[PATCH rtems-source-builder 2/2] qemu-xilinx: Update to 2023.2
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Apr 3 16:32:56 UTC 2024
Ping
On Tue, Mar 5, 2024 at 4:13 PM Kinsey Moore <kinsey.moore at oarcorp.com>
wrote:
> The 2020.2 version of Xilinx's qemu branch does not build on AArch64 due
> to a merge conflict that was integrated into the repository and never
> corrected. This brings qemu-xilinx up to 2023.2 to resolve that issue
> and allow it to build on AArch64 systems.
> bare/config/devel/qemu-xilinx-v2023.2-1.cfg | 37 +++++++++++++++++++++
> bare/config/devel/qemu-xilinx.bset | 2 +-
> 2 files changed, 38 insertions(+), 1 deletion(-)
> create mode 100644 bare/config/devel/qemu-xilinx-v2023.2-1.cfg
> diff --git a/bare/config/devel/qemu-xilinx-v2023.2-1.cfg
> b/bare/config/devel/qemu-xilinx-v2023.2-1.cfg
> new file mode 100644
> index 0000000..ab808bf
> --- /dev/null
> +++ b/bare/config/devel/qemu-xilinx-v2023.2-1.cfg
> @@ -0,0 +1,37 @@
> +# Xilinx Qemu from git
> +%if %{release} == %{nil}
> + %define release 1
> +%endif
> +%include %{_configdir}/base.cfg
> +%include %{_configdir}/bare-config.cfg
> +%define qemu_version xilinx_v2023.2
> +# Checkout the version tag and initialize all submodules.
> +%source set qemu git://
> github.com/Xilinx/qemu.git?protocol=https?checkout=%{qemu_version}?submodule=dtc?submodule=slirp?submodule=ui/keycodemapdb?submodule=tests/fp/berkeley-softfloat-3?submodule=tests/fp/berkeley-testfloat-3
> +# Patch to fix cgem priority queue interrupt functionality issue
> +#%patch add qemu --rsb-file=xlnx_cgem_zynqmp_versal.patch -p1
> https://devel.rtems.org/raw-attachment/ticket/4919/0001-hw-arm-xlnx-Connect-secondary-CGEM-IRQs-xlnx.patch
> +#%hash sha512 xlnx_cgem_zynqmp_versal.patch \
> tGjJn7o8/fQwdC0sgsYmPW6bqDzMkwhKRqBwuuy8sdEKivDj7uGISMj7p8Iwy9fkHiO3Dd3feno+iz5fHYGBkA==
> +# Patch to fix PPC64 build under GCC 13.2.0
> +#%patch add qemu --rsb-file=xlnx_ppc64_enum.patch -p1
> https://devel.rtems.org/raw-attachment/ticket/4988/0001-target-ppc-Resolve-int-enum-mismatch-on-ppc64.patch
> +#%hash sha512 xlnx_ppc64_enum.patch \
> afYfClJ5IO9eV23dOAqxurzAnwS1YmiOEPCts/ftXS/ddXp9Rx2oQYuKeZriawKw7MVlqWNv9eTc5ERoFhRKOg==
> +# The Qemu build instructions. We use 5.x.x Release 1.
> +%include %{_configdir}/qemu-5-1.cfg
> diff --git a/bare/config/devel/qemu-xilinx.bset
> b/bare/config/devel/qemu-xilinx.bset
> index 5bcbe2f..5a204ca 100644
> --- a/bare/config/devel/qemu-xilinx.bset
> +++ b/bare/config/devel/qemu-xilinx.bset
> @@ -21,4 +21,4 @@ devel/gettext-0.18.3.1-1
> devel/libffi-3.0.13-1
> devel/pixman-0.40.0-1
> devel/glib-2.56.4-1
> -devel/qemu-xilinx-v2020.2-1
> +devel/qemu-xilinx-v2023.2-1
> 2.39.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240403/76a0352c/attachment-0001.htm>
