if
>     RTEMS_DEBUG is defined or not.
> RTEMS_DEBUG introduces a behavioral change in rtems_chain_extract() such
> that extracted nodes are automatically set off-chain. When RTEMS_DEBUG
> is not set, node->next is left untouched. This has to be managed because
> this code needs the node to remain on-chain so that it is not re-queued
> during the operation.
Yes, but while a node is on a chain you must not call
rtems_chain_set_off_chain(). If you want to use the off-chain state,
then you have to use this:
or
rtems_chain_extract_unprotected(node);
The automatic set off-chain in RTEMS_DEBUG is just to ensure that basic
chain operations are used in the right state.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
