[PATCH] validation: Check stack of interrupted context
Tue Sep 26 05:59:12 UTC 2023
On 22.09.23 18:54, Kinsey Moore wrote:
> On Fri, Sep 22, 2023 at 10:46 AM Kinsey Moore <kinsey.moore at oarcorp.com
> <mailto:kinsey.moore at oarcorp.com>> wrote:
>     On Fri, Sep 22, 2023 at 7:44 AM Sebastian Huber
>     <sebastian.huber at embedded-brains.de
>     <mailto:sebastian.huber at embedded-brains.de>> wrote:
>         On 21.09.23 16:59, Kinsey Moore wrote:
>          > Ok, thanks! I'll take a look and see what I can find.
>         Thanks, I did run the test case also on riscv and it worked fine in
>         uniprocessor and SMP configurations.
>     Without the patch on SMP, I'm seeing a hang on "B:RtemsIntrReqRaise"
>     on QEMU (latest from RSB). With the patch on SMP, I'm seeing a
>     somewhat different assert from inside _Thread_Handler on line 139.
>     It seems related, so I'll keep looking into it.
> It looks like the "msr spsel, #" directives are swapped in the wrapper
> function that gets the non-interrupt stack pointer. This has the result
> of corrupting the interrupt stack with a value from the non-interrupt
> stack and leaving the interrupt stack in a state to continue
> recorrupting the non-interrupt stack. As you can imagine, this causes
> some problems. Swapping the spsel assembly seems to resolve the issue.
Thanks for having a look at this. I changed the code and now it works.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
