[PATCH 2/3] bsps/xil-ttc: Add XIL_FATAL_TTC_IRQ_INSTALL
Sebastian Huber
Wed Apr 10 11:15:55 UTC 2024
bsps/include/bsp/fatal.h | 3 +
bsps/shared/dev/clock/xil-ttc.c | 6 +-
.../bsps/fatal-clock-xil-ttc-irq-install.yml | 21 ++
spec/build/testsuites/validation/grp.yml | 2 +
.../bsps/tr-fatal-clock-xil-ttc-irq-install.c | 187 ++++++++++++++++++
.../bsps/tr-fatal-clock-xil-ttc-irq-install.h | 84 ++++++++
.../bsps/ts-fatal-clock-xil-ttc-irq-install.c | 79 ++++++++
7 files changed, 378 insertions(+), 4 deletions(-)
create mode 100644 spec/build/testsuites/validation/bsps/fatal-clock-xil-ttc-irq-install.yml
create mode 100644 testsuites/validation/bsps/tr-fatal-clock-xil-ttc-irq-install.c
create mode 100644 testsuites/validation/bsps/tr-fatal-clock-xil-ttc-irq-install.h
create mode 100644 testsuites/validation/bsps/ts-fatal-clock-xil-ttc-irq-install.c
diff --git a/bsps/include/bsp/fatal.h b/bsps/include/bsp/fatal.h
index ffdb4bc8e1..87fc481ead 100644
--- a/bsps/include/bsp/fatal.h
+++ b/bsps/include/bsp/fatal.h
@@ -214,6 +214,9 @@ typedef enum {
/* MicroBlaze fatal codes */
MICROBLAZE_FATAL_CLOCK_IRQ_INSTALL = BSP_FATAL_CODE_BLOCK(16),
+ /* Xilinx fatal codes */
+ XIL_FATAL_TTC_IRQ_INSTALL = BSP_FATAL_CODE_BLOCK(17),
} bsp_fatal_code;
RTEMS_NO_RETURN static inline void
diff --git a/bsps/shared/dev/clock/xil-ttc.c b/bsps/shared/dev/clock/xil-ttc.c
index 384f23663b..0140bb7445 100644
--- a/bsps/shared/dev/clock/xil-ttc.c
+++ b/bsps/shared/dev/clock/xil-ttc.c
@@ -35,11 +35,9 @@
* POSSIBILITY OF SUCH DAMAGE.
-#include <stdlib.h>
-#include <rtems.h>
#include <bsp.h>
#include <bsp/irq.h>
+#include <bsp/fatal.h>
#include <peripheral_maps/xilinx_zynqmp.h>
#include <dev/clock/xttcps_hw.h>
#include <rtems/timecounter.h>
@@ -211,7 +209,7 @@ static void zynqmp_ttc_clock_driver_support_install_isr(
&zynqmp_ttc_interrupt_entry
if ( sc != RTEMS_SUCCESSFUL ) {
- rtems_fatal_error_occurred(0xdeadbeef);
+ bsp_fatal(XIL_FATAL_TTC_IRQ_INSTALL);
diff --git a/spec/build/testsuites/validation/bsps/fatal-clock-xil-ttc-irq-install.yml b/spec/build/testsuites/validation/bsps/fatal-clock-xil-ttc-irq-install.yml
new file mode 100644
index 0000000000..253131551d
--- /dev/null
+++ b/spec/build/testsuites/validation/bsps/fatal-clock-xil-ttc-irq-install.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2024 embedded brains GmbH & Co. KG
+cppflags: []
+cxxflags: []
+enabled-by: bsps/arm/xilinx-zynqmp-rpu
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/validation/bsps/tr-fatal-clock-xil-ttc-irq-install.c
+- testsuites/validation/bsps/ts-fatal-clock-xil-ttc-irq-install.c
+stlib: []
+target: testsuites/validation/bsps/ts-fatal-clock-xil-ttc-irq-install.exe
+type: build
+use-after:
+- validation
+use-before: []
diff --git a/spec/build/testsuites/validation/grp.yml b/spec/build/testsuites/validation/grp.yml
index 726cf732dd..f10c6a9823 100644
--- a/spec/build/testsuites/validation/grp.yml
+++ b/spec/build/testsuites/validation/grp.yml
@@ -78,6 +78,8 @@ links:
uid: validation-tls-0
- role: build-dependency
uid: validation-tls-1
+- role: build-dependency
+ uid: bsps/fatal-clock-xil-ttc-irq-install
uid: bsps/fatal-sparc-leon3-cache-snooping-disabled-boot
diff --git a/testsuites/validation/bsps/tr-fatal-clock-xil-ttc-irq-install.c b/testsuites/validation/bsps/tr-fatal-clock-xil-ttc-irq-install.c
index 0000000000..731b454ee4
--- /dev/null
+++ b/testsuites/validation/bsps/tr-fatal-clock-xil-ttc-irq-install.c
@@ -0,0 +1,187 @@
+ * @file
+ * @ingroup DevClockXilTtcValFatalIrqInstall
+ * Copyright (C) 2024 embedded brains GmbH & Co. KG
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * This file is part of the RTEMS quality process and was automatically
+ * generated. If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual. The manual is provided as a part of
+ * a release. For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <bsp.h>
+#include <rtems.h>
+#include <rtems/sysinit.h>
+#include "tr-fatal-clock-xil-ttc-irq-install.h"
+#include <rtems/test.h>
+ * @defgroup DevClockXilTtcValFatalIrqInstall \
+ * spec:/dev/clock/xil-ttc/val/fatal-irq-install
+ * @ingroup TestsuitesBspsFatalClockXilTtcIrqInstall
+ * @brief Tests a fatal error.
