[PATCH 4/9] bsp/tms570: Add TMS570LC4357 PLL support
Sebastian Huber
Tue Apr 23 19:15:50 UTC 2024
Update #4982.
bsps/arm/tms570/include/bsp/ti_herc/reg_sys.h | 27 +++++++++++++++++++
1 file changed, 27 insertions(+)
diff --git a/bsps/arm/tms570/include/bsp/ti_herc/reg_sys.h b/bsps/arm/tms570/include/bsp/ti_herc/reg_sys.h
index d5583a1cca..1ca2bff685 100644
--- a/bsps/arm/tms570/include/bsp/ti_herc/reg_sys.h
+++ b/bsps/arm/tms570/include/bsp/ti_herc/reg_sys.h
@@ -355,6 +355,11 @@ typedef struct{
/* field: ROS - Reset on PLL Slip */
#define TMS570_SYS1_PLLCTL1_ROS BSP_BIT32(31)
+/* field: BPOS - Bypass of PLL Slip */
+#define TMS570_SYS1_PLLCTL1_BPOS(val) BSP_FLD32(val,29, 30)
+#define TMS570_SYS1_PLLCTL1_BPOS_GET(reg) BSP_FLD32GET(reg,29, 30)
+#define TMS570_SYS1_PLLCTL1_BPOS_SET(reg,val) BSP_FLD32SET(reg, val,29, 30)
/* field: MASK_SLIP - Mask detection of PLL slip */
#define TMS570_SYS1_PLLCTL1_MASK_SLIP(val) BSP_FLD32(val,29, 30)
#define TMS570_SYS1_PLLCTL1_MASK_SLIP_GET(reg) BSP_FLD32GET(reg,29, 30)
@@ -404,6 +409,28 @@ typedef struct{
#define TMS570_SYS1_PLLCTL2_SPR_AMOUNT_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
+/*--------------------TMS570_SYS1_PLLCTL3--------------------*/
+/* field: ODPLL2 - Internal PLL Output Divider. */
+#define TMS570_SYS1_PLLCTL3_ODPLL2(val) BSP_FLD32(val, 29, 31)
+#define TMS570_SYS1_PLLCTL3_ODPLL2_GET(reg) BSP_FLD32GET(reg, 29, 31)
+#define TMS570_SYS1_PLLCTL3_ODPLL2_SET(reg,val) BSP_FLD32SET(reg, val, 29, 31)
+/* field: PLLDIV2 - PLL2 Output Clock Divider. */
+#define TMS570_SYS1_PLLCTL3_PLLDIV2(val) BSP_FLD32(val, 24, 28)
+#define TMS570_SYS1_PLLCTL3_PLLDIV2_GET(reg) BSP_FLD32GET(reg, 24, 28)
+#define TMS570_SYS1_PLLCTL3_PLLDIV2_SET(reg,val) BSP_FLD32SET(reg, val, 24, 28)
+/* field: REFCLKDIV2 - Reference Clock Divider. */
+#define TMS570_SYS1_PLLCTL3_REFCLKDIV2(val) BSP_FLD32(val, 16, 21)
+#define TMS570_SYS1_PLLCTL3_REFCLKDIV2_GET(reg) BSP_FLD32GET(reg, 16, 21)
+#define TMS570_SYS1_PLLCTL3_REFCLKDIV2_SET(reg,val) BSP_FLD32SET(reg, val, 16, 21)
+/* field: PLLMUL2 - PLL2 Multiplication Factor. */
+#define TMS570_SYS1_PLLCTL3_PLLMUL2(val) BSP_FLD32(val, 0, 15)
+#define TMS570_SYS1_PLLCTL3_PLLMUL2_GET(reg) BSP_FLD32GET(reg, 0, 15)
+#define TMS570_SYS1_PLLCTL3_PLLMUL2_SET(reg,val) BSP_FLD32SET(reg, val, 0, 15)
/*--------------------TMS570_SYS1_SYSPC10--------------------*/
/* field: ECPCLK_SLEW - ECPCLK slew control. This bit controls between the fast or slow slew mode. */
#define TMS570_SYS1_SYSPC10_ECPCLK_SLEW BSP_BIT32(0)
2.35.3
