utf32 support
John Howard
echosoft.llc at gmail.com
Sat Apr 6 05:44:19 UTC 2024
testsuites/samples/utf32/utf32.h | 45 +-
1 file changed, 45 insertions(+), 0 deletion(-)
create mode 100644 testsuites/samples/utf32/utf32.h
diff --git a/testsuites/samples/utf32/utf32.h b/testsuites/samples/utf32/utf32.h
index 83f6342ab3..5ebcdc9ef2 100644
--- /dev/null
+++ b/testsuites/samples/utf32/utf32.h
@@ -0,0 +1,45 @@
+ Copyright 2024 John Howard
+ All Rights Reserved.
+ CUBITS is a trademark of John Howard.
+ CUBITS means Capital, Underline, Bold, Italic, Texture, and Strike.
+ This file is part of the RTEMS.org test suites samples.
+ Permission to use, copy, modify, and/or distribute this software for any
+ purpose with or without fee is hereby granted, provided that the above
+ copyright notice and this permission notice appear in all copies.
+ THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
+ WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
+ MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
+ ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
+ WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
+ ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
+ OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+/* Unicode & ISO 10646-2012 character ranges 0..\UFFFFFFFF. */
+typedef int utf32;
+/* Convert UTF32 Big Endian and Little Endian v ranges 0..0xFFFFFFFF. */
+#define CONVERT_(v) ((((v) & 255) << 24) | ((((v) >> 8) & 255) << 16) | \
+ ((((v) >> 16) & 255) << 8) | (((v) >> 24) & 255))
+/* Set zero-based nth bit of v ranges 0..0xFFFFFFFF. n ranges 0..31. */
+#define SETBIT_(v,n) ((v) |= (1 << (n)))
+/* Unset zero-based nth bit of v ranges 0..0xFFFFFFFF. n ranges 0..31. */
+#define UNSETBIT_(v,n) ((v) &= ~(1 << (n)))
+/* Test zero-based nth bit of v ranges 0..0xFFFFFFFF. n ranges 0..31. */
+#define TESTBIT_(v,n) (((v) & (1 << (n))) != 0)
+/* Unicode & ISO 10646-2012 codepoint v ranges 0..0x10FFFF. */
+#define CODEPOINT_(v) ((v) &= 0x1FFFFF; (((v) > 0x10FFFF) ? ((v) & 0xFFFF) : (v))
+/* CUBITS model: VGA, CGA, Custom, Texture, Cloudy, Glory, Shiny, Fiery. */
+#define SETMODEL_(v,m) ((v) |= ((m) << 21))
+/* CUBITS Texture ranges 0..255: VGA color index, CGA text attributes. */
+#define SETTEXTURE_(v,m) ((v) |= ((m) << 24))
2.42.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240406/0e0f98dc/attachment.htm>