+ * This test case performs the following actions:
+ * - The test action is carried out by the OccupyClockInterrupt() system
+ * initialization handler.
+ * - Check that the expected fatal source is present.
+ * - Check that the expected fatal code is present.
+ * @brief Test context for spec:/dev/clock/xil-ttc/val/fatal-irq-install test
+ * case.
+typedef struct {
+ * @brief This member contains a copy of the corresponding
+ * DevClockXilTtcValFatalIrqInstall_Run() parameter.
+ rtems_fatal_source source;
+ rtems_fatal_code code;
+} DevClockXilTtcValFatalIrqInstall_Context;
+static DevClockXilTtcValFatalIrqInstall_Context
+ DevClockXilTtcValFatalIrqInstall_Instance;
+static void ClockInterrupt( void *arg )
+ (void) arg;
+static rtems_interrupt_entry interrupt_entry = RTEMS_INTERRUPT_ENTRY_INITIALIZER(
+ ClockInterrupt,
+ NULL,
+ "Clock"
+static void OccupyClockInterrupt( void )
+ (void) rtems_interrupt_entry_install(
+ XIL_CLOCK_TTC_IRQ,
+ RTEMS_INTERRUPT_UNIQUE,
+ &interrupt_entry
+RTEMS_SYSINIT_ITEM(
+ OccupyClockInterrupt,
+ RTEMS_SYSINIT_DEVICE_DRIVERS,
+ RTEMS_SYSINIT_ORDER_FIRST
+static T_fixture DevClockXilTtcValFatalIrqInstall_Fixture = {
+ .setup = NULL,
+ .stop = NULL,
+ .teardown = NULL,
+ .scope = NULL,
+ .initial_context = &DevClockXilTtcValFatalIrqInstall_Instance
+ * @brief The test action is carried out by the OccupyClockInterrupt() system
+static void DevClockXilTtcValFatalIrqInstall_Action_0(
+ DevClockXilTtcValFatalIrqInstall_Context *ctx
+ /* Nothing to do */
+ * Check that the expected fatal source is present.
+ T_step_eq_int( 0, ctx->source, RTEMS_FATAL_SOURCE_BSP );
+ * Check that the expected fatal code is present.
+ T_step_eq_ulong(
+ 1,
+ ctx->code,
+void DevClockXilTtcValFatalIrqInstall_Run(
+ rtems_fatal_source source,
+ DevClockXilTtcValFatalIrqInstall_Context *ctx;
+ ctx = &DevClockXilTtcValFatalIrqInstall_Instance;
+ ctx->source = source;
+ ctx->code = code;
+ ctx = T_case_begin(
+ "DevClockXilTtcValFatalIrqInstall",
+ &DevClockXilTtcValFatalIrqInstall_Fixture
+ T_plan( 2 );
+ DevClockXilTtcValFatalIrqInstall_Action_0( ctx );
+ T_case_end();
diff --git a/testsuites/validation/bsps/tr-fatal-clock-xil-ttc-irq-install.h b/testsuites/validation/bsps/tr-fatal-clock-xil-ttc-irq-install.h
index 0000000000..74021233a0
--- /dev/null
+++ b/testsuites/validation/bsps/tr-fatal-clock-xil-ttc-irq-install.h
@@ -0,0 +1,84 @@
+ * @file
+ * are met:
+#ifndef _TR_FATAL_CLOCK_XIL_TTC_IRQ_INSTALL_H
+#define _TR_FATAL_CLOCK_XIL_TTC_IRQ_INSTALL_H
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup DevClockXilTtcValFatalIrqInstall
+ * @brief Runs the parameterized test case.
+ * @param source is fatal source.
+ * @param code is fatal code.
+#ifdef __cplusplus
+#endif
+#endif /* _TR_FATAL_CLOCK_XIL_TTC_IRQ_INSTALL_H */
diff --git a/testsuites/validation/bsps/ts-fatal-clock-xil-ttc-irq-install.c b/testsuites/validation/bsps/ts-fatal-clock-xil-ttc-irq-install.c
index 0000000000..e5c1062348
--- /dev/null
+++ b/testsuites/validation/bsps/ts-fatal-clock-xil-ttc-irq-install.c
@@ -0,0 +1,79 @@
+ * @file
+ * are met:
+#endif
+ * @defgroup TestsuitesBspsFatalClockXilTtcIrqInstall \
+ * spec:/testsuites/bsps/fatal-clock-xil-ttc-irq-install
+ * @ingroup RTEMSTestSuitesValidation
+ * @brief This validation test suite contains a test case which triggers a
+ * fatal error during system initialization.
+const char rtems_test_name[] = "TestsuitesBspsFatalClockXilTtcIrqInstall";
+#define FATAL_SYSINIT_RUN DevClockXilTtcValFatalIrqInstall_Run
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#include "ts-fatal-sysinit.h"
2.35.3
