[PATCH v2] rtems: Add get/set interrupt priorities
Tue Apr 9 14:28:15 UTC 2024
Add directives to get and set the priority of an interrupt vector.
Implement the directives for the following BSP families:
* arm/lpc24xx
* arm/lpc32xx
* powerpc/mpc55xxevb
* powerpc/qoriq
Implement the directives for the following interrupt controllers:
* GICv2 and GICv3 (arm and aarch64)
* NVIC (arm)
* PLIC (riscv)
Update #5002.
v2:
* Clarify documentation
* Add implementations
* Add validation tests
 bsps/arm/beagle/irq/irq.c                     |  19 +
 bsps/arm/csb336/irq/irq.c                     |  19 +
 bsps/arm/csb337/irq/irq.c                     |  19 +
 bsps/arm/edb7312/irq/irq.c                    |  19 +
 bsps/arm/gumstix/irq/irq.c                    |  19 +
 bsps/arm/lpc24xx/include/bsp/irq.h            |  10 +-
 bsps/arm/lpc24xx/irq/irq.c                    |  58 +-
 bsps/arm/lpc32xx/include/bsp/irq.h            |   4 -
 bsps/arm/lpc32xx/include/tm27.h               |  10 +-
 bsps/arm/lpc32xx/irq/irq.c                    |  56 +-
 bsps/arm/raspberrypi/irq/irq.c                |  19 +
 bsps/arm/rtl22xx/irq/irq.c                    |  19 +
 bsps/arm/shared/irq/irq-armv7m.c              |  30 +
 bsps/arm/smdk2410/irq/irq.c                   |  19 +
 bsps/arm/tms570/irq/irq.c                     |  19 +
 bsps/i386/shared/irq/irq.c                    |  19 +
 bsps/include/bsp/irq-generic.h                |  41 ++
 bsps/include/dev/irq/arm-gic-irq.h            |  10 -
 bsps/include/dev/irq/arm-gic-tm27.h           |   4 +-
 bsps/include/dev/irq/arm-gicv3.h              |   3 +
 bsps/lm32/shared/irq/irq.c                    |  19 +
 bsps/m68k/genmcf548x/irq/irq.c                |  19 +
 bsps/microblaze/microblaze_fpga/irq/irq.c     |  19 +
 bsps/mips/shared/irq/irq.c                    |  19 +
 bsps/powerpc/gen5200/irq/irq.c                |  19 +
 bsps/powerpc/gen83xx/irq/irq.c                |  19 +
 bsps/powerpc/mpc55xxevb/include/bsp/irq.h     |  17 +-
 bsps/powerpc/mpc55xxevb/start/irq.c           |  46 +-
 bsps/powerpc/mpc8260ads/irq/irq.c             |  19 +
 bsps/powerpc/psim/irq/irq_init.c              |  19 +
 bsps/powerpc/qemuppc/irq/irq_init.c           |  19 +
 bsps/powerpc/qoriq/clock/clock-config.c       |   5 +-
 bsps/powerpc/qoriq/include/bsp/irq.h          |  23 +-
 bsps/powerpc/qoriq/include/tm27.h             |   7 +-
 bsps/powerpc/qoriq/irq/irq.c                  |  56 +-
 bsps/powerpc/qoriq/mpci/intercom.c            |   5 +-
 bsps/powerpc/shared/irq/ppc-irq-generic.c     |  19 +
 bsps/powerpc/t32mppc/irq/irq.c                |  19 +
 bsps/powerpc/tqm8xx/irq/irq.c                 |  19 +
 bsps/powerpc/virtex/irq/irq_init.c            |  19 +
 bsps/riscv/griscv/irq/irq.c                   |  19 +
 bsps/riscv/riscv/irq/irq.c                    |  44 +-
 .../shared/dev/irq/arm-gicv2-get-attributes.c |   3 +
 bsps/shared/dev/irq/arm-gicv2-zynqmp.c        |   3 +
 bsps/shared/dev/irq/arm-gicv2.c               |  36 +-
 bsps/shared/dev/irq/arm-gicv3.c               |  65 +-
 bsps/shared/irq/irq-default.c                 |  19 +
 bsps/shared/irq/irq-priority.c                |  65 ++
 bsps/sparc/leon3/start/eirq.c                 |  19 +
 bsps/sparc/shared/irq/irq-shared.c            |  19 +
 bsps/x86_64/amd64/interrupts/idt.c            |  19 +
 cpukit/include/rtems/rtems/intr.h             | 166 ++++-
 spec/build/bsps/objirq.yml                    |   1 +
 spec/build/bsps/powerpc/ss555/bspss555.yml    |   1 +
 .../testsuites/validation/validation-intr.yml |   2 +
 testsuites/validation/tc-intr-get-priority.c  | 567 ++++++++++++++++++
 testsuites/validation/tc-intr-set-priority.c  | 504 ++++++++++++++++
 57 files changed, 2162 insertions(+), 212 deletions(-)
 create mode 100644 bsps/shared/irq/irq-priority.c
 create mode 100644 testsuites/validation/tc-intr-get-priority.c
 create mode 100644 testsuites/validation/tc-intr-set-priority.c
diff --git a/bsps/arm/beagle/irq/irq.c b/bsps/arm/beagle/irq/irq.c
index 0ae82aa95e..7cb37d86e4 100644
--- a/bsps/arm/beagle/irq/irq.c
+++ b/bsps/arm/beagle/irq/irq.c
@@ -163,6 +163,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
   return RTEMS_SUCCESSFUL;
+rtems_status_code bsp_interrupt_set_priority(
+  rtems_vector_number vector,
+  uint32_t priority
+  bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
+  return RTEMS_UNSATISFIED;
+rtems_status_code bsp_interrupt_get_priority(
+  uint32_t *priority
+  bsp_interrupt_assert(priority != NULL);
 void bsp_interrupt_facility_initialize(void)
   int i;
diff --git a/bsps/arm/csb336/irq/irq.c b/bsps/arm/csb336/irq/irq.c
index 2834eaf1f7..4ba8bd4ac4 100644
--- a/bsps/arm/csb336/irq/irq.c
+++ b/bsps/arm/csb336/irq/irq.c
@@ -88,6 +88,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
   _CPU_ISR_install_vector(ARM_EXCEPTION_IRQ, _ARMV4_Exception_interrupt, NULL);
diff --git a/bsps/arm/csb337/irq/irq.c b/bsps/arm/csb337/irq/irq.c
index 8bb39f1c69..a3b1fb0e6e 100644
--- a/bsps/arm/csb337/irq/irq.c
+++ b/bsps/arm/csb337/irq/irq.c
@@ -83,6 +83,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
   unsigned long i = 0;
diff --git a/bsps/arm/edb7312/irq/irq.c b/bsps/arm/edb7312/irq/irq.c
index 53f01eba65..7b0b342f89 100644
--- a/bsps/arm/edb7312/irq/irq.c
+++ b/bsps/arm/edb7312/irq/irq.c
@@ -125,6 +125,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
   uint32_t int_stat = 0;
diff --git a/bsps/arm/gumstix/irq/irq.c b/bsps/arm/gumstix/irq/irq.c
index c90f2fe92e..b671bd0dcc 100644
--- a/bsps/arm/gumstix/irq/irq.c
+++ b/bsps/arm/gumstix/irq/irq.c
@@ -80,6 +80,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
   /* disable all interrupts */
diff --git a/bsps/arm/lpc24xx/include/bsp/irq.h b/bsps/arm/lpc24xx/include/bsp/irq.h
index 42f1c6b92a..0fe9c4cda3 100644
--- a/bsps/arm/lpc24xx/include/bsp/irq.h
+++ b/bsps/arm/lpc24xx/include/bsp/irq.h
@@ -132,20 +132,12 @@
 #ifdef ARM_MULTILIB_ARCH_V4
   #define LPC24XX_IRQ_PRIORITY_VALUE_MAX 15
 #else
-  #define LPC24XX_IRQ_PRIORITY_VALUE_MAX 31
+  #define LPC24XX_IRQ_PRIORITY_VALUE_MAX 255
 #endif
 #define LPC24XX_IRQ_PRIORITY_COUNT (LPC24XX_IRQ_PRIORITY_VALUE_MAX + 1)
 #define LPC24XX_IRQ_PRIORITY_HIGHEST LPC24XX_IRQ_PRIORITY_VALUE_MIN
 #define LPC24XX_IRQ_PRIORITY_LOWEST LPC24XX_IRQ_PRIORITY_VALUE_MAX
-#ifndef ASM
-void lpc24xx_irq_set_priority(rtems_vector_number vector, unsigned priority);
-unsigned lpc24xx_irq_get_priority(rtems_vector_number vector);
-#endif /* ASM */
 #endif /* LIBBSP_ARM_LPC24XX_IRQ_H */
diff --git a/bsps/arm/lpc24xx/irq/irq.c b/bsps/arm/lpc24xx/irq/irq.c
index 560c5b810a..310e004479 100644
--- a/bsps/arm/lpc24xx/irq/irq.c
+++ b/bsps/arm/lpc24xx/irq/irq.c
@@ -47,34 +47,6 @@ static inline bool lpc24xx_irq_is_valid(rtems_vector_number vector)
   return vector < BSP_INTERRUPT_VECTOR_COUNT;
-  if (lpc24xx_irq_is_valid(vector)) {
-    if (priority > LPC24XX_IRQ_PRIORITY_VALUE_MAX) {
-      priority = LPC24XX_IRQ_PRIORITY_VALUE_MAX;
-    #ifdef ARM_MULTILIB_ARCH_V4
-      VICVectPriorityBase [vector] = priority;
-    #else
-      _ARMV7M_NVIC_Set_priority((int) vector, (int) (priority << 3));
-    #endif
-      return VICVectPriorityBase [vector];
-    #else
-      return (unsigned) (_ARMV7M_NVIC_Get_priority((int) vector) >> 3);
