[Bugfix rtems-lwip 3/4] Correct the task prio of link_detect_thread
Markus Moessner moma.devel at gmail.com
Tue Apr 2 07:44:17 UTC 2024
Running SMP on zynq7000 - my theory was that u might use QEMU.
Kinsey Moore <kinsey.moore at oarcorp.com> schrieb am Mo., 1. Apr. 2024, 16:35:
> You might be seeing different behavior than I have if you're running
> single-core. Almost all my lwIP usage has been on 4 cores on the ZynqMP.
> Kinsey
> On Sun, Mar 31, 2024 at 5:49 PM Bernd Moessner <berndmoessner80 at gmail.com>
> wrote:
>> On my side, the link_detect_thread never gets to running state.
>> I assume that the issues with the FreeRTOS tick rate and delay
>> definitions have never been observed as the associated thread
>> was never running / no one requied it to run. Previously, the
>> link_detect_thread was set to RTEMS_MAXIMUM_PRIORITY (255).
>> As far as I understand the docs, this should have worked out
>> (why didnt it?). Using sched_get_priority_max (returns 254),
>> the thread becomes active.
>>  rtemslwip/xilinx/xlwipopts.h | 4 +++-
>>  1 file changed, 3 insertions(+), 1 deletion(-)
>> diff --git a/rtemslwip/xilinx/xlwipopts.h b/rtemslwip/xilinx/xlwipopts.h
>> index 8befd67..0f4316f 100644
>> --- a/rtemslwip/xilinx/xlwipopts.h
>> +++ b/rtemslwip/xilinx/xlwipopts.h
>> @@ -27,8 +27,10 @@
>>  #ifndef __XLWIPOPTS_H__
>>  #define __XLWIPOPTS_H__
>> +#include <sched.h>
>>  /* These macros allow RTEMS to pretend to be FreeRTOS for Xilinx drivers
>> -#define tskIDLE_PRIORITY RTEMS_MAXIMUM_PRIORITY
>> +#define tskIDLE_PRIORITY sched_get_priority_max(SCHED_RR)
>>  #define portTICK_RATE_MS (1000 / rtems_clock_get_ticks_per_second())
>>  #define vTaskDelay(x) rtems_task_wake_after(x)
>> 2.34.1
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240402/7870d471/attachment.htm>
