rtems-kernel-init.c tries to re-make existing "/etc"
Peter Dufault
dufault at hda.com
Thu Apr 18 15:10:19 UTC 2024
> On Apr 18, 2024, at 10:55 AM, Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Apr 18, 2024 at 9:50 AM Peter Dufault <dufault at hda.com> wrote:
> > On Apr 18, 2024, at 10:34 AM, Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> > A patch for EEXIST here should be fine. It would be nice if the caller were more resilient.
> I also changed "default-network-init.h" to assert rtems_bsd_initialize() worked.
> sc = rtems_bsd_initialize();
> assert(sc == RTEMS_SUCCESSFUL);
> At least you get a panic message. I'll submit a patch.
> Why does /etc already exist? Is it really an error if it already exists?
> If the startup code untar'ed some initial file system contents before calling this, then /etc would almost certainly exist.
> Unless I am missing something EEXIST should be acceptable. Other errors are most likely really fatal.
> https://pubs.opengroup.org/onlinepubs/9699919799/functions/mkdir.html
> --joel
The function "_libcsupport_pwdgrp_init()" over in RTEMS also creates "/etc" through a "pthread_once()". A call to "getpwnam()", "getpwuid()", "getgrnam()" and family will create it. Apparently that is called first.
Peter Dufault
HD Associates, Inc. Software and System Engineering