-    #endif
-  } else {
-    return LPC24XX_IRQ_PRIORITY_VALUE_MIN - 1U;
 rtems_status_code bsp_interrupt_get_attributes(
@@ -82,6 +54,9 @@ rtems_status_code bsp_interrupt_get_attributes(
   rtems_interrupt_attributes *attributes
+  attributes->maximum_priority = LPC24XX_IRQ_PRIORITY_VALUE_MAX;
+  attributes->can_get_priority = true;
+  attributes->can_set_priority = true;
@@ -133,6 +108,33 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
+  if (priority > LPC24XX_IRQ_PRIORITY_VALUE_MAX) {
+    return RTEMS_INVALID_PRIORITY;
+  VICVectPriorityBase [vector] = priority;
+  return RTEMS_SUCCESSFUL;
+  *priority = VICVectPriorityBase [vector];
   volatile uint32_t *addr = VICVectAddrBase;
diff --git a/bsps/arm/lpc32xx/include/bsp/irq.h b/bsps/arm/lpc32xx/include/bsp/irq.h
index 1571ea5e6b..7cef217263 100644
--- a/bsps/arm/lpc32xx/include/bsp/irq.h
+++ b/bsps/arm/lpc32xx/include/bsp/irq.h
@@ -161,10 +161,6 @@ extern "C" {
 bool bsp_interrupt_is_valid_vector(rtems_vector_number vector);
-void lpc32xx_irq_set_priority(rtems_vector_number vector, unsigned priority);
-unsigned lpc32xx_irq_get_priority(rtems_vector_number vector);
 typedef enum {
   LPC32XX_IRQ_ACTIVE_LOW_OR_FALLING_EDGE,
   LPC32XX_IRQ_ACTIVE_HIGH_OR_RISING_EDGE
diff --git a/bsps/arm/lpc32xx/include/tm27.h b/bsps/arm/lpc32xx/include/tm27.h
index bd06894354..2ad5606cd0 100644
--- a/bsps/arm/lpc32xx/include/tm27.h
+++ b/bsps/arm/lpc32xx/include/tm27.h
@@ -93,13 +93,19 @@ static inline void Clear_tm27_intr(void)
   volatile lpc_timer *timer = LPC32XX_TM27_TIMER;
   timer->ir = LPC_TIMER_IR_MR0;
-  lpc32xx_irq_set_priority(LPC32XX_TM27_IRQ, LPC32XX_IRQ_PRIORITY_LOWEST);
+  (void) rtems_interrupt_set_priority(
+    LPC32XX_TM27_IRQ,
+    LPC32XX_IRQ_PRIORITY_LOWEST
 static inline void Lower_tm27_intr(void)
   bsp_interrupt_vector_enable(LPC32XX_TM27_IRQ);
-  lpc32xx_irq_set_priority(LPC32XX_TM27_IRQ, LPC32XX_IRQ_PRIORITY_HIGHEST);
+    LPC32XX_TM27_IRQ,
+    LPC32XX_IRQ_PRIORITY_HIGHEST
 #endif /* __tm27_h */
diff --git a/bsps/arm/lpc32xx/irq/irq.c b/bsps/arm/lpc32xx/irq/irq.c
index 418798f8cb..67c08c80e5 100644
--- a/bsps/arm/lpc32xx/irq/irq.c
+++ b/bsps/arm/lpc32xx/irq/irq.c
@@ -160,39 +160,44 @@ static inline unsigned lpc32xx_irq_get_index(uint32_t val)
   return val;
+  uint32_t priority
-  if (bsp_interrupt_is_valid_vector(vector)) {
-    rtems_interrupt_level level;
-    unsigned i = 0;
+  rtems_interrupt_level level;
+  uint32_t i;
-    if (priority > LPC32XX_IRQ_PRIORITY_LOWEST) {
-      priority = LPC32XX_IRQ_PRIORITY_LOWEST;
-    lpc32xx_irq_priority_table [vector] = (uint8_t) priority;
+  if (priority > LPC32XX_IRQ_PRIORITY_VALUE_MAX) {
-    for (i = LPC32XX_IRQ_PRIORITY_HIGHEST; i <= priority; ++i) {
-      rtems_interrupt_disable(level);
-      lpc32xx_irq_clear_bit_in_field(vector, &lpc32xx_irq_priority_masks [i]);
-      rtems_interrupt_enable(level);
+  rtems_interrupt_disable(level);
+  lpc32xx_irq_priority_table [vector] = (uint8_t) priority;
-    for (i = priority + 1; i <= LPC32XX_IRQ_PRIORITY_LOWEST; ++i) {
-      lpc32xx_irq_set_bit_in_field(vector, &lpc32xx_irq_priority_masks [i]);
+  for (i = LPC32XX_IRQ_PRIORITY_HIGHEST; i <= priority; ++i) {
+    lpc32xx_irq_clear_bit_in_field(vector, &lpc32xx_irq_priority_masks [i]);
+  for (i = priority + 1; i <= LPC32XX_IRQ_PRIORITY_LOWEST; ++i) {
+    lpc32xx_irq_set_bit_in_field(vector, &lpc32xx_irq_priority_masks [i]);
+  rtems_interrupt_enable(level);
-    return lpc32xx_irq_priority_table [vector];
-  } else {
-    return LPC32XX_IRQ_PRIORITY_LOWEST;
+  *priority lpc32xx_irq_priority_table [vector];
 void lpc32xx_irq_set_activation_polarity(rtems_vector_number vector, lpc32xx_irq_activation_polarity activation_polarity)
@@ -326,6 +331,9 @@ rtems_status_code bsp_interrupt_get_attributes(
   attributes->can_clear = is_sw_irq;
   attributes->can_get_affinity = true;
   attributes->can_set_affinity = true;
+  attributes->maximum_priority = LPC32XX_IRQ_PRIORITY_VALUE_MAX;
diff --git a/bsps/arm/raspberrypi/irq/irq.c b/bsps/arm/raspberrypi/irq/irq.c
index 7177cd2c05..06ce90fbb3 100644
--- a/bsps/arm/raspberrypi/irq/irq.c
+++ b/bsps/arm/raspberrypi/irq/irq.c
@@ -206,6 +206,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
 #if defined(RTEMS_SMP)
 rtems_status_code bsp_interrupt_get_affinity(
diff --git a/bsps/arm/rtl22xx/irq/irq.c b/bsps/arm/rtl22xx/irq/irq.c
index e69b74d02a..eb522d9267 100644
--- a/bsps/arm/rtl22xx/irq/irq.c
+++ b/bsps/arm/rtl22xx/irq/irq.c
@@ -82,6 +82,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
   volatile uint32_t *ctrl = (volatile uint32_t *) VICVectCntlBase;
diff --git a/bsps/arm/shared/irq/irq-armv7m.c b/bsps/arm/shared/irq/irq-armv7m.c
index 9e0c1f3a87..6606de8264 100644
--- a/bsps/arm/shared/irq/irq-armv7m.c
+++ b/bsps/arm/shared/irq/irq-armv7m.c
@@ -43,6 +43,9 @@ rtems_status_code bsp_interrupt_get_attributes(
+  attributes->maximum_priority = 255;
@@ -94,6 +97,33 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
+  if (priority > 255) {
+  _ARMV7M_NVIC_Set_priority((int) vector, (int) priority);
+  *priority = (uint32_t) _ARMV7M_NVIC_Get_priority((int) vector);
   ARMV7M_Exception_handler *vector_table;
diff --git a/bsps/arm/smdk2410/irq/irq.c b/bsps/arm/smdk2410/irq/irq.c
index 3bc46aa6d7..9081dd25d4 100644
--- a/bsps/arm/smdk2410/irq/irq.c
+++ b/bsps/arm/smdk2410/irq/irq.c
@@ -81,6 +81,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
diff --git a/bsps/arm/tms570/irq/irq.c b/bsps/arm/tms570/irq/irq.c
index 9a80e0e3d2..74e227f068 100644
--- a/bsps/arm/tms570/irq/irq.c
+++ b/bsps/arm/tms570/irq/irq.c
@@ -289,6 +289,25 @@ rtems_status_code bsp_interrupt_vector_disable(
+  uint32_t priority
  * @brief Init function of interrupt module
diff --git a/bsps/i386/shared/irq/irq.c b/bsps/i386/shared/irq/irq.c
index 57753c2f77..7ff3135781 100644
--- a/bsps/i386/shared/irq/irq.c
+++ b/bsps/i386/shared/irq/irq.c
@@ -337,6 +337,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
diff --git a/bsps/include/bsp/irq-generic.h b/bsps/include/bsp/irq-generic.h
index bd557df9dc..ee7d6850e4 100644
--- a/bsps/include/bsp/irq-generic.h
+++ b/bsps/include/bsp/irq-generic.h
@@ -373,6 +373,47 @@ rtems_status_code bsp_interrupt_raise_on(
 rtems_status_code bsp_interrupt_clear( rtems_vector_number vector );
+ * @brief Gets the priority of the interrupt vector.
+ * @param vector is the interrupt vector number.  The vector number shall be
+ *   less than BSP_INTERRUPT_VECTOR_COUNT.
+ * @param[out] priority is the pointer to an uint32_t object.  When the
+ *   directive call is successful, the priority of the interrupt vector will be
+ *   stored in this object.  The pointer shall be valid.
+ * @retval ::RTEMS_SUCCESSFUL The requested operation was successful.
+ * @retval ::RTEMS_UNSATISFIED There is no priority associated with the
+ *   interrupt vector.
+ * @brief Sets the priority of the interrupt vector.
+ * @param priority is the new priority for the interrupt vector.
+ * @retval ::RTEMS_INVALID_PRIORITY The priority specified by ``priority`` was
+ *   not a valid new priority for the interrupt vector.
+ * @retval ::RTEMS_UNSATISFIED The request to set the priority of the interrupt
+ *   vector has not been satisfied.
