RTEMS 6 branching
Vijay Kumar Banerjee
vijay at rtems.org
Tue Apr 23 21:45:55 UTC 2024
On Tue, Apr 23, 2024 at 1:02 PM Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Apr 23, 2024, 12:56 PM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> ----- Am 21. Apr 2024 um 3:00 schrieb Chris Johns chrisj at rtems.org:
>> > Hi,
>> > There has been some discussion about when we will branch and it is
>> timely we
>> > discuss this. This is my input. :)
>> > While I create the releases I am not solely responsible for milestone
>> dates or
>> > thresholds for a release.
>> > Please test the RC snaphots on our ftp server. Saying you have is as
>> important
>> > as reporting issues.
>> > 1. Are all the things need for the release resolved? Tickets reviewed?
>> It would be nice to have the interrupt get/set priority API in RTEMS 6.
>> The Cortex-M floating point issue is not yet fixed in the RTEMS master.
> There should be time to get it in. The Gitlab transition needs to be
> complete before the branch is cut.
>> > 2. The tickets are now in GitLab and locked down in Trac so how does
>> that work
>> > if we make a release now? I do not think it does.
>> > 3. GitLab is going to happen soon so do we take this moment in time and
>> make 6
>> > with GitLab and learn what we need to do easing dot releases that
>> always follow?
>> > If we do not we may end up with 6.1 and then 6.2 that has differences.
>> We should definitely wait with the release after the Gitlab migration is
>> done and some basic CI is running.
> I don't think holding a release for CI is needed. We have the same basic
> quality and testing we have now.
> Requiring more work and improvements just moves the release bar.
> That said, we do need to get some CI processes in place. Hopefully between
> 6.1 and 6.2, we will have at least one or two BSPs required to build.
>> > 4. GitLab breaks the release scripts for the release notes (ChangeLog).
>> Amar and
>> > I have discussed a few options but we are yet to test and settle on
>> anything. As
>> > is the case with these things easy is often is a series of small things
>> that
>> > take time to get right.
>> > 5. Have the docs been reviewed for RTEMS 5 vs RTEMS 6 changes? Are they
>> updated
>> > for a separated legacy network stack, net services and waf building?
> Ryan and Ray worked on the autoconf to waf documentation changes a couple
> of years ago.
> I have no idea what impact the separated Network stacks have on the
> documentation.
The legacy networking docs are separated now with instructions on how to
build them using waf:
https://docs.rtems.org/branches/master/legacy-networking/index.html
We might need to mention in the user manual that there is no default
networking stack anymore and the user needs to build the network stack
separately.
> > 6. I have a few small patches to push and then an update to the RSB to
>> pick
>> > those changes up before I can create RC4.
>> I recently checked in a fix for powerpc and the AArch64 multilib changes
>> for Cortex-A53 in GCC 13. To pick this up, the GCC commit needs to be
>> updated. Maybe we should even wait for the GCC 13.3 release.
> I asked about a gcc 13.3 release and we should not wait. They intend to do
> a 14 release before returning to 13.3. We should plan to do 6.1 with a GCC
> 13 branch hash and probably plan to swap that out with a 13.3 tarball when
> it's released.
> We are good at imposing more requirements. :)
>> > Thanks
>> > Chris
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> embedded brains GmbH & Co. KG
>> Herr Sebastian HUBER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: sebastian.huber at embedded-brains.de
>> phone: +49-89-18 94 741 - 16
>> fax: +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240423/c9d079d9/attachment.htm>
