[RSB PATCH] 6/rtems-gcc: Revert to the gcc-13 release branch for MacOS fixes
Joel Sherrill
joel at rtems.org
Sun Apr 14 03:57:16 UTC 2024
This is ok to push.
Unfortunate but this is the reality. A GCC 14 release is still future tense.
On Sat, Apr 13, 2024, 8:49 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> Change back to gcc-13 branch and a git version as gcc-13.2 does
> not build on MacOS 14.4. The fixes are on the gcc-13 release branch.
> rtems/config/6/rtems-default.bset | 2 +-
> rtems/config/tools/rtems-gcc-13-newlib-head.cfg | 6 +++---
> 2 files changed, 4 insertions(+), 4 deletions(-)
> diff --git a/rtems/config/6/rtems-default.bset
> b/rtems/config/6/rtems-default.bset
> index 2d7a223..2d51c50 100644
> --- a/rtems/config/6/rtems-default.bset
> +++ b/rtems/config/6/rtems-default.bset
> @@ -14,7 +14,7 @@
> %defineifnot with_rtems_gmp devel/gmp-6.3.0
> %defineifnot with_rtems_gdb tools/rtems-gdb-13.2
> %defineifnot with_rtems_binutils tools/rtems-binutils-2.41
> -%defineifnot with_rtems_gcc tools/rtems-gcc-13.2-newlib-head
> +%defineifnot with_rtems_gcc tools/rtems-gcc-13-newlib-head
> %defineifnot with_rtems_tools tools/rtems-tools-6
> tools/rtems-default-tools.bset
> diff --git a/rtems/config/tools/rtems-gcc-13-newlib-head.cfg
> b/rtems/config/tools/rtems-gcc-13-newlib-head.cfg
> index c73d5a6..4dbbd9b 100644
> --- a/rtems/config/tools/rtems-gcc-13-newlib-head.cfg
> +++ b/rtems/config/tools/rtems-gcc-13-newlib-head.cfg
> @@ -1,12 +1,12 @@
> %include %{_configdir}/checks.cfg
> %include %{_configdir}/base.cfg
> -%define gcc_version 8c04837
> +%define gcc_version 54a235e
> %define gcc_external 1
> %define gcc_expand_name gnu-mirror-gcc-%{gcc_version}
> %source set gcc --rsb-file=%{gcc_expand_name}.tar.gz
> https://codeload.github.com/RTEMS/gnu-mirror-gcc/tar.gz/%{gcc_version}
> %hash sha512 %{gcc_expand_name}.tar.gz \
> YSkX/JY61N+I4CPkJInUNGzwhb+uv+YNs9qcTxxJhg/HpGD5vI9duEPNw++F3y8J4re87DPJGIzV5DsFUBCJnA==
> UAXjyfPP883wjLDnobDk4wmg/vAO0I4LjzzurLCKejj0FUSk0KvlkVj1CF+3XwFcdlCWRhN7z/Ls4fOunafe9w==
> %define newlib_version 176b19f
> %define newlib_external 1
> @@ -19,4 +19,4 @@
> %define with_plugin 0
> %define with_iconv 1
> -%include %{_configdir}/gcc-12.cfg
> +%include %{_configdir}/gcc-13.cfg
> 2.39.3 (Apple Git-146)
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240413/6d9a3a7c/attachment.htm>