+  uint32_t            priority
  * @brief Gets the processor affinity set of the interrupt vector.
diff --git a/bsps/include/dev/irq/arm-gic-irq.h b/bsps/include/dev/irq/arm-gic-irq.h
index 1fcf594360..518256ad2b 100644
--- a/bsps/include/dev/irq/arm-gic-irq.h
+++ b/bsps/include/dev/irq/arm-gic-irq.h
@@ -64,16 +64,6 @@ extern "C" {
 #define ARM_GIC_DIST ((volatile gic_dist *) BSP_ARM_GIC_DIST_BASE)
-rtems_status_code arm_gic_irq_set_priority(
-  rtems_vector_number vector,
-  uint8_t priority
-rtems_status_code arm_gic_irq_get_priority(
-  uint8_t *priority
 rtems_status_code arm_gic_irq_set_group(
   gic_group group
diff --git a/bsps/include/dev/irq/arm-gic-tm27.h b/bsps/include/dev/irq/arm-gic-tm27.h
index f2a16afae3..6baab7a45c 100644
--- a/bsps/include/dev/irq/arm-gic-tm27.h
+++ b/bsps/include/dev/irq/arm-gic-tm27.h
@@ -80,7 +80,7 @@ static inline void Install_tm27_vector( rtems_interrupt_handler handler )
   _Assert_Unused_variable_equals( sc, RTEMS_SUCCESSFUL );
-  sc = arm_gic_irq_set_priority(
+  sc = rtems_interrupt_set_priority(
     ARM_GIC_TM27_IRQ_LOW,
     ARM_GIC_TM27_PRIO_LOW
@@ -99,7 +99,7 @@ static inline void Install_tm27_vector( rtems_interrupt_handler handler )
     ARM_GIC_TM27_IRQ_HIGH,
     ARM_GIC_TM27_PRIO_HIGH
diff --git a/bsps/include/dev/irq/arm-gicv3.h b/bsps/include/dev/irq/arm-gicv3.h
index 09d1b50422..74e29057b0 100644
--- a/bsps/include/dev/irq/arm-gicv3.h
+++ b/bsps/include/dev/irq/arm-gicv3.h
@@ -364,6 +364,9 @@ static inline void gicv3_get_attributes(
   attributes->maybe_enable = true;
   attributes->maybe_disable = true;
   attributes->can_raise = true;
   if ( vector <= ARM_GIC_IRQ_SGI_LAST ) {
diff --git a/bsps/lm32/shared/irq/irq.c b/bsps/lm32/shared/irq/irq.c
index 4a7f9bd444..a7c1af6587 100644
--- a/bsps/lm32/shared/irq/irq.c
+++ b/bsps/lm32/shared/irq/irq.c
@@ -72,3 +72,22 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
   lm32_interrupt_mask(1 << vector);
+  uint32_t priority
diff --git a/bsps/m68k/genmcf548x/irq/irq.c b/bsps/m68k/genmcf548x/irq/irq.c
index 0a1f8794e0..5624cd2aa1 100644
--- a/bsps/m68k/genmcf548x/irq/irq.c
+++ b/bsps/m68k/genmcf548x/irq/irq.c
@@ -136,6 +136,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
 static void set_exception_handler(rtems_vector_number vector, void_func handler)
   void **vbr;
diff --git a/bsps/microblaze/microblaze_fpga/irq/irq.c b/bsps/microblaze/microblaze_fpga/irq/irq.c
index f14eddc799..662eaf6ac6 100644
--- a/bsps/microblaze/microblaze_fpga/irq/irq.c
+++ b/bsps/microblaze/microblaze_fpga/irq/irq.c
@@ -122,6 +122,25 @@ rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number vector )
+  uint32_t priority
 void bsp_interrupt_facility_initialize( void )
diff --git a/bsps/mips/shared/irq/irq.c b/bsps/mips/shared/irq/irq.c
index 460da7a3f8..83c998ae3c 100644
--- a/bsps/mips/shared/irq/irq.c
+++ b/bsps/mips/shared/irq/irq.c
@@ -121,6 +121,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
   mips_install_isr_entries();
diff --git a/bsps/powerpc/gen5200/irq/irq.c b/bsps/powerpc/gen5200/irq/irq.c
index 3dee82d566..9f771576a3 100644
--- a/bsps/powerpc/gen5200/irq/irq.c
+++ b/bsps/powerpc/gen5200/irq/irq.c
@@ -414,6 +414,25 @@ rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number vector)
+  uint32_t priority
 #if (BENCHMARK_IRQ_PROCESSING == 0)
 void BSP_IRQ_Benchmarking_Reset( void)
diff --git a/bsps/powerpc/gen83xx/irq/irq.c b/bsps/powerpc/gen83xx/irq/irq.c
index f81fae2848..f82d9a352e 100644
--- a/bsps/powerpc/gen83xx/irq/irq.c
+++ b/bsps/powerpc/gen83xx/irq/irq.c
@@ -476,6 +476,25 @@ rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number vector)
+  uint32_t priority
  *  IRQ Handler: this is called from the primary exception dispatcher
diff --git a/bsps/powerpc/mpc55xxevb/include/bsp/irq.h b/bsps/powerpc/mpc55xxevb/include/bsp/irq.h
index 0df805791e..940b9f9288 100644
--- a/bsps/powerpc/mpc55xxevb/include/bsp/irq.h
+++ b/bsps/powerpc/mpc55xxevb/include/bsp/irq.h
@@ -453,13 +453,16 @@ extern "C" {
  * Interrupt controller
-#define MPC55XX_INTC_MIN_PRIORITY 1U
-#define MPC55XX_INTC_MAX_PRIORITY 15U
-#define MPC55XX_INTC_DISABLED_PRIORITY 0U
-#define MPC55XX_INTC_INVALID_PRIORITY (MPC55XX_INTC_MAX_PRIORITY + 1)
-#define MPC55XX_INTC_DEFAULT_PRIORITY (MPC55XX_INTC_MIN_PRIORITY + 1)
-#define MPC55XX_INTC_IS_VALID_PRIORITY(p) \
-  ((p) >= MPC55XX_INTC_DISABLED_PRIORITY && (p) <= MPC55XX_INTC_MAX_PRIORITY)
+ * These are RTEMS API priority values, not INTC priority values.  We have:
+ *   15 - API-priority == INTC-priority
+#define MPC55XX_INTC_MIN_PRIORITY 14U
+#define MPC55XX_INTC_MAX_PRIORITY 0U
+#define MPC55XX_INTC_DISABLED_PRIORITY 15U
+#define MPC55XX_INTC_INVALID_PRIORITY 16U
+#define MPC55XX_INTC_DEFAULT_PRIORITY 13U
+#define MPC55XX_INTC_IS_VALID_PRIORITY(p) (((uint32_t) (p)) <= 15U)
 rtems_status_code mpc55xx_interrupt_handler_install(
diff --git a/bsps/powerpc/mpc55xxevb/start/irq.c b/bsps/powerpc/mpc55xxevb/start/irq.c
index 05397ee7b1..ce05ea80a3 100644
--- a/bsps/powerpc/mpc55xxevb/start/irq.c
+++ b/bsps/powerpc/mpc55xxevb/start/irq.c
@@ -45,35 +45,30 @@
 #include <rtems/status-checks.h>
- * @brief Returns the priority @a priority of IRQ @a vector from the INTC.
-rtems_status_code mpc55xx_intc_get_priority( rtems_vector_number vector, unsigned *priority)
-	if (MPC55XX_IRQ_IS_VALID( vector)) {
-		*priority = INTC.PSR [vector].B.PRI;
-		return RTEMS_SUCCESSFUL;
-	} else {
-		*priority = MPC55XX_INTC_INVALID_PRIORITY;
-		return RTEMS_INVALID_NUMBER;
+	bsp_interrupt_assert( bsp_interrupt_is_valid_vector( vector));
+	bsp_interrupt_assert( priority != NULL);
+	*priority = INTC.PSR [vector].B.PRI;
- * @brief Sets the priority of IRQ @a vector to @a priority at the INTC.
