[PATCH 4/6] bsps/arm: Add Doxygen group for Armv7-M SysTick
Sebastian Huber
Tue Apr 23 19:10:37 UTC 2024
Change license to BSD-2-Clause according to file history and contributor
agreements.
bsps/arm/include/bsp/clock-armv7m.h | 49 +++++++++++++++++--
bsps/arm/shared/clock/clock-armv7m.c | 8 +++
.../arm/shared/cpucounter/cpucounter-armv7m.c | 8 +++
3 files changed, 61 insertions(+), 4 deletions(-)
diff --git a/bsps/arm/include/bsp/clock-armv7m.h b/bsps/arm/include/bsp/clock-armv7m.h
index 62f201153e..28adf34453 100644
--- a/bsps/arm/include/bsp/clock-armv7m.h
+++ b/bsps/arm/include/bsp/clock-armv7m.h
@@ -1,9 +1,37 @@
+ * @file
+ * @ingroup RTEMSDriverClockArmv7MSysTick
+ * @brief This header file provides support for Armv7-M clock drivers.
- * Copyright (c) 2011, 2018 Sebastian Huber. All rights reserved.
+ * Copyright (C) 2024 embedded brains GmbH & Co. KG
+ * Copyright (C) 2011, 2018 Sebastian Huber
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
#ifndef BSP_CLOCK_ARMV7M_H
@@ -18,6 +46,17 @@
extern "C" {
#endif /* __cplusplus */
+ * @defgroup RTEMSDriverClockArmv7MSysTick Armv7-M SysTick Clock Driver
+ * @ingroup RTEMSDriverClockImpl
+ * @brief This group contains the Armv7-M SysTick support and Clock Driver
+ * implementation.
#ifdef ARM_MULTILIB_ARCH_V7M
typedef struct {
@@ -67,6 +106,8 @@ static uint32_t _ARMV7M_Clock_counter(ARMV7M_Timecounter *tc)
#endif /* ARM_MULTILIB_ARCH_V7M */
#ifdef __cplusplus
diff --git a/bsps/arm/shared/clock/clock-armv7m.c b/bsps/arm/shared/clock/clock-armv7m.c
index ce1d3b38bd..ee3b8a7939 100644
--- a/bsps/arm/shared/clock/clock-armv7m.c
+++ b/bsps/arm/shared/clock/clock-armv7m.c
@@ -1,5 +1,13 @@
+ * @file
+ * @brief This source file contains the Armv7-M SysTick Clock Driver.
* Copyright (C) 2020 embedded brains GmbH & Co. KG
diff --git a/bsps/arm/shared/cpucounter/cpucounter-armv7m.c b/bsps/arm/shared/cpucounter/cpucounter-armv7m.c
index f43ad42248..95fdee365c 100644
--- a/bsps/arm/shared/cpucounter/cpucounter-armv7m.c
+++ b/bsps/arm/shared/cpucounter/cpucounter-armv7m.c
@@ -1,5 +1,13 @@
+ * @file
+ * @brief This source file contains the Armv7-M SysTick CPU counter.
* Copyright (C) 2016, 2018 embedded brains GmbH & Co. KG
2.35.3
