[rtems-tools PATCH 1/2] rtemstoolkit: Fix decoding unicode strings in output
Joel Sherrill
joel at rtems.org
Fri Apr 19 14:13:23 UTC 2024
Please apply both. I think this was the only bad issue with rc2 on CentOS 7
or 8.
On Thu, Apr 18, 2024 at 10:09 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> rtemstoolkit/execute.py | 12 ++++++++++--
> 1 file changed, 10 insertions(+), 2 deletions(-)
> diff --git a/rtemstoolkit/execute.py b/rtemstoolkit/execute.py
> index 31d3a8a..c7d8134 100755
> --- a/rtemstoolkit/execute.py
> +++ b/rtemstoolkit/execute.py
> @@ -37,6 +37,7 @@
> from __future__ import print_function
> import functools
> +import codecs
> import io
> import os
> import re
> @@ -203,6 +204,10 @@ class execute(object):
> stacktraces.trace()
> if trace_threads:
> print('execute:_readthread: start')
> + if sys.stdout.encoding is not None:
> + decoder =
> codecs.getincrementaldecoder(sys.stdout.encoding)()
> + else:
> + decoder = None
> count = 0
> line = ''
> try:
> @@ -222,8 +227,8 @@ class execute(object):
> _output_line(line + '\n', exe, prefix, out,
> count)
> break
> # str and bytes are the same type in Python2
> - if type(data) is not str and type(data) is bytes:
> - data = data.decode(sys.stdout.encoding)
> + if decoder is not None and type(data) is not str and
> + data = decoder.decode(data)
> last_ch = data[-1]
> sd = (line + data).split('\n')
> if last_ch != '\n':
> @@ -382,6 +387,9 @@ class execute(object):
> if self.verbose:
> log.output(what + ': ' + cs)
> log.trace('exe: %s' % (cs))
> + if shell and self.shell_exe:
> + command = arg_list(command)
> + command[:0] = self.shell_exe
> if not stdin and self.input:
> stdin = subprocess.PIPE
> if not stdout:
> 2.39.3 (Apple Git-146)
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240419/018f4d17/attachment.htm>