-rtems_status_code mpc55xx_intc_set_priority( rtems_vector_number vector, unsigned priority)
+rtems_status_code rtems_interrupt_set_priority(
+	uint32_t priority
-	if (MPC55XX_IRQ_IS_VALID( vector) && MPC55XX_INTC_IS_VALID_PRIORITY( priority)) {
-		INTC.PSR [vector].B.PRI = priority;
-		if (INTC.PSR [vector].B.PRI == priority) {
-		} else {
-			return RTEMS_IO_ERROR;
-	} else {
+	if (!MPC55XX_INTC_IS_VALID_PRIORITY( priority)) {
+	INTC.PSR [vector].B.PRI = priority;
@@ -168,6 +163,9 @@ rtems_status_code bsp_interrupt_get_attributes(
+  attributes->maximum_priority = 15;
diff --git a/bsps/powerpc/mpc8260ads/irq/irq.c b/bsps/powerpc/mpc8260ads/irq/irq.c
index 70cb5acf9b..2980f8d2f8 100644
--- a/bsps/powerpc/mpc8260ads/irq/irq.c
+++ b/bsps/powerpc/mpc8260ads/irq/irq.c
@@ -398,6 +398,25 @@ rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number irqnum)
+  uint32_t priority
 void bsp_interrupt_facility_initialize()
   rtems_status_code sc;
diff --git a/bsps/powerpc/psim/irq/irq_init.c b/bsps/powerpc/psim/irq/irq_init.c
index 16c30e714d..36d9527484 100644
--- a/bsps/powerpc/psim/irq/irq_init.c
+++ b/bsps/powerpc/psim/irq/irq_init.c
@@ -158,6 +158,25 @@ rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number irqnum)
+  uint32_t priority
diff --git a/bsps/powerpc/qemuppc/irq/irq_init.c b/bsps/powerpc/qemuppc/irq/irq_init.c
index 972a8456cc..d3120ade78 100644
--- a/bsps/powerpc/qemuppc/irq/irq_init.c
+++ b/bsps/powerpc/qemuppc/irq/irq_init.c
@@ -108,6 +108,25 @@ rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number irqnum)
+  uint32_t priority
diff --git a/bsps/powerpc/qoriq/clock/clock-config.c b/bsps/powerpc/qoriq/clock/clock-config.c
index 17347278f3..40a7daa353 100644
--- a/bsps/powerpc/qoriq/clock/clock-config.c
+++ b/bsps/powerpc/qoriq/clock/clock-config.c
@@ -115,10 +115,9 @@ static void qoriq_clock_handler_install(rtems_interrupt_handler handler)
 #endif
-  sc = qoriq_pic_set_priority(
     CLOCK_INTERRUPT,
-    QORIQ_PIC_PRIORITY_LOWEST,
-    NULL
+    QORIQ_PIC_PRIORITY_LOWEST
   if (sc != RTEMS_SUCCESSFUL) {
     bsp_fatal(QORIQ_FATAL_CLOCK_INTERRUPT_SET_PRIORITY);
diff --git a/bsps/powerpc/qoriq/include/bsp/irq.h b/bsps/powerpc/qoriq/include/bsp/irq.h
index 5eaf36ba4c..56b75e3d1c 100644
--- a/bsps/powerpc/qoriq/include/bsp/irq.h
+++ b/bsps/powerpc/qoriq/include/bsp/irq.h
@@ -394,19 +394,16 @@ extern "C" {
-#define QORIQ_PIC_PRIORITY_LOWEST 1
-#define QORIQ_PIC_PRIORITY_HIGHEST 15
-#define QORIQ_PIC_PRIORITY_DISABLED 0
-#define QORIQ_PIC_PRIORITY_INVALID (QORIQ_PIC_PRIORITY_HIGHEST + 1)
-#define QORIQ_PIC_PRIORITY_DEFAULT (QORIQ_PIC_PRIORITY_LOWEST + 1)
-#define QORIQ_PIC_PRIORITY_IS_VALID(p) \
-  ((p) >= QORIQ_PIC_PRIORITY_DISABLED && (p) <= QORIQ_PIC_PRIORITY_HIGHEST)
-rtems_status_code qoriq_pic_set_priority(
-  int new_priority,
-  int *old_priority
+ * These are RTEMS API priority values, not PIC priority values.  We have:
+ *   15 - API-priority == PIC-priority
+#define QORIQ_PIC_PRIORITY_LOWEST 14
+#define QORIQ_PIC_PRIORITY_HIGHEST 0
+#define QORIQ_PIC_PRIORITY_DISABLED 15
+#define QORIQ_PIC_PRIORITY_INVALID 16
+#define QORIQ_PIC_PRIORITY_DEFAULT 13
+#define QORIQ_PIC_PRIORITY_IS_VALID(p) (((uint32_t) (p)) <= 15)
 rtems_status_code qoriq_pic_msi_allocate(rtems_vector_number *vector);
diff --git a/bsps/powerpc/qoriq/include/tm27.h b/bsps/powerpc/qoriq/include/tm27.h
index 0c43823f0e..7e8c78e54b 100644
--- a/bsps/powerpc/qoriq/include/tm27.h
+++ b/bsps/powerpc/qoriq/include/tm27.h
@@ -58,6 +58,9 @@ static inline void Install_tm27_vector( rtems_interrupt_handler handler )
   rtems_vector_number low = QORIQ_IRQ_IPI_0 + IPI_INDEX_LOW;
   rtems_vector_number high = QORIQ_IRQ_IPI_0 + IPI_INDEX_HIGH;
+  (void) rtems_interrupt_set_priority(low, 14);
+  (void) rtems_interrupt_set_priority(high, 13);
   rtems_interrupt_entry_initialize(
     &entry_low,
     handler,
@@ -70,8 +73,6 @@ static inline void Install_tm27_vector( rtems_interrupt_handler handler )
     &entry_low
-  (void) qoriq_pic_set_priority(low, 1, NULL);
     &entry_high,
     handler,
@@ -83,8 +84,6 @@ static inline void Install_tm27_vector( rtems_interrupt_handler handler )
     RTEMS_INTERRUPT_UNIQUE,
     &entry_high
-  (void) qoriq_pic_set_priority(high, 2, NULL);
 static inline void qoriq_tm27_cause(uint32_t ipi_index)
diff --git a/bsps/powerpc/qoriq/irq/irq.c b/bsps/powerpc/qoriq/irq/irq.c
index 2a5e3e9a75..76e3e8ba0f 100644
--- a/bsps/powerpc/qoriq/irq/irq.c
+++ b/bsps/powerpc/qoriq/irq/irq.c
@@ -298,43 +298,50 @@ static bool pic_is_ipi(rtems_vector_number vector)
 	return (vector - QORIQ_IRQ_IPI_BASE) < 4;
-	int new_priority,
-	int *old_priority
-	rtems_status_code sc = RTEMS_SUCCESSFUL;
-	uint32_t old_vpr = 0;
+	volatile qoriq_pic_src_cfg *src_cfg;
 	if (QORIQ_IRQ_IS_MSI(vector)) {
-		volatile qoriq_pic_src_cfg *src_cfg = get_src_cfg(vector);
+	src_cfg = get_src_cfg(vector);
+	*priority = UINT32_C(15) - VPR_PRIORITY_GET(src_cfg->vpr);
-		if (QORIQ_PIC_PRIORITY_IS_VALID(new_priority)) {
-			rtems_interrupt_lock_context lock_context;
+	uint32_t priority
+	rtems_interrupt_lock_context lock_context;
+	uint32_t vpr;
-			rtems_interrupt_lock_acquire(&lock, &lock_context);
-			old_vpr = src_cfg->vpr;
-			src_cfg->vpr = VPR_PRIORITY_SET(old_vpr, (uint32_t) new_priority);
-			rtems_interrupt_lock_release(&lock, &lock_context);
-		} else if (new_priority < 0) {
-		} else {
-			sc = RTEMS_INVALID_PRIORITY;
-	} else {
-		sc = RTEMS_INVALID_ID;
+	if (QORIQ_IRQ_IS_MSI(vector)) {
-	if (old_priority != NULL) {
-		*old_priority = (int) VPR_PRIORITY_GET(old_vpr);
+	if (!QORIQ_PIC_PRIORITY_IS_VALID(priority)) {
-	return sc;
+	rtems_interrupt_lock_acquire(&lock, &lock_context);
+	vpr = src_cfg->vpr;
+	src_cfg->vpr = VPR_PRIORITY_SET(vpr, UINT32_C(15) - priority);
+	rtems_interrupt_lock_release(&lock, &lock_context);
 rtems_status_code qoriq_pic_set_sense_and_polarity(
@@ -472,6 +479,9 @@ rtems_status_code bsp_interrupt_get_attributes(
 	attributes->can_set_affinity = !(is_ipi || is_msi);
 	attributes->can_raise = is_ipi;
 	attributes->can_raise_on = is_ipi;
+	attributes->can_get_priority = !is_msi;
+	attributes->can_set_priority = !is_msi;
 	if (is_msi) {
 		attributes->can_be_triggered_by_message = true;
diff --git a/bsps/powerpc/qoriq/mpci/intercom.c b/bsps/powerpc/qoriq/mpci/intercom.c
index ae3c2d92e9..a27647c22e 100644
--- a/bsps/powerpc/qoriq/mpci/intercom.c
+++ b/bsps/powerpc/qoriq/mpci/intercom.c
@@ -313,10 +313,9 @@ void qoriq_intercom_init(void)
 	assert(sc == RTEMS_SUCCESSFUL);
 		QORIQ_IRQ_IPI_0,
-		NULL
diff --git a/bsps/powerpc/shared/irq/ppc-irq-generic.c b/bsps/powerpc/shared/irq/ppc-irq-generic.c
index f4b85f7bc0..d706c081c1 100644
--- a/bsps/powerpc/shared/irq/ppc-irq-generic.c
+++ b/bsps/powerpc/shared/irq/ppc-irq-generic.c
@@ -151,6 +151,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
diff --git a/bsps/powerpc/t32mppc/irq/irq.c b/bsps/powerpc/t32mppc/irq/irq.c
index a3f2504443..250a7021a0 100644
--- a/bsps/powerpc/t32mppc/irq/irq.c
+++ b/bsps/powerpc/t32mppc/irq/irq.c
@@ -92,6 +92,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
diff --git a/bsps/powerpc/tqm8xx/irq/irq.c b/bsps/powerpc/tqm8xx/irq/irq.c
index 2e8e229427..aeee5b2a35 100644
--- a/bsps/powerpc/tqm8xx/irq/irq.c
+++ b/bsps/powerpc/tqm8xx/irq/irq.c
@@ -143,6 +143,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
diff --git a/bsps/powerpc/virtex/irq/irq_init.c b/bsps/powerpc/virtex/irq/irq_init.c
index 320053e3a2..74e3b2ff7d 100644
--- a/bsps/powerpc/virtex/irq/irq_init.c
+++ b/bsps/powerpc/virtex/irq/irq_init.c
@@ -182,6 +182,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
 static int C_dispatch_irq_handler(BSP_Exception_frame *frame, unsigned int excNum)
   BSP_irq_handle_at_opbintc();
diff --git a/bsps/riscv/griscv/irq/irq.c b/bsps/riscv/griscv/irq/irq.c
index 12af7d7b3d..7b2f386f01 100644
--- a/bsps/riscv/griscv/irq/irq.c
+++ b/bsps/riscv/griscv/irq/irq.c
@@ -153,6 +153,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
   Processor_mask *affinity
diff --git a/bsps/riscv/riscv/irq/irq.c b/bsps/riscv/riscv/irq/irq.c
index ada418b7fb..f3aea1203a 100644
--- a/bsps/riscv/riscv/irq/irq.c
+++ b/bsps/riscv/riscv/irq/irq.c
@@ -356,6 +356,8 @@ rtems_status_code bsp_interrupt_get_attributes(
+  bool is_external = RISCV_INTERRUPT_VECTOR_IS_EXTERNAL(vector);
   attributes->is_maskable = true;
   attributes->can_enable = true;
@@ -364,8 +366,13 @@ rtems_status_code bsp_interrupt_get_attributes(
   attributes->can_raise = (vector == RISCV_INTERRUPT_VECTOR_SOFTWARE);
   attributes->can_raise_on = attributes->can_raise;
   attributes->cleared_by_acknowledge = true;
