[PATCH v2 3/9] bsps/leon3: Make GPTIMER fall back mandatory
Thu Sep 21 15:19:28 UTC 2023
Using the auto reload counter which generates the clock ticks for the
timecounter or CPU counter is quite difficult and only works in
uniprocessor configurations.
Update #4954.
 bsps/sparc/leon3/clock/ckinit.c      | 35 ++--------------------------
 bsps/sparc/leon3/include/bsp/leon3.h |  4 ----
 bsps/sparc/leon3/start/cpucounter.c  |  2 +-
 3 files changed, 3 insertions(+), 38 deletions(-)
diff --git a/bsps/sparc/leon3/clock/ckinit.c b/bsps/sparc/leon3/clock/ckinit.c
index eea4649fa3..d800f01e4a 100644
--- a/bsps/sparc/leon3/clock/ckinit.c
+++ b/bsps/sparc/leon3/clock/ckinit.c
@@ -69,19 +69,6 @@ static struct timecounter leon3_tc;
 static void leon3_tc_tick_default(void)
-#if !defined(RTEMS_SMP)
-  SPARC_Counter *counter;
-  rtems_interrupt_level level;
-  counter = &_SPARC_Counter;
-  rtems_interrupt_local_disable(level);
-  grlib_store_32(&LEON3_IrqCtrl_Regs->iclear, counter->pending_mask);
-  counter->accumulated += counter->interval;
-  rtems_interrupt_local_enable(level);
-#endif
   rtems_timecounter_tick();
@@ -238,29 +225,11 @@ static void leon3_clock_use_gptimer(
   gptimer_timer *timer
-#ifdef RTEMS_SMP
-   * The GR712RC for example has no timestamp unit in the interrupt
-   * controller.  At least on SMP configurations we must use a second timer
-   * in free running mode for the timecounter.  The timer is initialized by
-   * leon3_counter_initialize().
+   * As a fall back, use a second timer in free-running mode for the
+   * timecounter.  The timer is initialized by leon3_counter_initialize().
   tc->tc_get_timecount = _SPARC_Get_timecount_down;
-#else
-  counter->read_isr_disabled = _SPARC_Counter_read_clock_isr_disabled;
-  counter->read = _SPARC_Counter_read_clock;
-  counter->counter_register = &timer->tcntval;
-  counter->pending_register = &LEON3_IrqCtrl_Regs->ipend;
-  counter->pending_mask = UINT32_C(1) << clkirq;
-  counter->accumulated = rtems_configuration_get_microseconds_per_tick();
-  counter->interval = rtems_configuration_get_microseconds_per_tick();
-  tc->tc_get_timecount = _SPARC_Get_timecount_clock;
-#endif
   tc->tc_frequency = LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER,
   rtems_timecounter_install(tc);
diff --git a/bsps/sparc/leon3/include/bsp/leon3.h b/bsps/sparc/leon3/include/bsp/leon3.h
index fdb43b5817..84790b590f 100644
--- a/bsps/sparc/leon3/include/bsp/leon3.h
+++ b/bsps/sparc/leon3/include/bsp/leon3.h
@@ -188,11 +188,7 @@ static inline uint32_t leon3_get_cpu_count( const irqamp *regs )
  * @brief This constant defines the index of the GPTIMER timer used by the
  *   CPU counter if the CPU counter uses the GPTIMER.
-#if defined(RTEMS_SMP)
 #define LEON3_COUNTER_GPTIMER_INDEX ( LEON3_CLOCK_INDEX + 1 )
-#else
-#define LEON3_COUNTER_GPTIMER_INDEX LEON3_CLOCK_INDEX
-#endif
  * @brief This constant defines the frequency set by the boot loader of the
diff --git a/bsps/sparc/leon3/start/cpucounter.c b/bsps/sparc/leon3/start/cpucounter.c
index a6db7677a3..374e43c9b1 100644
--- a/bsps/sparc/leon3/start/cpucounter.c
+++ b/bsps/sparc/leon3/start/cpucounter.c
@@ -89,7 +89,7 @@ static void leon3_counter_use_gptimer(SPARC_Counter *counter, gptimer *gpt)
   counter->read = _SPARC_Counter_read_down;
-  /* Make timer free running */
+  /* Make timer free-running */
   grlib_store_32(&timer->trldval, 0xffffffff);
   grlib_store_32(&timer->tctrl, GPTIMER_TCTRL_EN | GPTIMER_TCTRL_RS);
2.35.3
