rtems-kernel-init.c tries to re-make existing "/etc"
Peter Dufault
dufault at hda.com
Thu Apr 18 14:17:49 UTC 2024
I just rebased to "6-freebsd-12". This change:
commit 62e0ca8283603573d42a0f15da044cd406a2f00a
Author: Kinsey Moore <kinsey.moore at oarcorp.com>
Date: Tue Jan 23 13:25:45 2024 -0600
rtemsbsd/rtems: Check function return values
[dufault at gen6 rtems-libbsd]$ git diff 6514d561587fd1527fe6a26cb43e6b5742c8c779 rtemsbsd/rtems/rtems-kernel-init.c
diff --git a/rtemsbsd/rtems/rtems-kernel-init.c b/rtemsbsd/rtems/rtems-kernel-init.c
index 90a9c80..8ac2f59 100644
--- a/rtemsbsd/rtems/rtems-kernel-init.c
+++ b/rtemsbsd/rtems/rtems-kernel-init.c
@@ -223,7 +223,9 @@ rtems_bsd_initialize(void)
return RTEMS_UNSATISFIED;
- mkdir("/etc", S_IRWXU | S_IRWXG | S_IRWXO);
+ if (mkdir("/etc", S_IRWXU | S_IRWXG | S_IRWXO) != 0) {
+ return RTEMS_UNSATISFIED;
sc = rtems_timer_initiate_server(rtems_bsd_get_task_priority(name),
rtems_bsd_get_task_stack_size(name), RTEMS_DEFAULT_ATTRIBUTES);
causes a crash at startup in "uma_zalloc()" (in at least the "telnetd01" test).
I printed out the error, the directory already exists:
mkdir("/etc",...): File exists
For now I'm just checking for EEXIST and ignoring the error.
Does anyone care to object now and say I should investigate further to fix the caller before I submit a patch?
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