-  attributes->can_get_affinity = RISCV_INTERRUPT_VECTOR_IS_EXTERNAL(vector);
-  attributes->can_set_affinity = attributes->can_get_affinity;
+  attributes->can_get_affinity = is_external;
+  attributes->can_set_affinity = is_external;
+  /* The PLIC priority is defined by a 32-bit WARL register */
+  attributes->maximum_priority = UINT32_MAX;
+  attributes->can_get_priority = is_external;
+  attributes->can_set_priority = is_external;
   if (vector == RISCV_INTERRUPT_VECTOR_SOFTWARE) {
     attributes->trigger_signal = RTEMS_INTERRUPT_NO_SIGNAL;
@@ -619,6 +626,39 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
+  if (!RISCV_INTERRUPT_VECTOR_IS_EXTERNAL(vector)) {
+  riscv_plic->priority[RISCV_INTERRUPT_VECTOR_EXTERNAL_TO_INDEX(vector)] =
+    UINT32_MAX - priority;
+  *priority = UINT32_MAX -
+    riscv_plic->priority[RISCV_INTERRUPT_VECTOR_EXTERNAL_TO_INDEX(vector)];
 #ifdef RTEMS_SMP
 rtems_status_code bsp_interrupt_set_affinity(
diff --git a/bsps/shared/dev/irq/arm-gicv2-get-attributes.c b/bsps/shared/dev/irq/arm-gicv2-get-attributes.c
index 3280671ab6..4bff328d55 100644
--- a/bsps/shared/dev/irq/arm-gicv2-get-attributes.c
+++ b/bsps/shared/dev/irq/arm-gicv2-get-attributes.c
@@ -45,6 +45,9 @@ rtems_status_code bsp_interrupt_get_attributes(
diff --git a/bsps/shared/dev/irq/arm-gicv2-zynqmp.c b/bsps/shared/dev/irq/arm-gicv2-zynqmp.c
index ee4479155a..051764f731 100644
--- a/bsps/shared/dev/irq/arm-gicv2-zynqmp.c
+++ b/bsps/shared/dev/irq/arm-gicv2-zynqmp.c
@@ -46,6 +46,9 @@ rtems_status_code bsp_interrupt_get_attributes(
diff --git a/bsps/shared/dev/irq/arm-gicv2.c b/bsps/shared/dev/irq/arm-gicv2.c
index 3cd27b2fa6..b76d263631 100644
--- a/bsps/shared/dev/irq/arm-gicv2.c
+++ b/bsps/shared/dev/irq/arm-gicv2.c
@@ -255,40 +255,36 @@ BSP_START_TEXT_SECTION void arm_gic_irq_initialize_secondary_cpu(void)
 #endif
-  uint8_t priority
+  uint32_t priority
+  volatile gic_dist *dist = ARM_GIC_DIST;
+  uint8_t gic_priority = (uint8_t) priority;
-    volatile gic_dist *dist = ARM_GIC_DIST;
-    gic_id_set_priority(dist, vector, priority);
-  } else {
+  if (gic_priority != priority) {
-  return sc;
+  gic_id_set_priority(dist, vector, gic_priority);
-  uint8_t *priority
-    *priority = gic_id_get_priority(dist, vector);
-  } else {
-  return sc;
+  *priority = gic_id_get_priority(dist, vector);
diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c
index f85582ccff..bd5f684678 100644
--- a/bsps/shared/dev/irq/arm-gicv3.c
+++ b/bsps/shared/dev/irq/arm-gicv3.c
@@ -192,53 +192,52 @@ BSP_START_TEXT_SECTION void arm_gic_irq_initialize_secondary_cpu(void)
 #endif
-  uint8_t priority
+  uint32_t priority
-    if (vector >= 32) {
-    } else {
-      gicv3_sgi_ppi_set_priority(
-        vector,
-        priority,
-        _SMP_Get_current_processor()
+  if (vector >= 32) {
+    gic_id_set_priority(dist, vector, priority);
   } else {
+    gicv3_sgi_ppi_set_priority(
+      vector,
+      priority,
+      _SMP_Get_current_processor()
-  return sc;
-  uint8_t *priority
-    } else {
-      *priority = gicv3_sgi_ppi_get_priority(
-        vector,
   } else {
+    *priority = gicv3_sgi_ppi_get_priority(
+      vector,
-  return sc;
 #ifdef RTEMS_SMP
diff --git a/bsps/shared/irq/irq-default.c b/bsps/shared/irq/irq-default.c
index 7210235aa6..d3eff19648 100644
--- a/bsps/shared/irq/irq-default.c
+++ b/bsps/shared/irq/irq-default.c
@@ -93,6 +93,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
   /* Nothing to do */
diff --git a/bsps/shared/irq/irq-priority.c b/bsps/shared/irq/irq-priority.c
new file mode 100644
index 0000000000..f3eb5a880a
--- /dev/null
+++ b/bsps/shared/irq/irq-priority.c
@@ -0,0 +1,65 @@
+ * @file
+ * @ingroup RTEMSImplClassicIntr
+ * @brief This source file contains the implementation of
+ *   rtems_interrupt_get_priority() and rtems_interrupt_set_priority().
+ * Copyright (C) 2024 embedded brains GmbH & Co. KG
+ * are met:
+#include <bsp/irq-generic.h>
+  uint32_t priority
+  if (!bsp_interrupt_is_valid_vector(vector)) {
+    return RTEMS_INVALID_ID;
+  return bsp_interrupt_set_priority(vector, priority);
+rtems_status_code rtems_interrupt_get_priority(
+  if (priority == NULL) {
+    return RTEMS_INVALID_ADDRESS;
+  return bsp_interrupt_get_priority(vector, priority);
diff --git a/bsps/sparc/leon3/start/eirq.c b/bsps/sparc/leon3/start/eirq.c
index a0934a7848..b6e106c587 100644
--- a/bsps/sparc/leon3/start/eirq.c
+++ b/bsps/sparc/leon3/start/eirq.c
@@ -353,6 +353,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
diff --git a/bsps/sparc/shared/irq/irq-shared.c b/bsps/sparc/shared/irq/irq-shared.c
index 18360b2b8e..c4190d860b 100644
--- a/bsps/sparc/shared/irq/irq-shared.c
+++ b/bsps/sparc/shared/irq/irq-shared.c
@@ -141,6 +141,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
diff --git a/bsps/x86_64/amd64/interrupts/idt.c b/bsps/x86_64/amd64/interrupts/idt.c
index 4a2949450a..cc6eb77e8b 100644
--- a/bsps/x86_64/amd64/interrupts/idt.c
+++ b/bsps/x86_64/amd64/interrupts/idt.c
@@ -145,6 +145,25 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  uint32_t priority
diff --git a/cpukit/include/rtems/rtems/intr.h b/cpukit/include/rtems/rtems/intr.h
index f682112bf5..b40c640534 100644
--- a/cpukit/include/rtems/rtems/intr.h
+++ b/cpukit/include/rtems/rtems/intr.h
@@ -9,7 +9,7 @@
- * Copyright (C) 2008, 2022 embedded brains GmbH & Co. KG
+ * Copyright (C) 2008, 2024 embedded brains GmbH & Co. KG
  * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
@@ -1688,6 +1688,147 @@ rtems_status_code rtems_interrupt_raise_on(
 rtems_status_code rtems_interrupt_clear( rtems_vector_number vector );
+/* Generated from spec:/rtems/intr/if/get-priority */
+ * @ingroup RTEMSAPIClassicIntr
+ * @retval ::RTEMS_INVALID_ADDRESS The ``priority`` parameter was NULL.
+ * @retval ::RTEMS_INVALID_ID There was no interrupt vector associated with the
+ *   number specified by ``vector``.
+ * @par Notes
+ * The rtems_interrupt_set_priority() directive may be used to set the priority
+ * associated with an interrupt vector.
+ * @par Constraints
+ * @parblock
+ * The following constraints apply to this directive:
+ * * The directive may be called from within interrupt context.
+ * * The directive may be called from within device driver initialization
+ *   context.
+ * * The directive may be called from within task context.
+ * * The directive will not cause the calling task to be preempted.
+ * @endparblock
+/* Generated from spec:/rtems/intr/if/set-priority */
+ * This directive sets the priority of the interrupt specified by ``vector`` to
+ * the priority specified by ``priority``.
+ * For processor-specific interrupts, the priority of the interrupt specific to
+ * a processor executing the directive call will be set.
+ * @par Notes
+ * @parblock
+ * The rtems_interrupt_get_priority() directive may be used to get the priority
+ * The interrupt prioritization support depends on the interrupt controller of
+ * the target.  It is strongly recommended to read the relevant hardware
+ * documentation.  What happens when the priority of a pending or active
+ * interrupt is changed, depends on the interrupt controller.  In general, you
+ * should set the interrupt priority of an interrupt vector before a handler is
+ * installed.  On some interrupt controllers, setting the priority to the
+ * maximum value (lowest importance) effectively disables the interrupt. On
+ * some architectures, a range of interrupt priority values may be not disabled
+ * by the interrupt disable directives.  Handlers of such interrupts shall not
+ * use operating system services.
+ * For the ARM Generic Interrupt Controller (GIC), an 8-bit priority value is
+ * supported.  The granularity of the priority levels depends on the interrupt
+ * controller configuration.  Some low-order bits of a priority value may be
+ * read-as-zero (RAZ) and writes are ignored (WI).  Where group 0 (FIQ) and
+ * group 1 (IRQ) interrupts are used, it is recommended to use the lower half
+ * of the supported priority value range for the group 0 interrupts and the
+ * upper half for group 1 interrupts.  This ensures that group 1 interrupts
+ * cannot preempt group 0 interrupts.
+ * For the Armv7-M Nested Vector Interrupt Controller (NVIC), an 8-bit priority
+ * value is supported.  The granularity of the priority levels depends on the
+ * interrupt controller configuration.  Some lower bits of a priority value may
+ * be read-as-zero (RAZ) and writes are ignored (WI).  Interrupts with a
+ * priority value less than 128 are not disabled by the RTEMS interrupt disable
+ * directives.  Handlers of such interrupts shall not use operating system
+ * services.
