[PATCH 1/2] bsps/xqspipsu: Break out RDID
Kinsey Moore kinsey.moore at oarcorp.com
Thu Sep 21 21:31:44 UTC 2023
Expose a function to read the NOR flash chip ID information beyond the
minimum 3 bytes for the lookup table.
 bsps/include/dev/spi/xqspipsu-flash-helper.h | 15 +++++++
 bsps/shared/dev/spi/xqspipsu-flash-helper.c  | 45 +++++++++++++-------
 2 files changed, 44 insertions(+), 16 deletions(-)
diff --git a/bsps/include/dev/spi/xqspipsu-flash-helper.h b/bsps/include/dev/spi/xqspipsu-flash-helper.h
index 5e4233e64e..1578fe8485 100644
--- a/bsps/include/dev/spi/xqspipsu-flash-helper.h
+++ b/bsps/include/dev/spi/xqspipsu-flash-helper.h
@@ -155,3 +155,18 @@ u32 QspiPsu_NOR_Get_Device_Size(XQspiPsu *QspiPsuPtr);
 u32 QspiPsu_NOR_Get_Sector_Size(XQspiPsu *QspiPsuPtr);
+ * This function performs a read of the RDID configuration space.
+ * @param	QspiPsuPtr is a pointer to the QSPIPSU driver component to use.
+ * @param	ReadBfrPtr is a pointer to a buffer to be filled with
+ * 		configuration data.
+ * @param	ReadLen is the total length of the configuration space to read.
+ * @return	XST_SUCCESS if successful, else XST_FAILURE.
+int QspiPsu_NOR_RDID(XQspiPsu *QspiPsuPtr, u8 *ReadBfrPtr, u32 ReadLen);
diff --git a/bsps/shared/dev/spi/xqspipsu-flash-helper.c b/bsps/shared/dev/spi/xqspipsu-flash-helper.c
index c9d8273b87..0dd065f02e 100644
--- a/bsps/shared/dev/spi/xqspipsu-flash-helper.c
+++ b/bsps/shared/dev/spi/xqspipsu-flash-helper.c
@@ -274,22 +274,9 @@ static void QspiPsuHandler(
- * Reads the flash ID and identifies the flash in FCT table.
- * @param	QspiPsuPtr is a pointer to the QSPIPSU driver component to use.
- * @return	XST_SUCCESS if successful, else XST_FAILURE.
- * @note	None.
-static int FlashReadID(XQspiPsu *QspiPsuPtr)
   int Status;
-  u32 ReadId = 0;
    * Read ID
@@ -303,7 +290,7 @@ static int FlashReadID(XQspiPsu *QspiPsuPtr)
   FlashMsg[1].TxBfrPtr = NULL;
   FlashMsg[1].RxBfrPtr = ReadBfrPtr;
-  FlashMsg[1].ByteCount = 3;
+  FlashMsg[1].ByteCount = ReadLen;
   FlashMsg[1].BusWidth = XQSPIPSU_SELECT_MODE_SPI;
   FlashMsg[1].Flags = XQSPIPSU_MSG_FLAG_RX;
@@ -314,7 +301,33 @@ static int FlashReadID(XQspiPsu *QspiPsuPtr)
   while (TransferInProgress);
-  rtems_cache_invalidate_multiple_data_lines(ReadBfrPtr, 3);
+  rtems_cache_invalidate_multiple_data_lines(ReadBfrPtr, ReadLen);
+  return XST_SUCCESS;
+ * Reads the flash ID and identifies the flash in FCT table.
+ * @note	None.
+static int FlashReadID(XQspiPsu *QspiPsuPtr)
+  u32 ReadId = 0;
+  u32 ReadLen = 3;
+  int Status;
+  Status = QspiPsu_NOR_RDID(QspiPsuPtr, ReadBfrPtr, ReadLen);
+  if (Status != XST_SUCCESS) {
+    return XST_FAILURE;
   /* In case of dual, read both and ensure they are same make/size */
2.39.2