+ * For the RISC-V Platform-Level Interrupt Controller (PLIC), all priority
+ * values from 0 up to and including the 0xffffffff are supported since the
+ * priority for the PLIC is defined by a write-any-read-legal (WARL) register.
+ * Please note that for this directive in contrast to the PLIC, a higher
+ * priority value is associated with a lower importance.  The maximum priority
+ * value (mapped to the value 0 for the PLIC) is reserved to mean "never
+ * interrupt" and effectively disables the interrupt.
+ * For the QorIQ Multicore Programmable Interrupt Controller (MPIC), a 4-bit
+ * priority value is supported.  Please note that for this directive in
+ * contrast to the MPIC, a higher priority value is associated with a lower
+ * importance. The maximum priority value of 15 (mapped to the value 0 for the
+ * MPIC) inhibits signalling of this interrupt.
+ * @endparblock
+ * @parblock
+ *   context.
+ * @endparblock
+  uint32_t            priority
 /* Generated from spec:/rtems/intr/if/get-affinity */
@@ -1965,6 +2106,29 @@ typedef struct {
    * rtems_interrupt_raise(), or rtems_interrupt_raise_on().
   rtems_interrupt_signal_variant trigger_signal;
+   * @brief This member is true, if the priority of the interrupt vector can be
+   *   obtained by rtems_interrupt_get_priority(), otherwise it is false.
+  bool can_get_priority;
+   *   set by rtems_interrupt_set_priority(), otherwise it is false.
+  bool can_set_priority;
+   * @brief This member represents the maximum priority value of the interrupt
+   *   vector.  By convention, the minimum priority value is zero.  Lower
+   *   priority values shall be associated with a higher importance.  The higher
+   *   the priority value, the less important is the service of the associated
+   *   interrupt vector.  Where nested interrupts are supported, interrupts with
+   *   a lower priority value may preempt other interrupts having a higher
+   *   priority value.
+  uint32_t maximum_priority;
 } rtems_interrupt_attributes;
 /* Generated from spec:/rtems/intr/if/get-attributes */
diff --git a/spec/build/bsps/objirq.yml b/spec/build/bsps/objirq.yml
index 2a817649d3..916cd1de12 100644
--- a/spec/build/bsps/objirq.yml
+++ b/spec/build/bsps/objirq.yml
@@ -21,6 +21,7 @@ source:
 - bsps/shared/irq/irq-info.c
 - bsps/shared/irq/irq-legacy.c
 - bsps/shared/irq/irq-lock.c
+- bsps/shared/irq/irq-priority.c
 - bsps/shared/irq/irq-record.c
 - bsps/shared/irq/irq-server.c
 - bsps/shared/irq/irq-shell.c
diff --git a/spec/build/bsps/powerpc/ss555/bspss555.yml b/spec/build/bsps/powerpc/ss555/bspss555.yml
index c97bbedf9f..d496aa4c20 100644
--- a/spec/build/bsps/powerpc/ss555/bspss555.yml
+++ b/spec/build/bsps/powerpc/ss555/bspss555.yml
@@ -80,6 +80,7 @@ source:
 - bsps/shared/irq/irq-handler-remove.c
diff --git a/spec/build/testsuites/validation/validation-intr.yml b/spec/build/testsuites/validation/validation-intr.yml
index bd3e888fce..eaf37da8d5 100644
--- a/spec/build/testsuites/validation/validation-intr.yml
+++ b/spec/build/testsuites/validation/validation-intr.yml
@@ -22,11 +22,13 @@ source:
 - testsuites/validation/tc-intr-entry-remove.c
 - testsuites/validation/tc-intr-get-affinity.c
 - testsuites/validation/tc-intr-get-attributes.c
+- testsuites/validation/tc-intr-get-priority.c
 - testsuites/validation/tc-intr-handler-iterate.c
 - testsuites/validation/tc-intr-is-pending.c
 - testsuites/validation/tc-intr-raise.c
 - testsuites/validation/tc-intr-raise-on.c
 - testsuites/validation/tc-intr-set-affinity.c
+- testsuites/validation/tc-intr-set-priority.c
 - testsuites/validation/tc-intr-vector-disable.c
 - testsuites/validation/tc-intr-vector-enable.c
 - testsuites/validation/tc-intr-vector-is-enabled.c
diff --git a/testsuites/validation/tc-intr-get-priority.c b/testsuites/validation/tc-intr-get-priority.c
index 0000000000..8975acddb5
--- /dev/null
+++ b/testsuites/validation/tc-intr-get-priority.c
@@ -0,0 +1,567 @@
+ * @file
+ * @ingroup RtemsIntrReqGetPriority
+ * are met:
+ * This file is part of the RTEMS quality process and was automatically
+ * generated.  If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual.  The manual is provided as a part of
+ * a release.  For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include "tx-support.h"
+#include <rtems/test.h>
+ * @defgroup RtemsIntrReqGetPriority spec:/rtems/intr/req/get-priority
+ * @ingroup TestsuitesValidationIntr
+typedef enum {
+  RtemsIntrReqGetPriority_Pre_Vector_Valid,
+  RtemsIntrReqGetPriority_Pre_Vector_Invalid,
+  RtemsIntrReqGetPriority_Pre_Vector_NA
+} RtemsIntrReqGetPriority_Pre_Vector;
+typedef enum {
+  RtemsIntrReqGetPriority_Pre_Priority_Valid,
+  RtemsIntrReqGetPriority_Pre_Priority_Null,
+  RtemsIntrReqGetPriority_Pre_Priority_NA
+} RtemsIntrReqGetPriority_Pre_Priority;
+typedef enum {
+  RtemsIntrReqGetPriority_Pre_CanGetPriority_Yes,
+  RtemsIntrReqGetPriority_Pre_CanGetPriority_No,
+  RtemsIntrReqGetPriority_Pre_CanGetPriority_NA
+} RtemsIntrReqGetPriority_Pre_CanGetPriority;
+typedef enum {
+  RtemsIntrReqGetPriority_Post_Status_Ok,
+  RtemsIntrReqGetPriority_Post_Status_InvAddr,
+  RtemsIntrReqGetPriority_Post_Status_InvId,
+  RtemsIntrReqGetPriority_Post_Status_Unsat,
+  RtemsIntrReqGetPriority_Post_Status_NA
+} RtemsIntrReqGetPriority_Post_Status;
+typedef enum {
+  RtemsIntrReqGetPriority_Post_PriorityObj_Set,
+  RtemsIntrReqGetPriority_Post_PriorityObj_Nop,
+  RtemsIntrReqGetPriority_Post_PriorityObj_NA
+} RtemsIntrReqGetPriority_Post_PriorityObj;
+typedef struct {
+  uint16_t Skip : 1;
+  uint16_t Pre_Vector_NA : 1;
+  uint16_t Pre_Priority_NA : 1;
+  uint16_t Pre_CanGetPriority_NA : 1;
+  uint16_t Post_Status : 3;
+  uint16_t Post_PriorityObj : 2;
+} RtemsIntrReqGetPriority_Entry;
+ * @brief Test context for spec:/rtems/intr/req/get-priority test case.
+typedef struct {
+   * @brief This member provides the object referenced by the ``priority``
+   *   parameter.
+  uint32_t priority_obj;
+   * @brief If this member is true, then the ``vector`` parameter shall be
+   *   valid.
+  bool valid_vector;
+   * @brief If this member is true, then getting the priority shall be
+   *   supported.
+   * @brief This member specifies the ``priority`` parameter value.
+  uint32_t *priority;
+   * @brief This member specifies the expected status.
+  rtems_status_code expected_status;
+   * @brief This member specifies the expected value of the priority object.
+  void (*expected_priority)(uint32_t);
+  struct {
+     * @brief This member defines the pre-condition indices for the next
+     *   action.
+    size_t pci[ 3 ];
+     * @brief This member defines the pre-condition states for the next action.
+    size_t pcs[ 3 ];
+     * @brief If this member is true, then the test action loop is executed.
+    bool in_action_loop;
+     * @brief This member contains the next transition map index.
+    size_t index;
+     * @brief This member contains the current transition map entry.
+    RtemsIntrReqGetPriority_Entry entry;
+     * @brief If this member is true, then the current transition variant
+     *   should be skipped.
+    bool skip;
+  } Map;
+} RtemsIntrReqGetPriority_Context;
+static RtemsIntrReqGetPriority_Context
+  RtemsIntrReqGetPriority_Instance;
+static const char * const RtemsIntrReqGetPriority_PreDesc_Vector[] = {
+  "Valid",
+  "Invalid",
+  "NA"
+static const char * const RtemsIntrReqGetPriority_PreDesc_Priority[] = {
+  "Valid",
+  "Null",
+  "NA"
+static const char * const RtemsIntrReqGetPriority_PreDesc_CanGetPriority[] = {
+  "Yes",
+  "No",
+  "NA"
+static const char * const * const RtemsIntrReqGetPriority_PreDesc[] = {
+  RtemsIntrReqGetPriority_PreDesc_Vector,
+  RtemsIntrReqGetPriority_PreDesc_Priority,
+  RtemsIntrReqGetPriority_PreDesc_CanGetPriority,
+  NULL
+typedef RtemsIntrReqGetPriority_Context Context;
+#define PRIORITY_UNSET (UINT32_MAX - 1234)
+static void PriorityIsSet( uint32_t priority )
+  T_lt_u32( priority, PRIORITY_UNSET );
+static void PriorityIsNotSet( uint32_t priority )
+  T_eq_u32( priority, PRIORITY_UNSET );
+static void CheckGetPriority( Context *ctx, rtems_vector_number vector )
+  rtems_status_code sc;
+  ctx->priority_obj = PRIORITY_UNSET;
+  sc = rtems_interrupt_get_priority( vector, ctx->priority );
+  T_rsc( sc, ctx->expected_status );
+  (*ctx->expected_priority)( ctx->priority_obj );
+static void RtemsIntrReqGetPriority_Pre_Vector_Prepare(
+  RtemsIntrReqGetPriority_Context   *ctx,
+  RtemsIntrReqGetPriority_Pre_Vector state
+  switch ( state ) {
+    case RtemsIntrReqGetPriority_Pre_Vector_Valid: {
+       * While the ``vector`` parameter is associated with an interrupt vector.
+      ctx->valid_vector = true;
+      break;
+    case RtemsIntrReqGetPriority_Pre_Vector_Invalid: {
+       * While the ``vector`` parameter is not associated with an interrupt
+       * vector.
+      ctx->valid_vector = false;
+      break;
+    case RtemsIntrReqGetPriority_Pre_Vector_NA:
+      break;
+static void RtemsIntrReqGetPriority_Pre_Priority_Prepare(
+  RtemsIntrReqGetPriority_Pre_Priority state
+    case RtemsIntrReqGetPriority_Pre_Priority_Valid: {
+       * While the ``priority`` parameter references an object of type
+       * uint32_t.
+      ctx->priority = &ctx->priority_obj;
+      break;
+    case RtemsIntrReqGetPriority_Pre_Priority_Null: {
+       * While the ``priority`` parameter is equal to NULL.
+      ctx->priority = NULL;
+      break;
+    case RtemsIntrReqGetPriority_Pre_Priority_NA:
+      break;
+static void RtemsIntrReqGetPriority_Pre_CanGetPriority_Prepare(
+  RtemsIntrReqGetPriority_Pre_CanGetPriority state
+    case RtemsIntrReqGetPriority_Pre_CanGetPriority_Yes: {
+       * While getting the priority for the interrupt vector specified by
+       * ``vector`` parameter is supported.
+      ctx->can_get_priority = true;
+      break;
+    case RtemsIntrReqGetPriority_Pre_CanGetPriority_No: {
+       * ``vector`` parameter is not supported.
+      ctx->can_get_priority = false;
+      break;
+    case RtemsIntrReqGetPriority_Pre_CanGetPriority_NA:
+      break;
+static void RtemsIntrReqGetPriority_Post_Status_Check(
+  RtemsIntrReqGetPriority_Post_Status state
+    case RtemsIntrReqGetPriority_Post_Status_Ok: {
+       * The return status of rtems_interrupt_get_priority() shall be
+       * RTEMS_SUCCESSFUL.
+      ctx->expected_status = RTEMS_SUCCESSFUL;
+      break;
+    case RtemsIntrReqGetPriority_Post_Status_InvAddr: {
+       * RTEMS_INVALID_ADDRESS.
+      ctx->expected_status = RTEMS_INVALID_ADDRESS;
+      break;
+    case RtemsIntrReqGetPriority_Post_Status_InvId: {
+       * RTEMS_INVALID_ID.
+      ctx->expected_status = RTEMS_INVALID_ID;
+      break;
+    case RtemsIntrReqGetPriority_Post_Status_Unsat: {
+       * RTEMS_UNSATISFIED.
+      ctx->expected_status = RTEMS_UNSATISFIED;
+      break;
+    case RtemsIntrReqGetPriority_Post_Status_NA:
+      break;
+static void RtemsIntrReqGetPriority_Post_PriorityObj_Check(
+  RtemsIntrReqGetPriority_Post_PriorityObj state
+  ctx->expected_priority = PriorityIsNotSet;
+    case RtemsIntrReqGetPriority_Post_PriorityObj_Set: {
+       * The value of the object referenced by the ``priority`` parameter shall
+       * be set by the directive call to a priority which the interrupt
+       * specified by the ``vector`` parameter had at some time point during
+       * the directive call.
+      ctx->expected_priority = PriorityIsSet;
+      break;
+    case RtemsIntrReqGetPriority_Post_PriorityObj_Nop: {
+       * not be changed by the directive call.
+      break;
+    case RtemsIntrReqGetPriority_Post_PriorityObj_NA:
+      break;
+static void RtemsIntrReqGetPriority_Action(
+  /* Action carried out by CheckGetPriority() */
+static void RtemsIntrReqGetPriority_Cleanup(
+  if ( ctx->valid_vector ) {
+    rtems_vector_number vector;
+    for (
+      vector = 0;
+      vector < BSP_INTERRUPT_VECTOR_COUNT;
+      ++vector
+      rtems_interrupt_attributes attr;
+      memset( &attr, 0, sizeof( attr ) );
+      sc = rtems_interrupt_get_attributes( vector, &attr );
+      if ( sc == RTEMS_INVALID_ID ) {
+        continue;
+      T_rsc_success( sc );
+      if ( attr.can_get_priority != ctx->can_get_priority ) {
+        continue;
+      CheckGetPriority( ctx, vector );
+  } else {
+    CheckGetPriority( ctx, BSP_INTERRUPT_VECTOR_COUNT );
+static const RtemsIntrReqGetPriority_Entry
+RtemsIntrReqGetPriority_Entries[] = {
+  { 0, 0, 0, 0, RtemsIntrReqGetPriority_Post_Status_InvAddr,
+    RtemsIntrReqGetPriority_Post_PriorityObj_NA },
+  { 0, 0, 0, 1, RtemsIntrReqGetPriority_Post_Status_InvId,
+    RtemsIntrReqGetPriority_Post_PriorityObj_Nop },
+  { 0, 0, 0, 1, RtemsIntrReqGetPriority_Post_Status_InvAddr,
+  { 0, 0, 0, 0, RtemsIntrReqGetPriority_Post_Status_Ok,
+    RtemsIntrReqGetPriority_Post_PriorityObj_Set },
+  { 0, 0, 0, 0, RtemsIntrReqGetPriority_Post_Status_Unsat,
+static const uint8_t
+RtemsIntrReqGetPriority_Map[] = {
+  3, 4, 0, 0, 1, 1, 2, 2
+static size_t RtemsIntrReqGetPriority_Scope( void *arg, char *buf, size_t n )
+  RtemsIntrReqGetPriority_Context *ctx;
+  ctx = arg;
+  if ( ctx->Map.in_action_loop ) {
+    return T_get_scope(
+      RtemsIntrReqGetPriority_PreDesc,
+      buf,
+      n,
+      ctx->Map.pcs
+  return 0;
+static T_fixture RtemsIntrReqGetPriority_Fixture = {
+  .setup = NULL,
+  .stop = NULL,
+  .teardown = NULL,
+  .scope = RtemsIntrReqGetPriority_Scope,
+  .initial_context = &RtemsIntrReqGetPriority_Instance
+static inline RtemsIntrReqGetPriority_Entry RtemsIntrReqGetPriority_PopEntry(
+  size_t index;
+  index = ctx->Map.index;
+  ctx->Map.index = index + 1;
+  return RtemsIntrReqGetPriority_Entries[
+    RtemsIntrReqGetPriority_Map[ index ]
+static void RtemsIntrReqGetPriority_SetPreConditionStates(
+  ctx->Map.pcs[ 0 ] = ctx->Map.pci[ 0 ];
+  ctx->Map.pcs[ 1 ] = ctx->Map.pci[ 1 ];
+  if ( ctx->Map.entry.Pre_CanGetPriority_NA ) {
+    ctx->Map.pcs[ 2 ] = RtemsIntrReqGetPriority_Pre_CanGetPriority_NA;
+  } else {
+    ctx->Map.pcs[ 2 ] = ctx->Map.pci[ 2 ];
+static void RtemsIntrReqGetPriority_TestVariant(
+  RtemsIntrReqGetPriority_Pre_Vector_Prepare( ctx, ctx->Map.pcs[ 0 ] );
+  RtemsIntrReqGetPriority_Pre_Priority_Prepare( ctx, ctx->Map.pcs[ 1 ] );
+  RtemsIntrReqGetPriority_Pre_CanGetPriority_Prepare( ctx, ctx->Map.pcs[ 2 ] );
+  RtemsIntrReqGetPriority_Action( ctx );
+  RtemsIntrReqGetPriority_Post_Status_Check( ctx, ctx->Map.entry.Post_Status );
+  RtemsIntrReqGetPriority_Post_PriorityObj_Check(
+    ctx,
+    ctx->Map.entry.Post_PriorityObj
+ * @fn void T_case_body_RtemsIntrReqGetPriority( void )
+T_TEST_CASE_FIXTURE(
+  RtemsIntrReqGetPriority,
+  &RtemsIntrReqGetPriority_Fixture
+  ctx = T_fixture_context();
+  ctx->Map.in_action_loop = true;
+  ctx->Map.index = 0;
+  for (
+    ctx->Map.pci[ 0 ] = RtemsIntrReqGetPriority_Pre_Vector_Valid;
+    ctx->Map.pci[ 0 ] < RtemsIntrReqGetPriority_Pre_Vector_NA;
+    ++ctx->Map.pci[ 0 ]
+    for (
+      ctx->Map.pci[ 1 ] = RtemsIntrReqGetPriority_Pre_Priority_Valid;
+      ctx->Map.pci[ 1 ] < RtemsIntrReqGetPriority_Pre_Priority_NA;
+      ++ctx->Map.pci[ 1 ]
+      for (
+        ctx->Map.pci[ 2 ] = RtemsIntrReqGetPriority_Pre_CanGetPriority_Yes;
+        ctx->Map.pci[ 2 ] < RtemsIntrReqGetPriority_Pre_CanGetPriority_NA;
+        ++ctx->Map.pci[ 2 ]
+        ctx->Map.entry = RtemsIntrReqGetPriority_PopEntry( ctx );
+        RtemsIntrReqGetPriority_SetPreConditionStates( ctx );
+        RtemsIntrReqGetPriority_TestVariant( ctx );
+        RtemsIntrReqGetPriority_Cleanup( ctx );
diff --git a/testsuites/validation/tc-intr-set-priority.c b/testsuites/validation/tc-intr-set-priority.c
index 0000000000..3742f2162d
--- /dev/null
+++ b/testsuites/validation/tc-intr-set-priority.c
@@ -0,0 +1,504 @@
+ * @file
+ * @ingroup RtemsIntrReqSetPriority
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsIntrReqSetPriority spec:/rtems/intr/req/set-priority
+typedef enum {
+  RtemsIntrReqSetPriority_Pre_Vector_Valid,
+  RtemsIntrReqSetPriority_Pre_Vector_Invalid,
+  RtemsIntrReqSetPriority_Pre_Vector_NA
+} RtemsIntrReqSetPriority_Pre_Vector;
+typedef enum {
+  RtemsIntrReqSetPriority_Pre_Priority_Valid,
+  RtemsIntrReqSetPriority_Pre_Priority_Invalid,
+  RtemsIntrReqSetPriority_Pre_Priority_NA
+} RtemsIntrReqSetPriority_Pre_Priority;
+typedef enum {
+  RtemsIntrReqSetPriority_Pre_CanSetPriority_Yes,
+  RtemsIntrReqSetPriority_Pre_CanSetPriority_No,
+  RtemsIntrReqSetPriority_Pre_CanSetPriority_NA
+} RtemsIntrReqSetPriority_Pre_CanSetPriority;
+typedef enum {
+  RtemsIntrReqSetPriority_Post_Status_Ok,
+  RtemsIntrReqSetPriority_Post_Status_InvId,
+  RtemsIntrReqSetPriority_Post_Status_InvPrio,
+  RtemsIntrReqSetPriority_Post_Status_Unsat,
+  RtemsIntrReqSetPriority_Post_Status_NA
+} RtemsIntrReqSetPriority_Post_Status;
+typedef struct {
+  uint8_t Skip : 1;
+  uint8_t Pre_Vector_NA : 1;
+  uint8_t Pre_Priority_NA : 1;
+  uint8_t Pre_CanSetPriority_NA : 1;
+  uint8_t Post_Status : 3;
+} RtemsIntrReqSetPriority_Entry;
+ * @brief Test context for spec:/rtems/intr/req/set-priority test case.
+typedef struct {
+   *   valid.
+   * @brief If this member is true, then the ``priority`` parameter shall be
+   *   valid.
+  bool valid_priority;
+   * @brief If this member is true, then setting the priority shall be
+   *   supported.
+  struct {
+     *   action.
+    size_t pci[ 3 ];
+    size_t pcs[ 3 ];
+    size_t index;
+    RtemsIntrReqSetPriority_Entry entry;
+    bool skip;
+  } Map;
+} RtemsIntrReqSetPriority_Context;
+static RtemsIntrReqSetPriority_Context
+  RtemsIntrReqSetPriority_Instance;
+static const char * const RtemsIntrReqSetPriority_PreDesc_Vector[] = {
+  "Valid",
+  "Invalid",
+  "NA"
+static const char * const RtemsIntrReqSetPriority_PreDesc_Priority[] = {
+  "Valid",
+  "Invalid",
+  "NA"
+static const char * const RtemsIntrReqSetPriority_PreDesc_CanSetPriority[] = {
+  "Yes",
+  "No",
+  "NA"
+static const char * const * const RtemsIntrReqSetPriority_PreDesc[] = {
+  RtemsIntrReqSetPriority_PreDesc_Vector,
+  RtemsIntrReqSetPriority_PreDesc_Priority,
+  RtemsIntrReqSetPriority_PreDesc_CanSetPriority,
+  NULL
+typedef RtemsIntrReqSetPriority_Context Context;
+static void CheckSetPriority( Context *ctx, rtems_vector_number vector )
+  uint32_t          priority;
+  if ( ctx->valid_priority ) {
+    (void) rtems_interrupt_get_priority( vector, &priority );
+  } else {
+    priority = UINT32_MAX;
+  sc = rtems_interrupt_set_priority( vector, priority );
+static void RtemsIntrReqSetPriority_Pre_Vector_Prepare(
+  RtemsIntrReqSetPriority_Context   *ctx,
+  RtemsIntrReqSetPriority_Pre_Vector state
+    case RtemsIntrReqSetPriority_Pre_Vector_Valid: {
+      break;
+    case RtemsIntrReqSetPriority_Pre_Vector_Invalid: {
+       * vector.
+      break;
+    case RtemsIntrReqSetPriority_Pre_Vector_NA:
+      break;
+static void RtemsIntrReqSetPriority_Pre_Priority_Prepare(
+  RtemsIntrReqSetPriority_Pre_Priority state
+    case RtemsIntrReqSetPriority_Pre_Priority_Valid: {
+       * While the ``priority`` parameter is a valid priority value.
+      ctx->valid_priority = true;
+      break;
+    case RtemsIntrReqSetPriority_Pre_Priority_Invalid: {
+       * While the ``priority`` parameter is an invalid priority value.
+      ctx->valid_priority = false;
+      break;
+    case RtemsIntrReqSetPriority_Pre_Priority_NA:
+      break;
+static void RtemsIntrReqSetPriority_Pre_CanSetPriority_Prepare(
+  RtemsIntrReqSetPriority_Pre_CanSetPriority state
+    case RtemsIntrReqSetPriority_Pre_CanSetPriority_Yes: {
+       * While setting the priority for the interrupt vector specified by
+      ctx->can_set_priority = true;
+      break;
+    case RtemsIntrReqSetPriority_Pre_CanSetPriority_No: {
+      ctx->can_set_priority = false;
+      break;
+    case RtemsIntrReqSetPriority_Pre_CanSetPriority_NA:
+      break;
+static void RtemsIntrReqSetPriority_Post_Status_Check(
+  RtemsIntrReqSetPriority_Post_Status state
+    case RtemsIntrReqSetPriority_Post_Status_Ok: {
+       * The return status of rtems_interrupt_set_priority() shall be
+      break;
+    case RtemsIntrReqSetPriority_Post_Status_InvId: {
+      break;
+    case RtemsIntrReqSetPriority_Post_Status_InvPrio: {
+       * RTEMS_INVALID_PRIORITY.
+      ctx->expected_status = RTEMS_INVALID_PRIORITY;
+      break;
+    case RtemsIntrReqSetPriority_Post_Status_Unsat: {
+      break;
+    case RtemsIntrReqSetPriority_Post_Status_NA:
+      break;
+static void RtemsIntrReqSetPriority_Action(
+  /* Action carried out by CheckSetPriority() */
+static void RtemsIntrReqSetPriority_Cleanup(
+    for (
+      vector = 0;
+      ++vector
+        continue;
+      if ( attr.can_set_priority != ctx->can_set_priority ) {
+        continue;
+      CheckSetPriority( ctx, vector );
+  } else {
+    CheckSetPriority( ctx, BSP_INTERRUPT_VECTOR_COUNT );
+static const RtemsIntrReqSetPriority_Entry
+RtemsIntrReqSetPriority_Entries[] = {
+  { 0, 0, 1, 1, RtemsIntrReqSetPriority_Post_Status_InvId },
+  { 0, 0, 1, 0, RtemsIntrReqSetPriority_Post_Status_Unsat },
+  { 0, 0, 0, 0, RtemsIntrReqSetPriority_Post_Status_Ok },
+  { 0, 0, 0, 0, RtemsIntrReqSetPriority_Post_Status_InvPrio }
+RtemsIntrReqSetPriority_Map[] = {
+  2, 1, 3, 1, 0, 0, 0, 0
+static size_t RtemsIntrReqSetPriority_Scope( void *arg, char *buf, size_t n )
+  RtemsIntrReqSetPriority_Context *ctx;
+  ctx = arg;
+      RtemsIntrReqSetPriority_PreDesc,
+      buf,
+      n,
+      ctx->Map.pcs
+  return 0;
+static T_fixture RtemsIntrReqSetPriority_Fixture = {
+  .setup = NULL,
+  .stop = NULL,
+  .teardown = NULL,
+  .scope = RtemsIntrReqSetPriority_Scope,
+  .initial_context = &RtemsIntrReqSetPriority_Instance
+static inline RtemsIntrReqSetPriority_Entry RtemsIntrReqSetPriority_PopEntry(
+  size_t index;
+  return RtemsIntrReqSetPriority_Entries[
+    RtemsIntrReqSetPriority_Map[ index ]
+static void RtemsIntrReqSetPriority_SetPreConditionStates(
+  if ( ctx->Map.entry.Pre_Priority_NA ) {
+    ctx->Map.pcs[ 1 ] = RtemsIntrReqSetPriority_Pre_Priority_NA;
+  } else {
+  if ( ctx->Map.entry.Pre_CanSetPriority_NA ) {
+    ctx->Map.pcs[ 2 ] = RtemsIntrReqSetPriority_Pre_CanSetPriority_NA;
+  } else {
+static void RtemsIntrReqSetPriority_TestVariant(
+  RtemsIntrReqSetPriority_Pre_Vector_Prepare( ctx, ctx->Map.pcs[ 0 ] );
+  RtemsIntrReqSetPriority_Pre_Priority_Prepare( ctx, ctx->Map.pcs[ 1 ] );
+  RtemsIntrReqSetPriority_Pre_CanSetPriority_Prepare( ctx, ctx->Map.pcs[ 2 ] );
+  RtemsIntrReqSetPriority_Action( ctx );
+  RtemsIntrReqSetPriority_Post_Status_Check( ctx, ctx->Map.entry.Post_Status );
+ * @fn void T_case_body_RtemsIntrReqSetPriority( void )
+  RtemsIntrReqSetPriority,
+  &RtemsIntrReqSetPriority_Fixture
+  for (
+    ctx->Map.pci[ 0 ] = RtemsIntrReqSetPriority_Pre_Vector_Valid;
+    ctx->Map.pci[ 0 ] < RtemsIntrReqSetPriority_Pre_Vector_NA;
+    for (
+      ctx->Map.pci[ 1 ] = RtemsIntrReqSetPriority_Pre_Priority_Valid;
+      ctx->Map.pci[ 1 ] < RtemsIntrReqSetPriority_Pre_Priority_NA;
+      for (
+        ctx->Map.pci[ 2 ] = RtemsIntrReqSetPriority_Pre_CanSetPriority_Yes;
+        ctx->Map.pci[ 2 ] < RtemsIntrReqSetPriority_Pre_CanSetPriority_NA;
+        ctx->Map.entry = RtemsIntrReqSetPriority_PopEntry( ctx );
+        RtemsIntrReqSetPriority_SetPreConditionStates( ctx );
+        RtemsIntrReqSetPriority_TestVariant( ctx );
+        RtemsIntrReqSetPriority_Cleanup( ctx );
2.35.3
